Hi
I have downloaded the buildroot from git clone git://git.buildroot.net/buildroot.
I compiled successfully for my target. But in the bin folder no symlink has created for binaries.
I added the bin folder path to #PATH.
So when i compile uboot with make CROSS_COMPILE=arm-linux- . It gives me following error
arm-linux-gcc not found.
Please help. Is there any option/script to create symlink for binaries in bin folder.
Regards
Jai Shiv
Hi
I'm not sure that I understand which binaries that you'd like. Host
tools such as the compiler can be found in the output/host/usr/bin
directory.
That does not sound like the right prefix. You didn't say what
buildroot configuration that you were using so I can't say for sure.
However, it's often longer like arm-none-linux-gnueabi- or similar. If
you look in your output/host/usr/bin directory, you should see what it
is.
Also, why don't you let Buildroot build uboot? It will set the
CROSS_COMPILE prefix correctly.
I'd recommend updating your PATH rather than creating symlinks to the
host tools.
Frank
Hi Frank
All the binaries under output/host/usr/bin having this prefix arm-buildroot-linux-uclibcgnueabi- .
For example for gcc it is like :
arm-buildroot-linux-uclibcgnueabi-gcc
So in Path variable i added the path of output/host/usr/bin folder.
And While compiling anything for arm target i gave CROSS_COMPILE= arm-buildroot-linux-uclibcgnueabi-
But it’s giving me same error.
In my another build machine there are symlink created for all binaries under output/host/usr/bin folder
For example : for gcc there is one binary arm-buildroot-linux-uclibcgnueabi-gcc and there is corresponding link present like
arm-linux-gcc ->arm-buildroot-linux-uclibcgnueabi-gcc
So while cross compiling a arm program I usually give arm-linux- and it’s work fine .
Hope You understood now.
Regads
Jai Shiv
