diff --git a/patches/defconfig b/patches/defconfig
index 60b160f3..4457adc4 100644
--- a/patches/defconfig
+++ b/patches/defconfig
@@ -11,16 +11,16 @@ CONFIG_AS_VERSION=24400
CONFIG_LD_IS_BFD=y
CONFIG_LD_VERSION=24400
CONFIG_LLD_VERSION=0
-CONFIG_RUSTC_VERSION=108500
-CONFIG_RUST_IS_AVAILABLE=y
-CONFIG_RUSTC_LLVM_VERSION=190107
+CONFIG_RUSTC_VERSION=107500
+CONFIG_RUSTC_LLVM_VERSION=170006
CONFIG_CC_HAS_ASM_GOTO_OUTPUT=y
CONFIG_CC_HAS_ASM_GOTO_TIED_OUTPUT=y
CONFIG_TOOLS_SUPPORT_RELR=y
CONFIG_CC_HAS_ASM_INLINE=y
CONFIG_CC_HAS_NO_PROFILE_FN_ATTR=y
CONFIG_LD_CAN_USE_KEEP_IN_OVERLAY=y
-CONFIG_PAHOLE_VERSION=130
+CONFIG_PAHOLE_VERSION=125
+CONFIG_CONSTRUCTORS=y
CONFIG_IRQ_WORK=y
CONFIG_BUILDTIME_TABLE_SORT=y
CONFIG_THREAD_INFO_IN_TASK=y
@@ -282,9 +282,6 @@ CONFIG_PERF_EVENTS=y
CONFIG_SYSTEM_DATA_VERIFICATION=y
CONFIG_PROFILING=y
-CONFIG_RUST=y
-CONFIG_RUSTC_VERSION_TEXT="rustc 1.85.0 (4d91de4e4 2025-02-17) (built from a source tarball)"
-CONFIG_BINDGEN_VERSION_TEXT="bindgen 0.71.1"
CONFIG_TRACEPOINTS=y
@@ -324,6 +321,7 @@ CONFIG_PGTABLE_LEVELS=4
CONFIG_ARCH_SUPPORTS_UPROBES=y
CONFIG_ARCH_PROC_KCORE_TEXT=y
CONFIG_BUILTIN_RETURN_ADDRESS_STRIPS_PAC=y
+CONFIG_KASAN_SHADOW_OFFSET=0xdfff800000000000
# Platform selection
@@ -423,8 +421,8 @@ CONFIG_ARM64_ERRATUM_3194386=y
# CONFIG_QCOM_QDF2400_ERRATUM_0065 is not set
# CONFIG_QCOM_FALKOR_ERRATUM_E1041 is not set
# CONFIG_NVIDIA_CARMEL_CNP_ERRATUM is not set
-# CONFIG_ROCKCHIP_ERRATUM_3588001 is not set
-# CONFIG_SOCIONEXT_SYNQUACER_PREITS is not set
+CONFIG_ROCKCHIP_ERRATUM_3588001=y
+CONFIG_SOCIONEXT_SYNQUACER_PREITS=y
# end of ARM errata workarounds via the alternatives framework
CONFIG_ARM64_4K_PAGES=y
@@ -545,8 +543,7 @@ CONFIG_ARCH_PKEY_BITS=3
# CONFIG_ARM64_SVE is not set
# CONFIG_ARM64_PSEUDO_NMI is not set
CONFIG_RELOCATABLE=y
-CONFIG_RANDOMIZE_BASE=y
-CONFIG_RANDOMIZE_MODULE_REGION_FULL=y
+# CONFIG_RANDOMIZE_BASE is not set
CONFIG_CC_HAVE_STACKPROTECTOR_SYSREG=y
CONFIG_STACKPROTECTOR_PER_TASK=y
# end of Kernel Features
@@ -989,7 +986,7 @@ CONFIG_PGTABLE_HAS_HUGE_LEAVES=y
CONFIG_CMA=y
# CONFIG_CMA_DEBUGFS is not set
# CONFIG_CMA_SYSFS is not set
-CONFIG_CMA_AREAS=20
+CONFIG_CMA_AREAS=7
CONFIG_GENERIC_EARLY_IOREMAP=y
CONFIG_DEFERRED_STRUCT_PAGE_INIT=y
CONFIG_PAGE_IDLE_FLAG=y
@@ -1031,7 +1028,13 @@ CONFIG_EXECMEM=y
# Data Access Monitoring
-# CONFIG_DAMON is not set
+CONFIG_DAMON=y
+CONFIG_DAMON_VADDR=y
+CONFIG_DAMON_PADDR=y
+CONFIG_DAMON_SYSFS=y
+# CONFIG_DAMON_DBGFS_DEPRECATED is not set
+CONFIG_DAMON_RECLAIM=y
+CONFIG_DAMON_LRU_SORT=y
# end of Data Access Monitoring
# end of Memory Management options
@@ -1187,7 +1190,7 @@ CONFIG_NETFILTER_NETLINK=m
CONFIG_NETFILTER_FAMILY_BRIDGE=y
CONFIG_NETFILTER_FAMILY_ARP=y
CONFIG_NETFILTER_BPF_LINK=y
-# CONFIG_NETFILTER_NETLINK_HOOK is not set
+CONFIG_NETFILTER_NETLINK_HOOK=m
CONFIG_NETFILTER_NETLINK_ACCT=m
CONFIG_NETFILTER_NETLINK_QUEUE=m
CONFIG_NETFILTER_NETLINK_LOG=m
@@ -1900,7 +1903,7 @@ CONFIG_MAC80211_LEDS=y
# CONFIG_MAC80211_MESSAGE_TRACING is not set
# CONFIG_MAC80211_DEBUG_MENU is not set
CONFIG_MAC80211_STA_HASH_MAX_SIZE=0
-CONFIG_RFKILL=m
+CONFIG_RFKILL=y
CONFIG_RFKILL_LEDS=y
CONFIG_RFKILL_INPUT=y
CONFIG_RFKILL_GPIO=m
@@ -1980,19 +1983,19 @@ CONFIG_PCIEASPM_DEFAULT=y
# CONFIG_PCIEASPM_POWER_SUPERSAVE is not set
# CONFIG_PCIEASPM_PERFORMANCE is not set
CONFIG_PCIE_PME=y
-CONFIG_PCIE_DPC=y
+# CONFIG_PCIE_DPC is not set
CONFIG_PCIE_PTM=y
CONFIG_PCI_MSI=y
CONFIG_PCI_QUIRKS=y
# CONFIG_PCI_DEBUG is not set
-CONFIG_PCI_REALLOC_ENABLE_AUTO=y
-CONFIG_PCI_STUB=m
-CONFIG_PCI_PF_STUB=m
+# CONFIG_PCI_REALLOC_ENABLE_AUTO is not set
+# CONFIG_PCI_STUB is not set
+# CONFIG_PCI_PF_STUB is not set
CONFIG_PCI_ATS=y
CONFIG_PCI_ECAM=y
CONFIG_PCI_IOV=y
# CONFIG_PCI_NPEM is not set
-CONFIG_PCI_PRI=y
+# CONFIG_PCI_PRI is not set
CONFIG_PCI_PASID=y
# CONFIG_PCI_P2PDMA is not set
CONFIG_PCI_LABEL=y
@@ -2097,7 +2100,6 @@ CONFIG_PREVENT_FIRMWARE_BUILD=y
CONFIG_FW_LOADER=y
CONFIG_FW_LOADER_DEBUG=y
-# CONFIG_RUST_FW_LOADER_ABSTRACTIONS is not set
CONFIG_FW_LOADER_PAGED_BUF=y
CONFIG_FW_LOADER_SYSFS=y
CONFIG_EXTRA_FIRMWARE="regulatory.db regulatory.db.p7s cadence/mhdp8546.bin"
@@ -2124,7 +2126,7 @@ CONFIG_GENERIC_CPU_VULNERABILITIES=y
CONFIG_SOC_BUS=y
CONFIG_REGMAP=y
CONFIG_REGMAP_I2C=y
-CONFIG_REGMAP_SPI=m
+CONFIG_REGMAP_SPI=y
CONFIG_REGMAP_MMIO=y
CONFIG_REGMAP_IRQ=y
CONFIG_DMA_SHARED_BUFFER=y
@@ -2199,7 +2201,6 @@ CONFIG_SYSFB=y
# CONFIG_SYSFB_SIMPLEFB is not set
CONFIG_TI_SCI_PROTOCOL=y
# CONFIG_ARM_FFA_TRANSPORT is not set
-CONFIG_FW_CS_DSP=m
# CONFIG_GOOGLE_FIRMWARE is not set
@@ -2275,7 +2276,6 @@ CONFIG_MTD_BLOCK=y
# CONFIG_SSFDC is not set
# CONFIG_SM_FTL is not set
# CONFIG_MTD_OOPS is not set
-# CONFIG_MTD_PSTORE is not set
# CONFIG_MTD_SWAP is not set
# CONFIG_MTD_PARTITIONED_MASTER is not set
@@ -2352,6 +2352,7 @@ CONFIG_MTD_RAW_NAND=y
# CONFIG_MTD_NAND_DENALI_PCI is not set
# CONFIG_MTD_NAND_DENALI_DT is not set
+# CONFIG_MTD_NAND_OMAP2 is not set
# CONFIG_MTD_NAND_CAFE is not set
# CONFIG_MTD_NAND_BRCMNAND is not set
# CONFIG_MTD_NAND_MXIC is not set
@@ -2445,7 +2446,6 @@ CONFIG_BLK_DEV_RAM_SIZE=16384
# CONFIG_CDROM_PKTCDVD is not set
CONFIG_ATA_OVER_ETH=m
CONFIG_VIRTIO_BLK=m
-# CONFIG_BLK_DEV_RUST_NULL is not set
CONFIG_BLK_DEV_RBD=m
# CONFIG_BLK_DEV_UBLK is not set
@@ -2466,6 +2466,7 @@ CONFIG_NVME_HWMON=y
# Misc devices
+CONFIG_SENSORS_LIS3LV02D=m
CONFIG_AD525X_DPOT=m
CONFIG_AD525X_DPOT_I2C=m
CONFIG_AD525X_DPOT_SPI=m
@@ -2491,6 +2492,7 @@ CONFIG_SRAM_DMA_HEAP=y
# CONFIG_DW_XDATA_PCIE is not set
CONFIG_PCI_ENDPOINT_TEST=m
# CONFIG_XILINX_SDFEC is not set
+CONFIG_MISC_RTSX=m
# CONFIG_HISI_HIKEY_USB is not set
# CONFIG_OPEN_DICE is not set
# CONFIG_VCPU_STALL_DETECTOR is not set
@@ -2521,15 +2523,15 @@ CONFIG_EEPROM_EE1004=m
# end of Texas Instruments shared transport line discipline
# CONFIG_SENSORS_LIS3_SPI is not set
-# CONFIG_SENSORS_LIS3_I2C is not set
-# CONFIG_ALTERA_STAPL is not set
+CONFIG_SENSORS_LIS3_I2C=m
+CONFIG_ALTERA_STAPL=m
# CONFIG_VMWARE_VMCI is not set
# CONFIG_GENWQE is not set
# CONFIG_ECHO is not set
# CONFIG_BCM_VK is not set
# CONFIG_MISC_ALCOR_PCI is not set
-# CONFIG_MISC_RTSX_PCI is not set
-# CONFIG_MISC_RTSX_USB is not set
+CONFIG_MISC_RTSX_PCI=m
+CONFIG_MISC_RTSX_USB=m
# CONFIG_UACCE is not set
# CONFIG_PVPANIC is not set
# CONFIG_GP_PCI1XXXX is not set
@@ -2568,6 +2570,7 @@ CONFIG_SCSI_FC_ATTRS=m
CONFIG_SCSI_ISCSI_ATTRS=m
CONFIG_SCSI_SAS_ATTRS=y
CONFIG_SCSI_SAS_LIBSAS=y
+CONFIG_SCSI_SAS_ATA=y
CONFIG_SCSI_SAS_HOST_SMP=y
CONFIG_SCSI_SRP_ATTRS=m
# end of SCSI Transports
@@ -2596,8 +2599,10 @@ CONFIG_ISCSI_BOOT_SYSFS=m
# CONFIG_SCSI_ESAS2R is not set
# CONFIG_MEGARAID_NEWGEN is not set
# CONFIG_MEGARAID_LEGACY is not set
-# CONFIG_MEGARAID_SAS is not set
-# CONFIG_SCSI_MPT3SAS is not set
+CONFIG_MEGARAID_SAS=y
+CONFIG_SCSI_MPT3SAS=m
+CONFIG_SCSI_MPT2SAS_MAX_SGE=128
+CONFIG_SCSI_MPT3SAS_MAX_SGE=128
# CONFIG_SCSI_MPT2SAS is not set
# CONFIG_SCSI_MPI3MR is not set
# CONFIG_SCSI_SMARTPQI is not set
@@ -2632,7 +2637,7 @@ CONFIG_ISCSI_BOOT_SYSFS=m
# CONFIG_SCSI_DH is not set
# end of SCSI device support
-CONFIG_ATA=m
+CONFIG_ATA=y
CONFIG_SATA_HOST=y
CONFIG_ATA_VERBOSE_ERROR=y
CONFIG_ATA_FORCE=y
@@ -2641,14 +2646,14 @@ CONFIG_SATA_PMP=y
# Controllers with non-SFF native interface
-CONFIG_SATA_AHCI=m
-CONFIG_SATA_MOBILE_LPM_POLICY=3
-# CONFIG_SATA_AHCI_PLATFORM is not set
+CONFIG_SATA_AHCI=y
+CONFIG_SATA_MOBILE_LPM_POLICY=0
+CONFIG_SATA_AHCI_PLATFORM=y
# CONFIG_AHCI_DWC is not set
# CONFIG_AHCI_CEVA is not set
# CONFIG_SATA_INIC162X is not set
# CONFIG_SATA_ACARD_AHCI is not set
-# CONFIG_SATA_SIL24 is not set
+CONFIG_SATA_SIL24=y
CONFIG_ATA_SFF=y
@@ -2664,7 +2669,7 @@ CONFIG_ATA_BMDMA=y
# CONFIG_ATA_PIIX is not set
# CONFIG_SATA_DWC is not set
-CONFIG_SATA_MV=m
+# CONFIG_SATA_MV is not set
# CONFIG_SATA_NV is not set
# CONFIG_SATA_PROMISE is not set
# CONFIG_SATA_SIL is not set
@@ -2718,7 +2723,8 @@ CONFIG_SATA_MV=m
# CONFIG_PATA_MPIIX is not set
# CONFIG_PATA_NS87410 is not set
# CONFIG_PATA_OPTI is not set
-# CONFIG_PATA_OF_PLATFORM is not set
+CONFIG_PATA_PLATFORM=y
+CONFIG_PATA_OF_PLATFORM=y
# CONFIG_PATA_RZ1000 is not set
@@ -2781,7 +2787,6 @@ CONFIG_TARGET_CORE=m
CONFIG_TCM_IBLOCK=m
CONFIG_TCM_FILEIO=m
CONFIG_TCM_PSCSI=m
-# CONFIG_TCM_USER2 is not set
CONFIG_LOOPBACK_TARGET=m
CONFIG_ISCSI_TARGET=m
# CONFIG_SBP_TARGET is not set
@@ -2831,7 +2836,7 @@ CONFIG_NETCONSOLE_DYNAMIC=y
# CONFIG_NETCONSOLE_EXTENDED_LOG is not set
CONFIG_NETPOLL=y
CONFIG_NET_POLL_CONTROLLER=y
-CONFIG_NTB_NETDEV=m
+# CONFIG_NTB_NETDEV is not set
CONFIG_TUN=m
CONFIG_TAP=m
# CONFIG_TUN_VNET_CROSS_LE is not set
@@ -2844,7 +2849,7 @@ CONFIG_VSOCKMON=m
# CONFIG_MHI_NET is not set
# CONFIG_ARCNET is not set
CONFIG_ATM_DRIVERS=y
-# CONFIG_ATM_DUMMY is not set
+CONFIG_ATM_DUMMY=m
# CONFIG_ATM_TCP is not set
# CONFIG_ATM_LANAI is not set
# CONFIG_ATM_ENI is not set
@@ -2856,13 +2861,9 @@ CONFIG_ATM_DRIVERS=y
# CONFIG_ATM_SOLOS is not set
CONFIG_ETHERNET=y
CONFIG_MDIO=m
-CONFIG_NET_VENDOR_3COM=y
-CONFIG_VORTEX=m
-CONFIG_TYPHOON=m
-CONFIG_NET_VENDOR_ADAPTEC=y
-CONFIG_ADAPTEC_STARFIRE=m
-CONFIG_NET_VENDOR_AGERE=y
-CONFIG_ET131X=m
+# CONFIG_NET_VENDOR_3COM is not set
+# CONFIG_NET_VENDOR_ADAPTEC is not set
+# CONFIG_NET_VENDOR_AGERE is not set
CONFIG_NET_VENDOR_ALACRITECH=y
# CONFIG_SLICOSS is not set
# CONFIG_NET_VENDOR_ALTEON is not set
@@ -2936,7 +2937,7 @@ CONFIG_NET_VENDOR_MARVELL=y
CONFIG_SKGE=m
# CONFIG_SKGE_DEBUG is not set
# CONFIG_SKGE_GENESIS is not set
-CONFIG_SKY2=m
+CONFIG_SKY2=y
# CONFIG_SKY2_DEBUG is not set
# CONFIG_OCTEONTX2_AF is not set
# CONFIG_OCTEONTX2_PF is not set
@@ -2998,7 +2999,7 @@ CONFIG_NET_VENDOR_SOCIONEXT=y
# CONFIG_NET_VENDOR_TEHUTI is not set
CONFIG_NET_VENDOR_TI=y
CONFIG_TI_DAVINCI_MDIO=y
-CONFIG_TI_CPSW_PHY_SEL=y
+# CONFIG_TI_CPSW_PHY_SEL is not set
CONFIG_TI_CPSW_PROXY_CLIENT=m
CONFIG_TI_K3_CPPI_DESC_POOL=y
CONFIG_TI_K3_AM65_CPSW_NUSS=y
@@ -3010,7 +3011,7 @@ CONFIG_TI_ICSSG_PRUETH=m
# CONFIG_TI_ICSSG_PRUETH_SR1 is not set
CONFIG_TI_ICSS_IEP=m
CONFIG_TI_PRUETH_ECAP=m
-CONFIG_TI_PRUETH=m
+# CONFIG_TI_PRUETH is not set
CONFIG_NET_VENDOR_VERTEXCOM=y
# CONFIG_MSE102X is not set
# CONFIG_NET_VENDOR_VIA is not set
@@ -3032,7 +3033,6 @@ CONFIG_SWPHY=y
CONFIG_LED_TRIGGER_PHY=y
CONFIG_PHYLIB_LEDS=y
CONFIG_FIXED_PHY=y
-# CONFIG_RUST_PHYLIB_ABSTRACTIONS is not set
# CONFIG_SFP is not set
@@ -3169,7 +3169,7 @@ CONFIG_MDIO_GPIO=y
# MDIO Multiplexers
CONFIG_MDIO_BUS_MUX=y
-CONFIG_MDIO_BUS_MUX_GPIO=y
+# CONFIG_MDIO_BUS_MUX_GPIO is not set
CONFIG_MDIO_BUS_MUX_MULTIPLEXER=y
CONFIG_MDIO_BUS_MUX_MMIOREG=y
@@ -3277,7 +3277,7 @@ CONFIG_CARL9170_LEDS=y
CONFIG_CARL9170_WPC=y
# CONFIG_CARL9170_HWRNG is not set
CONFIG_ATH6KL=m
-CONFIG_ATH6KL_SDIO=m
+# CONFIG_ATH6KL_SDIO is not set
CONFIG_ATH6KL_USB=m
# CONFIG_ATH6KL_DEBUG is not set
# CONFIG_ATH6KL_TRACING is not set
@@ -3289,8 +3289,8 @@ CONFIG_WIL6210_DEBUGFS=y
CONFIG_ATH10K=m
CONFIG_ATH10K_CE=y
CONFIG_ATH10K_PCI=m
-CONFIG_ATH10K_AHB=y
-CONFIG_ATH10K_SDIO=m
+# CONFIG_ATH10K_AHB is not set
+# CONFIG_ATH10K_SDIO is not set
CONFIG_ATH10K_USB=m
# CONFIG_ATH10K_DEBUG is not set
# CONFIG_ATH10K_DEBUGFS is not set
@@ -3303,9 +3303,7 @@ CONFIG_ATH11K_AHB=m
CONFIG_ATH11K_PCI=m
# CONFIG_ATH11K_DEBUG is not set
# CONFIG_ATH11K_TRACING is not set
-CONFIG_ATH12K=m
