Hello Again,
Is anyone using DROPBEAR and Buildroot for building on the BBBW?
So far:
Starting network: OK
Starting dropbear sshd: OK
You have made it!
cork login: cork
Password:
Login incorrect
cork login: root
Password:
# [ 31.846332] wlan-en-regulator: disabling
As you can tell, I have dropbear attached, can sign in via USB to TTL on /dev/ttyUSB0, and have no clue as how to sign in via SSH so far.
Here are some more ideas I have listed in case you are interested.
U-Boot SPL 2021.04 (Aug 15 2021 - 03:28:27 -0500)
Trying to boot from MMC1
U-Boot 2021.04 (Aug 15 2021 - 03:28:27 -0500)
CPU : AM335X-GP rev 2.1
Model: TI AM335x BeagleBone Black
DRAM: 512 MiB
WDT: Started with servicing (60s timeout)
NAND: 0 MiB
Loading Environment from FAT... OK
<ethaddr> not set. Validating first E-fuse MAC
Net: Could not get PHY for ethernet@4a100000: addr 0
eth2: ethernet@4a100000, eth3: usb_ether
=> boot
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
Failed to load 'boot.scr'
Failed to load 'uEnv.txt'
Scanning mmc 0:1...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
142 bytes read in 4 ms (34.2 KiB/s)
1: buildroot
Retrieving file: /zImage
5777216 bytes read in 379 ms (14.5 MiB/s)
append: console=ttyO0,115200 root=/dev/mmcblk0p2 rootwait
Retrieving file: /am335x-boneblack-wireless.dtb
59750 bytes read in 7 ms (8.1 MiB/s)
## Flattened Device Tree blob at 88000000
Loading Device Tree to 8ffee000, end 8ffff965 ... OK
Starting kernel ...
[ 0.000000] Linux version 5.4.140 (morter@morter) (gcc version 10.2.1 20201103 (GNU Toolchain for the A-profile Architecture 10.2-2020.11 (arm-10.16))) #1 SMP Sun Aug 15 05:22:19 CDT 2021
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] OF: fdt: Machine model: TI AM335x BeagleBone Black Wireless
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] cma: Reserved 16 MiB at 0x9e800000
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (sgx neon)
[ 0.000000] percpu: Embedded 20 pages/cpu s49228 r8192 d24500 u81920
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129412
[ 0.000000] Kernel command line: console=ttyO0,115200 root=/dev/mmcblk0p2 rootwait
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 486212K/522240K available (9216K kernel code, 713K rwdata, 2048K rodata, 1024K init, 259K bss, 19644K reserved, 16384K cma-reserved, 0K highmem)
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] IRQ: Found an INTC at 0x(ptrval) (revision 5.0) with 128 interrupts
[ 0.000000] random: get_random_bytes called from start_kernel+0x2b0/0x4f4 with crng_init=0
[ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[ 0.000015] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000035] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000046] OMAP clocksource: timer1 at 24000000 Hz
[ 0.000832] timer_probe: no matching timers found
[ 0.001279] Console: colour dummy device 80x30
[ 0.001312] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[ 0.001319] This ensures that you still see kernel messages. Please
[ 0.001324] update your kernel commandline.
[ 0.001365] Calibrating delay loop... 996.14 BogoMIPS (lpj=4980736)
[ 0.089159] pid_max: default: 32768 minimum: 301
[ 0.089344] LSM: Security Framework initializing
[ 0.089439] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.089452] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.090469] CPU: Testing write buffer coherency: ok
[ 0.090546] CPU0: Spectre v2: using BPIALL workaround
[ 0.090982] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 0.091730] Setting up static identity map for 0x80100000 - 0x80100078
[ 0.091915] rcu: Hierarchical SRCU implementation.
[ 0.092304] smp: Bringing up secondary CPUs ...
[ 0.092315] smp: Brought up 1 node, 1 CPU
[ 0.092324] SMP: Total of 1 processors activated (996.14 BogoMIPS).
[ 0.092331] CPU: All CPU(s) started in SVC mode.
[ 0.092943] devtmpfs: initialized
[ 0.104912] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.105213] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.105240] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[ 0.106543] pinctrl core: initialized pinctrl subsystem
[ 0.107929] NET: Registered protocol family 16
[ 0.110715] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.138277] l3-aon-clkctrl:0000:0: failed to disable
[ 0.139867] audit: initializing netlink subsys (disabled)
[ 0.141000] cpuidle: using governor menu
[ 0.160130] audit: type=2000 audit(0.140:1): state=initialized audit_enabled=0 res=1
[ 0.161853] No ATAGs?
