We have a board based upon the Beagleboard xM rev. C. We have been running QNX on it. We are trying to experiment with RT Linux by following the instructions at https://eewiki.net/display/linuxonarm/BeagleBoard and the kernel builds fine. We have a problem with the gpios that identify the board revision, since we do not have these gpios wired. I modified u-boot/board/ti/beagle/beagle.c to return revision=2 in get_board_revision. But when I compile u-boot, I get an error of
/home/users/staff/tpeterson/work/epic2-rt-linux/gcc-linaro-5.3.1-2016.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-ld.bfd: u-boot-spl section .rodata' will not fit in region .sram’
/home/users/staff/tpeterson/work/epic2-rt-linux/gcc-linaro-5.3.1-2016.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-ld.bfd: region `.sram’ overflowed by 2848 bytes
scripts/Makefile.spl:290: recipe for target ‘spl/u-boot-spl’ failed
Not sure where to fix this.
I also could not find anything in the kernel source that is the equivalent get_board_revision call.
Any help is greatly appreciated.
