Yeah, there are two dashes before version. The g++ in that folder is just a symbolic link to another file which is two directories down in the bin folder. Does this file exist relative to the original folder:
…/…/bin/arm-angstrom-linux-gnueabi-g++
Which I believe is this file:
/usr/local/angstrom/arm/bin/arm-angstrom-linux-gnueabi-g++
Does this file exist? My guess is it doesn’t exist.
Clearly you do have a g++ on your system, but that would be the native x86 g++, and not the cross compile g++.
Try typing arm- and then hit the tab twice (autocomplete) to see if you have any arm cross compiler installed on your system.
John
Hi John;
When I type arm-[tab][tab] it doesn’t autocomplete.
However, here is the contents of the directory you mentioned.
In the browser it shows as an executable, however when I try to “execute” it I get a “no such program” error message L
Could there be a conflict somewhere in the path or permissions ?
beaglebone@ubuntu:/usr/local/angstrom/arm/bin$ ls -l
-rwxr-xr-x 1 root root 483996 Mar 16 2011 arm-angstrom-linux-gnueabi-addr2line
-rwxr-xr-x 1 root root 503544 Mar 16 2011 arm-angstrom-linux-gnueabi-ar
-rwxr-xr-x 1 root root 853272 Mar 16 2011 arm-angstrom-linux-gnueabi-as
-rwxr-xr-x 1 root root 483800 Mar 16 2011 arm-angstrom-linux-gnueabi-c++filt
-rwxr-xr-x 1 root root 436563 Mar 16 2011 arm-angstrom-linux-gnueabi-cpp
-rwxr-xr-x 1 root root 438687 Mar 16 2011 arm-angstrom-linux-gnueabi-g++
-rwxr-xr-x 1 root root 434700 Mar 16 2011 arm-angstrom-linux-gnueabi-gcc
-rwxr-xr-x 1 root root 17422 Mar 16 2011 arm-angstrom-linux-gnueabi-gccbug
-rwxr-xr-x 1 root root 75976 Mar 16 2011 arm-angstrom-linux-gnueabi-gcov
-rwxr-xr-x 1 root root 3184888 Mar 16 2011 arm-angstrom-linux-gnueabi-gdb
-rwxr-xr-x 1 root root 3184892 Mar 16 2011 arm-angstrom-linux-gnueabi-gdbtui
-rwxr-xr-x 1 root root 442039 Mar 16 2011 arm-angstrom-linux-gnueabi-gfortran
-rwxr-xr-x 1 root root 538904 Mar 16 2011 arm-angstrom-linux-gnueabi-gprof
-rwxr-xr-x 1 root root 873752 Mar 16 2011 arm-angstrom-linux-gnueabi-ld
-rwxr-xr-x 1 root root 490292 Mar 16 2011 arm-angstrom-linux-gnueabi-nm
-rwxr-xr-x 1 root root 629144 Mar 16 2011 arm-angstrom-linux-gnueabi-objcopy
-rwxr-xr-x 1 root root 759480 Mar 16 2011 arm-angstrom-linux-gnueabi-objdump
-rwxr-xr-x 1 root root 503548 Mar 16 2011 arm-angstrom-linux-gnueabi-ranlib
-rwxr-xr-x 1 root root 261868 Mar 16 2011 arm-angstrom-linux-gnueabi-readelf
-rwxr-xr-x 1 root root 748476 Mar 16 2011 arm-angstrom-linux-gnueabi-run
-rwxr-xr-x 1 root root 483988 Mar 16 2011 arm-angstrom-linux-gnueabi-size
-rwxr-xr-x 1 root root 483960 Mar 16 2011 arm-angstrom-linux-gnueabi-strings
-rwxr-xr-x 1 root root 629144 Mar 16 2011 arm-angstrom-linux-gnueabi-strip
-rwxr-xr-x 1 root root 281569 Mar 16 2011 i686-linux-libtool
-rwxr-xr-x 1 root root 281569 Mar 16 2011 libtool
-rwxr-xr-x 1 root root 68311 Mar 16 2011 libtoolize
lrwxrwxrwx 1 root root 9 Mar 18 2011 lrelease → lrelease4
-rwxr-xr-x 1 root root 1445808 Mar 18 2011 lrelease4
lrwxrwxrwx 1 root root 8 Mar 18 2011 lupdate → lupdate4
-rwxr-xr-x 1 root root 1873816 Mar 18 2011 lupdate4
lrwxrwxrwx 1 root root 4 Mar 18 2011 moc → moc4
-rwxr-xr-x 1 root root 907660 Mar 18 2011 moc4
-rwxr-xr-x 1 root root 12344 Mar 16 2011 opkg-cl
-rwxr-xr-x 1 root root 1671 Mar 16 2011 opkg-key
-rwxr-xr-x 1 root root 88372 Mar 16 2011 pkg-config
lrwxrwxrwx 1 root root 13 Mar 18 2011 qdbuscpp2xml → qdbuscpp2xml4
-rwxr-xr-x 1 root root 1362620 Mar 18 2011 qdbuscpp2xml4
lrwxrwxrwx 1 root root 13 Mar 18 2011 qdbusxml2cpp → qdbusxml2cpp4
-rwxr-xr-x 1 root root 1562652 Mar 18 2011 qdbusxml2cpp4
lrwxrwxrwx 1 root root 6 Mar 18 2011 qmake → qmake2
-rwxr-xr-x 1 root root 3272168 Mar 18 2011 qmake2
lrwxrwxrwx 1 root root 4 Mar 18 2011 rcc → rcc4
-rwxr-xr-x 1 root root 966932 Mar 18 2011 rcc4
lrwxrwxrwx 1 root root 4 Mar 18 2011 uic → uic4
lrwxrwxrwx 1 root root 5 Mar 18 2011 uic3 → uic34
-rwxr-xr-x 1 root root 10331364 Mar 18 2011 uic34
-rwxr-xr-x 1 root root 1329196 Mar 18 2011 uic4
-rwxr-xr-x 1 root root 4524 Mar 16 2011 update-alternatives
