[Buster -> Bullseye upgrade] Can't upgrade BBGW kernel without breaking WiFi
I have a network of BBGW devices that I’ve been occasionally upgrading without incident using apt update/upgrade. I’ve been unable to upgrade since kernel 5.10.131-ti-r50 without breaking the overlays. I just tried again with 5.10.145-ti-r53 and got the following errors on boot:
[ 0.152508] l3-aon-clkctrl:0000:0: failed to disable
[ 8.873701] debugfs: Directory ‘49000000.dma’ with parent ‘dmaengine’ already present!
[ 8.909230] gpio-of-helper ocp:cape-universal: Failed to get gpio property of ‘P8_03’
[ 8.909258] gpio-of-helper ocp:cape-universal: Failed to create gpio entry
[ 9.278730] pinctrl-single 44e10800.pinmux: pin PIN10 already requested by ocp:P8_14_pinmux; cannot claim for 47810000.mmc
[ 9.295244] pinctrl-single 44e10800.pinmux: pin-10 (47810000.mmc) status -22
[ 9.314462] pinctrl-single 44e10800.pinmux: could not request pin 10 (PIN10) from group pinmux_wl18xx_pins on device pinctrl-single
[ 9.332757] sdhci-omap 47810000.mmc: Error applying setting, reverse things back
[ 9.431407] omap_voltage_late_init: Voltage driver support not added
[ 53.070992] Bluetooth: hci0: command 0x1001 tx timeout
[ 61.166954] Bluetooth: hci0: Reading TI version information failed (-110)
[ 61.174031] Bluetooth: hci0: download firmware failed, retrying…
[ 63.216044] Bluetooth: hci0: command 0x1001 tx timeout
[ 71.407047] Bluetooth: hci0: Reading TI version information failed (-110)
[ 71.414091] Bluetooth: hci0: download firmware failed, retrying…
[ 73.455163] Bluetooth: hci0: command 0x1001 tx timeout
I have to edit uEnv.txt and comment out the line “enable_uboot_overlays=1” in order to get the WiFi working and eliminate the errors seen above. If I do this though my other overlays don’t work. The line “enable_uboot_cape_universal=1” has always been commented out. My version of bb-u-boot-am335x-evm is 2022.04.20220602.1-0~bullseye+20220720, and I reran /opt/u-boot/bb-u-boot-am335x-evm/install.sh a few times with no effect.
Any idea what happened with these latest updates that broke my setup?
Thanks for any help!
Here’s the version info:
beagle-version
eeprom:[A335BNLTGW1ABBGW19010472]
model:[TI_AM335x_BeagleBone_Green_Wireless]
dogtag:[BeagleBoard.org Debian Buster IoT Image 2020-05-18]
bootloader:[eMMC-(default)]:[/dev/mmcblk1]:[U-Boot SPL 2022.04-gd0771d53 (Jul 21 2022 - 02:13:23 +0000)]:[location: dd MBR]
UBOOT: Booted Device-Tree:[am335x-bonegreen-wireless.dts]
kernel:[5.10.145-ti-r53]
/boot/uEnv.txt Settings:
pkg check: to individually upgrade run: [sudo apt install --only-upgrade ]
pkg:[bb-cape-overlays]:[4.14.20210821.0-0~bullseye+20210821]
pkg:[bb-customizations]:[1.20221108.0-0~bullseye+20221108]
pkg:[bb-usb-gadgets]:[1.20220816.0-0~bullseye+20220816]
pkg:[bb-wl18xx-firmware]:[1.20211222.2-0~bullseye+20211222]
pkg:[kmod]:[28-1]
WARNING:pkg:[librobotcontrol]:[NOT_INSTALLED]
cmdline:[console=ttyS0,115200n8 root=/dev/mmcblk1p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet]
dmesg | grep remote
[ 3.648580] remoteproc remoteproc0: wkup_m3 is available
[ 28.815943] remoteproc remoteproc0: powering up wkup_m3
[ 28.815983] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217148
[ 28.816266] remoteproc remoteproc0: remote processor wkup_m3 is now up
[ 40.079155] Bluetooth: hci0: change remote baud rate command in firmware
[ 42.356427] remoteproc remoteproc1: 4a334000.pru is available
[ 42.397025] remoteproc remoteproc2: 4a338000.pru is available
[ 56.471204] Bluetooth: hci0: change remote baud rate command in firmware
dmesg | grep pru
dmesg | grep pinctrl-single
[ 3.515831] pinctrl-single 44e10800.pinmux: 142 pins, size 568
dmesg | grep gpio-of-helper
lsusb
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. Hub
END
I am not a real person but a quick guesser in this matter. I looked over the beagle-version script output.
