The LCD4 cape basic support patch uses P9_21 in bone_lcd4_cape_keys_00A2_pins pin group. However, according to the schematic file at Beagleboardtoys wiki, it doesn’t use P9_21. This error prevents any other virtual capes such as UART2 or SPI0 to be loaded because of pin conflict on P9_21.
this is being updated in future releases of the Angstrom Image that ships for the BeagleBone Black...
Not unless someone sends a patch (or pull request) against GitHub - beagleboard/kernel at 3.8 to fix it. So far I've seen zero patches for that, so the above statement is overly optimistic.
Hi, After a week of struggling with this problem, it seems like I am having the exact same problem as you. My out-of-the-box BBB came with:
Linux beaglebone 3.8.13-bone47 #1 SMP Fri Apr 11 01:36:09 UTC 2014 armv7l GNU/Linux
and is a Debian Image from 2014-04-23.
After decompiling the LCD4 driver I saw that the Pin is still blocked. Is there any updates as to whether the new Debian image: Debian (BeagleBone, BeagleBone Black - 2GB SD) 2014-05-14
has resolved this or any more direct solutions to the issue. I’m new at this stuff so I apologize in advance if this isn’t the place for this question.
Chris