-# CONFIG_ATH12K_DEBUG is not set
-# CONFIG_ATH12K_TRACING is not set
+# CONFIG_ATH12K is not set
CONFIG_WLAN_VENDOR_ATMEL=y
CONFIG_AT76C50X_USB=m
CONFIG_WLAN_VENDOR_BROADCOM=y
@@ -3316,7 +3314,7 @@ CONFIG_BRCMUTIL=m
CONFIG_BRCMFMAC=m
CONFIG_BRCMFMAC_PROTO_BCDC=y
CONFIG_BRCMFMAC_PROTO_MSGBUF=y
-CONFIG_BRCMFMAC_SDIO=y
+# CONFIG_BRCMFMAC_SDIO is not set
CONFIG_BRCMFMAC_USB=y
CONFIG_BRCMFMAC_PCIE=y
# CONFIG_BRCM_TRACING is not set
@@ -3363,7 +3361,7 @@ CONFIG_P54_LEDS=y
CONFIG_WLAN_VENDOR_MARVELL=y
CONFIG_LIBERTAS=m
CONFIG_LIBERTAS_USB=m
-CONFIG_LIBERTAS_SDIO=m
+# CONFIG_LIBERTAS_SDIO is not set
# CONFIG_LIBERTAS_SPI is not set
# CONFIG_LIBERTAS_DEBUG is not set
CONFIG_LIBERTAS_MESH=y
@@ -3371,7 +3369,7 @@ CONFIG_LIBERTAS_THINFIRM=m
# CONFIG_LIBERTAS_THINFIRM_DEBUG is not set
CONFIG_LIBERTAS_THINFIRM_USB=m
CONFIG_MWIFIEX=m
-CONFIG_MWIFIEX_SDIO=m
+# CONFIG_MWIFIEX_SDIO is not set
CONFIG_MWIFIEX_PCIE=m
CONFIG_MWIFIEX_USB=m
CONFIG_MWL8K=m
@@ -3380,7 +3378,6 @@ CONFIG_MT7601U=m
CONFIG_MT76_CORE=m
CONFIG_MT76_LEDS=y
CONFIG_MT76_USB=m
-CONFIG_MT76_SDIO=m
CONFIG_MT76x02_LIB=m
CONFIG_MT76x02_USB=m
CONFIG_MT76_CONNAC_LIB=m
@@ -3397,21 +3394,19 @@ CONFIG_MT7615_COMMON=m
CONFIG_MT7615E=m
CONFIG_MT7663_USB_SDIO_COMMON=m
CONFIG_MT7663U=m
-CONFIG_MT7663S=m
+# CONFIG_MT7663S is not set
CONFIG_MT7915E=m
CONFIG_MT7921_COMMON=m
CONFIG_MT7921E=m
-CONFIG_MT7921S=m
+# CONFIG_MT7921S is not set
CONFIG_MT7921U=m
CONFIG_MT7996E=m
-CONFIG_MT7925_COMMON=m
-CONFIG_MT7925E=m
-CONFIG_MT7925U=m
+# CONFIG_MT7925E is not set
+# CONFIG_MT7925U is not set
CONFIG_WLAN_VENDOR_MICROCHIP=y
CONFIG_WILC1000=m
-CONFIG_WILC1000_SDIO=m
+# CONFIG_WILC1000_SDIO is not set
CONFIG_WILC1000_SPI=m
-# CONFIG_WILC1000_HW_OOB_INTR is not set
CONFIG_WLAN_VENDOR_PURELIFI=y
# CONFIG_PLFXLC is not set
CONFIG_WLAN_VENDOR_RALINK=y
@@ -3457,7 +3452,7 @@ CONFIG_RTL8188EE=m
CONFIG_RTL8192EE=m
CONFIG_RTL8821AE=m
CONFIG_RTL8192CU=m
-CONFIG_RTL8192DU=m
+# CONFIG_RTL8192DU is not set
CONFIG_RTLWIFI=m
CONFIG_RTLWIFI_PCI=m
CONFIG_RTLWIFI_USB=m
@@ -3471,26 +3466,24 @@ CONFIG_RTL8XXXU=m
CONFIG_RTW88=m
CONFIG_RTW88_CORE=m
CONFIG_RTW88_PCI=m
-CONFIG_RTW88_SDIO=m
CONFIG_RTW88_USB=m
CONFIG_RTW88_8822B=m
CONFIG_RTW88_8822C=m
CONFIG_RTW88_8723X=m
-CONFIG_RTW88_8703B=m
CONFIG_RTW88_8723D=m
CONFIG_RTW88_8821C=m
CONFIG_RTW88_8822BE=m
-CONFIG_RTW88_8822BS=m
+# CONFIG_RTW88_8822BS is not set
CONFIG_RTW88_8822BU=m
CONFIG_RTW88_8822CE=m
-CONFIG_RTW88_8822CS=m
+# CONFIG_RTW88_8822CS is not set
CONFIG_RTW88_8822CU=m
CONFIG_RTW88_8723DE=m
-CONFIG_RTW88_8723DS=m
-CONFIG_RTW88_8723CS=m
+# CONFIG_RTW88_8723DS is not set
+# CONFIG_RTW88_8723CS is not set
CONFIG_RTW88_8723DU=m
CONFIG_RTW88_8821CE=m
-CONFIG_RTW88_8821CS=m
+# CONFIG_RTW88_8821CS is not set
CONFIG_RTW88_8821CU=m
# CONFIG_RTW88_DEBUG is not set
# CONFIG_RTW88_DEBUGFS is not set
@@ -3501,15 +3494,13 @@ CONFIG_RTW89_8851B=m
CONFIG_RTW89_8852A=m
CONFIG_RTW89_8852B_COMMON=m
CONFIG_RTW89_8852B=m
-CONFIG_RTW89_8852BT=m
CONFIG_RTW89_8852C=m
-CONFIG_RTW89_8922A=m
CONFIG_RTW89_8851BE=m
CONFIG_RTW89_8852AE=m
CONFIG_RTW89_8852BE=m
-CONFIG_RTW89_8852BTE=m
+# CONFIG_RTW89_8852BTE is not set
CONFIG_RTW89_8852CE=m
-CONFIG_RTW89_8922AE=m
+# CONFIG_RTW89_8922AE is not set
# CONFIG_RTW89_DEBUGMSG is not set
# CONFIG_RTW89_DEBUGFS is not set
CONFIG_WLAN_VENDOR_RSI=y
@@ -3519,13 +3510,13 @@ CONFIG_RSI_DEBUGFS=y
CONFIG_RSI_USB=m
CONFIG_RSI_COEX=y
CONFIG_WLAN_VENDOR_SILABS=y
-# CONFIG_WFX is not set
+CONFIG_WFX=m
CONFIG_WLAN_VENDOR_ST=y
# CONFIG_CW1200 is not set
CONFIG_WLAN_VENDOR_TI=y
CONFIG_WL1251=m
CONFIG_WL1251_SPI=m
-CONFIG_WL1251_SDIO=m
+# CONFIG_WL1251_SDIO is not set
CONFIG_WL12XX=m
CONFIG_WL18XX=m
CONFIG_CC33XX=m
@@ -3556,10 +3547,17 @@ CONFIG_IEEE802154_HWSIM=m
# Wireless WAN
-# CONFIG_WWAN is not set
+CONFIG_WWAN=m
+CONFIG_WWAN_DEBUGFS=y
+# CONFIG_WWAN_HWSIM is not set
+CONFIG_MHI_WWAN_CTRL=m
+CONFIG_MHI_WWAN_MBIM=m
+# CONFIG_RPMSG_WWAN_CTRL is not set
+CONFIG_IOSM=m
+# CONFIG_MTK_T7XX is not set
# end of Wireless WAN
-CONFIG_VMXNET3=m
+# CONFIG_VMXNET3 is not set
# CONFIG_NETDEVSIM is not set
CONFIG_NET_FAILOVER=m
# CONFIG_ISDN is not set
@@ -3569,7 +3567,7 @@ CONFIG_NET_FAILOVER=m
CONFIG_INPUT=y
CONFIG_INPUT_LEDS=y
-CONFIG_INPUT_FF_MEMLESS=m
+CONFIG_INPUT_FF_MEMLESS=y
CONFIG_INPUT_SPARSEKMAP=m
CONFIG_INPUT_MATRIXKMAP=m
CONFIG_INPUT_VIVALDIFMAP=y
@@ -3579,7 +3577,7 @@ CONFIG_INPUT_VIVALDIFMAP=y
# CONFIG_INPUT_MOUSEDEV is not set
CONFIG_INPUT_JOYDEV=m
-CONFIG_INPUT_EVDEV=m
+CONFIG_INPUT_EVDEV=y
# CONFIG_INPUT_EVBUG is not set
@@ -3587,7 +3585,7 @@ CONFIG_INPUT_EVDEV=m
CONFIG_INPUT_KEYBOARD=y
CONFIG_KEYBOARD_ADC=m
-CONFIG_KEYBOARD_ADP5588=m
+# CONFIG_KEYBOARD_ADP5588 is not set
# CONFIG_KEYBOARD_ADP5589 is not set
CONFIG_KEYBOARD_ATKBD=y
# CONFIG_KEYBOARD_QT1050 is not set
@@ -3600,7 +3598,7 @@ CONFIG_KEYBOARD_GPIO=y
# CONFIG_KEYBOARD_TCA6416 is not set
# CONFIG_KEYBOARD_TCA8418 is not set
CONFIG_KEYBOARD_MATRIX=m
-CONFIG_KEYBOARD_LM8323=m
+# CONFIG_KEYBOARD_LM8323 is not set
# CONFIG_KEYBOARD_LM8333 is not set
CONFIG_KEYBOARD_MAX7359=m
# CONFIG_KEYBOARD_MPR121 is not set
@@ -3619,7 +3617,7 @@ CONFIG_KEYBOARD_STOWAWAY=m
CONFIG_INPUT_MOUSE=y
# CONFIG_MOUSE_PS2 is not set
# CONFIG_MOUSE_SERIAL is not set
-# CONFIG_MOUSE_APPLETOUCH is not set
+CONFIG_MOUSE_APPLETOUCH=m
# CONFIG_MOUSE_BCM5974 is not set
# CONFIG_MOUSE_CYAPA is not set
CONFIG_MOUSE_ELAN_I2C=m
@@ -3652,15 +3650,16 @@ CONFIG_JOYSTICK_SPACEBALL=m
CONFIG_JOYSTICK_STINGER=m
CONFIG_JOYSTICK_TWIDJOY=m
CONFIG_JOYSTICK_ZHENHUA=m
-# CONFIG_JOYSTICK_AS5011 is not set
-CONFIG_JOYSTICK_JOYDUMP=m
+CONFIG_JOYSTICK_AS5011=m
+# CONFIG_JOYSTICK_JOYDUMP is not set
CONFIG_JOYSTICK_XPAD=m
CONFIG_JOYSTICK_XPAD_FF=y
CONFIG_JOYSTICK_XPAD_LEDS=y
-# CONFIG_JOYSTICK_PSXPAD_SPI is not set
+CONFIG_JOYSTICK_PSXPAD_SPI=y
+CONFIG_JOYSTICK_PSXPAD_SPI_FF=y
CONFIG_JOYSTICK_PXRC=m
# CONFIG_JOYSTICK_QWIIC is not set
-# CONFIG_JOYSTICK_FSIA6B is not set
+CONFIG_JOYSTICK_FSIA6B=m
# CONFIG_JOYSTICK_SENSEHAT is not set
# CONFIG_JOYSTICK_SEESAW is not set
CONFIG_INPUT_TABLET=y
@@ -3677,7 +3676,7 @@ CONFIG_TOUCHSCREEN_AD7879=m
CONFIG_TOUCHSCREEN_AD7879_I2C=m
# CONFIG_TOUCHSCREEN_AD7879_SPI is not set
# CONFIG_TOUCHSCREEN_ADC is not set
-CONFIG_TOUCHSCREEN_AR1021_I2C=m
+CONFIG_TOUCHSCREEN_AR1021_I2C=y
CONFIG_TOUCHSCREEN_ATMEL_MXT=m
# CONFIG_TOUCHSCREEN_ATMEL_MXT_T37 is not set
# CONFIG_TOUCHSCREEN_AUO_PIXCIR is not set
@@ -3690,7 +3689,7 @@ CONFIG_TOUCHSCREEN_ATMEL_MXT=m
# CONFIG_TOUCHSCREEN_CYTTSP5 is not set
CONFIG_TOUCHSCREEN_DYNAPRO=m
CONFIG_TOUCHSCREEN_HAMPSHIRE=m
-CONFIG_TOUCHSCREEN_EETI=m
+# CONFIG_TOUCHSCREEN_EETI is not set
# CONFIG_TOUCHSCREEN_EGALAX is not set
# CONFIG_TOUCHSCREEN_EGALAX_SERIAL is not set
# CONFIG_TOUCHSCREEN_EXC3000 is not set
@@ -3706,13 +3705,13 @@ CONFIG_TOUCHSCREEN_ILI210X=m
# CONFIG_TOUCHSCREEN_S6SY761 is not set
CONFIG_TOUCHSCREEN_GUNZE=m
# CONFIG_TOUCHSCREEN_EKTF2127 is not set
-CONFIG_TOUCHSCREEN_ELAN=m
+# CONFIG_TOUCHSCREEN_ELAN is not set
CONFIG_TOUCHSCREEN_ELO=m
CONFIG_TOUCHSCREEN_WACOM_W8001=m
# CONFIG_TOUCHSCREEN_WACOM_I2C is not set
# CONFIG_TOUCHSCREEN_MAX11801 is not set
# CONFIG_TOUCHSCREEN_MMS114 is not set
-CONFIG_TOUCHSCREEN_MELFAS_MIP4=m
+# CONFIG_TOUCHSCREEN_MELFAS_MIP4 is not set
# CONFIG_TOUCHSCREEN_MSG2638 is not set
CONFIG_TOUCHSCREEN_MTOUCH=m
# CONFIG_TOUCHSCREEN_NOVATEK_NVT_TS is not set
@@ -3720,7 +3719,7 @@ CONFIG_TOUCHSCREEN_MTOUCH=m
# CONFIG_TOUCHSCREEN_IMX6UL_TSC is not set
CONFIG_TOUCHSCREEN_INEXIO=m
CONFIG_TOUCHSCREEN_PENMOUNT=m
-CONFIG_TOUCHSCREEN_EDT_FT5X06=m
+CONFIG_TOUCHSCREEN_EDT_FT5X06=y
CONFIG_TOUCHSCREEN_TOUCHRIGHT=m
CONFIG_TOUCHSCREEN_TOUCHWIN=m
CONFIG_TOUCHSCREEN_TI_AM335X_TSC=m
@@ -3747,16 +3746,17 @@ CONFIG_TOUCHSCREEN_USB_NEXIO=y
CONFIG_TOUCHSCREEN_USB_EASYTOUCH=y
CONFIG_TOUCHSCREEN_TOUCHIT213=m
# CONFIG_TOUCHSCREEN_TSC_SERIO is not set
+CONFIG_TOUCHSCREEN_TSC200X_CORE=m
# CONFIG_TOUCHSCREEN_TSC2004 is not set
-# CONFIG_TOUCHSCREEN_TSC2005 is not set
+CONFIG_TOUCHSCREEN_TSC2005=m
CONFIG_TOUCHSCREEN_TSC2007=m
# CONFIG_TOUCHSCREEN_TSC2007_IIO is not set
# CONFIG_TOUCHSCREEN_RM_TS is not set
-CONFIG_TOUCHSCREEN_SILEAD=m
+CONFIG_TOUCHSCREEN_SILEAD=y
# CONFIG_TOUCHSCREEN_SIS_I2C is not set
-CONFIG_TOUCHSCREEN_ST1232=m
+# CONFIG_TOUCHSCREEN_ST1232 is not set
# CONFIG_TOUCHSCREEN_STMFTS is not set
-CONFIG_TOUCHSCREEN_SUR40=m
+# CONFIG_TOUCHSCREEN_SUR40 is not set
# CONFIG_TOUCHSCREEN_SURFACE3_SPI is not set
# CONFIG_TOUCHSCREEN_SX8654 is not set
CONFIG_TOUCHSCREEN_TPS6507X=m
@@ -3769,14 +3769,16 @@ CONFIG_TOUCHSCREEN_TPS6507X=m
# CONFIG_TOUCHSCREEN_ZINITIX is not set
# CONFIG_TOUCHSCREEN_HIMAX_HX83112B is not set
CONFIG_INPUT_MISC=y
-# CONFIG_INPUT_AD714X is not set
+CONFIG_INPUT_AD714X=m
+CONFIG_INPUT_AD714X_I2C=m
+CONFIG_INPUT_AD714X_SPI=m
# CONFIG_INPUT_ATMEL_CAPTOUCH is not set
# CONFIG_INPUT_BMA150 is not set
# CONFIG_INPUT_E3X0_BUTTON is not set
-# CONFIG_INPUT_MMA8450 is not set
-CONFIG_INPUT_GPIO_BEEPER=m
+CONFIG_INPUT_MMA8450=m
+# CONFIG_INPUT_GPIO_BEEPER is not set
CONFIG_INPUT_GPIO_DECODER=m
-CONFIG_INPUT_GPIO_VIBRA=m
+# CONFIG_INPUT_GPIO_VIBRA is not set
CONFIG_INPUT_ATI_REMOTE2=m
CONFIG_INPUT_KEYSPAN_REMOTE=m
# CONFIG_INPUT_KXTJ9 is not set
@@ -3784,8 +3786,10 @@ CONFIG_INPUT_POWERMATE=m
CONFIG_INPUT_YEALINK=m
CONFIG_INPUT_CM109=m
# CONFIG_INPUT_REGULATOR_HAPTIC is not set
-CONFIG_INPUT_TPS65219_PWRBUTTON=m
+CONFIG_INPUT_TPS65219_PWRBUTTON=y
+# CONFIG_INPUT_AXP20X_PEK is not set
CONFIG_INPUT_UINPUT=m
+# CONFIG_INPUT_PALMAS_PWRBUTTON is not set
# CONFIG_INPUT_PCF8574 is not set
CONFIG_INPUT_PWM_BEEPER=m
# CONFIG_INPUT_PWM_VIBRA is not set
@@ -3820,8 +3824,8 @@ CONFIG_RMI4_F55=y
# Hardware I/O ports
CONFIG_SERIO=y
-CONFIG_SERIO_SERPORT=y
-# CONFIG_SERIO_AMBAKMI is not set
+CONFIG_SERIO_SERPORT=m
+CONFIG_SERIO_AMBAKMI=y
# CONFIG_SERIO_PCIPS2 is not set
CONFIG_SERIO_LIBPS2=y
# CONFIG_SERIO_RAW is not set
@@ -3863,9 +3867,9 @@ CONFIG_SERIAL_8250_CONSOLE=y
CONFIG_SERIAL_8250_DMA=y
CONFIG_SERIAL_8250_PCILIB=y
CONFIG_SERIAL_8250_PCI=y
-# CONFIG_SERIAL_8250_EXAR is not set
-CONFIG_SERIAL_8250_NR_UARTS=12
-CONFIG_SERIAL_8250_RUNTIME_UARTS=12
+CONFIG_SERIAL_8250_EXAR=y
+CONFIG_SERIAL_8250_NR_UARTS=10
+CONFIG_SERIAL_8250_RUNTIME_UARTS=10
CONFIG_SERIAL_8250_EXTENDED=y
# CONFIG_SERIAL_8250_MANY_PORTS is not set
# CONFIG_SERIAL_8250_PCI1XXXX is not set
@@ -3887,11 +3891,13 @@ CONFIG_SERIAL_OF_PLATFORM=y
# CONFIG_SERIAL_AMBA_PL010 is not set
# CONFIG_SERIAL_AMBA_PL011 is not set
# CONFIG_SERIAL_EARLYCON_SEMIHOST is not set
+# CONFIG_SERIAL_KGDB_NMI is not set
CONFIG_SERIAL_MAX3100=m
CONFIG_SERIAL_MAX310X=m
# CONFIG_SERIAL_UARTLITE is not set
CONFIG_SERIAL_CORE=y
CONFIG_SERIAL_CORE_CONSOLE=y
+CONFIG_CONSOLE_POLL=y
# CONFIG_SERIAL_JSM is not set
# CONFIG_SERIAL_SIFIVE is not set
# CONFIG_SERIAL_SCCNXP is not set
@@ -3901,7 +3907,8 @@ CONFIG_SERIAL_CORE_CONSOLE=y
# CONFIG_SERIAL_XILINX_PS_UART is not set
# CONFIG_SERIAL_ARC is not set
# CONFIG_SERIAL_RP2 is not set
-# CONFIG_SERIAL_FSL_LPUART is not set
+CONFIG_SERIAL_FSL_LPUART=y
+CONFIG_SERIAL_FSL_LPUART_CONSOLE=y
# CONFIG_SERIAL_FSL_LINFLEXUART is not set
# CONFIG_SERIAL_CONEXANT_DIGICOLOR is not set
# CONFIG_SERIAL_SPRD is not set
@@ -3909,7 +3916,7 @@ CONFIG_SERIAL_CORE_CONSOLE=y
CONFIG_SERIAL_MCTRL_GPIO=y