The first line of my reply makes me think of the dtb. Should it be .dts instead of .dtb?
P.S. Maybe it needs to be compiled by the device-tree-compiler? Sorry. I am really just reaching out here since I have used the am335x boards from beagleboard.org on many occasions and added in uEnv.txt in the /boot dir. a dtb=am335x-boneblue.dtb and NOT dtb=am335x-boneblue.dts.
I will check my board and run beagle-version as I have not done this yet.
UPDATE
I was wrong. I ran sudo beagle-version.
This is my updated ideas w/ kernel 4.19.x: UBOOT: Booted Device-Tree:[am335x-boneblack-uboot-univ.dts] .
Sorry for my reaching out. I may dive deeper in it. Please give me some time. Hello, sorry for the delay…
Does this help: https://www.freedesktop.org/wiki/Software/systemd/NetworkTarget/
I am not sure if what you are doing consists of available scripts on boot but there is a section, pardon my French, that states Cut the Crap on the site listed. It helps the .service files on boot work even after or before said network up/down/whatever.
Okay, reflashed that old image..
debian@beaglebone:~$ sudo /opt/scripts/tools/version.sh
git:/opt/scripts/:[029041f6866049997bbfd2c7667b3c6e8c95201c]
eeprom:[A335BNLTGW1ABBGW16062749]
bootloader:[microSD-(push-button)]:[/dev/mmcblk0]:[U-Boot 2019.04-00002-g31a8ae0206]:[location: dd MBR]
UBOOT: Booted Device-Tree:[am335x-bonegreen-wireless-uboot-univ.dts]
UBOOT: Loaded Overlay:[AM335X-PRU-RPROC-4-19-TI-00A0]
UBOOT: Loaded Overlay:[BB-ADC-00A0]
UBOOT: Loaded Overlay:[BB-BBGW-WL1835-00A0]
UBOOT: Loaded Overlay:[BB-BONE-eMMC1-01-00A0]
kernel:[4.19.94-ti-r43]
nodejs:[v10.19.0]
uboot_overlay_options:[uboot_overlay_pru=/lib/firmware/AM335X-PRU-RPROC-4-19-TI-00A0.dtbo]
pkg check: to individually upgrade run: [sudo apt install --only-upgrade <pkg>]
pkg:[bb-cape-overlays]:[4.14.20200430.0-0~buster+20200430]
pkg:[bb-wl18xx-firmware]:[1.20200420.1-0~buster+20200424]
pkg:[kmod]:[26-1]
pkg:[librobotcontrol]:[1.0.4-git20190227.1-0rcnee0~buster+20190327]
pkg:[firmware-ti-connectivity]:[20190717-2rcnee1~buster+20200305]
groups:[debian : debian adm kmem dialout cdrom floppy audio dip video plugdev users systemd-journal input bluetooth netdev i2c gpio pwm eqep remoteproc admin spi iio docker tisdk weston-launch xenomai cloud9ide]
cmdline:[console=ttyO0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet]
dmesg | grep remote
[   58.935334] remoteproc remoteproc0: wkup_m3 is available
[   58.998956] remoteproc remoteproc0: powering up wkup_m3
[   58.998989] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217168
[   58.999274] remoteproc remoteproc0: remote processor wkup_m3 is now up
[   60.852577] remoteproc remoteproc1: 4a334000.pru is available
[   60.867817] remoteproc remoteproc2: 4a338000.pru is available
dmesg | grep pru
[   60.852752] pru-rproc 4a334000.pru: PRU rproc node pru@4a334000 probed successfully
[   60.868051] pru-rproc 4a338000.pru: PRU rproc node pru@4a338000 probed successfully
[    0.917775] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[    0.930272] gpio-of-helper ocp:cape-universal: ready
lsusb
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
END
So let’s see what breaks it..
