Building Ångström fails
Hi:
  I'm following the instructions at [1] and it fails with:
Did you put in your proxy config like the instructions say?
I just checked with the IT guys here and we don't run a firewall
proxy.
Any other suggestions?
--Mark
I bumped into this a fair bit myself when I was told to follow those same instructions. I retried many, many times across multiple days, since it wouldn’t usually stop at the same place twice, if I waited a 1-3 hours between attempts.
David Bliss
Blumberg 106
1-616-284-1273
CM 1534
proxy.
Can you run the failing instruction manually?
Philip
It appears this [1] command is failing. It starts the command and
gets about 104k into the directory and then hangs.
The connection finally times out.
--Mark
[1] git clone "git://git.openembedded.org/openembedded" $
{OE_SOURCE_DIR}/openembedded