# CONFIG_SERIAL_NONSTANDARD is not set
-# CONFIG_N_GSM is not set
+CONFIG_N_GSM=m
CONFIG_NOZOMI=m
# CONFIG_NULL_TTY is not set
CONFIG_HVC_DRIVER=y
@@ -3919,7 +3926,7 @@ CONFIG_SERIAL_DEV_BUS=y
CONFIG_SERIAL_DEV_CTRL_TTYPORT=y
CONFIG_TTY_PRINTK=m
CONFIG_TTY_PRINTK_LEVEL=6
-CONFIG_VIRTIO_CONSOLE=y
+CONFIG_VIRTIO_CONSOLE=m
# CONFIG_IPMI_HANDLER is not set
# CONFIG_SSIF_IPMI_BMC is not set
# CONFIG_IPMB_DEVICE_INTERFACE is not set
@@ -3931,25 +3938,23 @@ CONFIG_HW_RANDOM_VIRTIO=m
CONFIG_HW_RANDOM_OPTEE=m
# CONFIG_HW_RANDOM_CCTRNG is not set
# CONFIG_HW_RANDOM_XIPHERA is not set
-CONFIG_HW_RANDOM_ARM_SMCCC_TRNG=m
-CONFIG_HW_RANDOM_CN10K=m
+# CONFIG_HW_RANDOM_ARM_SMCCC_TRNG is not set
+# CONFIG_HW_RANDOM_CN10K is not set
# CONFIG_APPLICOM is not set
CONFIG_DEVMEM=y
CONFIG_DEVPORT=y
CONFIG_TCG_TPM=y
# CONFIG_TCG_TPM2_HMAC is not set
CONFIG_HW_RANDOM_TPM=y
-CONFIG_TCG_TIS_CORE=m
# CONFIG_TCG_TIS is not set
-CONFIG_TCG_TIS_SPI=m
-CONFIG_TCG_TIS_SPI_CR50=y
+# CONFIG_TCG_TIS_SPI is not set
# CONFIG_TCG_TIS_I2C is not set
-CONFIG_TCG_TIS_I2C_CR50=m
-# CONFIG_TCG_TIS_I2C_ATMEL is not set
-CONFIG_TCG_TIS_I2C_INFINEON=m
+# CONFIG_TCG_TIS_I2C_CR50 is not set
+CONFIG_TCG_TIS_I2C_ATMEL=y
+CONFIG_TCG_TIS_I2C_INFINEON=y
# CONFIG_TCG_TIS_I2C_NUVOTON is not set
# CONFIG_TCG_ATMEL is not set
-CONFIG_TCG_VTPM_PROXY=m
+# CONFIG_TCG_VTPM_PROXY is not set
# CONFIG_TCG_FTPM_TEE is not set
# CONFIG_TCG_TIS_ST33ZP24_I2C is not set
# CONFIG_TCG_TIS_ST33ZP24_SPI is not set
@@ -3968,12 +3973,12 @@ CONFIG_I2C_MUX=y
# Multiplexer I2C Chip support
-# CONFIG_I2C_ARB_GPIO_CHALLENGE is not set
+CONFIG_I2C_ARB_GPIO_CHALLENGE=m
CONFIG_I2C_MUX_GPIO=y
# CONFIG_I2C_MUX_GPMUX is not set
# CONFIG_I2C_MUX_LTC4306 is not set
# CONFIG_I2C_MUX_PCA9541 is not set
-CONFIG_I2C_MUX_PCA954x=m
+CONFIG_I2C_MUX_PCA954x=y
CONFIG_I2C_MUX_PINCTRL=y
CONFIG_I2C_MUX_REG=m
# CONFIG_I2C_DEMUX_PINCTRL is not set
@@ -3981,6 +3986,7 @@ CONFIG_I2C_MUX_REG=m
# CONFIG_I2C_MUX_MULE is not set
# end of Multiplexer I2C Chip support
+CONFIG_I2C_ATR=m
CONFIG_I2C_HELPER_AUTO=y
CONFIG_I2C_ALGOBIT=y
@@ -4042,7 +4048,7 @@ CONFIG_I2C_TINY_USB=m
# CONFIG_I2C_VIRTIO is not set
# end of I2C Hardware Bus support
-CONFIG_I2C_STUB=m
+# CONFIG_I2C_STUB is not set
CONFIG_I2C_SLAVE=y
CONFIG_I2C_SLAVE_EEPROM=y
# CONFIG_I2C_SLAVE_TESTUNIT is not set
@@ -4089,7 +4095,7 @@ CONFIG_SPI_OMAP24XX=y
# SPI Multiplexer support
-CONFIG_SPI_MUX=m
+# CONFIG_SPI_MUX is not set
# SPI Protocol Masters
@@ -4122,14 +4128,14 @@ CONFIG_PPS_CLIENT_GPIO=m
CONFIG_PTP_1588_CLOCK=y
CONFIG_PTP_1588_CLOCK_OPTIONAL=y
-CONFIG_DP83640_PHY=m
-CONFIG_PTP_1588_CLOCK_INES=m
+# CONFIG_DP83640_PHY is not set
+# CONFIG_PTP_1588_CLOCK_INES is not set
CONFIG_PTP_1588_CLOCK_KVM=y
-CONFIG_PTP_1588_CLOCK_IDT82P33=m
-CONFIG_PTP_1588_CLOCK_IDTCM=m
+# CONFIG_PTP_1588_CLOCK_IDT82P33 is not set
+# CONFIG_PTP_1588_CLOCK_IDTCM is not set
# CONFIG_PTP_1588_CLOCK_FC3W is not set
# CONFIG_PTP_1588_CLOCK_MOCK is not set
-CONFIG_PTP_1588_CLOCK_OCP=m
+# CONFIG_PTP_1588_CLOCK_OCP is not set
# end of PTP clock support
CONFIG_PINCTRL=y
@@ -4139,6 +4145,7 @@ CONFIG_GENERIC_PINMUX_FUNCTIONS=y
CONFIG_PINCONF=y
CONFIG_GENERIC_PINCONF=y
# CONFIG_DEBUG_PINCTRL is not set
+# CONFIG_PINCTRL_AXP209 is not set
# CONFIG_PINCTRL_AW9523 is not set
# CONFIG_PINCTRL_CY8C95X0 is not set
CONFIG_PINCTRL_MAX77620=y
@@ -4147,6 +4154,7 @@ CONFIG_PINCTRL_MCP23S08_SPI=m
CONFIG_PINCTRL_MCP23S08=m
# CONFIG_PINCTRL_MICROCHIP_SGPIO is not set
# CONFIG_PINCTRL_OCELOT is not set
+# CONFIG_PINCTRL_PALMAS is not set
# CONFIG_PINCTRL_SCMI is not set
CONFIG_PINCTRL_SINGLE=y
# CONFIG_PINCTRL_STMFX is not set
@@ -4179,13 +4187,14 @@ CONFIG_GPIO_MAX730X=m
# CONFIG_GPIO_CADENCE is not set
CONFIG_GPIO_DAVINCI=y
# CONFIG_GPIO_DWAPB is not set
+# CONFIG_GPIO_EXAR is not set
# CONFIG_GPIO_FTGPIO010 is not set
CONFIG_GPIO_GENERIC_PLATFORM=y
# CONFIG_GPIO_GRGPIO is not set
# CONFIG_GPIO_HISI is not set
# CONFIG_GPIO_HLWD is not set
# CONFIG_GPIO_LOGICVC is not set
-# CONFIG_GPIO_MB86S7X is not set
+CONFIG_GPIO_MB86S7X=y
# CONFIG_GPIO_PL061 is not set
# CONFIG_GPIO_SIFIVE is not set
CONFIG_GPIO_SYSCON=y
@@ -4213,7 +4222,9 @@ CONFIG_GPIO_TPIC2810=m
# MFD GPIO expanders
+CONFIG_GPIO_BD9571MWV=m
CONFIG_GPIO_MAX77620=y
+# CONFIG_GPIO_PALMAS is not set
CONFIG_GPIO_TPS65219=y
# end of MFD GPIO expanders
@@ -4246,9 +4257,9 @@ CONFIG_GPIO_XRA1403=m
# Virtual GPIO drivers
CONFIG_GPIO_AGGREGATOR=y
-# CONFIG_GPIO_LATCH is not set
+CONFIG_GPIO_LATCH=m
# CONFIG_GPIO_MOCKUP is not set
-# CONFIG_GPIO_VIRTIO is not set
+CONFIG_GPIO_VIRTIO=m
# CONFIG_GPIO_SIM is not set
# end of Virtual GPIO drivers
@@ -4310,8 +4321,7 @@ CONFIG_POWER_RESET_SYSCON_POWEROFF=y
CONFIG_REBOOT_MODE=m
CONFIG_SYSCON_REBOOT_MODE=m
# CONFIG_NVMEM_REBOOT_MODE is not set
-CONFIG_POWER_SEQUENCING=y
-# CONFIG_POWER_SEQUENCING_QCOM_WCN is not set
+# CONFIG_POWER_SEQUENCING is not set
CONFIG_POWER_SUPPLY=y
# CONFIG_POWER_SUPPLY_DEBUG is not set
CONFIG_POWER_SUPPLY_HWMON=y
@@ -4319,7 +4329,7 @@ CONFIG_GENERIC_ADC_BATTERY=m
# CONFIG_IP5XXX_POWER is not set
# CONFIG_TEST_POWER is not set
# CONFIG_CHARGER_ADP5061 is not set
-CONFIG_BATTERY_CW2015=m
+# CONFIG_BATTERY_CW2015 is not set
CONFIG_BATTERY_DS2760=m
# CONFIG_BATTERY_DS2780 is not set
# CONFIG_BATTERY_DS2781 is not set
@@ -4331,6 +4341,9 @@ CONFIG_BATTERY_SBS=m
CONFIG_BATTERY_BQ27XXX=m
# CONFIG_BATTERY_BQ27XXX_I2C is not set
CONFIG_BATTERY_BQ27XXX_HDQ=m
+# CONFIG_CHARGER_AXP20X is not set
+# CONFIG_BATTERY_AXP20X is not set
+# CONFIG_AXP20X_POWER is not set
# CONFIG_BATTERY_MAX17040 is not set
# CONFIG_BATTERY_MAX17042 is not set
# CONFIG_BATTERY_MAX1720X is not set
@@ -4392,7 +4405,7 @@ CONFIG_SENSORS_AS370=m
CONFIG_SENSORS_ASC7621=m
# CONFIG_SENSORS_ASUS_ROG_RYUJIN is not set
CONFIG_SENSORS_AXI_FAN_CONTROL=m
-# CONFIG_SENSORS_ARM_SCMI is not set
+CONFIG_SENSORS_ARM_SCMI=m
CONFIG_SENSORS_ARM_SCPI=m
CONFIG_SENSORS_ATXP1=m
# CONFIG_SENSORS_CHIPCAP2 is not set
@@ -4410,10 +4423,10 @@ CONFIG_SENSORS_FTSTEUTATES=m
CONFIG_SENSORS_GL518SM=m
CONFIG_SENSORS_GL520SM=m
CONFIG_SENSORS_G760A=m
-# CONFIG_SENSORS_G762 is not set
+CONFIG_SENSORS_G762=m
CONFIG_SENSORS_GPIO_FAN=y
CONFIG_SENSORS_HIH6130=m
-# CONFIG_SENSORS_HS3001 is not set
+CONFIG_SENSORS_HS3001=m
CONFIG_SENSORS_IIO_HWMON=m
CONFIG_SENSORS_IT87=m
CONFIG_SENSORS_JC42=m
@@ -4425,7 +4438,7 @@ CONFIG_SENSORS_LTC2947=m
CONFIG_SENSORS_LTC2947_I2C=m
CONFIG_SENSORS_LTC2947_SPI=m
CONFIG_SENSORS_LTC2990=m
-CONFIG_SENSORS_LTC2991=m
+# CONFIG_SENSORS_LTC2991 is not set
CONFIG_SENSORS_LTC2992=m
CONFIG_SENSORS_LTC4151=m
CONFIG_SENSORS_LTC4215=m
@@ -4433,7 +4446,7 @@ CONFIG_SENSORS_LTC4222=m
CONFIG_SENSORS_LTC4245=m
CONFIG_SENSORS_LTC4260=m
CONFIG_SENSORS_LTC4261=m
-CONFIG_SENSORS_LTC4282=m
+# CONFIG_SENSORS_LTC4282 is not set
CONFIG_SENSORS_MAX1111=m
CONFIG_SENSORS_MAX127=m
CONFIG_SENSORS_MAX16065=m
@@ -4483,22 +4496,22 @@ CONFIG_SENSORS_NCT7802=m
CONFIG_SENSORS_NCT7904=m
CONFIG_SENSORS_NPCM7XX=m
CONFIG_SENSORS_NZXT_KRAKEN2=m
-CONFIG_SENSORS_NZXT_KRAKEN3=m
+# CONFIG_SENSORS_NZXT_KRAKEN3 is not set
CONFIG_SENSORS_NZXT_SMART2=m
CONFIG_SENSORS_OCC_P8_I2C=m
CONFIG_SENSORS_OCC=m
CONFIG_SENSORS_PCF8591=m
CONFIG_PMBUS=m
CONFIG_SENSORS_PMBUS=m
-CONFIG_SENSORS_ACBEL_FSG032=m
+# CONFIG_SENSORS_ACBEL_FSG032 is not set
CONFIG_SENSORS_ADM1266=m
CONFIG_SENSORS_ADM1275=m
-CONFIG_SENSORS_ADP1050=m
+# CONFIG_SENSORS_ADP1050 is not set
CONFIG_SENSORS_BEL_PFE=m
CONFIG_SENSORS_BPA_RS600=m
CONFIG_SENSORS_DELTA_AHE50DC_FAN=m
CONFIG_SENSORS_FSP_3Y=m
-# CONFIG_SENSORS_IBM_CFFPS is not set
+CONFIG_SENSORS_IBM_CFFPS=m
CONFIG_SENSORS_DPS920AB=m
CONFIG_SENSORS_INSPUR_IPSPS=m
CONFIG_SENSORS_IR35221=m
@@ -4522,19 +4535,19 @@ CONFIG_SENSORS_MAX20751=m
CONFIG_SENSORS_MAX31785=m
CONFIG_SENSORS_MAX34440=m
CONFIG_SENSORS_MAX8688=m
-CONFIG_SENSORS_MP2856=m
+# CONFIG_SENSORS_MP2856 is not set
CONFIG_SENSORS_MP2888=m
-CONFIG_SENSORS_MP2891=m
+# CONFIG_SENSORS_MP2891 is not set
CONFIG_SENSORS_MP2975=m
-CONFIG_SENSORS_MP2993=m
+# CONFIG_SENSORS_MP2993 is not set
# CONFIG_SENSORS_MP2975_REGULATOR is not set
CONFIG_SENSORS_MP5023=m
-CONFIG_SENSORS_MP5920=m
-CONFIG_SENSORS_MP5990=m
-CONFIG_SENSORS_MP9941=m
+# CONFIG_SENSORS_MP5920 is not set
+# CONFIG_SENSORS_MP5990 is not set
+# CONFIG_SENSORS_MP9941 is not set
# CONFIG_SENSORS_MPQ7932_REGULATOR is not set
CONFIG_SENSORS_MPQ7932=m
-CONFIG_SENSORS_MPQ8785=m
+# CONFIG_SENSORS_MPQ8785 is not set
CONFIG_SENSORS_PIM4328=m
CONFIG_SENSORS_PLI1209BC=m
CONFIG_SENSORS_PLI1209BC_REGULATOR=y
@@ -4549,12 +4562,12 @@ CONFIG_SENSORS_TPS53679=m
CONFIG_SENSORS_TPS546D24=m
CONFIG_SENSORS_UCD9000=m
CONFIG_SENSORS_UCD9200=m
-CONFIG_SENSORS_XDP710=m
+# CONFIG_SENSORS_XDP710 is not set
CONFIG_SENSORS_XDPE152=m
CONFIG_SENSORS_XDPE122=m
CONFIG_SENSORS_XDPE122_REGULATOR=y
CONFIG_SENSORS_ZL6100=m
-CONFIG_SENSORS_PT5161L=m
+# CONFIG_SENSORS_PT5161L is not set
CONFIG_SENSORS_PWM_FAN=m
CONFIG_SENSORS_SBTSI=m
CONFIG_SENSORS_SBRMI=m
@@ -4584,8 +4597,7 @@ CONFIG_SENSORS_INA209=m
CONFIG_SENSORS_INA2XX=m
CONFIG_SENSORS_INA238=m
CONFIG_SENSORS_INA3221=m
-CONFIG_SENSORS_SPD5118=m
-CONFIG_SENSORS_SPD5118_DETECT=y
+# CONFIG_SENSORS_SPD5118 is not set
CONFIG_SENSORS_TC74=m
CONFIG_SENSORS_THMC50=m
CONFIG_SENSORS_TMP102=m
@@ -4595,7 +4607,7 @@ CONFIG_SENSORS_TMP401=m
CONFIG_SENSORS_TMP421=m
CONFIG_SENSORS_TMP464=m
CONFIG_SENSORS_TMP513=m
-# CONFIG_SENSORS_VIA686A is not set
+CONFIG_SENSORS_VIA686A=m
CONFIG_SENSORS_VT1211=m
CONFIG_SENSORS_VT8231=m
CONFIG_SENSORS_W83773G=m
@@ -4641,24 +4653,18 @@ CONFIG_WATCHDOG_CORE=y
CONFIG_WATCHDOG_HANDLE_BOOT_ENABLED=y
CONFIG_WATCHDOG_OPEN_TIMEOUT=0
CONFIG_WATCHDOG_SYSFS=y
-CONFIG_WATCHDOG_HRTIMER_PRETIMEOUT=y
+# CONFIG_WATCHDOG_HRTIMER_PRETIMEOUT is not set
# Watchdog Pretimeout Governors
-CONFIG_WATCHDOG_PRETIMEOUT_GOV=y
-CONFIG_WATCHDOG_PRETIMEOUT_GOV_SEL=m
-CONFIG_WATCHDOG_PRETIMEOUT_GOV_NOOP=y
-CONFIG_WATCHDOG_PRETIMEOUT_GOV_PANIC=m
-CONFIG_WATCHDOG_PRETIMEOUT_DEFAULT_GOV_NOOP=y
-# CONFIG_WATCHDOG_PRETIMEOUT_DEFAULT_GOV_PANIC is not set
+# CONFIG_WATCHDOG_PRETIMEOUT_GOV is not set
# Watchdog Device Drivers
-CONFIG_SOFT_WATCHDOG=y
-# CONFIG_SOFT_WATCHDOG_PRETIMEOUT is not set
-CONFIG_GPIO_WATCHDOG=m
+# CONFIG_SOFT_WATCHDOG is not set
+# CONFIG_GPIO_WATCHDOG is not set
# CONFIG_XILINX_WATCHDOG is not set
# CONFIG_XILINX_WINDOW_WATCHDOG is not set
# CONFIG_ZIIRAVE_WATCHDOG is not set
@@ -4666,10 +4672,10 @@ CONFIG_GPIO_WATCHDOG=m
# CONFIG_ARM_SBSA_WATCHDOG is not set
# CONFIG_CADENCE_WATCHDOG is not set
# CONFIG_DW_WATCHDOG is not set
-CONFIG_K3_RTI_WATCHDOG=y
+CONFIG_K3_RTI_WATCHDOG=m
# CONFIG_MAX63XX_WATCHDOG is not set
# CONFIG_MAX77620_WATCHDOG is not set
-# CONFIG_ARM_SMC_WATCHDOG is not set
+CONFIG_ARM_SMC_WATCHDOG=y
# CONFIG_ALIM7101_WDT is not set
# CONFIG_I6300ESB_WDT is not set
# CONFIG_HP_WATCHDOG is not set
@@ -4686,9 +4692,24 @@ CONFIG_K3_RTI_WATCHDOG=y
# CONFIG_USBPCWATCHDOG is not set
CONFIG_SSB_POSSIBLE=y
-# CONFIG_SSB is not set
+CONFIG_SSB=m
+CONFIG_SSB_SPROM=y
+CONFIG_SSB_PCIHOST_POSSIBLE=y
+CONFIG_SSB_PCIHOST=y
+CONFIG_SSB_SDIOHOST_POSSIBLE=y
+# CONFIG_SSB_SDIOHOST is not set
+CONFIG_SSB_DRIVER_PCICORE_POSSIBLE=y
+CONFIG_SSB_DRIVER_PCICORE=y
+# CONFIG_SSB_DRIVER_GPIO is not set
CONFIG_BCMA_POSSIBLE=y
-# CONFIG_BCMA is not set
+CONFIG_BCMA=m
+CONFIG_BCMA_HOST_PCI_POSSIBLE=y