debian@beaglebone:~$ sudo ifconfig wlan0
wlan0: flags=-28605<UP,BROADCAST,RUNNING,MULTICAST,DYNAMIC>  mtu 1500
        inet 192.168.2.29  netmask 255.255.252.0  broadcast 192.168.3.255
        inet6 fe80::8a4a:eaff:fe62:1e54  prefixlen 64  scopeid 0x20<link>
        ether 88:4a:ea:62:1e:54  txqueuelen 1000  (Ethernet)
        RX packets 895  bytes 160684 (156.9 KiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 263  bytes 41462 (40.4 KiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
debian@beaglebone:~$ ping -c3 www.google.com
PING www.google.com (142.250.69.228) 56(84) bytes of data.
64 bytes from den08s05-in-f4.1e100.net (142.250.69.228): icmp_seq=1 ttl=58 time=45.3 ms
64 bytes from den08s05-in-f4.1e100.net (142.250.69.228): icmp_seq=2 ttl=58 time=43.4 ms
64 bytes from den08s05-in-f4.1e100.net (142.250.69.228): icmp_seq=3 ttl=58 time=42.2 ms
--- www.google.com ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 4ms
rtt min/avg/max/mdev = 42.241/43.652/45.295/1.268 ms
Upgrade /opt/scripts/tools/
debian@beaglebone:~$ cd /opt/scripts/tools/
debian@beaglebone:/opt/scripts/tools$ git pull
remote: Enumerating objects: 268, done.
remote: Counting objects: 100% (268/268), done.
remote: Compressing objects: 100% (81/81), done.
remote: Total 235 (delta 176), reused 204 (delta 148), pack-reused 0
Receiving objects: 100% (235/235), 32.18 KiB | 2.14 MiB/s, done.
Resolving deltas: 100% (176/176), completed with 28 local objects.
From https://github.com/RobertCNelson/boot-scripts
   029041f..9c0602c  master     -> origin/master
Updating 029041f..9c0602c
Fast-forward
 boot/am335x_evm.sh                                 |  59 +--
 boot/bbai.sh                                       |  31 +-
 boot/generic-startup.sh                            |  17 +-
 device/bbai64/BBAI64-eeprom.dump                   | Bin 0 -> 28 bytes
 device/bone/capes/BeagleBoard.org/A1Fan_Cape.dump  | Bin 0 -> 88 bytes
 device/bone/show-pins.pl                           | 418 ++++++++++++++++++---
 tools/config_checking/docker/check-config.sh       | 215 +++++++----
 tools/developers/nfs-rsync.sh                      |   2 +-
 tools/developers/secondary_rootfs.sh               |   4 +-
 tools/developers/update_bootloader.sh              |  11 +-
 tools/eMMC/bbb-eMMC-flasher-eewiki-12mb.sh         |  14 +-
 tools/eMMC/bbb-eMMC-flasher-eewiki-ext4.sh         |  14 +-
 tools/eMMC/functions.sh                            | 102 ++---
 .../init-eMMC-flasher-from-usb-media-v1-bbgw.sh    |   4 +-
 tools/eMMC/init-eMMC-flasher-v2.sh                 |   4 +-
 tools/eMMC/init-eMMC-flasher-v3-bbbl.sh            |   4 +-
 tools/eMMC/init-eMMC-flasher-v3-bbbw.sh            |   4 +-
 tools/eMMC/init-eMMC-flasher-v3-bbgw.sh            |   4 +-
 tools/generate_extlinux.sh                         |  26 +-
 tools/grow_partition.sh                            |   8 +-
 tools/non-mmc-rootfs/mv_rootfs_dev_sda.sh          |   4 +-
 tools/update_kernel.sh                             | 182 ++++++++-
 tools/version.sh                                   |  11 +
 23 files changed, 868 insertions(+), 270 deletions(-)
 create mode 100644 device/bbai64/BBAI64-eeprom.dump
 create mode 100644 device/bone/capes/BeagleBoard.org/A1Fan_Cape.dump
debian@beaglebone:/opt/scripts/tools$ sudo reboot
git:/opt/scripts/:[9c0602cc5de15e35bcbff32e80511c72b03e7a16]