[ 0.161861] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.178504] edma 49000000.edma: TI EDMA DMA engine driver
[ 0.182205] iommu: Default domain type: Translated
[ 0.183901] vgaarb: loaded
[ 0.184477] SCSI subsystem initialized
[ 0.185310] pps_core: LinuxPPS API ver. 1 registered
[ 0.185322] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.185345] PTP clock support registered
[ 0.186294] clocksource: Switched to clocksource timer1
[ 0.631453] VFS: Disk quotas dquot_6.6.0
[ 0.631562] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.641031] thermal_sys: Registered thermal governor 'fair_share'
[ 0.641039] thermal_sys: Registered thermal governor 'step_wise'
[ 0.641057] thermal_sys: Registered thermal governor 'user_space'
[ 0.641642] NET: Registered protocol family 2
[ 0.641872] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.642600] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.642635] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 0.642677] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.642736] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.642845] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.642868] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.643033] NET: Registered protocol family 1
[ 0.643817] RPC: Registered named UNIX socket transport module.
[ 0.643830] RPC: Registered udp transport module.
[ 0.643836] RPC: Registered tcp transport module.
[ 0.643842] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.643858] PCI: CLS 0 bytes, default 64
[ 0.645127] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 0.646865] Initialise system trusted keyrings
[ 0.647315] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 0.648533] NFS: Registering the id_resolver key type
[ 0.648579] Key type id_resolver registered
[ 0.648587] Key type id_legacy registered
[ 0.648631] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 0.648965] Key type asymmetric registered
[ 0.648976] Asymmetric key parser 'x509' registered
[ 0.648995] io scheduler mq-deadline registered
[ 0.649003] io scheduler kyber registered
[ 0.653547] OMAP GPIO hardware version 0.1
[ 0.698420] GPIO line 106 (LS_BUF_EN) hogged as output/high
[ 0.705418] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[ 0.710158] Serial: 8250/16550 driver, 6 ports, IRQ sharing enabled
[ 0.713488] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 29, base_baud = 3000000) is a 8250
[ 1.329205] printk: console [ttyS0] enabled
[ 1.334738] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 46, base_baud = 3000000) is a 8250
[ 1.343793] serial serial0: tty port ttyS3 registered
[ 1.361414] brd: module loaded
[ 1.373451] loop: module loaded
[ 1.378555] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 1.386785] libphy: Fixed MDIO Bus: probed
[ 1.392663] i2c /dev entries driver
[ 1.398293] sdhci: Secure Digital Host Controller Interface driver
[ 1.404509] sdhci: Copyright(c) Pierre Ossman
[ 1.409955] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000 microseconds (-22)
[ 1.418765] omap_hsmmc 48060000.mmc: Got CD GPIO
[ 1.477223] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.483530] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.491452] oprofile: using arm/armv7
[ 1.495439] Initializing XFRM netlink socket
[ 1.500032] NET: Registered protocol family 10
[ 1.505799] Segment Routing with IPv6
[ 1.509677] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 1.516481] NET: Registered protocol family 17
[ 1.520981] NET: Registered protocol family 15
[ 1.525531] Key type dns_resolver registered
[ 1.529924] ThumbEE CPU extension supported.
[ 1.534223] Registering SWP/SWPB emulation handler
[ 1.539066] omap_voltage_late_init: Voltage driver support not added
[ 1.545457] sr_dev_init: Unknown instance smartreflex0
[ 1.550878] SmartReflex Class3 initialized
[ 1.555629] Loading compiled-in X.509 certificates
[ 1.586764] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.598295] mmc0: new high speed SDHC card at address aaaa
[ 1.604697] mmcblk0: mmc0:aaaa SL08G 7.40 GiB
[ 1.613080] mmcblk0: p1 p2
[ 1.617038] random: fast init done
[ 1.630136] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 1.635892] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 1.643617] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[ 1.674112] mmc1: new high speed MMC card at address 0001
[ 1.680527] mmcblk1: mmc1:0001 S10004 3.56 GiB
[ 1.685421] mmcblk1boot0: mmc1:0001 S10004 partition 1 4.00 MiB
[ 1.691791] mmcblk1boot1: mmc1:0001 S10004 partition 2 4.00 MiB
[ 1.698134] mmcblk1rpmb: mmc1:0001 S10004 partition 3 4.00 MiB, chardev (249:0)
[ 1.760289] hctosys: unable to open rtc device (rtc0)
