Hi
I am trying to get a camera Starlight Xpress MX716 working with
beagleboard. For that I have to compile the drivers and build kernel
modules ccd.ko, sx_usb.ko and insert them into the kernel.
How do I cross compile these modules from the C code for beagleboard?
I am sorry, this might be a silly query, but I have just begun to use
beagleboard a few weeks back.
This sounds like a general linux kernel module question. Anyway AFAIK
this camera is not supported in the kernel tree (i may be wrong), so
are you
planning to write the driver yourself?
There are a lot of howtos available on how to compile and insert
modules.
Hi Deepak,
Thank you for the response.
The driver is already written for kernel 2.6. I have successfully
tried it on a linux desktop.
I want to cross compile the driver for the beagleboard, running
angstrom linux.
I am searching for the howtos. Also thought of just posting this
question on this group, in case anyone had come across a good howto,
and would want to share.
I2C: ready OMAP3503-GP rev 2, CPU-OPP2 L3-165MHz OMAP3 Beagle board + LPDDR/NAND DRAM: 128 MB NAND: 256 MiB MUSB: using high speed In: serial Out: serial Err: serial Board revision Ax/Bx Serial #55ba0002000000000403193412013014 Hit any key to stop autoboot: 0
NAND read: device 0 offset 0x280000, size 0x400000 4194304 bytes read: OK ## Booting kernel from Legacy Image at 80000000 … Image Name: Linux-2.6.29-rc3-omap1 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 1787480 Bytes = 1.7 MB Load Address: 80008000 Entry Point: 80008000 Verifying Checksum … OK Loading Kernel Image … OK OK