bootloader:[microSD-(push-button)]:[/dev/mmcblk0]:[U-Boot SPL 2019.04-00002-g31a8ae0206 (May 13 2020 - 09:26:17 -0500)]:[location: dd MBR]
nodejs:[v10.19.0]
pkg:[bb-customizations]:[1.20200511.1-0~buster+20200511]
pkg:[bb-usb-gadgets]:[1.20200504.0-0~buster+20200504]
pkg:[kmod]:[26-1]
dmesg | grep remote
[   58.544246] remoteproc remoteproc0: wkup_m3 is available
[   58.680001] remoteproc remoteproc0: powering up wkup_m3
[   58.680033] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217168
[   58.680307] remoteproc remoteproc0: remote processor wkup_m3 is now up
[   60.533631] remoteproc remoteproc1: 4a334000.pru is available
[   60.548951] remoteproc remoteproc2: 4a338000.pru is available
dmesg | grep pru
[   60.533866] pru-rproc 4a334000.pru: PRU rproc node pru@4a334000 probed successfully
[   60.549167] pru-rproc 4a338000.pru: PRU rproc node pru@4a338000 probed successfully
[    0.917874] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[    0.930348] gpio-of-helper ocp:cape-universal: ready
lsusb
END
Full Upgrade
debian@beaglebone:~$ sudo apt upgrade
Reading package lists... Done
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
The following NEW packages will be installed:
  gt libconfig9 libusbgx
The following packages have been kept back:
  c9-core-installer
The following packages will be upgraded:
  apt apt-utils avahi-daemon avahi-utils base-files bb-bbai-firmware
  bb-cape-overlays bb-customizations bb-node-red-installer bb-usb-gadgets
  bb-wl18xx-firmware bind9-host bluetooth bluez bone101 bzip2 ca-certificates
  connman curl dbus debconf debconf-i18n debian-archive-keyring
  device-tree-compiler dirmngr distro-info-data dnsmasq dnsmasq-base dpkg
  dpkg-dev file git git-man gnupg gnupg-l10n gnupg-utils gpg gpg-agent
  gpg-wks-client gpg-wks-server gpgconf gpgsm gpgv groff-base gzip hostapd
  iproute2 iputils-ping isc-dhcp-client isc-dhcp-common klibc-utils
  libapt-inst2.0 libapt-pkg5.0 libavahi-client3 libavahi-common-data
  libavahi-common3 libavahi-core7 libbind9-161 libbluetooth3 libbrotli1
  libbsd0 libbz2-1.0 libc-ares2 libc-bin libc-dev-bin libc-l10n libc6
  libc6-dev libcpupower1 libcurl3-gnutls libcurl4 libdbus-1-3 libdbus-1-dev
  libdns-export1104 libdns1104 libdpkg-perl libexpat1 libexpat1-dev
  libfreetype6 libgcrypt20 libglib2.0-0 libgmp10 libgnutls30 libgssapi-krb5-2
  libhogweed4 libicu63 libisc-export1100 libisc1100 libisccc161 libisccfg163
  libjpeg62-turbo libjs-jquery libjson-c3 libk5crypto3 libklibc libkrb5-3
  libkrb5support0 libksba8 libldap-2.4-2 libldap-common liblwres161 liblz4-1
  liblzma5 libmagic-mgc libmagic1 libncurses-dev libncurses5-dev libncurses6
  libncursesw6 libnettle6 libnginx-mod-http-auth-pam libnginx-mod-http-dav-ext
  libnginx-mod-http-echo libnginx-mod-http-geoip
  libnginx-mod-http-image-filter libnginx-mod-http-subs-filter
  libnginx-mod-http-upstream-fair libnginx-mod-http-xslt-filter
  libnginx-mod-mail libnginx-mod-stream libnode-dev libnode64 libnss-systemd
  libp11-kit0 libpam-systemd libpcap0.8 libperl5.28 libpython3.7
  libpython3.7-dev libpython3.7-minimal libpython3.7-stdlib librobotcontrol
  libsasl2-2 libsasl2-modules-db libsqlite3-0 libssl-dev libssl1.1 libsystemd0
  libtiff5 libtinfo6 libudev1 libuv1 libuv1-dev libwebp6 libx11-6 libx11-data