[ 1.772353] omap_hsmmc 47810000.mmc: card claims to support voltages below defined range
[ 1.786529] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.794775] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.809590] mmc2: new high speed SDIO card at address 0001
[ 1.815793] devtmpfs: mounted
[ 1.820248] Freeing unused kernel memory: 1024K
[ 1.825293] Run /sbin/init as init process
[ 1.967817] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Starting syslogd: OK
Starting klogd: OK
Running sysctl: OK
Saving random seed: [ 2.190093] random: dd: uninitialized urandom read (512 bytes read)
and…
messages
# cat messages
Jan 1 00:00:02 cork syslog.info syslogd started: BusyBox v1.33.1
Jan 1 00:00:02 cork user.notice kernel: klogd started: BusyBox v1.33.1 (2021-08-15 03:21:44 CDT)
Jan 1 00:00:02 cork user.info kernel: [ 0.000000] Booting Linux on physical CPU 0x0
Jan 1 00:00:02 cork user.notice kernel: [ 0.000000] Linux version 5.4.140 (morter@morter) (gcc version 10.2.1 20201103 (GNU Toolchain for the A-profile Architecture 10.2-2020.11 (arm-10.16))) #1 SMP Sun Aug 15 05:22:19 CDT 2021
Jan 1 00:00:02 cork user.info kernel: [ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
Jan 1 00:00:02 cork user.info kernel: [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Jan 1 00:00:02 cork user.info kernel: [ 0.000000] OF: fdt: Machine model: TI AM335x BeagleBone Black Wireless
Jan 1 00:00:02 cork user.info kernel: [ 0.000000] Memory policy: Data cache writeback
Jan 1 00:00:02 cork user.info kernel: [ 0.000000] cma: Reserved 16 MiB at 0x9e800000
Jan 1 00:00:02 cork user.debug kernel: [ 0.000000] On node 0 totalpages: 130560
Jan 1 00:00:02 cork user.debug kernel: [ 0.000000] Normal zone: 1148 pages used for memmap
Jan 1 00:00:02 cork user.debug kernel: [ 0.000000] Normal zone: 0 pages reserved
Jan 1 00:00:02 cork user.debug kernel: [ 0.000000] Normal zone: 130560 pages, LIFO batch:31
Jan 1 00:00:02 cork user.info kernel: [ 0.000000] CPU: All CPU(s) started in SVC mode.
Jan 1 00:00:02 cork user.info kernel: [ 0.000000] AM335X ES2.1 (sgx neon)
Jan 1 00:00:02 cork user.info kernel: [ 0.000000] percpu: Embedded 20 pages/cpu s49228 r8192 d24500 u81920
Jan 1 00:00:02 cork user.debug kernel: [ 0.000000] pcpu-alloc: s49228 r8192 d24500 u81920 alloc=20*4096
Jan 1 00:00:02 cork user.debug kernel: [ 0.000000] pcpu-alloc: [0] 0
Jan 1 00:00:02 cork user.info kernel: [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129412
Jan 1 00:00:02 cork user.notice kernel: [ 0.000000] Kernel command line: console=ttyO0,115200 root=/dev/mmcblk0p2 rootwait
Jan 1 00:00:02 cork user.info kernel: [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
Jan 1 00:00:02 cork user.info kernel: [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
Jan 1 00:00:02 cork user.info kernel: [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
Jan 1 00:00:02 cork user.info kernel: [ 0.000000] Memory: 486212K/522240K available (9216K kernel code, 713K rwdata, 2048K rodata, 1024K init, 259K bss, 19644K reserved, 16384K cma-reserved, 0K highmem)
Jan 1 00:00:02 cork user.info kernel: [ 0.000000] rcu: Hierarchical RCU implementation.
Jan 1 00:00:02 cork user.info kernel: [ 0.000000] rcu: RCU event tracing is enabled.
Jan 1 00:00:02 cork user.info kernel: [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
Jan 1 00:00:02 cork user.info kernel: [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
Jan 1 00:00:02 cork user.info kernel: [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
Jan 1 00:00:02 cork user.info kernel: [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
Jan 1 00:00:02 cork user.info kernel: [ 0.000000] IRQ: Found an INTC at 0x(ptrval) (revision 5.0) with 128 interrupts
Jan 1 00:00:02 cork user.notice kernel: [ 0.000000] random: get_random_bytes called from start_kernel+0x2b0/0x4f4 with crng_init=0
Jan 1 00:00:02 cork user.info kernel: [ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz
Jan 1 00:00:02 cork user.info kernel: [ 0.000015] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
Jan 1 00:00:02 cork user.info kernel: [ 0.000035] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
Jan 1 00:00:02 cork user.info kernel: [ 0.000046] OMAP clocksource: timer1 at 24000000 Hz
Jan 1 00:00:02 cork user.crit kernel: [ 0.000832] timer_probe: no matching timers found
Jan 1 00:00:02 cork user.info kernel: [ 0.001279] Console: colour dummy device 80x30
Jan 1 00:00:02 cork user.err kernel: [ 0.001312] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
Jan 1 00:00:02 cork user.err kernel: [ 0.001319] This ensures that you still see kernel messages. Please
Jan 1 00:00:02 cork user.err kernel: [ 0.001324] update your kernel commandline.
