Building kernel for Beagleboard-C4
I tried to build image for my Beagleboard-C4 using the recent version of Angstrom and Yoctoproject/Poky, but got the following problem:
I compiled all kernels I found compatible with my board: 3.2, 3.3, 3.4, 3.7, 3.8, 3.14, including mainline and ti-staging, but none of them running on my board. The result is the same for all:
--------------- 8< -------------------
Loading file "/boot/uImage" from mmc device 0:2 (xxa2)
3394824 bytes read
Booting from mmc ...
## Booting kernel from Legacy Image at 80200000 ...
    Image Name: Linux-3.3.7
    Data Size: 3394760 Bytes = 3.2 MiB
    Load Address: 80008000
    Entry Point: 80008000
    Verifying Checksum ... OK
    Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
No more output, heartbeat LED is not blinking.
Except the version 3.14.25: it runs perfectly, but I could not compile the package omap3-sgx-modules because it seems incompatible with this kernel (4.05, 4.09, 5.01 versions). I can compile it with older kernels (using the 4.09 version) but they do not run at all.
How can I build a working kernel+omap3-sgx-modules? Some years ago it worked for me.
Thanx in advance
Gyorgy Kovesdi
If you're still using uImage, your u-boot is too old, please use the matching u-boot found in $DEPLOY_DIR