  libxml2 libxslt1.1 libzstd1 linux-cpupower linux-libc-dev locales
  ncurses-base ncurses-bin nginx nginx-common nginx-full node-ansi-regex
  node-end-of-stream node-hosted-git-info node-ini node-minimist node-tar
  node-y18n nodejs nodejs-doc npm openssl perl perl-base perl-modules-5.28
  python3.7 python3.7-dev python3.7-minimal rsyslog screen sudo systemd
  systemd-sysv ti-pru-cgt-installer tzdata udev unzip vim vim-common
  vim-runtime vim-tiny wpasupplicant xxd xz-utils zlib1g
191 upgraded, 3 newly installed, 0 to remove and 1 not upgraded.
Need to get 330 MB of archives.
After this operation, 94.9 MB of additional disk space will be used.
Do you want to continue? [Y/n]
I’m going to disable the “bb-cape-overlays” it’s broken things before…
debian@beaglebone:~$ sudo apt-mark hold bb-cape-overlays
bb-cape-overlays set on hold.
debian@beaglebone:~$ sudo apt-mark showhold
bb-cape-overlays
c9-core-installer
real upgrade
  bb-cape-overlays c9-core-installer
  bb-customizations bb-node-red-installer bb-usb-gadgets bb-wl18xx-firmware
  bind9-host bluetooth bluez bone101 bzip2 ca-certificates connman curl dbus
  debconf debconf-i18n debian-archive-keyring device-tree-compiler dirmngr
  distro-info-data dnsmasq dnsmasq-base dpkg dpkg-dev file git git-man gnupg
  gnupg-l10n gnupg-utils gpg gpg-agent gpg-wks-client gpg-wks-server gpgconf
  gpgsm gpgv groff-base gzip hostapd iproute2 iputils-ping isc-dhcp-client
  isc-dhcp-common klibc-utils libapt-inst2.0 libapt-pkg5.0 libavahi-client3
  libavahi-common-data libavahi-common3 libavahi-core7 libbind9-161
  libbluetooth3 libbrotli1 libbsd0 libbz2-1.0 libc-ares2 libc-bin libc-dev-bin
  libc-l10n libc6 libc6-dev libcpupower1 libcurl3-gnutls libcurl4 libdbus-1-3
  libdbus-1-dev libdns-export1104 libdns1104 libdpkg-perl libexpat1
  libexpat1-dev libfreetype6 libgcrypt20 libglib2.0-0 libgmp10 libgnutls30
  libgssapi-krb5-2 libhogweed4 libicu63 libisc-export1100 libisc1100
  libisccc161 libisccfg163 libjpeg62-turbo libjs-jquery libjson-c3
  libk5crypto3 libklibc libkrb5-3 libkrb5support0 libksba8 libldap-2.4-2
  libldap-common liblwres161 liblz4-1 liblzma5 libmagic-mgc libmagic1
  libncurses-dev libncurses5-dev libncurses6 libncursesw6 libnettle6
  libnginx-mod-http-auth-pam libnginx-mod-http-dav-ext libnginx-mod-http-echo
  libnginx-mod-http-geoip libnginx-mod-http-image-filter
  libnginx-mod-http-subs-filter libnginx-mod-http-upstream-fair
  libnginx-mod-http-xslt-filter libnginx-mod-mail libnginx-mod-stream
  libnode-dev libnode64 libnss-systemd libp11-kit0 libpam-systemd libpcap0.8
  libperl5.28 libpython3.7 libpython3.7-dev libpython3.7-minimal
  libpython3.7-stdlib librobotcontrol libsasl2-2 libsasl2-modules-db
  libsqlite3-0 libssl-dev libssl1.1 libsystemd0 libtiff5 libtinfo6 libudev1
  libuv1 libuv1-dev libwebp6 libx11-6 libx11-data libxml2 libxslt1.1 libzstd1
  linux-cpupower linux-libc-dev locales ncurses-base ncurses-bin nginx
  nginx-common nginx-full node-ansi-regex node-end-of-stream
  node-hosted-git-info node-ini node-minimist node-tar node-y18n nodejs
  nodejs-doc npm openssl perl perl-base perl-modules-5.28 python3.7
  python3.7-dev python3.7-minimal rsyslog screen sudo systemd systemd-sysv
  ti-pru-cgt-installer tzdata udev unzip vim vim-common vim-runtime vim-tiny
190 upgraded, 3 newly installed, 0 to remove and 2 not upgraded.