Jan 1 00:00:02 cork user.info kernel: [ 0.001365] Calibrating delay loop... 996.14 BogoMIPS (lpj=4980736)
Jan 1 00:00:02 cork user.info kernel: [ 0.089159] pid_max: default: 32768 minimum: 301
Jan 1 00:00:02 cork user.info kernel: [ 0.089344] LSM: Security Framework initializing
Jan 1 00:00:02 cork user.info kernel: [ 0.089439] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
Jan 1 00:00:02 cork user.info kernel: [ 0.089452] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
Jan 1 00:00:02 cork user.info kernel: [ 0.090469] CPU: Testing write buffer coherency: ok
Jan 1 00:00:02 cork user.info kernel: [ 0.090546] CPU0: Spectre v2: using BPIALL workaround
Jan 1 00:00:02 cork user.info kernel: [ 0.090982] CPU0: thread -1, cpu 0, socket -1, mpidr 0
Jan 1 00:00:02 cork user.info kernel: [ 0.091730] Setting up static identity map for 0x80100000 - 0x80100078
Jan 1 00:00:02 cork user.info kernel: [ 0.091915] rcu: Hierarchical SRCU implementation.
Jan 1 00:00:02 cork user.info kernel: [ 0.092304] smp: Bringing up secondary CPUs ...
Jan 1 00:00:02 cork user.info kernel: [ 0.092315] smp: Brought up 1 node, 1 CPU
Jan 1 00:00:02 cork user.info kernel: [ 0.092324] SMP: Total of 1 processors activated (996.14 BogoMIPS).
Jan 1 00:00:02 cork user.info kernel: [ 0.092331] CPU: All CPU(s) started in SVC mode.
Jan 1 00:00:02 cork user.info kernel: [ 0.092943] devtmpfs: initialized
Jan 1 00:00:02 cork user.info kernel: [ 0.104912] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
Jan 1 00:00:02 cork user.info kernel: [ 0.105213] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Jan 1 00:00:02 cork user.info kernel: [ 0.105240] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
Jan 1 00:00:02 cork user.info kernel: [ 0.106543] pinctrl core: initialized pinctrl subsystem
Jan 1 00:00:02 cork user.info kernel: [ 0.107929] NET: Registered protocol family 16
Jan 1 00:00:02 cork user.info kernel: [ 0.110715] DMA: preallocated 256 KiB pool for atomic coherent allocations
Jan 1 00:00:02 cork user.err kernel: [ 0.138277] l3-aon-clkctrl:0000:0: failed to disable
Jan 1 00:00:02 cork user.info kernel: [ 0.139867] audit: initializing netlink subsys (disabled)
Jan 1 00:00:02 cork user.info kernel: [ 0.141000] cpuidle: using governor menu
Jan 1 00:00:02 cork user.notice kernel: [ 0.160130] audit: type=2000 audit(0.140:1): state=initialized audit_enabled=0 res=1
Jan 1 00:00:02 cork user.info kernel: [ 0.161853] No ATAGs?
Jan 1 00:00:02 cork user.info kernel: [ 0.161861] hw-breakpoint: debug architecture 0x4 unsupported.
Jan 1 00:00:02 cork user.info kernel: [ 0.178504] edma 49000000.edma: TI EDMA DMA engine driver
Jan 1 00:00:02 cork user.debug kernel: [ 0.179387] reg-fixed-voltage fixedregulator0: GPIO lookup for consumer (null)
Jan 1 00:00:02 cork user.debug kernel: [ 0.179398] reg-fixed-voltage fixedregulator0: using device tree for GPIO lookup
Jan 1 00:00:02 cork user.debug kernel: [ 0.179422] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/fixedregulator0[0]'
Jan 1 00:00:02 cork user.debug kernel: [ 0.179434] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/fixedregulator0[0]'
Jan 1 00:00:02 cork user.debug kernel: [ 0.179445] reg-fixed-voltage fixedregulator0: using lookup tables for GPIO lookup
Jan 1 00:00:02 cork user.debug kernel: [ 0.179453] reg-fixed-voltage fixedregulator0: No GPIO consumer (null) found
Jan 1 00:00:02 cork user.debug kernel: [ 0.179848] reg-fixed-voltage fixedregulator@2: GPIO lookup for consumer (null)
Jan 1 00:00:02 cork user.debug kernel: [ 0.179856] reg-fixed-voltage fixedregulator@2: using device tree for GPIO lookup
Jan 1 00:00:02 cork user.debug kernel: [ 0.179872] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/fixedregulator@2[0]'
Jan 1 00:00:02 cork user.debug kernel: [ 0.179895] reg-fixed-voltage fixedregulator@2: No GPIO consumer (null) found
Jan 1 00:00:02 cork user.info kernel: [ 0.182205] iommu: Default domain type: Translated
Jan 1 00:00:02 cork user.info kernel: [ 0.183901] vgaarb: loaded
Jan 1 00:00:02 cork user.notice kernel: [ 0.184477] SCSI subsystem initialized
Jan 1 00:00:02 cork user.debug kernel: [ 0.184816] libata version 3.00 loaded.