+# CONFIG_BCMA_HOST_PCI is not set
+# CONFIG_BCMA_HOST_SOC is not set
+# CONFIG_BCMA_DRIVER_PCI is not set
+# CONFIG_BCMA_DRIVER_GMAC_CMN is not set
+# CONFIG_BCMA_DRIVER_GPIO is not set
+# CONFIG_BCMA_DEBUG is not set
# Multifunction device drivers
@@ -4704,8 +4725,9 @@ CONFIG_MFD_CORE=y
# CONFIG_MFD_ATMEL_FLEXCOM is not set
# CONFIG_MFD_ATMEL_HLCDC is not set
# CONFIG_MFD_BCM590XX is not set
-# CONFIG_MFD_BD9571MWV is not set
-# CONFIG_MFD_AXP20X_I2C is not set
+CONFIG_MFD_BD9571MWV=y
+CONFIG_MFD_AXP20X=y
+CONFIG_MFD_AXP20X_I2C=y
# CONFIG_MFD_CS42L43_I2C is not set
# CONFIG_MFD_MADERA is not set
# CONFIG_MFD_MAX5970 is not set
@@ -4721,7 +4743,7 @@ CONFIG_MFD_CORE=y
# CONFIG_MFD_MC13XXX_SPI is not set
# CONFIG_MFD_MC13XXX_I2C is not set
# CONFIG_MFD_MP2629 is not set
-# CONFIG_MFD_HI6421_PMIC is not set
+CONFIG_MFD_HI6421_PMIC=y
# CONFIG_LPC_ICH is not set
# CONFIG_LPC_SCH is not set
# CONFIG_MFD_IQS62X is not set
@@ -4769,11 +4791,11 @@ CONFIG_MFD_MAX77620=y
# CONFIG_MFD_SKY81452 is not set
# CONFIG_MFD_STMPE is not set
CONFIG_MFD_SYSCON=y
-CONFIG_MFD_TI_AM335X_TSCADC=y
+CONFIG_MFD_TI_AM335X_TSCADC=m
# CONFIG_MFD_LP3943 is not set
# CONFIG_MFD_LP8788 is not set
# CONFIG_MFD_TI_LMU is not set
-# CONFIG_MFD_PALMAS is not set
+CONFIG_MFD_PALMAS=y
# CONFIG_TPS6105X is not set
# CONFIG_TPS65010 is not set
# CONFIG_TPS6507X is not set
@@ -4790,7 +4812,7 @@ CONFIG_MFD_TPS65219=y
# CONFIG_MFD_TPS65912_SPI is not set
CONFIG_MFD_TPS6594=y
CONFIG_MFD_TPS6594_I2C=y
-# CONFIG_MFD_TPS6594_SPI is not set
+CONFIG_MFD_TPS6594_SPI=y
# CONFIG_TWL4030_CORE is not set
# CONFIG_TWL6040_CORE is not set
# CONFIG_MFD_WL1273_CORE is not set
@@ -4806,7 +4828,7 @@ CONFIG_MFD_TPS6594_I2C=y
# CONFIG_MFD_WM831X_SPI is not set
# CONFIG_MFD_WM8350_I2C is not set
# CONFIG_MFD_WM8994 is not set
-# CONFIG_MFD_ROHM_BD718XX is not set
+CONFIG_MFD_ROHM_BD718XX=y
# CONFIG_MFD_ROHM_BD71828 is not set
# CONFIG_MFD_ROHM_BD957XMUF is not set
# CONFIG_MFD_ROHM_BD96801 is not set
@@ -4833,12 +4855,17 @@ CONFIG_REGULATOR_USERSPACE_CONSUMER=y
# CONFIG_REGULATOR_AD5398 is not set
# CONFIG_REGULATOR_ARM_SCMI is not set
# CONFIG_REGULATOR_AW37503 is not set
+CONFIG_REGULATOR_AXP20X=y
+CONFIG_REGULATOR_BD718XX=y
+CONFIG_REGULATOR_BD9571MWV=y
# CONFIG_REGULATOR_DA9121 is not set
# CONFIG_REGULATOR_DA9210 is not set
# CONFIG_REGULATOR_DA9211 is not set
-# CONFIG_REGULATOR_FAN53555 is not set
+CONFIG_REGULATOR_FAN53555=y
# CONFIG_REGULATOR_FAN53880 is not set
CONFIG_REGULATOR_GPIO=y
+# CONFIG_REGULATOR_HI6421 is not set
+CONFIG_REGULATOR_HI6421V530=y
# CONFIG_REGULATOR_ISL9305 is not set
# CONFIG_REGULATOR_ISL6271A is not set
# CONFIG_REGULATOR_LP3971 is not set
@@ -4849,13 +4876,13 @@ CONFIG_REGULATOR_GPIO=y
# CONFIG_REGULATOR_LTC3676 is not set
# CONFIG_REGULATOR_MAX1586 is not set
# CONFIG_REGULATOR_MAX77503 is not set
-# CONFIG_REGULATOR_MAX77620 is not set
+CONFIG_REGULATOR_MAX77620=y
# CONFIG_REGULATOR_MAX77857 is not set
# CONFIG_REGULATOR_MAX8649 is not set
# CONFIG_REGULATOR_MAX8660 is not set
# CONFIG_REGULATOR_MAX8893 is not set
# CONFIG_REGULATOR_MAX8952 is not set
-# CONFIG_REGULATOR_MAX8973 is not set
+CONFIG_REGULATOR_MAX8973=y
# CONFIG_REGULATOR_MAX20086 is not set
# CONFIG_REGULATOR_MAX20411 is not set
# CONFIG_REGULATOR_MAX77826 is not set
@@ -4865,15 +4892,17 @@ CONFIG_REGULATOR_GPIO=y
# CONFIG_REGULATOR_MP886X is not set
# CONFIG_REGULATOR_MPQ7920 is not set
# CONFIG_REGULATOR_MT6311 is not set
-# CONFIG_REGULATOR_PCA9450 is not set
+CONFIG_REGULATOR_PALMAS=y
+CONFIG_REGULATOR_PCA9450=y
# CONFIG_REGULATOR_PF8X00 is not set
-# CONFIG_REGULATOR_PFUZE100 is not set
+CONFIG_REGULATOR_PFUZE100=y
# CONFIG_REGULATOR_PV88060 is not set
# CONFIG_REGULATOR_PV88080 is not set
# CONFIG_REGULATOR_PV88090 is not set
CONFIG_REGULATOR_PWM=y
# CONFIG_REGULATOR_RAA215300 is not set
CONFIG_REGULATOR_RASPBERRYPI_TOUCHSCREEN_ATTINY=m
+CONFIG_REGULATOR_ROHM=y
# CONFIG_REGULATOR_RT4801 is not set
# CONFIG_REGULATOR_RT4803 is not set
# CONFIG_REGULATOR_RT5190A is not set
@@ -4949,7 +4978,6 @@ CONFIG_VIDEO_V4L2_SUBDEV_API=y
CONFIG_VIDEO_TUNER=m
CONFIG_V4L2_JPEG_HELPER=m
CONFIG_V4L2_MEM2MEM_DEV=m
-# CONFIG_V4L2_FLASH_LED_CLASS is not set
CONFIG_V4L2_FWNODE=m
CONFIG_V4L2_ASYNC=m
CONFIG_V4L2_CCI=m
@@ -5128,7 +5156,7 @@ CONFIG_V4L_PLATFORM_DRIVERS=y
# CONFIG_DVB_PLATFORM_DRIVERS is not set
CONFIG_V4L_MEM2MEM_DRIVERS=y
# CONFIG_VIDEO_MEM2MEM_DEINTERLACE is not set
-# CONFIG_VIDEO_MUX is not set
+CONFIG_VIDEO_MUX=m
# Allegro DVT media platform drivers
@@ -5257,13 +5285,10 @@ CONFIG_MEDIA_COMMON_OPTIONS=y
# common driver options
CONFIG_CYPRESS_FIRMWARE=m
-CONFIG_TTPCI_EEPROM=m
CONFIG_UVC_COMMON=m
CONFIG_VIDEO_CX2341X=m
CONFIG_VIDEO_TVEEPROM=m
CONFIG_DVB_B2C2_FLEXCOP=m
-CONFIG_VIDEO_SAA7146=m
-CONFIG_VIDEO_SAA7146_VV=m
CONFIG_SMS_SIANO_MDTV=m
# CONFIG_SMS_SIANO_DEBUGFS is not set
CONFIG_VIDEOBUF2_CORE=m
@@ -5304,7 +5329,7 @@ CONFIG_VIDEO_IMX290=m
CONFIG_VIDEO_IMX390=m
# CONFIG_VIDEO_IMX412 is not set
# CONFIG_VIDEO_IMX415 is not set
-CONFIG_VIDEO_IMX708=m
+# CONFIG_VIDEO_IMX708 is not set
CONFIG_VIDEO_IMX728=m
# CONFIG_VIDEO_MT9M001 is not set
# CONFIG_VIDEO_MT9M111 is not set
@@ -5415,7 +5440,7 @@ CONFIG_VIDEO_SAA6588=m
# Video decoders
-# CONFIG_VIDEO_ADV7180 is not set
+CONFIG_VIDEO_ADV7180=m
# CONFIG_VIDEO_ADV7183 is not set
# CONFIG_VIDEO_ADV748X is not set
# CONFIG_VIDEO_ADV7604 is not set
@@ -5429,7 +5454,8 @@ CONFIG_VIDEO_KS0127=m
# CONFIG_VIDEO_ML86V7667 is not set
CONFIG_VIDEO_SAA7110=m
CONFIG_VIDEO_SAA711X=m
-# CONFIG_VIDEO_TC358743 is not set
+CONFIG_VIDEO_TC358743=m
+# CONFIG_VIDEO_TC358743_CEC is not set
# CONFIG_VIDEO_TC358746 is not set
# CONFIG_VIDEO_TVP514X is not set
CONFIG_VIDEO_TVP5150=m
@@ -5494,8 +5520,8 @@ CONFIG_VIDEO_M52790=m
# Video serializers and deserializers
# CONFIG_VIDEO_DS90UB913 is not set
-# CONFIG_VIDEO_DS90UB953 is not set
-# CONFIG_VIDEO_DS90UB960 is not set
+CONFIG_VIDEO_DS90UB953=m
+CONFIG_VIDEO_DS90UB960=m
# CONFIG_VIDEO_MAX96714 is not set
# CONFIG_VIDEO_MAX96717 is not set
# end of Video serializers and deserializers
@@ -5503,7 +5529,7 @@ CONFIG_VIDEO_M52790=m
# Media SPI Adapters
-# CONFIG_CXD2880_SPI_DRV is not set
+CONFIG_CXD2880_SPI_DRV=m
# CONFIG_VIDEO_GS1662 is not set
# end of Media SPI Adapters
@@ -5620,7 +5646,7 @@ CONFIG_DVB_DIB3000MB=m
CONFIG_DVB_DIB3000MC=m
CONFIG_DVB_DIB7000M=m
CONFIG_DVB_DIB7000P=m
-# CONFIG_DVB_DIB9000 is not set
+CONFIG_DVB_DIB9000=m
CONFIG_DVB_DRXD=m
CONFIG_DVB_EC100=m
CONFIG_DVB_L64781=m
@@ -5629,7 +5655,7 @@ CONFIG_DVB_NXT6000=m
CONFIG_DVB_RTL2830=m
CONFIG_DVB_RTL2832=m
CONFIG_DVB_RTL2832_SDR=m
-# CONFIG_DVB_S5H1432 is not set
+CONFIG_DVB_S5H1432=m
CONFIG_DVB_SI2168=m
CONFIG_DVB_SP887X=m
CONFIG_DVB_STV0367=m
@@ -5637,7 +5663,7 @@ CONFIG_DVB_TDA10048=m
CONFIG_DVB_TDA1004X=m
CONFIG_DVB_ZD1301_DEMOD=m
CONFIG_DVB_ZL10353=m
-# CONFIG_DVB_CXD2880 is not set
+CONFIG_DVB_CXD2880=m
# DVB-C (cable) frontends
@@ -5675,7 +5701,7 @@ CONFIG_DVB_S921=m
# ISDB-S (satellite) & ISDB-T (terrestrial) frontends
-# CONFIG_DVB_MN88443X is not set
+CONFIG_DVB_MN88443X=m
CONFIG_DVB_TC90522=m
@@ -5698,10 +5724,10 @@ CONFIG_DVB_ISL6405=m
CONFIG_DVB_ISL6421=m
CONFIG_DVB_ISL6423=m
CONFIG_DVB_IX2505V=m
-# CONFIG_DVB_LGS8GL5 is not set
+CONFIG_DVB_LGS8GL5=m
CONFIG_DVB_LGS8GXX=m
CONFIG_DVB_LNBH25=m
-# CONFIG_DVB_LNBH29 is not set
+CONFIG_DVB_LNBH29=m
CONFIG_DVB_LNBP21=m
CONFIG_DVB_LNBP22=m
CONFIG_DVB_M88RS2000=m
@@ -5752,7 +5778,6 @@ CONFIG_DRM_PANIC_FOREGROUND_COLOR=0xffffff
CONFIG_DRM_PANIC_BACKGROUND_COLOR=0x000000
# CONFIG_DRM_PANIC_DEBUG is not set
CONFIG_DRM_PANIC_SCREEN="user"
-# CONFIG_DRM_PANIC_SCREEN_QR_CODE is not set
# CONFIG_DRM_DEBUG_DP_MST_TOPOLOGY_REFS is not set
# CONFIG_DRM_DEBUG_MODESET_LOCK is not set
CONFIG_DRM_FBDEV_EMULATION=y
@@ -5770,11 +5795,10 @@ CONFIG_DRM_DISPLAY_HDMI_HELPER=y
CONFIG_DRM_DISPLAY_HDMI_STATE_HELPER=y
CONFIG_DRM_TTM=m
CONFIG_DRM_EXEC=m
-CONFIG_DRM_GPUVM=m
CONFIG_DRM_BUDDY=m
CONFIG_DRM_TTM_HELPER=m
CONFIG_DRM_GEM_DMA_HELPER=y
-CONFIG_DRM_GEM_SHMEM_HELPER=y
+CONFIG_DRM_GEM_SHMEM_HELPER=m
CONFIG_DRM_SUBALLOC_HELPER=m
CONFIG_DRM_SCHED=m
@@ -5783,7 +5807,7 @@ CONFIG_DRM_SCHED=m
# CONFIG_DRM_I2C_CH7006 is not set
# CONFIG_DRM_I2C_SIL164 is not set
-# CONFIG_DRM_I2C_NXP_TDA998X is not set
+CONFIG_DRM_I2C_NXP_TDA998X=y
# CONFIG_DRM_I2C_NXP_TDA9950 is not set
# end of I2C encoder or helper chips
@@ -5815,6 +5839,7 @@ CONFIG_DRM_AMDGPU_USERPTR=y
CONFIG_DRM_AMD_DC=y
CONFIG_DRM_AMD_DC_FP=y
CONFIG_DRM_AMD_DC_SI=y
+# CONFIG_DEBUG_KERNEL_DC is not set
# CONFIG_DRM_AMD_SECURE_DISPLAY is not set
# end of Display Engine Configuration
@@ -5840,8 +5865,8 @@ CONFIG_DRM_PANEL=y
# CONFIG_DRM_PANEL_AUO_A030JTN01 is not set
# CONFIG_DRM_PANEL_BOE_BF060Y8M_AJ0 is not set
# CONFIG_DRM_PANEL_BOE_HIMAX8279D is not set
-CONFIG_DRM_PANEL_BOE_TH101MB31UIG002_28A=m
-CONFIG_DRM_PANEL_BOE_TV101WUM_NL6=m
+# CONFIG_DRM_PANEL_BOE_TH101MB31UIG002_28A is not set
+# CONFIG_DRM_PANEL_BOE_TV101WUM_NL6 is not set
# CONFIG_DRM_PANEL_BOE_TV101WUM_LL2 is not set
# CONFIG_DRM_PANEL_EBBG_FT8719 is not set
# CONFIG_DRM_PANEL_ELIDA_KD35T133 is not set
@@ -5849,7 +5874,7 @@ CONFIG_DRM_PANEL_BOE_TV101WUM_NL6=m
CONFIG_DRM_PANEL_FEIYANG_FY07024DI26A30D=m
# CONFIG_DRM_PANEL_DSI_CM is not set
CONFIG_DRM_PANEL_LVDS=m
-CONFIG_DRM_PANEL_HIMAX_HX83102=m
+# CONFIG_DRM_PANEL_HIMAX_HX83102 is not set
# CONFIG_DRM_PANEL_HIMAX_HX83112A is not set
# CONFIG_DRM_PANEL_HIMAX_HX8394 is not set
# CONFIG_DRM_PANEL_ILITEK_IL9322 is not set
@@ -5857,15 +5882,15 @@ CONFIG_DRM_PANEL_HIMAX_HX83102=m
# CONFIG_DRM_PANEL_ILITEK_ILI9805 is not set
# CONFIG_DRM_PANEL_ILITEK_ILI9806E is not set
# CONFIG_DRM_PANEL_ILITEK_ILI9881C is not set
-CONFIG_DRM_PANEL_ILITEK_ILI9882T=m
+# CONFIG_DRM_PANEL_ILITEK_ILI9882T is not set
# CONFIG_DRM_PANEL_INNOLUX_EJ030NA is not set
-CONFIG_DRM_PANEL_INNOLUX_P079ZCA=m
+# CONFIG_DRM_PANEL_INNOLUX_P079ZCA is not set
# CONFIG_DRM_PANEL_JADARD_JD9365DA_H3 is not set
# CONFIG_DRM_PANEL_JDI_LPM102A188A is not set
# CONFIG_DRM_PANEL_JDI_LT070ME05000 is not set
# CONFIG_DRM_PANEL_JDI_R63452 is not set
# CONFIG_DRM_PANEL_KHADAS_TS050 is not set
-CONFIG_DRM_PANEL_KINGDISPLAY_KD097D04=m
+# CONFIG_DRM_PANEL_KINGDISPLAY_KD097D04 is not set
# CONFIG_DRM_PANEL_LEADTEK_LTK050H3146W is not set
# CONFIG_DRM_PANEL_LEADTEK_LTK500HD1829 is not set
# CONFIG_DRM_PANEL_LINCOLNTECH_LCD197 is not set
@@ -5887,16 +5912,16 @@ CONFIG_DRM_PANEL_KINGDISPLAY_KD097D04=m
# CONFIG_DRM_PANEL_OLIMEX_LCD_OLINUXINO is not set
# CONFIG_DRM_PANEL_ORISETECH_OTA5601A is not set
# CONFIG_DRM_PANEL_ORISETECH_OTM8009A is not set
-# CONFIG_DRM_PANEL_OSD_OSD101T2587_53TS is not set
+CONFIG_DRM_PANEL_OSD_OSD101T2587_53TS=y
# CONFIG_DRM_PANEL_PANASONIC_VVX10F034N00 is not set
-CONFIG_DRM_PANEL_RASPBERRYPI_TOUCHSCREEN=y
-# CONFIG_DRM_PANEL_RAYDIUM_RM67191 is not set
+CONFIG_DRM_PANEL_RASPBERRYPI_TOUCHSCREEN=m
+CONFIG_DRM_PANEL_RAYDIUM_RM67191=m
# CONFIG_DRM_PANEL_RAYDIUM_RM68200 is not set
# CONFIG_DRM_PANEL_RAYDIUM_RM692E5 is not set
# CONFIG_DRM_PANEL_RAYDIUM_RM69380 is not set
# CONFIG_DRM_PANEL_RONBO_RB070D30 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6E88A0_AMS452EF01 is not set
-CONFIG_DRM_PANEL_SAMSUNG_ATNA33XC20=m
+# CONFIG_DRM_PANEL_SAMSUNG_ATNA33XC20 is not set