After this operation, 96.6 MB of additional disk space will be used.
loading /boot/vmlinuz-4.19.94-ti-r43 ...
10095616 bytes read in 661 ms (14.6 MiB/s)
debug: [enable_uboot_overlays=1] ...
debug: [enable_uboot_cape_universal=1] ...
debug: [uboot_base_dtb_univ=am335x-bonegreen-wireless-uboot-univ.dtb] ...
uboot_overlays: [uboot_base_dtb=am335x-bonegreen-wireless-uboot-univ.dtb] ...
uboot_overlays: Switching too: dtb=am335x-bonegreen-wireless-uboot-univ.dtb ...
loading /boot/dtbs/4.19.94-ti-r43/am335x-bonegreen-wireless-uboot-univ.dtb ...
157133 bytes read in 94 ms (1.6 MiB/s)
uboot_overlays: [fdt_buffer=0x60000] ...
uboot_overlays: loading /lib/firmware/BB-ADC-00A0.dtbo ...
867 bytes read in 423 ms (2 KiB/s)
uboot_overlays: loading /lib/firmware/BB-BONE-eMMC1-01-00A0.dtbo ...
1584 bytes read in 152 ms (9.8 KiB/s)
uboot_overlays: loading /lib/firmware/BB-BBGW-WL1835-00A0.dtbo ...
4785 bytes read in 489 ms (8.8 KiB/s)
uboot_overlays: loading /lib/firmware/AM335X-PRU-RPROC-4-19-TI-00A0.dtbo ...
3801 bytes read in 317 ms (10.7 KiB/s)
loading /boot/initrd.img-4.19.94-ti-r43 ...
64 bytes from den08s05-in-f4.1e100.net (142.250.69.228): icmp_seq=1 ttl=58 time=46.7 ms
64 bytes from den08s05-in-f4.1e100.net (142.250.69.228): icmp_seq=2 ttl=58 time=43.5 ms
64 bytes from den08s05-in-f4.1e100.net (142.250.69.228): icmp_seq=3 ttl=58 time=44.5 ms
3 packets transmitted, 3 received, 0% packet loss, time 5ms
rtt min/avg/max/mdev = 43.528/44.909/46.670/1.321 ms
[sudo] password for debian:
nodejs:[v10.24.0]
pkg:[bb-customizations]:[1.20221108.0-0~buster+20221108]
pkg:[bb-usb-gadgets]:[1.20220816.0-0~buster+20220816]
pkg:[bb-wl18xx-firmware]:[1.20211222.2-0~buster+20211222]
pkg:[kmod]:[26-1]
pkg:[librobotcontrol]:[1.0.5-git20200715.0-0~buster+20200716]
dmesg | grep remote
[   47.815490] remoteproc remoteproc0: wkup_m3 is available
[   47.939871] remoteproc remoteproc0: powering up wkup_m3
[   47.939904] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217168
[   47.940196] remoteproc remoteproc0: remote processor wkup_m3 is now up
[   50.779363] remoteproc remoteproc1: 4a334000.pru is available
[   50.819830] remoteproc remoteproc2: 4a338000.pru is available
dmesg | grep pru
[   50.796781] pru-rproc 4a334000.pru: PRU rproc node pru@4a334000 probed successfully
[   50.820043] pru-rproc 4a338000.pru: PRU rproc node pru@4a338000 probed successfully
[    0.945252] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[    0.957796] gpio-of-helper ocp:cape-universal: ready
lsusb
END
debian@beaglebone:~$ sudo apt-mark unhold bb-cape-overlays
Canceled hold on bb-cape-overlays.