Jan 1 00:00:02 cork user.info kernel: [ 0.185310] pps_core: LinuxPPS API ver. 1 registered
Jan 1 00:00:02 cork user.info kernel: [ 0.185322] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
Jan 1 00:00:02 cork user.info kernel: [ 0.185345] PTP clock support registered
Jan 1 00:00:02 cork user.info kernel: [ 0.186294] clocksource: Switched to clocksource timer1
Jan 1 00:00:02 cork user.notice kernel: [ 0.631453] VFS: Disk quotas dquot_6.6.0
Jan 1 00:00:02 cork user.info kernel: [ 0.631562] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Jan 1 00:00:02 cork user.info kernel: [ 0.641031] thermal_sys: Registered thermal governor 'fair_share'
Jan 1 00:00:02 cork user.info kernel: [ 0.641039] thermal_sys: Registered thermal governor 'step_wise'
Jan 1 00:00:02 cork user.info kernel: [ 0.641057] thermal_sys: Registered thermal governor 'user_space'
Jan 1 00:00:02 cork user.info kernel: [ 0.641642] NET: Registered protocol family 2
Jan 1 00:00:02 cork user.info kernel: [ 0.641872] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
Jan 1 00:00:02 cork user.info kernel: [ 0.642600] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
Jan 1 00:00:02 cork user.info kernel: [ 0.642635] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
Jan 1 00:00:02 cork user.info kernel: [ 0.642677] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
Jan 1 00:00:02 cork user.info kernel: [ 0.642736] TCP: Hash tables configured (established 4096 bind 4096)
Jan 1 00:00:02 cork user.info kernel: [ 0.642845] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
Jan 1 00:00:02 cork user.info kernel: [ 0.642868] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
Jan 1 00:00:02 cork user.info kernel: [ 0.643033] NET: Registered protocol family 1
Jan 1 00:00:02 cork user.info kernel: [ 0.643817] RPC: Registered named UNIX socket transport module.
Jan 1 00:00:02 cork user.info kernel: [ 0.643830] RPC: Registered udp transport module.
Jan 1 00:00:02 cork user.info kernel: [ 0.643836] RPC: Registered tcp transport module.
Jan 1 00:00:02 cork user.info kernel: [ 0.643842] RPC: Registered tcp NFSv4.1 backchannel transport module.
Jan 1 00:00:02 cork user.info kernel: [ 0.643858] PCI: CLS 0 bytes, default 64
Jan 1 00:00:02 cork user.info kernel: [ 0.645127] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
Jan 1 00:00:02 cork user.notice kernel: [ 0.646865] Initialise system trusted keyrings
Jan 1 00:00:02 cork user.info kernel: [ 0.647315] workingset: timestamp_bits=14 max_order=17 bucket_order=3
Jan 1 00:00:02 cork user.notice kernel: [ 0.648533] NFS: Registering the id_resolver key type
Jan 1 00:00:02 cork user.notice kernel: [ 0.648579] Key type id_resolver registered
Jan 1 00:00:02 cork user.notice kernel: [ 0.648587] Key type id_legacy registered
Jan 1 00:00:02 cork user.info kernel: [ 0.648631] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
Jan 1 00:00:02 cork user.notice kernel: [ 0.648965] Key type asymmetric registered
Jan 1 00:00:02 cork user.notice kernel: [ 0.648976] Asymmetric key parser 'x509' registered
Jan 1 00:00:02 cork user.info kernel: [ 0.648995] io scheduler mq-deadline registered
Jan 1 00:00:02 cork user.info kernel: [ 0.649003] io scheduler kyber registered
Jan 1 00:00:02 cork user.debug kernel: [ 0.653354] gpio gpiochip0: (gpio-0-31): added GPIO chardev (254:0)
Jan 1 00:00:02 cork user.debug kernel: [ 0.653473] gpiochip_setup_dev: registered GPIOs 0 to 31 on device: gpiochip0 (gpio-0-31)
Jan 1 00:00:02 cork user.info kernel: [ 0.653547] OMAP GPIO hardware version 0.1
Jan 1 00:00:02 cork user.debug kernel: [ 0.678560] gpio gpiochip1: (gpio-32-63): added GPIO chardev (254:1)