# CONFIG_DRM_PANEL_SAMSUNG_DB7430 is not set
# CONFIG_DRM_PANEL_SAMSUNG_LD9040 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6E3FA7 is not set
@@ -5915,7 +5940,7 @@ CONFIG_DRM_PANEL_SAMSUNG_ATNA33XC20=m
# CONFIG_DRM_PANEL_SHARP_LS060T1SX01 is not set
# CONFIG_DRM_PANEL_SITRONIX_ST7701 is not set
CONFIG_DRM_PANEL_SITRONIX_ST7703=m
-CONFIG_DRM_PANEL_SITRONIX_ST7789V=m
+# CONFIG_DRM_PANEL_SITRONIX_ST7789V is not set
# CONFIG_DRM_PANEL_SONY_ACX565AKM is not set
# CONFIG_DRM_PANEL_SONY_TD4353_JDI is not set
# CONFIG_DRM_PANEL_SONY_TULIP_TRULY_NT35521 is not set
@@ -5927,7 +5952,7 @@ CONFIG_DRM_PANEL_SIMPLE=m
# CONFIG_DRM_PANEL_TPO_TD028TTEC1 is not set
# CONFIG_DRM_PANEL_TPO_TD043MTEA1 is not set
# CONFIG_DRM_PANEL_TPO_TPG110 is not set
-# CONFIG_DRM_PANEL_TRULY_NT35597_WQXGA is not set
+CONFIG_DRM_PANEL_TRULY_NT35597_WQXGA=m
# CONFIG_DRM_PANEL_VISIONOX_R66451 is not set
# CONFIG_DRM_PANEL_VISIONOX_RM69299 is not set
# CONFIG_DRM_PANEL_VISIONOX_VTDR6130 is not set
@@ -5944,11 +5969,11 @@ CONFIG_DRM_PANEL_BRIDGE=y
# CONFIG_DRM_CHIPONE_ICN6211 is not set
# CONFIG_DRM_CHRONTEL_CH7033 is not set
CONFIG_DRM_DISPLAY_CONNECTOR=y
-CONFIG_DRM_ITE_IT6505=m
+# CONFIG_DRM_ITE_IT6505 is not set
# CONFIG_DRM_LONTIUM_LT8912B is not set
# CONFIG_DRM_LONTIUM_LT9211 is not set
-# CONFIG_DRM_LONTIUM_LT9611 is not set
-CONFIG_DRM_LONTIUM_LT9611UXC=m
+CONFIG_DRM_LONTIUM_LT9611=m
+# CONFIG_DRM_LONTIUM_LT9611UXC is not set
CONFIG_DRM_ITE_IT66121=y
CONFIG_DRM_LVDS_CODEC=y
# CONFIG_DRM_MEGACHIPS_STDPXXXX_GE_B850V3_FW is not set
@@ -5961,14 +5986,14 @@ CONFIG_DRM_NWL_MIPI_DSI=m
CONFIG_DRM_SII902X=y
# CONFIG_DRM_SII9234 is not set
CONFIG_DRM_SIMPLE_BRIDGE=m
-# CONFIG_DRM_THINE_THC63LVD1024 is not set
-# CONFIG_DRM_TOSHIBA_TC358762 is not set
+CONFIG_DRM_THINE_THC63LVD1024=m
+CONFIG_DRM_TOSHIBA_TC358762=m
# CONFIG_DRM_TOSHIBA_TC358764 is not set
-# CONFIG_DRM_TOSHIBA_TC358767 is not set
-# CONFIG_DRM_TOSHIBA_TC358768 is not set
+CONFIG_DRM_TOSHIBA_TC358767=m
+CONFIG_DRM_TOSHIBA_TC358768=m
# CONFIG_DRM_TOSHIBA_TC358775 is not set
# CONFIG_DRM_TI_DLPC3433 is not set
-# CONFIG_DRM_TI_TFP410 is not set
+CONFIG_DRM_TI_TFP410=y
# CONFIG_DRM_TI_SN65DSI83 is not set
CONFIG_DRM_TI_SN65DSI86=m
CONFIG_DRM_TI_TPD12S015=y
@@ -5989,9 +6014,9 @@ CONFIG_DRM_CDNS_MHDP8546_J721E=y
# CONFIG_DRM_ARCPGU is not set
# CONFIG_DRM_BOCHS is not set
# CONFIG_DRM_CIRRUS_QEMU is not set
-CONFIG_DRM_GM12U320=m
+# CONFIG_DRM_GM12U320 is not set
# CONFIG_DRM_PANEL_MIPI_DBI is not set
-CONFIG_DRM_SIMPLEDRM=y
+CONFIG_DRM_SIMPLEDRM=m
CONFIG_TINYDRM_HX8357D=m
CONFIG_TINYDRM_ILI9163=m
CONFIG_TINYDRM_ILI9225=m
@@ -6007,10 +6032,8 @@ CONFIG_TINYDRM_ST7735R=m
# CONFIG_DRM_PANTHOR is not set
CONFIG_DRM_TIDSS=y
# CONFIG_DRM_GUD is not set
-CONFIG_DRM_SSD130X=m
-CONFIG_DRM_SSD130X_I2C=m
-CONFIG_DRM_SSD130X_SPI=m
-CONFIG_DRM_POWERVR=m
+# CONFIG_DRM_SSD130X is not set
+# CONFIG_DRM_POWERVR is not set
# CONFIG_DRM_WERROR is not set
CONFIG_DRM_PANEL_ORIENTATION_QUIRKS=y
@@ -6052,7 +6075,8 @@ CONFIG_FB_EFI=y
# CONFIG_FB_VIRTUAL is not set
# CONFIG_FB_METRONOME is not set
# CONFIG_FB_MB862XX is not set
-CONFIG_FB_SSD1307=m
+CONFIG_FB_SIMPLE=m
+CONFIG_FB_SSD1307=y
# CONFIG_FB_SM712 is not set
CONFIG_FB_CORE=y
CONFIG_FB_NOTIFY=y
@@ -6073,7 +6097,7 @@ CONFIG_FB_IOMEM_FOPS=y
CONFIG_FB_IOMEM_HELPERS=y
CONFIG_FB_SYSMEM_HELPERS=y
CONFIG_FB_SYSMEM_HELPERS_DEFERRED=y
-CONFIG_FB_BACKLIGHT=m
+CONFIG_FB_BACKLIGHT=y
CONFIG_FB_MODE_HELPERS=y
CONFIG_FB_TILEBLITTING=y
# end of Frame buffer Devices
@@ -6091,7 +6115,7 @@ CONFIG_BACKLIGHT_PWM=y
# CONFIG_BACKLIGHT_ADP8860 is not set
# CONFIG_BACKLIGHT_ADP8870 is not set
# CONFIG_BACKLIGHT_LM3509 is not set
-CONFIG_BACKLIGHT_LM3630A=m
+# CONFIG_BACKLIGHT_LM3630A is not set
# CONFIG_BACKLIGHT_LM3639 is not set
CONFIG_BACKLIGHT_LP855X=m
# CONFIG_BACKLIGHT_MP3309C is not set
@@ -6138,7 +6162,6 @@ CONFIG_SND_DMAENGINE_PCM=m
CONFIG_SND_HWDEP=m
CONFIG_SND_SEQ_DEVICE=m
CONFIG_SND_RAWMIDI=m
-CONFIG_SND_COMPRESS_OFFLOAD=m
CONFIG_SND_JACK=y
CONFIG_SND_JACK_INPUT_DEV=y
CONFIG_SND_OSSEMUL=y
@@ -6175,14 +6198,78 @@ CONFIG_SND_MTPAV=m
CONFIG_SND_SERIAL_U16550=m
# CONFIG_SND_SERIAL_GENERIC is not set
CONFIG_SND_MPU401=m
-# CONFIG_SND_PCI is not set
+CONFIG_SND_PCI=y
+# CONFIG_SND_AD1889 is not set
+# CONFIG_SND_ALS300 is not set
+# CONFIG_SND_ALI5451 is not set
+# CONFIG_SND_ATIIXP is not set
+# CONFIG_SND_ATIIXP_MODEM is not set
+# CONFIG_SND_AU8810 is not set
+# CONFIG_SND_AU8820 is not set
+# CONFIG_SND_AU8830 is not set
+# CONFIG_SND_AW2 is not set
+# CONFIG_SND_AZT3328 is not set
+# CONFIG_SND_BT87X is not set
+# CONFIG_SND_CA0106 is not set
+# CONFIG_SND_CMIPCI is not set
+# CONFIG_SND_OXYGEN is not set
+# CONFIG_SND_CS4281 is not set
+# CONFIG_SND_CS46XX is not set
+# CONFIG_SND_CTXFI is not set
+# CONFIG_SND_DARLA20 is not set
+# CONFIG_SND_GINA20 is not set
+# CONFIG_SND_LAYLA20 is not set
+# CONFIG_SND_DARLA24 is not set
+# CONFIG_SND_GINA24 is not set
+# CONFIG_SND_LAYLA24 is not set
+# CONFIG_SND_MONA is not set
+# CONFIG_SND_MIA is not set
+# CONFIG_SND_ECHO3G is not set
+# CONFIG_SND_INDIGO is not set
+# CONFIG_SND_INDIGOIO is not set
+# CONFIG_SND_INDIGODJ is not set
+# CONFIG_SND_INDIGOIOX is not set
+# CONFIG_SND_INDIGODJX is not set
+# CONFIG_SND_EMU10K1 is not set
+# CONFIG_SND_EMU10K1X is not set
+# CONFIG_SND_ENS1370 is not set
+# CONFIG_SND_ENS1371 is not set
+# CONFIG_SND_ES1938 is not set
+# CONFIG_SND_ES1968 is not set
+# CONFIG_SND_FM801 is not set
+# CONFIG_SND_HDSP is not set
+# CONFIG_SND_HDSPM is not set
+# CONFIG_SND_ICE1712 is not set
+# CONFIG_SND_ICE1724 is not set
+# CONFIG_SND_INTEL8X0 is not set
+# CONFIG_SND_INTEL8X0M is not set
+# CONFIG_SND_KORG1212 is not set
+# CONFIG_SND_LOLA is not set
+# CONFIG_SND_LX6464ES is not set
+# CONFIG_SND_MAESTRO3 is not set
+# CONFIG_SND_MIXART is not set
+# CONFIG_SND_NM256 is not set
+# CONFIG_SND_PCXHR is not set
+# CONFIG_SND_RIPTIDE is not set
+# CONFIG_SND_RME32 is not set
+# CONFIG_SND_RME96 is not set
+# CONFIG_SND_RME9652 is not set
+# CONFIG_SND_SE6X is not set
+# CONFIG_SND_SONICVIBES is not set
+# CONFIG_SND_TRIDENT is not set
+# CONFIG_SND_VIA82XX is not set
+# CONFIG_SND_VIA82XX_MODEM is not set
+# CONFIG_SND_VIRTUOSO is not set
+# CONFIG_SND_VX222 is not set
+# CONFIG_SND_YMFPCI is not set
# HD-Audio
+# CONFIG_SND_HDA_INTEL is not set
# end of HD-Audio
-CONFIG_SND_HDA_PREALLOC_SIZE=2048
+CONFIG_SND_HDA_PREALLOC_SIZE=64
CONFIG_SND_SPI=y
CONFIG_SND_USB=y
CONFIG_SND_USB_AUDIO=m
@@ -6211,7 +6298,6 @@ CONFIG_SND_FIREWIRE=y
# CONFIG_SND_FIREFACE is not set
CONFIG_SND_SOC=m
CONFIG_SND_SOC_GENERIC_DMAENGINE_PCM=y
-CONFIG_SND_SOC_COMPRESS=y
# CONFIG_SND_SOC_ADI is not set
# CONFIG_SND_SOC_AMD_ACP is not set
# CONFIG_SND_AMD_ACP_CONFIG is not set
@@ -6276,7 +6362,6 @@ CONFIG_SND_SOC_I2C_AND_SPI=m
# CODEC drivers
-CONFIG_SND_SOC_WM_ADSP=m
# CONFIG_SND_SOC_AC97_CODEC is not set
# CONFIG_SND_SOC_ADAU1372_I2C is not set
# CONFIG_SND_SOC_ADAU1372_SPI is not set
@@ -6304,9 +6389,8 @@ CONFIG_SND_SOC_AK4554=m
# CONFIG_SND_SOC_AW87390 is not set
# CONFIG_SND_SOC_AW88399 is not set
# CONFIG_SND_SOC_BD28623 is not set
-CONFIG_SND_SOC_BT_SCO=m
+# CONFIG_SND_SOC_BT_SCO is not set
# CONFIG_SND_SOC_CHV3_CODEC is not set
-CONFIG_SND_SOC_CS_AMP_LIB=m
# CONFIG_SND_SOC_CS35L32 is not set
# CONFIG_SND_SOC_CS35L33 is not set
# CONFIG_SND_SOC_CS35L34 is not set
@@ -6316,12 +6400,11 @@ CONFIG_SND_SOC_CS_AMP_LIB=m
# CONFIG_SND_SOC_CS35L41_I2C is not set
# CONFIG_SND_SOC_CS35L45_SPI is not set
# CONFIG_SND_SOC_CS35L45_I2C is not set
-CONFIG_SND_SOC_CS35L56=m
-CONFIG_SND_SOC_CS35L56_SHARED=m
-CONFIG_SND_SOC_CS35L56_I2C=m
-CONFIG_SND_SOC_CS35L56_SPI=m
+# CONFIG_SND_SOC_CS35L56_I2C is not set
+# CONFIG_SND_SOC_CS35L56_SPI is not set
# CONFIG_SND_SOC_CS42L42 is not set
-# CONFIG_SND_SOC_CS42L51_I2C is not set
+CONFIG_SND_SOC_CS42L51=m
+CONFIG_SND_SOC_CS42L51_I2C=m
# CONFIG_SND_SOC_CS42L52 is not set
# CONFIG_SND_SOC_CS42L56 is not set
# CONFIG_SND_SOC_CS42L73 is not set
@@ -6346,32 +6429,32 @@ CONFIG_SND_SOC_HDMI_CODEC=m
# CONFIG_SND_SOC_ES7241 is not set
# CONFIG_SND_SOC_ES8311 is not set
CONFIG_SND_SOC_ES8316=m
-CONFIG_SND_SOC_ES8326=m
-# CONFIG_SND_SOC_ES8328_I2C is not set
-# CONFIG_SND_SOC_ES8328_SPI is not set
-CONFIG_SND_SOC_GTM601=m
+# CONFIG_SND_SOC_ES8326 is not set
+CONFIG_SND_SOC_ES8328=m
+CONFIG_SND_SOC_ES8328_I2C=m
+CONFIG_SND_SOC_ES8328_SPI=m
+# CONFIG_SND_SOC_GTM601 is not set
# CONFIG_SND_SOC_HDA is not set
# CONFIG_SND_SOC_ICS43432 is not set
# CONFIG_SND_SOC_IDT821034 is not set
# CONFIG_SND_SOC_MAX98088 is not set
-CONFIG_SND_SOC_MAX98090=m
+# CONFIG_SND_SOC_MAX98090 is not set
CONFIG_SND_SOC_MAX98357A=m
# CONFIG_SND_SOC_MAX98504 is not set
# CONFIG_SND_SOC_MAX9867 is not set
-CONFIG_SND_SOC_MAX98927=m
+# CONFIG_SND_SOC_MAX98927 is not set
# CONFIG_SND_SOC_MAX98520 is not set
# CONFIG_SND_SOC_MAX98373_I2C is not set
# CONFIG_SND_SOC_MAX98388 is not set
-CONFIG_SND_SOC_MAX98390=m
+# CONFIG_SND_SOC_MAX98390 is not set
# CONFIG_SND_SOC_MAX98396 is not set
# CONFIG_SND_SOC_MAX9860 is not set
-CONFIG_SND_SOC_MSM8916_WCD_DIGITAL=m
+# CONFIG_SND_SOC_MSM8916_WCD_DIGITAL is not set
# CONFIG_SND_SOC_PCM1681 is not set
# CONFIG_SND_SOC_PCM1789_I2C is not set
# CONFIG_SND_SOC_PCM179X_I2C is not set
# CONFIG_SND_SOC_PCM179X_SPI is not set
-CONFIG_SND_SOC_PCM186X=m
-CONFIG_SND_SOC_PCM186X_I2C=m
+# CONFIG_SND_SOC_PCM186X_I2C is not set
# CONFIG_SND_SOC_PCM186X_SPI is not set
# CONFIG_SND_SOC_PCM3060_I2C is not set
# CONFIG_SND_SOC_PCM3060_SPI is not set
@@ -6384,10 +6467,9 @@ CONFIG_SND_SOC_PCM512x_I2C=m
# CONFIG_SND_SOC_PCM512x_SPI is not set
# CONFIG_SND_SOC_PCM6240 is not set
# CONFIG_SND_SOC_PEB2466 is not set
-CONFIG_SND_SOC_RL6231=m
-CONFIG_SND_SOC_RT5616=m
+# CONFIG_SND_SOC_RT5616 is not set
# CONFIG_SND_SOC_RT5631 is not set
-CONFIG_SND_SOC_RT5640=m
+# CONFIG_SND_SOC_RT5640 is not set
# CONFIG_SND_SOC_RT5659 is not set
# CONFIG_SND_SOC_RT9120 is not set
# CONFIG_SND_SOC_RTQ9128 is not set
@@ -6408,15 +6490,13 @@ CONFIG_SND_SOC_SPDIF=m
# CONFIG_SND_SOC_STA32X is not set
# CONFIG_SND_SOC_STA350 is not set
# CONFIG_SND_SOC_STI_SAS is not set
-CONFIG_SND_SOC_TAC5X1X_I2C=m
-CONFIG_SND_SOC_TAS2552=m
-CONFIG_SND_SOC_TAS2562=m
+# CONFIG_SND_SOC_TAC5X1X_I2C is not set
+# CONFIG_SND_SOC_TAS2552 is not set
+# CONFIG_SND_SOC_TAS2562 is not set
# CONFIG_SND_SOC_TAS2764 is not set
# CONFIG_SND_SOC_TAS2770 is not set
# CONFIG_SND_SOC_TAS2780 is not set
-CONFIG_SND_SOC_TAS2781_COMLIB=m
-CONFIG_SND_SOC_TAS2781_FMWLIB=m
-CONFIG_SND_SOC_TAS2781_I2C=m
+# CONFIG_SND_SOC_TAS2781_I2C is not set
# CONFIG_SND_SOC_TAS5086 is not set
# CONFIG_SND_SOC_TAS571X is not set
# CONFIG_SND_SOC_TAS5720 is not set
@@ -6479,12 +6559,11 @@ CONFIG_SND_SOC_WM8960=m
# CONFIG_SND_SOC_NAU8821 is not set
# CONFIG_SND_SOC_NAU8822 is not set
# CONFIG_SND_SOC_NAU8824 is not set
-# CONFIG_SND_SOC_TPA6130A2 is not set
-CONFIG_SND_SOC_LPASS_MACRO_COMMON=m
-CONFIG_SND_SOC_LPASS_WSA_MACRO=m
-CONFIG_SND_SOC_LPASS_VA_MACRO=m
-CONFIG_SND_SOC_LPASS_RX_MACRO=m
-CONFIG_SND_SOC_LPASS_TX_MACRO=m
+CONFIG_SND_SOC_TPA6130A2=m
+# CONFIG_SND_SOC_LPASS_WSA_MACRO is not set
+# CONFIG_SND_SOC_LPASS_VA_MACRO is not set
+# CONFIG_SND_SOC_LPASS_RX_MACRO is not set
+# CONFIG_SND_SOC_LPASS_TX_MACRO is not set
