building org.openembedded.dev angstrom
hi
i am trying to build the dev branch of angstrom for my beagleboard,
but keep hitting hurdles. i am roughly following
http://www.angstrom-distribution.org/building-angstrom . The dev
branch does not include bit bake, so i have installed it from the
ubuntu lucid package (i am on ubuntu karmic, bit i could not get past
"NameError: global name 'os'" errors with the karmic version, or the
old one in stable/2009).
next i hit permission errors
OSError: [Errno 13] Permission denied: '/OE'
which i fixed by adding ${EOTREE} into the paths in build/conf/
local.conf
now i am getting:
NOTE: Parsing finished. 0 cached, 0 parsed, 0 skipped, 0 masked.
NOTE: Cache is clean, not saving.
ERROR: Nothing PROVIDES 'console-image'
i have added
BBFILES="${OETREE}/openembedded/recipes/*/*.bb"
to source-me.txt
but that does not help.
any ideas how to precede.
thanks, sam
Dear Sam,
can you build the branch »stable/2009«? If not I suggest to first try to
run this successfully.
If you still have problems afterward please contact
angstrom-distro-users [1] with the reference to the posted message.
Paul
[1] http://www.angstrom-distribution.org/contact
Don't EVER install bitbake from distro packages, they are either broken or outdated. Just download the bitbake tarball from berlios.de and run it from where you untarred it.
regards,
Koen
your local.conf file contains references to /OE instead of ${OETREE}.
If I recall there are three of them. You need to fix those.
(and I agree with koen, don't use bitbake from distro's, they are
generally outdated).
FMN
Thanks for the suggestions.
Ubuntu Lucid has BitBake Build Tool Core version 1.8.18, bitbake
version 1.8.18, which seems to be the latest. using the 1.8.18 from
http://developer.berlios.de/projects/bitbake gives the same error.
stable/2009 builds ok
i have changed all 3 of the /OE to ${OETREE}
still get the ERROR: Nothing PROVIDES 'console-image'
Sam
Have you re-source-d your source-me.txt file?
Is OETREE set before you set BBFILES
Does
ls ${OETREE}/openembedded/recipes/*/*.bb
yield anything (after replacing OETREE with the proper value).
it is probably a very simple config issue, but without your files and
dir structure, it is impossible to tell...
FM
i have been sourcing the source-me.txt, doing things like
ls $PKGDIR
shows me the folders
here are me source-me.txt, and local.conf
http://pastebin.com/f1412de4a
ls ${OETREE}/openembedded/recipes/*/*.bb lists 8065 files.
sam@oberon:/data/beagleboard/angstrom/openembedded$ ls ${OETREE}/
openembedded/recipes/*/*.bb | grep console
/data/beagleboard/angstrom/openembedded/recipes/console-tools/console-
tools_0.3.2.bb
/data/beagleboard/angstrom/openembedded/recipes/exmap-console/exmap-
console_0.4.1.bb
console_svn.bb
/data/beagleboard/angstrom/openembedded/recipes/hal/
consolekit_0.3.0.bb
/data/beagleboard/angstrom/openembedded/recipes/images/altboot-console-
image.bb
/data/beagleboard/angstrom/openembedded/recipes/images/console-base-
image.bb
image.bb
/data/beagleboard/angstrom/openembedded/recipes/images/console-mipv6-
image.bb
/data/beagleboard/angstrom/openembedded/recipes/images/fso-console-
image.bb
/data/beagleboard/angstrom/openembedded/recipes/images/fso2-console-
image.bb
/data/beagleboard/angstrom/openembedded/recipes/opie-console/opie-
console_1.2.2.bb
console_1.2.3.bb
console_1.2.4.bb
console_cvs.bb
/data/beagleboard/angstrom/openembedded/recipes/xorg-app/
xconsole_1.0.2.bb
xconsole_1.0.3.bb
thanks
sam
>> > hi
>> >http://www.angstrom-distribution.org/building-angstrom. The dev
>> > local.conf
>> > now i am getting:
>> > i have added
>> > to source-me.txt
>> FMN
>http://developer.berlios.de/projects/bitbakegives the same error.
> Sam
Does
FM
ls $PKGDIR
tools_0.3.2.bb
console_0.4.1.bb
console_svn.bb
consolekit_0.3.0.bb
image.bb
image.bb
image.bb
Your local.conf says:
BBFILES := "${OETREE}/org.openembedded.dev/recipes/*/*.bb"
but your recipes are in openembedded
so the above line should read:
BBFILES := "${OETREE}/openembedded/recipes/*/*.bb"
Have fun, Frans
thanks, that seems to have done the trick. well spotted.
sam