Jan 1 00:00:02 cork user.debug kernel: [ 0.678686] gpiochip_setup_dev: registered GPIOs 32 to 63 on device: gpiochip1 (gpio-32-63)
Jan 1 00:00:02 cork user.debug kernel: [ 0.697060] gpio gpiochip2: (gpio-64-95): added GPIO chardev (254:2)
Jan 1 00:00:02 cork user.debug kernel: [ 0.697164] gpiochip_setup_dev: registered GPIOs 64 to 95 on device: gpiochip2 (gpio-64-95)
Jan 1 00:00:02 cork user.debug kernel: [ 0.698404] gpio gpiochip3: Persistence not supported for GPIO 10
Jan 1 00:00:02 cork user.info kernel: [ 0.698420] GPIO line 106 (LS_BUF_EN) hogged as output/high
Jan 1 00:00:02 cork user.debug kernel: [ 0.698758] gpio gpiochip3: (gpio-96-127): added GPIO chardev (254:3)
Jan 1 00:00:02 cork user.debug kernel: [ 0.698850] gpiochip_setup_dev: registered GPIOs 96 to 127 on device: gpiochip3 (gpio-96-127)
Jan 1 00:00:02 cork user.info kernel: [ 0.705418] pinctrl-single 44e10800.pinmux: 142 pins, size 568
Jan 1 00:00:02 cork user.debug kernel: [ 0.707854] gpio-clk clk_mcasp0: GPIO lookup for consumer enable
Jan 1 00:00:02 cork user.debug kernel: [ 0.707866] gpio-clk clk_mcasp0: using device tree for GPIO lookup
Jan 1 00:00:02 cork user.debug kernel: [ 0.707906] of_get_named_gpiod_flags: parsed 'enable-gpios' property of node '/clk_mcasp0[0]' - status (0)
Jan 1 00:00:02 cork user.debug kernel: [ 0.707986] gpio gpiochip1: Persistence not supported for GPIO 27
Jan 1 00:00:02 cork user.info kernel: [ 0.710158] Serial: 8250/16550 driver, 6 ports, IRQ sharing enabled
Jan 1 00:00:02 cork user.info kernel: [ 0.713488] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 29, base_baud = 3000000) is a 8250
Jan 1 00:00:02 cork user.info kernel: [ 1.329205] printk: console [ttyS0] enabled
Jan 1 00:00:02 cork user.info kernel: [ 1.334738] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 46, base_baud = 3000000) is a 8250
Jan 1 00:00:02 cork user.info kernel: [ 1.343793] serial serial0: tty port ttyS3 registered
Jan 1 00:00:02 cork user.info kernel: [ 1.361414] brd: module loaded
Jan 1 00:00:02 cork user.info kernel: [ 1.373451] loop: module loaded
Jan 1 00:00:02 cork user.err kernel: [ 1.378555] mtdoops: mtd device (mtddev=name/number) must be supplied
Jan 1 00:00:02 cork user.debug kernel: [ 1.386737] mdio_bus fixed-0: GPIO lookup for consumer reset
Jan 1 00:00:02 cork user.debug kernel: [ 1.386747] mdio_bus fixed-0: using lookup tables for GPIO lookup
Jan 1 00:00:02 cork user.debug kernel: [ 1.386755] mdio_bus fixed-0: No GPIO consumer reset found
Jan 1 00:00:02 cork user.info kernel: [ 1.386785] libphy: Fixed MDIO Bus: probed
Jan 1 00:00:02 cork user.info kernel: [ 1.392663] i2c /dev entries driver
Jan 1 00:00:02 cork user.info kernel: [ 1.398293] sdhci: Secure Digital Host Controller Interface driver
Jan 1 00:00:02 cork user.info kernel: [ 1.404509] sdhci: Copyright(c) Pierre Ossman
Jan 1 00:00:02 cork user.debug kernel: [ 1.409827] omap_hsmmc 48060000.mmc: GPIO lookup for consumer cd
Jan 1 00:00:02 cork user.debug kernel: [ 1.409837] omap_hsmmc 48060000.mmc: using device tree for GPIO lookup
Jan 1 00:00:02 cork user.debug kernel: [ 1.409881] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@60000/mmc@0[0]' - status (0)
Jan 1 00:00:02 cork user.debug kernel: [ 1.409939] gpio gpiochip0: Persistence not supported for GPIO 6
Jan 1 00:00:02 cork user.info kernel: [ 1.409955] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000 microseconds (-22)
Jan 1 00:00:02 cork user.info kernel: [ 1.418765] omap_hsmmc 48060000.mmc: Got CD GPIO
Jan 1 00:00:02 cork user.debug kernel: [ 1.423405] omap_hsmmc 48060000.mmc: GPIO lookup for consumer wp
Jan 1 00:00:02 cork user.debug kernel: [ 1.423411] omap_hsmmc 48060000.mmc: using device tree for GPIO lookup