# end of CODEC drivers
CONFIG_SND_SIMPLE_CARD_UTILS=m
@@ -6492,13 +6571,13 @@ CONFIG_SND_SIMPLE_CARD=m
CONFIG_SND_AUDIO_GRAPH_CARD=m
# CONFIG_SND_AUDIO_GRAPH_CARD2 is not set
# CONFIG_SND_TEST_COMPONENT is not set
-CONFIG_SND_VIRTIO=m
+# CONFIG_SND_VIRTIO is not set
CONFIG_HID_SUPPORT=y
-CONFIG_HID=y
+CONFIG_HID=m
CONFIG_HID_BATTERY_STRENGTH=y
CONFIG_HIDRAW=y
-CONFIG_UHID=y
-CONFIG_HID_GENERIC=y
+CONFIG_UHID=m
+CONFIG_HID_GENERIC=m
# Special HID drivers
@@ -6593,14 +6672,14 @@ CONFIG_HID_PLANTRONICS=m
CONFIG_HID_PLAYSTATION=m
CONFIG_PLAYSTATION_FF=y
# CONFIG_HID_PXRC is not set
-# CONFIG_HID_RAZER is not set
+CONFIG_HID_RAZER=m
CONFIG_HID_PRIMAX=m
CONFIG_HID_RETRODE=m
CONFIG_HID_ROCCAT=m
CONFIG_HID_SAITEK=m
CONFIG_HID_SAMSUNG=m
CONFIG_HID_SEMITEK=m
-# CONFIG_HID_SIGMAMICRO is not set
+CONFIG_HID_SIGMAMICRO=m
CONFIG_HID_SONY=m
CONFIG_SONY_FF=y
CONFIG_HID_SPEEDLINK=m
@@ -6621,7 +6700,7 @@ CONFIG_HID_THRUSTMASTER=m
CONFIG_THRUSTMASTER_FF=y
CONFIG_HID_UDRAW_PS3=m
CONFIG_HID_U2FZERO=m
-# CONFIG_HID_UNIVERSAL_PIDFF is not set
+CONFIG_HID_UNIVERSAL_PIDFF=m
CONFIG_HID_WACOM=m
CONFIG_HID_WIIMOTE=m
# CONFIG_HID_WINWING is not set
@@ -6645,21 +6724,27 @@ CONFIG_HID_MCP2221=m
# USB HID support
-CONFIG_USB_HID=y
+CONFIG_USB_HID=m
CONFIG_HID_PID=y
CONFIG_USB_HIDDEV=y
+# USB HID Boot Protocol drivers
+# CONFIG_USB_KBD is not set
+# CONFIG_USB_MOUSE is not set
+# end of USB HID Boot Protocol drivers
# end of USB HID support
-CONFIG_I2C_HID=y
-CONFIG_I2C_HID_OF=m
-CONFIG_I2C_HID_OF_ELAN=m
-CONFIG_I2C_HID_OF_GOODIX=m
-CONFIG_I2C_HID_CORE=m
+CONFIG_I2C_HID=m
+# CONFIG_I2C_HID_OF is not set
+# CONFIG_I2C_HID_OF_ELAN is not set
+# CONFIG_I2C_HID_OF_GOODIX is not set
CONFIG_USB_OHCI_LITTLE_ENDIAN=y
CONFIG_USB_SUPPORT=y
CONFIG_USB_COMMON=y
CONFIG_USB_LED_TRIG=y
-CONFIG_USB_ULPI_BUS=m
+# CONFIG_USB_ULPI_BUS is not set
CONFIG_USB_CONN_GPIO=m
CONFIG_USB_ARCH_HAS_HCD=y
CONFIG_USB=y
@@ -6689,7 +6774,7 @@ CONFIG_USB_MON=m
CONFIG_USB_XHCI_HCD=y
# CONFIG_USB_XHCI_DBGCAP is not set
CONFIG_USB_XHCI_PCI=y
-CONFIG_USB_XHCI_PCI_RENESAS=m
+# CONFIG_USB_XHCI_PCI_RENESAS is not set
CONFIG_USB_XHCI_PLATFORM=y
CONFIG_USB_EHCI_HCD=y
CONFIG_USB_EHCI_ROOT_HUB_TT=y
@@ -6700,12 +6785,15 @@ CONFIG_USB_EHCI_HCD_PLATFORM=m
# CONFIG_USB_OXU210HP_HCD is not set
# CONFIG_USB_ISP116X_HCD is not set
# CONFIG_USB_MAX3421_HCD is not set
-CONFIG_USB_OHCI_HCD=y
+CONFIG_USB_OHCI_HCD=m
CONFIG_USB_OHCI_HCD_PCI=m
+# CONFIG_USB_OHCI_HCD_SSB is not set
CONFIG_USB_OHCI_HCD_PLATFORM=m
# CONFIG_USB_UHCI_HCD is not set
# CONFIG_USB_SL811_HCD is not set
# CONFIG_USB_R8A66597_HCD is not set
+# CONFIG_USB_HCD_BCMA is not set
+# CONFIG_USB_HCD_SSB is not set
# CONFIG_USB_HCD_TEST_MODE is not set
@@ -6879,7 +6967,7 @@ CONFIG_USB_HSIC_USB3503=m
# CONFIG_USB_HSIC_USB4604 is not set
# CONFIG_USB_LINK_LAYER_TEST is not set
CONFIG_USB_CHAOSKEY=m
-CONFIG_USB_ONBOARD_DEV=y
+CONFIG_USB_ONBOARD_DEV=m
# CONFIG_USB_ONBOARD_DEV_USB5744 is not set
# CONFIG_USB_ATM is not set
@@ -6887,7 +6975,7 @@ CONFIG_USB_ONBOARD_DEV=y
# USB Physical Layer drivers
CONFIG_USB_PHY=y
-CONFIG_NOP_USB_XCEIV=y
+CONFIG_NOP_USB_XCEIV=m
# CONFIG_USB_GPIO_VBUS is not set
# CONFIG_USB_ISP1301 is not set
# CONFIG_USB_ULPI is not set
@@ -6898,7 +6986,7 @@ CONFIG_USB_GADGET=y
# CONFIG_USB_GADGET_DEBUG_FILES is not set
# CONFIG_USB_GADGET_DEBUG_FS is not set
CONFIG_USB_GADGET_VBUS_DRAW=500
-CONFIG_USB_GADGET_STORAGE_NUM_BUFFERS=2
+CONFIG_USB_GADGET_STORAGE_NUM_BUFFERS=32
# CONFIG_U_SERIAL_CONSOLE is not set
@@ -6914,7 +7002,7 @@ CONFIG_USB_GADGET_STORAGE_NUM_BUFFERS=2
# CONFIG_USB_BDC_UDC is not set
# CONFIG_USB_AMD5536UDC is not set
# CONFIG_USB_NET2272 is not set
-CONFIG_USB_NET2280=m
+# CONFIG_USB_NET2280 is not set
# CONFIG_USB_GOKU is not set
# CONFIG_USB_EG20T is not set
# CONFIG_USB_GADGET_XILINX is not set
@@ -7001,10 +7089,10 @@ CONFIG_TYPEC_TCPM=m
# CONFIG_TYPEC_TCPCI is not set
CONFIG_TYPEC_FUSB302=m
# CONFIG_TYPEC_UCSI is not set
-CONFIG_TYPEC_TPS6598X=y
+CONFIG_TYPEC_TPS6598X=m
# CONFIG_TYPEC_ANX7411 is not set
# CONFIG_TYPEC_RT1719 is not set
-# CONFIG_TYPEC_HD3SS3220 is not set
+CONFIG_TYPEC_HD3SS3220=y
# CONFIG_TYPEC_STUSB160X is not set
# CONFIG_TYPEC_WUSB3801 is not set
@@ -7012,7 +7100,7 @@ CONFIG_TYPEC_TPS6598X=y
# USB Type-C Multiplexer/DeMultiplexer Switch support
# CONFIG_TYPEC_MUX_FSA4480 is not set
-CONFIG_TYPEC_MUX_GPIO_SBU=m
+# CONFIG_TYPEC_MUX_GPIO_SBU is not set
# CONFIG_TYPEC_MUX_PI3USB30532 is not set
# CONFIG_TYPEC_MUX_IT5205 is not set
# CONFIG_TYPEC_MUX_NB7VPQ904M is not set
@@ -7023,8 +7111,7 @@ CONFIG_TYPEC_MUX_GPIO_SBU=m
# USB Type-C Alternate Mode drivers
-CONFIG_TYPEC_DP_ALTMODE=m
-CONFIG_TYPEC_NVIDIA_ALTMODE=m
+# CONFIG_TYPEC_DP_ALTMODE is not set
# end of USB Type-C Alternate Mode drivers
CONFIG_USB_ROLE_SWITCH=y
@@ -7060,25 +7147,26 @@ CONFIG_MMC_SPI=y
CONFIG_MMC_VUB300=m
CONFIG_MMC_USHC=m
# CONFIG_MMC_USDHI6ROL0 is not set
+# CONFIG_MMC_REALTEK_PCI is not set
+# CONFIG_MMC_REALTEK_USB is not set
CONFIG_MMC_CQHCI=y
CONFIG_MMC_HSQ=y
# CONFIG_MMC_TOSHIBA_PCI is not set
# CONFIG_MMC_MTK is not set
# CONFIG_MMC_SDHCI_XENON is not set
CONFIG_MMC_SDHCI_AM654=y
-CONFIG_SCSI_UFSHCD=m
-# CONFIG_SCSI_UFS_BSG is not set
+CONFIG_SCSI_UFSHCD=y
+CONFIG_SCSI_UFS_BSG=y
# CONFIG_SCSI_UFS_HWMON is not set
-CONFIG_SCSI_UFSHCD_PCI=m
-# CONFIG_SCSI_UFS_DWC_TC_PCI is not set
-CONFIG_SCSI_UFSHCD_PLATFORM=m
-# CONFIG_SCSI_UFS_CDNS_PLATFORM is not set
+# CONFIG_SCSI_UFSHCD_PCI is not set
+CONFIG_SCSI_UFSHCD_PLATFORM=y
+CONFIG_SCSI_UFS_CDNS_PLATFORM=y
# CONFIG_SCSI_UFS_DWC_TC_PLATFORM is not set
-# CONFIG_SCSI_UFS_TI_J721E is not set
+CONFIG_SCSI_UFS_TI_J721E=y
# CONFIG_MEMSTICK is not set
CONFIG_NEW_LEDS=y
CONFIG_LEDS_CLASS=y
-CONFIG_LEDS_CLASS_FLASH=m
+# CONFIG_LEDS_CLASS_FLASH is not set
CONFIG_LEDS_CLASS_MULTICOLOR=m
CONFIG_LEDS_BRIGHTNESS_HW_CHANGED=y
@@ -7102,11 +7190,16 @@ CONFIG_LEDS_GPIO=y
CONFIG_LEDS_LP3944=m
# CONFIG_LEDS_LP3952 is not set
# CONFIG_LEDS_LP50XX is not set
-# CONFIG_LEDS_LP55XX_COMMON is not set
+CONFIG_LEDS_LP55XX_COMMON=m
+# CONFIG_LEDS_LP5521 is not set
+CONFIG_LEDS_LP5523=m
+# CONFIG_LEDS_LP5562 is not set
+# CONFIG_LEDS_LP5569 is not set
+# CONFIG_LEDS_LP8501 is not set
# CONFIG_LEDS_LP8860 is not set
CONFIG_LEDS_PCA955X=m
# CONFIG_LEDS_PCA955X_GPIO is not set
-# CONFIG_LEDS_PCA963X is not set
+CONFIG_LEDS_PCA963X=m
# CONFIG_LEDS_PCA995X is not set
CONFIG_LEDS_DAC124S085=m
CONFIG_LEDS_PWM=y
@@ -7114,8 +7207,8 @@ CONFIG_LEDS_REGULATOR=m
# CONFIG_LEDS_BD2606MVV is not set
CONFIG_LEDS_BD2802=m
CONFIG_LEDS_LT3593=m
-# CONFIG_LEDS_TCA6507 is not set
-# CONFIG_LEDS_TLC591XX is not set
+CONFIG_LEDS_TCA6507=m
+CONFIG_LEDS_TLC591XX=y
# CONFIG_LEDS_LM355x is not set
# CONFIG_LEDS_IS31FL319X is not set
# CONFIG_LEDS_IS31FL32XX is not set
@@ -7133,14 +7226,6 @@ CONFIG_LEDS_SYSCON=y
# Flash and Torch LED drivers
-# CONFIG_LEDS_AAT1290 is not set
-# CONFIG_LEDS_AS3645A is not set
-# CONFIG_LEDS_KTD2692 is not set
-# CONFIG_LEDS_LM3601X is not set
-# CONFIG_LEDS_RT4505 is not set
-# CONFIG_LEDS_RT8515 is not set
-# CONFIG_LEDS_SGM3140 is not set
-# CONFIG_LEDS_SY7802 is not set
# RGB LED drivers
@@ -7203,74 +7288,75 @@ CONFIG_RTC_INTF_DEV=y
# I2C RTC drivers
-CONFIG_RTC_DRV_ABB5ZES3=m
-CONFIG_RTC_DRV_ABEOZ9=m
-CONFIG_RTC_DRV_ABX80X=m
-CONFIG_RTC_DRV_DS1307=m
+CONFIG_RTC_DRV_ABB5ZES3=y
+CONFIG_RTC_DRV_ABEOZ9=y
+CONFIG_RTC_DRV_ABX80X=y
+CONFIG_RTC_DRV_DS1307=y
# CONFIG_RTC_DRV_DS1307_CENTURY is not set
-CONFIG_RTC_DRV_DS1374=m
+CONFIG_RTC_DRV_DS1374=y
CONFIG_RTC_DRV_DS1374_WDT=y
-CONFIG_RTC_DRV_DS1672=m
-CONFIG_RTC_DRV_HYM8563=m
-CONFIG_RTC_DRV_MAX6900=m
-CONFIG_RTC_DRV_MAX31335=m
+CONFIG_RTC_DRV_DS1672=y
+CONFIG_RTC_DRV_HYM8563=y
+CONFIG_RTC_DRV_MAX6900=y
+# CONFIG_RTC_DRV_MAX31335 is not set
CONFIG_RTC_DRV_MAX77686=y
-CONFIG_RTC_DRV_NCT3018Y=m
-CONFIG_RTC_DRV_RS5C372=m
-CONFIG_RTC_DRV_ISL1208=m
-CONFIG_RTC_DRV_ISL12022=m
-CONFIG_RTC_DRV_ISL12026=m
-CONFIG_RTC_DRV_X1205=m
-CONFIG_RTC_DRV_PCF8523=m
-CONFIG_RTC_DRV_PCF85063=m
-CONFIG_RTC_DRV_PCF85363=m
-CONFIG_RTC_DRV_PCF8563=m
-CONFIG_RTC_DRV_PCF8583=m
-CONFIG_RTC_DRV_M41T80=m
+# CONFIG_RTC_DRV_NCT3018Y is not set
+CONFIG_RTC_DRV_RS5C372=y
+CONFIG_RTC_DRV_ISL1208=y
+CONFIG_RTC_DRV_ISL12022=y
+CONFIG_RTC_DRV_ISL12026=y
+CONFIG_RTC_DRV_X1205=y
+CONFIG_RTC_DRV_PCF8523=y
+CONFIG_RTC_DRV_PCF85063=y
+CONFIG_RTC_DRV_PCF85363=y
+CONFIG_RTC_DRV_PCF8563=y
+CONFIG_RTC_DRV_PCF8583=y
+CONFIG_RTC_DRV_M41T80=y
CONFIG_RTC_DRV_M41T80_WDT=y
-CONFIG_RTC_DRV_BQ32K=m
+CONFIG_RTC_DRV_BQ32K=y
+CONFIG_RTC_DRV_PALMAS=y
CONFIG_RTC_DRV_TPS6594=y
-CONFIG_RTC_DRV_S35390A=m
-CONFIG_RTC_DRV_FM3130=m
-CONFIG_RTC_DRV_RX8010=m
-CONFIG_RTC_DRV_RX8111=m
-CONFIG_RTC_DRV_RX8581=m
-CONFIG_RTC_DRV_RX8025=m
-CONFIG_RTC_DRV_EM3027=m
+CONFIG_RTC_DRV_S35390A=y
+CONFIG_RTC_DRV_FM3130=y
+CONFIG_RTC_DRV_RX8010=y
+# CONFIG_RTC_DRV_RX8111 is not set
+CONFIG_RTC_DRV_RX8581=y
+CONFIG_RTC_DRV_RX8025=y
+CONFIG_RTC_DRV_EM3027=y
CONFIG_RTC_DRV_RV3028=m
-CONFIG_RTC_DRV_RV3032=m
-CONFIG_RTC_DRV_RV8803=m
-CONFIG_RTC_DRV_SD2405AL=m
-CONFIG_RTC_DRV_SD3078=m
+# CONFIG_RTC_DRV_RV3032 is not set
+CONFIG_RTC_DRV_RV8803=y
+# CONFIG_RTC_DRV_SD2405AL is not set
+# CONFIG_RTC_DRV_SD3078 is not set
# SPI RTC drivers
-CONFIG_RTC_DRV_M41T93=m
-CONFIG_RTC_DRV_M41T94=m
-CONFIG_RTC_DRV_DS1302=m
-CONFIG_RTC_DRV_DS1305=m
-CONFIG_RTC_DRV_DS1343=m
-CONFIG_RTC_DRV_DS1347=m
-CONFIG_RTC_DRV_DS1390=m
-CONFIG_RTC_DRV_MAX6916=m
-CONFIG_RTC_DRV_R9701=m
-CONFIG_RTC_DRV_RX4581=m
-CONFIG_RTC_DRV_RS5C348=m
-CONFIG_RTC_DRV_MAX6902=m
-CONFIG_RTC_DRV_PCF2123=m
-CONFIG_RTC_DRV_MCP795=m
+CONFIG_RTC_DRV_M41T93=y
+CONFIG_RTC_DRV_M41T94=y
+CONFIG_RTC_DRV_DS1302=y
+CONFIG_RTC_DRV_DS1305=y
+CONFIG_RTC_DRV_DS1343=y
+CONFIG_RTC_DRV_DS1347=y
+CONFIG_RTC_DRV_DS1390=y
+CONFIG_RTC_DRV_MAX6916=y
+CONFIG_RTC_DRV_R9701=y
+CONFIG_RTC_DRV_RX4581=y
+CONFIG_RTC_DRV_RS5C348=y
+CONFIG_RTC_DRV_MAX6902=y
+CONFIG_RTC_DRV_PCF2123=y
+CONFIG_RTC_DRV_MCP795=y
CONFIG_RTC_I2C_AND_SPI=y
# SPI and I2C RTC drivers
-CONFIG_RTC_DRV_DS3232=m
+CONFIG_RTC_DRV_DS3232=y
CONFIG_RTC_DRV_DS3232_HWMON=y
-CONFIG_RTC_DRV_PCF2127=m
-CONFIG_RTC_DRV_RV3029C2=m
+CONFIG_RTC_DRV_PCF2127=y
+CONFIG_RTC_DRV_RV3029C2=y
CONFIG_RTC_DRV_RV3029_HWMON=y
-CONFIG_RTC_DRV_RX6110=m
+CONFIG_RTC_DRV_RX6110=y
# Platform RTC drivers
@@ -7293,7 +7379,7 @@ CONFIG_RTC_DRV_M48T35=m
CONFIG_RTC_DRV_M48T59=m
CONFIG_RTC_DRV_MSM6242=m
CONFIG_RTC_DRV_RP5C01=m
-CONFIG_RTC_DRV_OPTEE=m
+# CONFIG_RTC_DRV_OPTEE is not set
# CONFIG_RTC_DRV_ZYNQMP is not set
@@ -7309,7 +7395,7 @@ CONFIG_RTC_DRV_TI_K3=y
# HID Sensor RTC drivers
-# CONFIG_RTC_DRV_HID_SENSOR_TIME is not set
+CONFIG_RTC_DRV_HID_SENSOR_TIME=m
# CONFIG_RTC_DRV_GOLDFISH is not set
CONFIG_DMADEVICES=y
# CONFIG_DMADEVICES_DEBUG is not set
@@ -7368,16 +7454,32 @@ CONFIG_DMABUF_HEAPS_CMA=y
CONFIG_DMABUF_HEAPS_CARVEOUT=y
# end of DMABUF options
-CONFIG_UIO=m
-CONFIG_UIO_CIF=m
-CONFIG_UIO_PDRV_GENIRQ=m
-CONFIG_UIO_DMEM_GENIRQ=m
-# CONFIG_UIO_AEC is not set
-# CONFIG_UIO_SERCOS3 is not set
-# CONFIG_UIO_PCI_GENERIC is not set
-# CONFIG_UIO_NETX is not set
-# CONFIG_UIO_MF624 is not set
-# CONFIG_VFIO is not set
+# CONFIG_UIO is not set
+CONFIG_VFIO=y
+CONFIG_VFIO_GROUP=y
+CONFIG_VFIO_CONTAINER=y
+CONFIG_VFIO_IOMMU_TYPE1=y
+# CONFIG_VFIO_NOIOMMU is not set
+CONFIG_VFIO_VIRQFD=y
+# CONFIG_VFIO_DEBUGFS is not set
