Hello There,
I am building external kernel modules now. I was using make
and at times Kbuild
also with my Makefile
. Anyway, is there a way to make header files available in the external kernel module building within a Makefile or a Kbuild file?
For instance:
I have kernel_char.c
and kernel_char_one.h
that I want to build into an external kernel module
My userspace module needs to know of the kernel_char_one.h
file just like my external kernel module
called kernel_char.c
. Is there a way to make
these files understand each other via a Makefile
and a Kbuild
file?
P.S. I started an idea, questioning, on unix.stackexchange.com already and I was thinking since listings or examples are not available for my use case, I could turn here and reference where I did look:
a. kernel docs.
b. External Kernel Modules on the docs.
c. random sites around the internet.
Also…
Looking through the logs:
taints kernel
shows up for one of my external kernel modules
. It runs and works but creates issues with the internal components in a way that is marking the kernel as tainted.
Is there a reason why my external kernel module(s) are tainting the kernel?
You wouldn’t by accident have forgotten this line at the bottom of your driver, would you?
I will report after checking…
I checked…I have it recorded in the file(s).
Take a look here and run the suggested script to reveal more…
Tainted kernels — The Linux Kernel documentation
Thank you…I am reviewing it.
Hey there…I think I got to the point where I can ask specifics:
- There is no Makefile in
/lib/modules/$(shell uname -r)/build
or /lib/modules/$(shell uname -r)/
- I use this command to make the Makefile available:
sudo touch Makefile
I am trying to build external kernel modules in a directory and getting more errors with Bullseye compared to Buster now:
make -C /lib/modules/`uname -r`/
M=/home/debian/Move_to_Bullseye_BBB/kernel_modules/Kernel_Modules_One
make[1]: Entering directory '/lib/modules/5.10.168-ti-r82'
make[1]: *** No targets. Stop.
make[1]: Leaving directory '/lib/modules/5.10.168-ti-r82'
make: *** [Makefile:6: default] Error 2
I had to make the /build/
dir. in the /lib/modules/5.10.x/
Any feedback is welcomed.
Update
sudo apt install linux-headers-$(uname -r)
Blah…sorry.
Another Update
Still nothing. I moved to Bookworm. I will test another day.
Start here instead of walking the desert…
I used that one already for Buster and got it. I tried with Bullseye and did not get it. I now have Bookworm on the BBB and will test in the future.