  c9-core-installer
  bb-cape-overlays
1 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
Need to get 61.1 kB of archives.
After this operation, 1,654 kB disk space will be freed.
Running uname_boot ...
157133 bytes read in 93 ms (1.6 MiB/s)
654 bytes read in 446 ms (1000 Bytes/s)
1614 bytes read in 197 ms (7.8 KiB/s)
4289 bytes read in 944 ms (3.9 KiB/s)
3653 bytes read in 549 ms (5.9 KiB/s)
7050074 bytes read in 471 ms (14.3 MiB/s)
WiFi still works.
64 bytes from den08s05-in-f4.1e100.net (142.250.69.228): icmp_seq=1 ttl=58 time=43.4 ms
64 bytes from den08s05-in-f4.1e100.net (142.250.69.228): icmp_seq=2 ttl=58 time=47.7 ms
64 bytes from den08s05-in-f4.1e100.net (142.250.69.228): icmp_seq=3 ttl=58 time=43.7 ms
rtt min/avg/max/mdev = 43.369/44.895/47.659/1.965 ms
UBOOT: Loaded Overlay:[BB-ADC-00A0.bb.org-overlays]
UBOOT: Loaded Overlay:[BB-BBGW-WL1835-00A0.bb.org-overlays]
UBOOT: Loaded Overlay:[BB-BONE-eMMC1-01-00A0.bb.org-overlays]
nodejs:[v10.24.0]
pkg:[bb-cape-overlays]:[4.14.20210821.0-0~buster+20210821]
pkg:[kmod]:[26-1]
dmesg | grep remote
[   37.168933] Bluetooth: hci0: change remote baud rate command in firmware
[   48.647416] remoteproc remoteproc0: wkup_m3 is available
[   48.867951] remoteproc remoteproc0: powering up wkup_m3
[   48.867985] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217168
[   48.868268] remoteproc remoteproc0: remote processor wkup_m3 is now up
dmesg | grep pru
[    0.945496] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[    1.387227] pinctrl-single 44e10800.pinmux: pin PIN30 already requested by 481a6000.serial; cannot claim for leds
[    1.397688] pinctrl-single 44e10800.pinmux: pin-30 (leds) status -22
[    1.404107] pinctrl-single 44e10800.pinmux: could not request pin 30 (PIN30) from group pinmux_bt_pins  on device pinctrl-single
[    0.958042] gpio-of-helper ocp:cape-universal: ready
lsusb
END
Upgrade U-Boot
debian@beaglebone:~$ sudo apt install bb-u-boot-am335x-evm
debian@beaglebone:~$ lsblk
NAME         MAJ:MIN RM  SIZE RO TYPE MOUNTPOINT
mmcblk0      179:0    0 29.7G  0 disk
└─mmcblk0p1  179:1    0  3.5G  0 part /
mmcblk1      179:8    0  3.7G  0 disk
mmcblk1boot0 179:16   0    2M  1 disk
mmcblk1boot1 179:24   0    2M  1 disk
debian@beaglebone:~$ sudo /opt/u-boot/bb-u-boot-am335x-evm/install-mmcblk0.sh
dd if=/opt/u-boot/bb-u-boot-am335x-evm/MLO of=/dev/mmcblk0 count=2 seek=1 bs=128k
0+1 records in
0+1 records out
92336 bytes (92 kB, 90 KiB) copied, 0.00242409 s, 38.1 MB/s
dd if=/opt/u-boot/bb-u-boot-am335x-evm/u-boot.img of=/dev/mmcblk0 count=4 seek=1 bs=384k
1+1 records in
1+1 records out
471808 bytes (472 kB, 461 KiB) copied, 0.00876237 s, 53.8 MB/s
