I’ve been trying to build U-Boot (the 2016.03 version) from the instructions in
https://eewiki.net/display/linuxonarm/BeagleBone+Black
and have ended up with the following shell script:
#!/bin/bash
export CROSS_COMPILE="/home/beagle/linux-dev/dl/gcc-linaro-arm-linux-gnueabihf-4.7-2013.04-20130415_linux/bin/arm-linux-gnueabihf-"
export CC="/home/beagle/linux-dev/dl/gcc-linaro-arm-linux-gnueabihf-4.7-2013.04-20130415_linux/bin/arm-linux-gnueabihf-"
export ARCH=arm
make distclean
make am335x_evm_defconfig
make
eof
which uses a 32-bit Linaro compiler which I’ve used for U-Boot before.
The sources patch correctly, but the compile fails (the log is below). Does anyone
know of a 32-bit compiler which will compile the current U-Boot?
Thanks - C W Rose
Build log for U-Boot:
CLEAN tools
CLEAN tools/lib tools/common
CLEAN scripts/basic
CLEAN scripts/kconfig
CLEAN include/config include/generated spl
CLEAN .config include/autoconf.mk include/autoconf.mk.dep include/config.h
HOSTCC scripts/basic/fixdep
HOSTCC scripts/kconfig/conf.o
SHIPPED scripts/kconfig/zconf.tab.c
SHIPPED scripts/kconfig/zconf.lex.c
SHIPPED scripts/kconfig/zconf.hash.c
HOSTCC scripts/kconfig/zconf.tab.o
HOSTLD scripts/kconfig/conf