Jan 1 00:00:02 cork user.debug kernel: [ 1.423429] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@60000/mmc@0[0]'
Jan 1 00:00:02 cork user.debug kernel: [ 1.423442] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/interconnect@48000000/segment@0/target-module@60000/mmc@0[0]'
Jan 1 00:00:02 cork user.debug kernel: [ 1.423454] omap_hsmmc 48060000.mmc: using lookup tables for GPIO lookup
Jan 1 00:00:02 cork user.debug kernel: [ 1.423461] omap_hsmmc 48060000.mmc: No GPIO consumer wp found
Jan 1 00:00:02 cork user.debug kernel: [ 1.450573] omap_hsmmc 481d8000.mmc: GPIO lookup for consumer cd
Jan 1 00:00:02 cork user.debug kernel: [ 1.450585] omap_hsmmc 481d8000.mmc: using device tree for GPIO lookup
Jan 1 00:00:02 cork user.debug kernel: [ 1.450609] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp/interconnect@48000000/segment@100000/target-module@d8000/mmc@0[0]'
Jan 1 00:00:02 cork user.debug kernel: [ 1.450623] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp/interconnect@48000000/segment@100000/target-module@d8000/mmc@0[0]'
Jan 1 00:00:02 cork user.debug kernel: [ 1.450633] omap_hsmmc 481d8000.mmc: using lookup tables for GPIO lookup
Jan 1 00:00:02 cork user.debug kernel: [ 1.450641] omap_hsmmc 481d8000.mmc: No GPIO consumer cd found
Jan 1 00:00:02 cork user.debug kernel: [ 1.450648] omap_hsmmc 481d8000.mmc: GPIO lookup for consumer wp
Jan 1 00:00:02 cork user.debug kernel: [ 1.450654] omap_hsmmc 481d8000.mmc: using device tree for GPIO lookup
Jan 1 00:00:02 cork user.debug kernel: [ 1.450667] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/interconnect@48000000/segment@100000/target-module@d8000/mmc@0[0]'
Jan 1 00:00:02 cork user.debug kernel: [ 1.450680] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/interconnect@48000000/segment@100000/target-module@d8000/mmc@0[0]'
Jan 1 00:00:02 cork user.debug kernel: [ 1.450688] omap_hsmmc 481d8000.mmc: using lookup tables for GPIO lookup
Jan 1 00:00:02 cork user.debug kernel: [ 1.450694] omap_hsmmc 481d8000.mmc: No GPIO consumer wp found
Jan 1 00:00:02 cork user.debug kernel: [ 1.475801] omap_hsmmc 47810000.mmc: GPIO lookup for consumer wp
Jan 1 00:00:02 cork user.debug kernel: [ 1.475812] omap_hsmmc 47810000.mmc: using device tree for GPIO lookup
Jan 1 00:00:02 cork user.debug kernel: [ 1.475833] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/target-module@47810000/mmc@0[0]'
Jan 1 00:00:02 cork user.debug kernel: [ 1.475846] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/target-module@47810000/mmc@0[0]'
Jan 1 00:00:02 cork user.debug kernel: [ 1.475857] omap_hsmmc 47810000.mmc: using lookup tables for GPIO lookup
Jan 1 00:00:02 cork user.debug kernel: [ 1.475864] omap_hsmmc 47810000.mmc: No GPIO consumer wp found
Jan 1 00:00:02 cork user.info kernel: [ 1.477223] sdhci-pltfm: SDHCI platform and OF driver helper
Jan 1 00:00:02 cork user.info kernel: [ 1.483530] ledtrig-cpu: registered to indicate activity on CPUs
Jan 1 00:00:02 cork user.info kernel: [ 1.491452] oprofile: using arm/armv7
Jan 1 00:00:02 cork user.info kernel: [ 1.495439] Initializing XFRM netlink socket
Jan 1 00:00:02 cork user.info kernel: [ 1.500032] NET: Registered protocol family 10
Jan 1 00:00:02 cork user.info kernel: [ 1.505799] Segment Routing with IPv6
Jan 1 00:00:02 cork user.info kernel: [ 1.509677] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
Jan 1 00:00:02 cork user.info kernel: [ 1.516481] NET: Registered protocol family 17
Jan 1 00:00:02 cork user.info kernel: [ 1.520981] NET: Registered protocol family 15
Jan 1 00:00:02 cork user.notice kernel: [ 1.525531] Key type dns_resolver registered
Jan 1 00:00:02 cork user.info kernel: [ 1.529924] ThumbEE CPU extension supported.
