Build root(can't open /dev/ttyO0: No such file or directory )
Hi ,
I am using Build root buildroot-2018.08. I am doing nfs mounting on Beaglebone black.
while booting I am getting the following logs.
How to fix this issue…Need help
ubuntu@ubuntu-MS-7A15:~$ sudo minicom
[sudo] password for ubuntu:
Welcome to minicom 2.7.1
OPTIONS: I18n
Compiled on Aug 13 2017, 15:25:34.
Port /dev/ttyUSB0, 16:43:29
Press CTRL-A Z for help on special keys
U-Boot SPL 2018.09-00002-g0b54a51eee (Sep 10 2018 - 19:41:39 -0500)
Trying to boot from MMC2
Loading Environment from EXT4…
** Unable to use mmc 0:1 for loading the env **
U-Boot 2018.09-00002-g0b54a51eee (Sep 10 2018 - 19:41:39 -0500), Build: jenkins5
CPU : AM335X-GP rev 2.1
I2C: ready
DRAM: 512 MiB
No match for driver ‘omap_hsmmc’
Some drivers were not found
RTC 32KCLK Source: External.
Board: BeagleBone Black
not set. Validating first E-fuse MAC
BeagleBone Black:
BeagleBone: cape eeprom: i2c_probe: 0x54:
BeagleBone: cape eeprom: i2c_probe: 0x55:
BeagleBone: cape eeprom: i2c_probe: 0x56:
BeagleBone: cape eeprom: i2c_probe: 0x57:
Net: eth0: MII MODE
cpsw, usb_ether
Press SPACE to abort autoboot in 2 seconds
board_name=[A335BNLT] …
board_rev=[00C0] …
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
Scanning mmc 0:1…
Checking for: /uEnv.txt …
500 bytes read in 5 ms (97.7 KiB/s)
Loaded environment from /uEnv.txt
Checking if uenvcmd is set …
Running uenvcmd …
Booting from network…
link up on port 0, speed 100, full duplex
Using cpsw device
TFTP from server 192.168.7.1; our IP address is 192.168.7.3
Filename ‘uImage’.
Load address: 0x82000000
Loading: #################################################################
Hi.
The serial ports have been default-renamed from ttyOx to ttySx.
There is a kernel config to not do this.
Or you can create links from /dev/ttyOx to /dev/ttySx so that programs trying to use ttyOx works.
/Sven
