I am trying to build an image using image builder[1].
I seek clarity on the correct approach if I intend to only build a console image. The steps I took are based on README.md in the repo
Running ./beagleboard.org_image.sh seems to generate all the images. Can I clarify what is the best way to modify the script to properly generate only a console image?
I have also ran:
./RootStock-NG.sh -c rcn-ee_console_debian_jessie_armhf
The resultant image is bootable but I am unsure if this is the BBB debian console image.
I am also under the impression whichever step I chose, I still need to generate an image file for my microsd card
sudo ./setup_sdcard.sh --img-2gb bone-debian-7.X-201Y-MM-DD --dtb beaglebone \
--enable-systemd --bbb-old-bootloader-in-emmc
Please correct me if any of my assumptions are wrong. Thanks
[1]https://github.com/beagleboard/image-builder
I have also ran:
Close:
./RootStock-NG.sh -c bb.org-debian-jessie-console-v4.4
for jessie, you can drop the --enable-systemd, that was for wheezy..
the default options i usually pass are:
--img-2gb bone-debian-7.X-201Y-MM-DD --dtb beaglebone --rootfs_label
rootfs --hostname beaglebone --enable-cape-universal
if you want it to auto flash the eMMC also add:
--emmc-flasher
I have also ran:
Close:
In general, what are the differences between the bb.org, rcn-eewiki, machinekit and seeed generated?
–enable-systemd --bbb-old-bootloader-in-emmc
for jessie, you can drop the --enable-systemd, that was for wheezy…
–img-2gb bone-debian-7.X-201Y-MM-DD --dtb beaglebone --rootfs_label
–bbb-old-bootloader-in-emmc
for the option --img-2gb, how do you arrive at the choice of 2gb instead of say 8gb?
So the bb.org is for beagleboard.org images.
rcn-ee are the ones i've shoved on elinux
eewiki are the ones used for the eewiki.net guide's
machinekit is the bb.org image customized for xenomai and the machinekit project
seeed is bb.org image plus a few addons for SeeedStudio's out of box
experience (just one extra package)
say 8gb?
i know it'll fit, there's no error checking if you specify an img file
too small.. if it's too big you just waste time writing it to the
microSD..
you also don't have to use "--img-Xgb" as the setup_sdcard.sh script
can also directly write the image to a microSD card.