+# VFIO support for PCI devices
+CONFIG_VFIO_PCI_CORE=y
+CONFIG_VFIO_PCI_MMAP=y
+CONFIG_VFIO_PCI_INTX=y
+CONFIG_VFIO_PCI=y
+# CONFIG_NVGRACE_GPU_VFIO_PCI is not set
+# end of VFIO support for PCI devices
+# VFIO support for platform devices
+# CONFIG_VFIO_PLATFORM is not set
+# CONFIG_VFIO_AMBA is not set
+# end of VFIO support for platform devices
CONFIG_IRQ_BYPASS_MANAGER=y
CONFIG_VIRT_DRIVERS=y
CONFIG_VMGENID=y
@@ -7390,7 +7492,6 @@ CONFIG_VIRTIO_PCI_LIB_LEGACY=y
CONFIG_VIRTIO_MENU=y
CONFIG_VIRTIO_PCI=y
CONFIG_VIRTIO_PCI_LEGACY=y
-CONFIG_VIRTIO_PMEM=m
CONFIG_VIRTIO_BALLOON=m
CONFIG_VIRTIO_INPUT=m
CONFIG_VIRTIO_MMIO=m
@@ -7417,7 +7518,11 @@ CONFIG_GREYBUS_BEAGLEPLAY=m
CONFIG_GREYBUS_ES2=m
# CONFIG_COMEDI is not set
CONFIG_STAGING=y
-# CONFIG_RTLLIB is not set
+CONFIG_RTLLIB=m
+CONFIG_RTLLIB_CRYPTO_CCMP=m
+CONFIG_RTLLIB_CRYPTO_TKIP=m
+CONFIG_RTLLIB_CRYPTO_WEP=m
+CONFIG_RTL8192E=m
CONFIG_RTL8723BS=m
CONFIG_R8712U=m
# CONFIG_RTS5208 is not set
@@ -7465,9 +7570,7 @@ CONFIG_AD5933=m
# CONFIG_FB_SM750 is not set
CONFIG_STAGING_MEDIA=y
-CONFIG_DVB_AV7110=m
-CONFIG_DVB_AV7110_OSD=y
-CONFIG_DVB_SP8870=m
+# CONFIG_DVB_AV7110 is not set
# CONFIG_VIDEO_MAX96712 is not set
@@ -7512,7 +7615,6 @@ CONFIG_GREYBUS_AUDIO=m
CONFIG_GREYBUS_BOOTROM=m
CONFIG_GREYBUS_FIRMWARE=m
CONFIG_GREYBUS_HID=m
-CONFIG_GREYBUS_LIGHT=m
CONFIG_GREYBUS_LOG=m
CONFIG_GREYBUS_LOOPBACK=m
CONFIG_GREYBUS_POWER=m
@@ -7565,15 +7667,17 @@ CONFIG_COMMON_CLK=y
# CONFIG_COMMON_CLK_SI570 is not set
# CONFIG_COMMON_CLK_CDCE706 is not set
# CONFIG_COMMON_CLK_CDCE925 is not set
-# CONFIG_COMMON_CLK_CS2000_CP is not set
+CONFIG_COMMON_CLK_CS2000_CP=y
# CONFIG_COMMON_CLK_AXI_CLKGEN is not set
# CONFIG_COMMON_CLK_XGENE is not set
-CONFIG_COMMON_CLK_PWM=m
+# CONFIG_COMMON_CLK_PALMAS is not set
+CONFIG_COMMON_CLK_PWM=y
# CONFIG_COMMON_CLK_RS9_PCIE is not set
# CONFIG_COMMON_CLK_SI521XX is not set
# CONFIG_COMMON_CLK_VC3 is not set
-# CONFIG_COMMON_CLK_VC5 is not set
+CONFIG_COMMON_CLK_VC5=y
# CONFIG_COMMON_CLK_VC7 is not set
+CONFIG_COMMON_CLK_BD718XX=m
# CONFIG_COMMON_CLK_FIXED_MMIO is not set
CONFIG_TI_SCI_CLK=y
# CONFIG_TI_SCI_CLK_PROBE_FROM_FW is not set
@@ -7599,12 +7703,12 @@ CONFIG_ARM64_ERRATUM_858921=y
# end of Clock Source drivers
CONFIG_MAILBOX=y
-CONFIG_ARM_MHU=m
+CONFIG_ARM_MHU=y
# CONFIG_ARM_MHU_V2 is not set
# CONFIG_ARM_MHU_V3 is not set
-CONFIG_PLATFORM_MHU=m
+CONFIG_PLATFORM_MHU=y
# CONFIG_PL320_MBOX is not set
-CONFIG_OMAP2PLUS_MBOX=y
+CONFIG_OMAP2PLUS_MBOX=m
# CONFIG_ALTERA_MBOX is not set
CONFIG_TI_MESSAGE_MANAGER=y
# CONFIG_MAILBOX_TEST is not set
@@ -7618,8 +7722,7 @@ CONFIG_IOMMU_SUPPORT=y
CONFIG_IOMMU_IO_PGTABLE=y
CONFIG_IOMMU_IO_PGTABLE_LPAE=y
# CONFIG_IOMMU_IO_PGTABLE_LPAE_SELFTEST is not set
-CONFIG_IOMMU_IO_PGTABLE_ARMV7S=y
-# CONFIG_IOMMU_IO_PGTABLE_ARMV7S_SELFTEST is not set
+# CONFIG_IOMMU_IO_PGTABLE_ARMV7S is not set
# CONFIG_IOMMU_IO_PGTABLE_DART is not set
# end of Generic IOMMU Pagetable Support
@@ -7757,10 +7860,10 @@ CONFIG_PM_DEVFREQ=y
# DEVFREQ Governors
CONFIG_DEVFREQ_GOV_SIMPLE_ONDEMAND=y
-# CONFIG_DEVFREQ_GOV_PERFORMANCE is not set
-# CONFIG_DEVFREQ_GOV_POWERSAVE is not set
-CONFIG_DEVFREQ_GOV_USERSPACE=m
-CONFIG_DEVFREQ_GOV_PASSIVE=m
+CONFIG_DEVFREQ_GOV_PERFORMANCE=y
+CONFIG_DEVFREQ_GOV_POWERSAVE=y
+CONFIG_DEVFREQ_GOV_USERSPACE=y
+CONFIG_DEVFREQ_GOV_PASSIVE=y
# DEVFREQ Drivers
@@ -7776,6 +7879,7 @@ CONFIG_EXTCON=y
CONFIG_EXTCON_GPIO=y
# CONFIG_EXTCON_LC824206XA is not set
# CONFIG_EXTCON_MAX3355 is not set
+CONFIG_EXTCON_PALMAS=m
CONFIG_EXTCON_PTN5150=m
# CONFIG_EXTCON_RT8973A is not set
# CONFIG_EXTCON_SM5502 is not set
@@ -7783,15 +7887,16 @@ CONFIG_EXTCON_USB_GPIO=y
# CONFIG_EXTCON_USBC_TUSB320 is not set
CONFIG_MEMORY=y
# CONFIG_ARM_PL172_MPMC is not set
-# CONFIG_OMAP_GPMC is not set
-CONFIG_IIO=m
+CONFIG_OMAP_GPMC=y
+# CONFIG_OMAP_GPMC_DEBUG is not set
+CONFIG_IIO=y
CONFIG_IIO_BUFFER=y
CONFIG_IIO_BUFFER_CB=m
CONFIG_IIO_BUFFER_DMA=m
CONFIG_IIO_BUFFER_DMAENGINE=m
CONFIG_IIO_BUFFER_HW_CONSUMER=m
-CONFIG_IIO_KFIFO_BUF=m
-CONFIG_IIO_TRIGGERED_BUFFER=m
+CONFIG_IIO_KFIFO_BUF=y
+CONFIG_IIO_TRIGGERED_BUFFER=y
CONFIG_IIO_CONFIGFS=m
CONFIG_IIO_GTS_HELPER=m
CONFIG_IIO_TRIGGER=y
@@ -7881,16 +7986,16 @@ CONFIG_AD4130=m
CONFIG_AD4695=m
CONFIG_AD7091R=m
CONFIG_AD7091R5=m
-CONFIG_AD7091R8=m
+# CONFIG_AD7091R8 is not set
CONFIG_AD7124=m
-CONFIG_AD7173=m
+# CONFIG_AD7173 is not set
CONFIG_AD7192=m
CONFIG_AD7266=m
CONFIG_AD7280=m
CONFIG_AD7291=m
CONFIG_AD7292=m
CONFIG_AD7298=m
-CONFIG_AD7380=m
+# CONFIG_AD7380 is not set
CONFIG_AD7476=m
CONFIG_AD7606=m
CONFIG_AD7606_IFACE_PARALLEL=m
@@ -7902,16 +8007,18 @@ CONFIG_AD7791=m
CONFIG_AD7793=m
CONFIG_AD7887=m
CONFIG_AD7923=m
-CONFIG_AD7944=m
+# CONFIG_AD7944 is not set
CONFIG_AD7949=m
CONFIG_AD799X=m
CONFIG_AD9467=m
+CONFIG_AXP20X_ADC=m
+CONFIG_AXP288_ADC=m
CONFIG_CC10001_ADC=m
CONFIG_ENVELOPE_DETECTOR=m
CONFIG_HI8435=m
CONFIG_HX711=m
CONFIG_INA2XX_ADC=m
-CONFIG_LTC2309=m
+# CONFIG_LTC2309 is not set
CONFIG_LTC2471=m
CONFIG_LTC2485=m
CONFIG_LTC2496=m
@@ -7923,15 +8030,16 @@ CONFIG_MAX11205=m
CONFIG_MAX11410=m
CONFIG_MAX1241=m
CONFIG_MAX1363=m
-CONFIG_MAX34408=m
+# CONFIG_MAX34408 is not set
CONFIG_MAX9611=m
CONFIG_MCP320X=m
CONFIG_MCP3422=m
-CONFIG_MCP3564=m
+# CONFIG_MCP3564 is not set
CONFIG_MCP3911=m
CONFIG_NAU7802=m
CONFIG_PAC1921=m
-CONFIG_PAC1934=m
+# CONFIG_PAC1934 is not set
+CONFIG_PALMAS_GPADC=m
CONFIG_RICHTEK_RTQ6056=m
CONFIG_SD_ADC_MODULATOR=m
CONFIG_TI_ADC081C=m
@@ -7942,10 +8050,10 @@ CONFIG_TI_ADC108S102=m
CONFIG_TI_ADC128S052=m
CONFIG_TI_ADC161S626=m
CONFIG_TI_ADS1015=m
-CONFIG_TI_ADS1119=m
+# CONFIG_TI_ADS1119 is not set
CONFIG_TI_ADS7924=m
CONFIG_TI_ADS1100=m
-CONFIG_TI_ADS1298=m
+# CONFIG_TI_ADS1298 is not set
CONFIG_TI_ADS7950=m
CONFIG_TI_ADS8344=m
CONFIG_TI_ADS8688=m
@@ -7990,16 +8098,14 @@ CONFIG_AD7746=m
# Chemical Sensors
-CONFIG_AOSONG_AGS02MA=m
+# CONFIG_AOSONG_AGS02MA is not set
CONFIG_ATLAS_PH_SENSOR=m
CONFIG_ATLAS_EZO_SENSOR=m
CONFIG_BME680=m
CONFIG_BME680_I2C=m
CONFIG_BME680_SPI=m
CONFIG_CCS811=m
-CONFIG_ENS160=m
-CONFIG_ENS160_I2C=m
-CONFIG_ENS160_SPI=m
+# CONFIG_ENS160 is not set
CONFIG_IAQCORE=m
CONFIG_PMS7003=m
CONFIG_SCD30_CORE=m
@@ -8056,7 +8162,7 @@ CONFIG_AD5592R=m
CONFIG_AD5593R=m
CONFIG_AD5504=m
CONFIG_AD5624R_SPI=m
-CONFIG_AD9739A=m
+# CONFIG_AD9739A is not set
CONFIG_LTC2688=m
CONFIG_AD5686=m
CONFIG_AD5686_SPI=m
@@ -8082,7 +8188,7 @@ CONFIG_MAX5522=m
CONFIG_MAX5821=m
CONFIG_MCP4725=m
CONFIG_MCP4728=m
-CONFIG_MCP4821=m
+# CONFIG_MCP4821 is not set
CONFIG_MCP4922=m
CONFIG_TI_DAC082S085=m
CONFIG_TI_DAC5571=m
@@ -8119,7 +8225,7 @@ CONFIG_AD9523=m
CONFIG_ADF4350=m
CONFIG_ADF4371=m
CONFIG_ADF4377=m
-CONFIG_ADMFM2000=m
+# CONFIG_ADMFM2000 is not set
CONFIG_ADMV1013=m
CONFIG_ADMV1014=m
CONFIG_ADMV4420=m
@@ -8173,7 +8279,7 @@ CONFIG_DHT11=m
CONFIG_ENS210=m
CONFIG_HDC100X=m
CONFIG_HDC2010=m
-CONFIG_HDC3020=m
+# CONFIG_HDC3020 is not set
CONFIG_HID_SENSOR_HUMIDITY=m
CONFIG_HTS221=m
CONFIG_HTS221_I2C=m
@@ -8193,9 +8299,8 @@ CONFIG_ADIS16480=m
CONFIG_BMI160=m
CONFIG_BMI160_I2C=m
CONFIG_BMI160_SPI=m
-CONFIG_BMI323=m
-CONFIG_BMI323_I2C=m
-CONFIG_BMI323_SPI=m
+# CONFIG_BMI323_I2C is not set
+# CONFIG_BMI323_SPI is not set
CONFIG_BOSCH_BNO055=m
CONFIG_BOSCH_BNO055_SERIAL=m
CONFIG_BOSCH_BNO055_I2C=m
@@ -8228,7 +8333,7 @@ CONFIG_ADUX1020=m
CONFIG_AL3010=m
CONFIG_AL3320A=m
CONFIG_APDS9300=m
-CONFIG_APDS9306=m
+# CONFIG_APDS9306 is not set
CONFIG_APDS9960=m
CONFIG_AS73211=m
CONFIG_BH1745=m
@@ -8244,14 +8349,14 @@ CONFIG_GP2AP020A00F=m
CONFIG_SENSORS_ISL29018=m
CONFIG_SENSORS_ISL29028=m
CONFIG_ISL29125=m
-CONFIG_ISL76682=m
+# CONFIG_ISL76682 is not set
CONFIG_HID_SENSOR_ALS=m
CONFIG_HID_SENSOR_PROX=m
CONFIG_JSA1212=m
CONFIG_ROHM_BU27008=m
CONFIG_ROHM_BU27034=m
CONFIG_RPR0521=m
-CONFIG_LTR390=m
+# CONFIG_LTR390 is not set
CONFIG_LTR501=m
CONFIG_LTRF216A=m
CONFIG_LV0104CS=m
@@ -8278,9 +8383,9 @@ CONFIG_US5182D=m
CONFIG_VCNL4000=m
CONFIG_VCNL4035=m
CONFIG_VEML6030=m
-CONFIG_VEML6040=m
+# CONFIG_VEML6040 is not set
CONFIG_VEML6070=m
-CONFIG_VEML6075=m
+# CONFIG_VEML6075 is not set
CONFIG_VL6180=m
CONFIG_ZOPT2201=m
# end of Light sensors
@@ -8288,7 +8393,7 @@ CONFIG_ZOPT2201=m
# Magnetometer sensors
-CONFIG_AF8133J=m
+# CONFIG_AF8133J is not set
CONFIG_AK8974=m
CONFIG_AK8975=m
CONFIG_AK09911=m
@@ -8366,7 +8471,7 @@ CONFIG_LMP91000=m
# Pressure sensors
CONFIG_ABP060MG=m
-CONFIG_ROHM_BM1390=m
+# CONFIG_ROHM_BM1390 is not set
CONFIG_BMP280=m
CONFIG_BMP280_I2C=m
CONFIG_BMP280_SPI=m
@@ -8374,9 +8479,7 @@ CONFIG_DLHL60D=m
CONFIG_DPS310=m
CONFIG_HID_SENSOR_PRESS=m
CONFIG_HP03=m
-CONFIG_HSC030PA=m
-CONFIG_HSC030PA_I2C=m
-CONFIG_HSC030PA_SPI=m
+# CONFIG_HSC030PA is not set
CONFIG_ICP10100=m
CONFIG_MPL115=m
CONFIG_MPL115_I2C=m
@@ -8444,7 +8547,7 @@ CONFIG_MAXIM_THERMOCOUPLE=m
CONFIG_HID_SENSOR_TEMP=m
CONFIG_MLX90614=m
CONFIG_MLX90632=m
-CONFIG_MLX90635=m
+# CONFIG_MLX90635 is not set
CONFIG_TMP006=m
CONFIG_TMP007=m
CONFIG_TMP117=m
@@ -8453,7 +8556,7 @@ CONFIG_TSYS02D=m
CONFIG_MAX30208=m
CONFIG_MAX31856=m
CONFIG_MAX31865=m
-CONFIG_MCP9600=m
+# CONFIG_MCP9600 is not set
# end of Temperature sensors
CONFIG_NTB=m
@@ -8473,7 +8576,7 @@ CONFIG_PWM=y
# CONFIG_PWM_FSL_FTM is not set
CONFIG_PWM_GPIO=m
CONFIG_PWM_OMAP_DMTIMER=y
-CONFIG_PWM_PCA9685=m
+CONFIG_PWM_PCA9685=y
CONFIG_PWM_TIECAP=y
CONFIG_PWM_TIEHRPWM=y
# CONFIG_PWM_XILINX is not set
@@ -8510,7 +8613,7 @@ CONFIG_RESET_TI_SYSCON=y
CONFIG_GENERIC_PHY=y
CONFIG_GENERIC_PHY_MIPI_DPHY=y
-# CONFIG_PHY_CAN_TRANSCEIVER is not set
+CONFIG_PHY_CAN_TRANSCEIVER=m
# PHY drivers for Broadcom platforms
@@ -8529,12 +8632,9 @@ CONFIG_PHY_CADENCE_SIERRA=y
# CONFIG_PHY_CPCAP_USB is not set
# CONFIG_PHY_MAPPHONE_MDM6600 is not set
# CONFIG_PHY_OCELOT_SERDES is not set
-# CONFIG_PHY_QCOM_USB_HS is not set
-# CONFIG_PHY_QCOM_USB_HSIC is not set
CONFIG_PHY_AM654_SERDES=y
CONFIG_PHY_J721E_WIZ=y
-# CONFIG_OMAP_USB2 is not set
-# CONFIG_PHY_TUSB1210 is not set
+CONFIG_OMAP_USB2=m
CONFIG_PHY_TI_GMII_SEL=y
# end of PHY Subsystem
@@ -8551,7 +8651,7 @@ CONFIG_ARM_CCN=m
CONFIG_ARM_CMN=m
# CONFIG_ARM_NI is not set
CONFIG_ARM_PMU=y
-CONFIG_ARM_SMMU_V3_PMU=m
+# CONFIG_ARM_SMMU_V3_PMU is not set
CONFIG_ARM_PMUV3=y
CONFIG_ARM_DSU_PMU=m
CONFIG_ARM_SPE_PMU=m
@@ -8569,22 +8669,12 @@ CONFIG_RAS=y
CONFIG_ANDROID_BINDER_IPC=m
# CONFIG_ANDROID_BINDERFS is not set
-CONFIG_ANDROID_BINDER_DEVICES="binder"
+CONFIG_ANDROID_BINDER_DEVICES="binder,hwbinder,vndbinder"
# CONFIG_ANDROID_BINDER_IPC_SELFTEST is not set
# end of Android
-CONFIG_LIBNVDIMM=m
-CONFIG_BLK_DEV_PMEM=m
-CONFIG_ND_CLAIM=y
-CONFIG_ND_BTT=m
-CONFIG_BTT=y
-CONFIG_ND_PFN=m
-CONFIG_NVDIMM_PFN=y
-CONFIG_NVDIMM_DAX=y
-CONFIG_OF_PMEM=m
-CONFIG_NVDIMM_KEYS=y
-# CONFIG_NVDIMM_SECURITY_TEST is not set
-CONFIG_DAX=y
+# CONFIG_LIBNVDIMM is not set
+# CONFIG_DAX is not set
CONFIG_NVMEM=y
CONFIG_NVMEM_SYSFS=y
CONFIG_NVMEM_LAYOUTS=y
@@ -8597,21 +8687,44 @@ CONFIG_NVMEM_LAYOUTS=y
CONFIG_NVMEM_LAYOUT_U_BOOT_ENV=y
# end of Layout Types
-CONFIG_NVMEM_RMEM=m
+# CONFIG_NVMEM_RMEM is not set
CONFIG_NVMEM_U_BOOT_ENV=y
# HW tracing support
-# CONFIG_STM is not set
+CONFIG_STM=m
+# CONFIG_STM_PROTO_BASIC is not set
+# CONFIG_STM_PROTO_SYS_T is not set
+# CONFIG_STM_DUMMY is not set
+# CONFIG_STM_SOURCE_CONSOLE is not set
+# CONFIG_STM_SOURCE_HEARTBEAT is not set
+# CONFIG_STM_SOURCE_FTRACE is not set