Jan 1 00:00:02 cork user.notice kernel: [ 1.534223] Registering SWP/SWPB emulation handler
Jan 1 00:00:02 cork user.err kernel: [ 1.539066] omap_voltage_late_init: Voltage driver support not added
Jan 1 00:00:02 cork user.err kernel: [ 1.545457] sr_dev_init: Unknown instance smartreflex0
Jan 1 00:00:02 cork user.info kernel: [ 1.550878] SmartReflex Class3 initialized
Jan 1 00:00:02 cork user.notice kernel: [ 1.555629] Loading compiled-in X.509 certificates
Jan 1 00:00:02 cork user.debug kernel: [ 1.578273] reg-fixed-voltage fixedregulator@2: GPIO lookup for consumer (null)
Jan 1 00:00:02 cork user.debug kernel: [ 1.578288] reg-fixed-voltage fixedregulator@2: using device tree for GPIO lookup
Jan 1 00:00:02 cork user.debug kernel: [ 1.578326] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/fixedregulator@2[0]'
Jan 1 00:00:02 cork user.debug kernel: [ 1.578360] of_get_named_gpiod_flags: parsed 'gpio' property of node '/fixedregulator@2[0]' - status (0)
Jan 1 00:00:02 cork user.debug kernel: [ 1.578387] gpio gpiochip3: Persistence not supported for GPIO 9
Jan 1 00:00:02 cork user.warn kernel: [ 1.586764] mmc0: host does not support reading read-only switch, assuming write-enable
Jan 1 00:00:02 cork user.info kernel: [ 1.598295] mmc0: new high speed SDHC card at address aaaa
Jan 1 00:00:02 cork user.info kernel: [ 1.604697] mmcblk0: mmc0:aaaa SL08G 7.40 GiB
Jan 1 00:00:02 cork user.info kernel: [ 1.613080] mmcblk0: p1 p2
Jan 1 00:00:02 cork user.notice kernel: [ 1.617038] random: fast init done
Jan 1 00:00:02 cork user.info kernel: [ 1.630136] tps65217 0-0024: TPS65217 ID 0xe version 1.2
Jan 1 00:00:02 cork user.info kernel: [ 1.635892] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
Jan 1 00:00:02 cork user.info kernel: [ 1.643617] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
Jan 1 00:00:02 cork user.debug kernel: [ 1.650036] omap_hsmmc 47810000.mmc: GPIO lookup for consumer wp
Jan 1 00:00:02 cork user.debug kernel: [ 1.650045] omap_hsmmc 47810000.mmc: using device tree for GPIO lookup
Jan 1 00:00:02 cork user.debug kernel: [ 1.650068] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/target-module@47810000/mmc@0[0]'
Jan 1 00:00:02 cork user.debug kernel: [ 1.650082] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/target-module@47810000/mmc@0[0]'
Jan 1 00:00:02 cork user.debug kernel: [ 1.650093] omap_hsmmc 47810000.mmc: using lookup tables for GPIO lookup
Jan 1 00:00:02 cork user.debug kernel: [ 1.650101] omap_hsmmc 47810000.mmc: No GPIO consumer wp found
Jan 1 00:00:02 cork user.info kernel: [ 1.674112] mmc1: new high speed MMC card at address 0001
Jan 1 00:00:02 cork user.info kernel: [ 1.680527] mmcblk1: mmc1:0001 S10004 3.56 GiB
Jan 1 00:00:02 cork user.info kernel: [ 1.685421] mmcblk1boot0: mmc1:0001 S10004 partition 1 4.00 MiB
Jan 1 00:00:02 cork user.info kernel: [ 1.691791] mmcblk1boot1: mmc1:0001 S10004 partition 2 4.00 MiB
Jan 1 00:00:02 cork user.info kernel: [ 1.698134] mmcblk1rpmb: mmc1:0001 S10004 partition 3 4.00 MiB, chardev (249:0)
Jan 1 00:00:02 cork user.info kernel: [ 1.760289] hctosys: unable to open rtc device (rtc0)
Jan 1 00:00:02 cork user.warn kernel: [ 1.772353] omap_hsmmc 47810000.mmc: card claims to support voltages below defined range
Jan 1 00:00:02 cork user.info kernel: [ 1.786529] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Jan 1 00:00:02 cork user.info kernel: [ 1.794775] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
Jan 1 00:00:02 cork user.info kernel: [ 1.809590] mmc2: new high speed SDIO card at address 0001
Jan 1 00:00:02 cork user.info kernel: [ 1.815793] devtmpfs: mounted
Jan 1 00:00:02 cork user.info kernel: [ 1.820248] Freeing unused kernel memory: 1024K
Jan 1 00:00:02 cork user.info kernel: [ 1.825293] Run /sbin/init as init process
Jan 1 00:00:02 cork user.info kernel: [ 1.967817] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Jan 1 00:00:02 cork user.notice kernel: [ 2.190093] random: dd: uninitialized urandom read (512 bytes read)
Jan 1 00:00:02 cork daemon.info : starting pid 105, tty '/dev/console': '/sbin/getty -L console 0 vt100 '
Jan 1 00:00:02 cork authpriv.info dropbear[104]: Running in background
Jan 1 00:00:20 cork auth.warn login[105]: invalid password for 'UNKNOWN' on 'console'
Jan 1 00:00:27 cork auth.info login[105]: root login on 'console'
Jan 1 00:00:31 cork user.info kernel: [ 31.846332] wlan-en-regulator: disabling
Jan 1 00:07:33 cork syslog.info syslogd started: BusyBox v1.33.1
This is usually too much info. for me to process as of now b/c I am too immature to handle things currently. If you are using busybox, buildroot, and uboot, please chime in where you think I amy be missing the next steps from: Buildroot - Making Embedded Linux Easy on page 13 of 34 at Customize the Linux kernel configuration .
It seems that wlan-en-regulator: disabling is an issue so far.
P.S. Sorry for the long, drawn out promotion. If you know of where to look from here, please do pitch in.