# CONFIG_INTEL_TH is not set
# CONFIG_HISI_PTT is not set
# end of HW tracing support
-# CONFIG_FPGA is not set
+CONFIG_FPGA=m
+CONFIG_ALTERA_PR_IP_CORE=m
+CONFIG_ALTERA_PR_IP_CORE_PLAT=m
+CONFIG_FPGA_MGR_ALTERA_PS_SPI=m
+# CONFIG_FPGA_MGR_ALTERA_CVP is not set
+CONFIG_FPGA_MGR_XILINX_CORE=m
+# CONFIG_FPGA_MGR_XILINX_SELECTMAP is not set
+CONFIG_FPGA_MGR_XILINX_SPI=m
+CONFIG_FPGA_MGR_ICE40_SPI=m
+CONFIG_FPGA_MGR_MACHXO2_SPI=m
+CONFIG_FPGA_BRIDGE=m
+CONFIG_ALTERA_FREEZE_BRIDGE=m
+CONFIG_XILINX_PR_DECOUPLER=m
+CONFIG_FPGA_REGION=m
+CONFIG_OF_FPGA_REGION=m
+# CONFIG_FPGA_DFL is not set
+# CONFIG_FPGA_MGR_MICROCHIP_SPI is not set
+# CONFIG_FPGA_MGR_LATTICE_SYSCONFIG_SPI is not set
# CONFIG_FSI is not set
-CONFIG_TEE=m
-CONFIG_OPTEE=m
+CONFIG_TEE=y
+CONFIG_OPTEE=y
# CONFIG_OPTEE_INSECURE_LOAD_IMAGE is not set
CONFIG_MULTIPLEXER=y
@@ -8634,9 +8747,8 @@ CONFIG_TI_ECAP_CAPTURE=m
CONFIG_TI_EQEP=m
# CONFIG_MOST is not set
# CONFIG_PECI is not set
-CONFIG_HTE=y
+# CONFIG_HTE is not set
# CONFIG_CDX_BUS is not set
-CONFIG_DPLL=y
# end of Device Drivers
@@ -8664,15 +8776,7 @@ CONFIG_JFS_POSIX_ACL=y
CONFIG_JFS_SECURITY=y
# CONFIG_JFS_DEBUG is not set
# CONFIG_JFS_STATISTICS is not set
-CONFIG_XFS_FS=y
-CONFIG_XFS_SUPPORT_V4=y
-CONFIG_XFS_SUPPORT_ASCII_CI=y
-CONFIG_XFS_QUOTA=y
-CONFIG_XFS_POSIX_ACL=y
-CONFIG_XFS_RT=y
-# CONFIG_XFS_ONLINE_SCRUB is not set
-# CONFIG_XFS_WARN is not set
-# CONFIG_XFS_DEBUG is not set
+# CONFIG_XFS_FS is not set
CONFIG_GFS2_FS=m
CONFIG_GFS2_FS_LOCKING_DLM=y
# CONFIG_OCFS2_FS is not set
@@ -8682,8 +8786,8 @@ CONFIG_BTRFS_FS_POSIX_ACL=y
# CONFIG_BTRFS_DEBUG is not set
# CONFIG_BTRFS_ASSERT is not set
# CONFIG_BTRFS_FS_REF_VERIFY is not set
-# CONFIG_NILFS2_FS is not set
-CONFIG_F2FS_FS=y
+CONFIG_NILFS2_FS=m
+CONFIG_F2FS_FS=m
CONFIG_F2FS_STAT_FS=y
CONFIG_F2FS_FS_XATTR=y
CONFIG_F2FS_FS_POSIX_ACL=y
@@ -8700,7 +8804,7 @@ CONFIG_F2FS_IOSTAT=y
# CONFIG_F2FS_UNFAIR_RWSEM is not set
# CONFIG_BCACHEFS_FS is not set
CONFIG_ZONEFS_FS=m
-CONFIG_FS_DAX=y
+# CONFIG_FS_DAX is not set
CONFIG_FS_POSIX_ACL=y
CONFIG_EXPORTFS=y
CONFIG_EXPORTFS_BLOCK_OPS=y
@@ -8717,15 +8821,14 @@ CONFIG_FANOTIFY_ACCESS_PERMISSIONS=y
CONFIG_QUOTA=y
CONFIG_QUOTA_NETLINK_INTERFACE=y
# CONFIG_QUOTA_DEBUG is not set
-CONFIG_QUOTA_TREE=m
-CONFIG_QFMT_V1=m
-CONFIG_QFMT_V2=m
+CONFIG_QUOTA_TREE=y
+# CONFIG_QFMT_V1 is not set
+CONFIG_QFMT_V2=y
CONFIG_QUOTACTL=y
CONFIG_AUTOFS_FS=y
CONFIG_FUSE_FS=y
CONFIG_CUSE=m
-CONFIG_VIRTIO_FS=y
-CONFIG_FUSE_DAX=y
+CONFIG_VIRTIO_FS=m
CONFIG_FUSE_PASSTHROUGH=y
CONFIG_OVERLAY_FS=y
# CONFIG_OVERLAY_FS_REDIRECT_DIR is not set
@@ -8738,7 +8841,7 @@ CONFIG_OVERLAY_FS_REDIRECT_ALWAYS_FOLLOW=y
# Caches
-CONFIG_NETFS_SUPPORT=y
+CONFIG_NETFS_SUPPORT=m
CONFIG_NETFS_STATS=y
# CONFIG_NETFS_DEBUG is not set
CONFIG_FSCACHE=y
@@ -8771,9 +8874,9 @@ CONFIG_EXFAT_FS=m
CONFIG_EXFAT_DEFAULT_IOCHARSET="utf8"
CONFIG_NTFS3_FS=m
# CONFIG_NTFS3_64BIT_CLUSTER is not set
-# CONFIG_NTFS3_LZX_XPRESS is not set
-# CONFIG_NTFS3_FS_POSIX_ACL is not set
-# CONFIG_NTFS_FS is not set
+CONFIG_NTFS3_LZX_XPRESS=y
+CONFIG_NTFS3_FS_POSIX_ACL=y
+CONFIG_NTFS_FS=m
# end of DOS/FAT/EXFAT/NT Filesystems
@@ -8801,17 +8904,19 @@ CONFIG_EFIVAR_FS=m
# end of Pseudo filesystems
CONFIG_MISC_FILESYSTEMS=y
-# CONFIG_ORANGEFS_FS is not set
-# CONFIG_ADFS_FS is not set
-# CONFIG_AFFS_FS is not set
+CONFIG_ORANGEFS_FS=m
+CONFIG_ADFS_FS=m
+# CONFIG_ADFS_FS_RW is not set
+CONFIG_AFFS_FS=m
CONFIG_ECRYPT_FS=m
CONFIG_ECRYPT_FS_MESSAGING=y
-# CONFIG_HFS_FS is not set
-# CONFIG_HFSPLUS_FS is not set
-# CONFIG_BEFS_FS is not set
-# CONFIG_BFS_FS is not set
-# CONFIG_EFS_FS is not set
-CONFIG_JFFS2_FS=y
+CONFIG_HFS_FS=m
+CONFIG_HFSPLUS_FS=m
+CONFIG_BEFS_FS=m
+# CONFIG_BEFS_DEBUG is not set
+CONFIG_BFS_FS=m
+CONFIG_EFS_FS=m
+CONFIG_JFFS2_FS=m
CONFIG_JFFS2_FS_DEBUG=0
CONFIG_JFFS2_FS_WRITEBUFFER=y
# CONFIG_JFFS2_FS_WBUF_VERIFY is not set
@@ -8829,7 +8934,7 @@ CONFIG_JFFS2_CMODE_PRIORITY=y
# CONFIG_JFFS2_CMODE_SIZE is not set
# CONFIG_JFFS2_CMODE_FAVOURLZO is not set
CONFIG_UBIFS_FS=y
-CONFIG_UBIFS_FS_ADVANCED_COMPR=y
+# CONFIG_UBIFS_FS_ADVANCED_COMPR is not set
CONFIG_UBIFS_FS_LZO=y
CONFIG_UBIFS_FS_ZLIB=y
CONFIG_UBIFS_FS_ZSTD=y
@@ -8873,12 +8978,8 @@ CONFIG_PSTORE_COMPRESS=y
# CONFIG_PSTORE_CONSOLE is not set
# CONFIG_PSTORE_PMSG is not set
# CONFIG_PSTORE_FTRACE is not set
-CONFIG_PSTORE_RAM=m
-CONFIG_PSTORE_ZONE=m
-CONFIG_PSTORE_BLK=m
-CONFIG_PSTORE_BLK_BLKDEV=""
-CONFIG_PSTORE_BLK_KMSG_SIZE=64
-CONFIG_PSTORE_BLK_MAX_REASON=2
+# CONFIG_PSTORE_RAM is not set
+# CONFIG_PSTORE_BLK is not set
# CONFIG_SYSV_FS is not set
# CONFIG_UFS_FS is not set
# CONFIG_EROFS_FS is not set
@@ -8898,7 +8999,7 @@ CONFIG_NFS_V4_1_IMPLEMENTATION_ID_DOMAIN="kernel.org"
# CONFIG_NFS_V4_1_MIGRATION is not set
CONFIG_NFS_V4_SECURITY_LABEL=y
CONFIG_ROOT_NFS=y
-CONFIG_NFS_FSCACHE=y
+# CONFIG_NFS_FSCACHE is not set
# CONFIG_NFS_USE_LEGACY_DNS is not set
CONFIG_NFS_USE_KERNEL_DNS=y
CONFIG_NFS_DEBUG=y
@@ -8923,10 +9024,10 @@ CONFIG_NFS_COMMON=y
# CONFIG_NFS_LOCALIO is not set
CONFIG_NFS_V4_2_SSC_HELPER=y
CONFIG_SUNRPC=y
-CONFIG_SUNRPC_GSS=m
+CONFIG_SUNRPC_GSS=y
CONFIG_SUNRPC_BACKCHANNEL=y
CONFIG_SUNRPC_SWAP=y
-CONFIG_RPCSEC_GSS_KRB5=m
+CONFIG_RPCSEC_GSS_KRB5=y
CONFIG_RPCSEC_GSS_KRB5_ENCTYPES_AES_SHA1=y
# CONFIG_RPCSEC_GSS_KRB5_ENCTYPES_CAMELLIA is not set
CONFIG_RPCSEC_GSS_KRB5_ENCTYPES_AES_SHA2=y
@@ -9107,7 +9208,7 @@ CONFIG_EVM_ATTR_FSUUID=y
# CONFIG_DEFAULT_SECURITY_TOMOYO is not set
CONFIG_DEFAULT_SECURITY_APPARMOR=y
# CONFIG_DEFAULT_SECURITY_DAC is not set
-CONFIG_LSM="landlock,lockdown,yama,loadpin,safesetid,integrity,apparmor,selinux,smack,tomoyo,bpf,ipe"
+CONFIG_LSM="landlock,lockdown,yama,loadpin,safesetid,integrity,apparmor,selinux,smack,tomoyo,bpf"
# Kernel hardening options
@@ -9183,7 +9284,7 @@ CONFIG_CRYPTO_ENGINE=m
CONFIG_CRYPTO_RSA=y
CONFIG_CRYPTO_DH=y
-CONFIG_CRYPTO_DH_RFC7919_GROUPS=y
+# CONFIG_CRYPTO_DH_RFC7919_GROUPS is not set
CONFIG_CRYPTO_ECC=y
CONFIG_CRYPTO_ECDH=y
CONFIG_CRYPTO_ECDSA=y
@@ -9354,8 +9455,7 @@ CONFIG_CRYPTO_HW=y
# CONFIG_CRYPTO_DEV_ATMEL_ECC is not set
# CONFIG_CRYPTO_DEV_ATMEL_SHA204A is not set
# CONFIG_CRYPTO_DEV_CCP is not set
-CONFIG_CRYPTO_DEV_NITROX=m
-CONFIG_CRYPTO_DEV_NITROX_CNN55XX=m
+# CONFIG_CRYPTO_DEV_NITROX_CNN55XX is not set
# CONFIG_CRYPTO_DEV_QAT_DH895xCC is not set
# CONFIG_CRYPTO_DEV_QAT_C3XXX is not set
# CONFIG_CRYPTO_DEV_QAT_C62X is not set
@@ -9366,7 +9466,7 @@ CONFIG_CRYPTO_DEV_NITROX_CNN55XX=m
# CONFIG_CRYPTO_DEV_QAT_C62XVF is not set
# CONFIG_CRYPTO_DEV_CAVIUM_ZIP is not set
CONFIG_CRYPTO_DEV_VIRTIO=m
-CONFIG_CRYPTO_DEV_SAFEXCEL=m
+# CONFIG_CRYPTO_DEV_SAFEXCEL is not set
CONFIG_CRYPTO_DEV_CCREE=m
# CONFIG_CRYPTO_DEV_HISI_SEC is not set
# CONFIG_CRYPTO_DEV_AMLOGIC_GXL is not set
@@ -9451,7 +9551,7 @@ CONFIG_CRC32_SLICEBY8=y
# CONFIG_CRC32_SARWATE is not set
# CONFIG_CRC32_BIT is not set
CONFIG_CRC64=y
-# CONFIG_CRC4 is not set
+CONFIG_CRC4=m
CONFIG_CRC7=y
CONFIG_LIBCRC32C=y
CONFIG_CRC8=y
@@ -9464,8 +9564,8 @@ CONFIG_ZLIB_INFLATE=y
CONFIG_ZLIB_DEFLATE=y
CONFIG_LZO_COMPRESS=y
CONFIG_LZO_DECOMPRESS=y
-CONFIG_LZ4_COMPRESS=y
-CONFIG_LZ4HC_COMPRESS=y
+CONFIG_LZ4_COMPRESS=m
+CONFIG_LZ4HC_COMPRESS=m
CONFIG_LZ4_DECOMPRESS=y
CONFIG_ZSTD_COMMON=y
CONFIG_ZSTD_COMPRESS=y
@@ -9490,7 +9590,6 @@ CONFIG_DECOMPRESS_LZ4=y
CONFIG_DECOMPRESS_ZSTD=y
CONFIG_GENERIC_ALLOCATOR=y
CONFIG_REED_SOLOMON=m
-CONFIG_REED_SOLOMON_ENC8=y
CONFIG_REED_SOLOMON_DEC8=y
CONFIG_TEXTSEARCH=y
CONFIG_TEXTSEARCH_KMP=m
@@ -9572,10 +9671,10 @@ CONFIG_FONT_TER16x32=y
CONFIG_SG_SPLIT=y
CONFIG_SG_POOL=y
CONFIG_ARCH_HAS_PMEM_API=y
-CONFIG_MEMREGION=y
CONFIG_ARCH_HAS_UACCESS_FLUSHCACHE=y
CONFIG_ARCH_STACKWALK=y
CONFIG_STACKDEPOT=y
+CONFIG_STACKDEPOT_ALWAYS_INIT=y
CONFIG_STACKDEPOT_MAX_FRAMES=64
CONFIG_SBITMAP=y
# CONFIG_LWQ_TEST is not set
@@ -9610,11 +9709,20 @@ CONFIG_DEBUG_MISC=y
# Compile-time checks and compiler options
+CONFIG_DEBUG_INFO=y
CONFIG_AS_HAS_NON_CONST_ULEB128=y
-CONFIG_DEBUG_INFO_NONE=y
-# CONFIG_DEBUG_INFO_DWARF_TOOLCHAIN_DEFAULT is not set
+# CONFIG_DEBUG_INFO_NONE is not set
+CONFIG_DEBUG_INFO_DWARF_TOOLCHAIN_DEFAULT=y
# CONFIG_DEBUG_INFO_DWARF4 is not set
# CONFIG_DEBUG_INFO_DWARF5 is not set
+# CONFIG_DEBUG_INFO_REDUCED is not set
+CONFIG_DEBUG_INFO_COMPRESSED_NONE=y
+# CONFIG_DEBUG_INFO_COMPRESSED_ZLIB is not set
+# CONFIG_DEBUG_INFO_SPLIT is not set
+# CONFIG_DEBUG_INFO_BTF is not set
+CONFIG_PAHOLE_HAS_SPLIT_BTF=y
+CONFIG_PAHOLE_HAS_LANG_EXCLUDE=y
+CONFIG_GDB_SCRIPTS=y
CONFIG_FRAME_WARN=2048
CONFIG_STRIP_ASM_SYMS=y
# CONFIG_READABLE_ASM is not set
@@ -9624,7 +9732,8 @@ CONFIG_SECTION_MISMATCH_WARN_ONLY=y
# CONFIG_DEBUG_FORCE_FUNCTION_ALIGN_64B is not set
CONFIG_ARCH_WANT_FRAME_POINTERS=y
CONFIG_FRAME_POINTER=y
-# CONFIG_VMLINUX_MAP is not set
+CONFIG_VMLINUX_MAP=y
+# CONFIG_BUILTIN_MODULE_RANGES is not set
# CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set
# end of Compile-time checks and compiler options
@@ -9640,12 +9749,18 @@ CONFIG_DEBUG_FS_ALLOW_ALL=y
# CONFIG_DEBUG_FS_DISALLOW_MOUNT is not set
# CONFIG_DEBUG_FS_ALLOW_NONE is not set
CONFIG_HAVE_ARCH_KGDB=y
-# CONFIG_KGDB is not set
+CONFIG_KGDB=y
+CONFIG_KGDB_HONOUR_BLOCKLIST=y
+CONFIG_KGDB_SERIAL_CONSOLE=y
+# CONFIG_KGDB_TESTS is not set
+CONFIG_KGDB_KDB=y
+CONFIG_KDB_DEFAULT_ENABLE=0x1
+CONFIG_KDB_KEYBOARD=y
+CONFIG_KDB_CONTINUE_CATASTROPHIC=0
CONFIG_ARCH_HAS_UBSAN=y
# CONFIG_UBSAN is not set
CONFIG_HAVE_ARCH_KCSAN=y
CONFIG_HAVE_KCSAN_COMPILER=y
-# CONFIG_KCSAN is not set
# end of Generic Kernel Debugging Instruments
@@ -9663,6 +9778,7 @@ CONFIG_PAGE_EXTENSION=y
# CONFIG_DEBUG_PAGEALLOC is not set
CONFIG_SLUB_DEBUG=y
# CONFIG_SLUB_DEBUG_ON is not set
+# CONFIG_SLUB_RCU_DEBUG is not set
CONFIG_PAGE_OWNER=y
CONFIG_PAGE_POISONING=y
# CONFIG_DEBUG_PAGE_REF is not set
@@ -9695,7 +9811,17 @@ CONFIG_HAVE_ARCH_KASAN_VMALLOC=y
CONFIG_CC_HAS_KASAN_GENERIC=y
CONFIG_CC_HAS_KASAN_SW_TAGS=y
CONFIG_CC_HAS_WORKING_NOSANITIZE_ADDRESS=y
-# CONFIG_KASAN is not set
+CONFIG_KASAN=y
+CONFIG_CC_HAS_KASAN_MEMINTRINSIC_PREFIX=y
+CONFIG_KASAN_GENERIC=y
+# CONFIG_KASAN_SW_TAGS is not set
+# CONFIG_KASAN_HW_TAGS is not set
+# CONFIG_KASAN_OUTLINE is not set
+CONFIG_KASAN_INLINE=y
+CONFIG_KASAN_STACK=y
+CONFIG_KASAN_VMALLOC=y
+# CONFIG_KASAN_MODULE_TEST is not set
+# CONFIG_KASAN_EXTRA_INFO is not set
CONFIG_HAVE_ARCH_KFENCE=y
CONFIG_KFENCE=y
CONFIG_KFENCE_SAMPLE_INTERVAL=0
@@ -9734,7 +9860,7 @@ CONFIG_SCHED_INFO=y
CONFIG_SCHEDSTATS=y
# end of Scheduler Debugging
-# CONFIG_DEBUG_PREEMPT is not set
+CONFIG_DEBUG_PREEMPT=y
# Lock Debugging (spinlocks, mutexes, etc...)
@@ -9757,7 +9883,7 @@ CONFIG_LOCK_DEBUGGING_SUPPORT=y
# CONFIG_DEBUG_IRQFLAGS is not set
CONFIG_STACKTRACE=y
# CONFIG_WARN_ALL_UNSEEDED_RANDOM is not set
-# CONFIG_DEBUG_KOBJECT is not set
+CONFIG_DEBUG_KOBJECT=y
# Debug kernel data structures
@@ -9866,6 +9992,7 @@ CONFIG_HAVE_SAMPLE_FTRACE_DIRECT_MULTI=y
# arm64 Debugging
CONFIG_PID_IN_CONTEXTIDR=y
+# CONFIG_DEBUG_EFI is not set
# CONFIG_ARM64_RELOC_TEST is not set
# CONFIG_CORESIGHT is not set
# end of arm64 Debugging
@@ -9891,8 +10018,5 @@ CONFIG_MEMTEST=y
# Rust hacking
-# CONFIG_RUST_DEBUG_ASSERTIONS is not set
-CONFIG_RUST_OVERFLOW_CHECKS=y
-# CONFIG_RUST_BUILD_ASSERT_ALLOW is not set
# end of Rust hacking
# end of Kernel hacking