bootloader:[microSD-(push-button)]:[/dev/mmcblk0]:[U-Boot SPL 2019.04-g923f8b8 (Jan 02 2022 - 19:05:15 +0000)]:[location: dd MBR]
bootloader:[microSD-(push-button)]:[/dev/mmcblk0]:[U-Boot 2019.04-g923f8b8]:[location: dd MBR]
nodejs:[v10.24.0]
pkg:[kmod]:[26-1]
cmdline:[console=ttyS0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet]
dmesg | grep remote
[   37.850836] Bluetooth: hci0: change remote baud rate command in firmware
dmesg | grep pru
[    0.945942] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[    1.395049] pinctrl-single 44e10800.pinmux: pin PIN30 already requested by 481a6000.serial; cannot claim for leds
[    1.405513] pinctrl-single 44e10800.pinmux: pin-30 (leds) status -22
[    1.411934] pinctrl-single 44e10800.pinmux: could not request pin 30 (PIN30) from group pinmux_bt_pins  on device pinctrl-single
[    0.958487] gpio-of-helper ocp:cape-universal: ready
lsusb
END
upgrade kernel bbb.io-kernel-4.19-ti-am335x
debian@beaglebone:~$ sudo apt install -y bbb.io-kernel-4.19-ti-am335x
The following additional packages will be installed:
  bbb.io-kernel-tasks libpruio-modules-4.19.94-ti-r73
  linux-image-4.19.94-ti-r73 rtl8723bu-modules-4.19.94-ti-r73
  rtl8821cu-modules-4.19.94-ti-r73 ti-sgx-ti335x-modules-4.19.94-ti-r73
  bbb.io-kernel-4.19-ti-am335x bbb.io-kernel-tasks
  libpruio-modules-4.19.94-ti-r73 linux-image-4.19.94-ti-r73
  rtl8723bu-modules-4.19.94-ti-r73 rtl8821cu-modules-4.19.94-ti-r73
0 upgraded, 7 newly installed, 0 to remove and 1 not upgraded.
Need to get 34.1 MB of archives.
After this operation, 80.4 MB of additional disk space will be used.
Get:1 http://repos.rcn-ee.com/debian buster/main armhf linux-image-4.19.94-ti-r73 armhf 1buster [28.6 MB]
Get:2 http://repos.rcn-ee.com/debian buster/main armhf bbb.io-kernel-tasks armhf 1.20221109.0-0~buster+20221109 [1,156 B]
Get:3 http://repos.rcn-ee.com/debian buster/main armhf bbb.io-kernel-4.19-ti-am335x armhf 1.20221109.0-0~buster+20221109 [1,264 B]
Get:4 http://repos.rcn-ee.com/debian buster/main armhf libpruio-modules-4.19.94-ti-r73 armhf 1buster [6,060 B]
Get:5 http://repos.rcn-ee.com/debian buster/main armhf rtl8723bu-modules-4.19.94-ti-r73 armhf 1buster [4,797 kB]
Get:6 http://repos.rcn-ee.com/debian buster/main armhf rtl8821cu-modules-4.19.94-ti-r73 armhf 1buster [558 kB]
Get:7 http://repos.rcn-ee.com/debian buster/main armhf ti-sgx-ti335x-modules-4.19.94-ti-r73 armhf 1buster [100 kB]
Fetched 34.1 MB in 7s (4,650 kB/s)
Overlays in new location: boot/dtbs/4.19.94-ti-r73/overlays/
loading /boot/vmlinuz-4.19.94-ti-r73 ...
10170880 bytes read in 674 ms (14.4 MiB/s)
loading /boot/dtbs/4.19.94-ti-r73/am335x-bonegreen-wireless-uboot-univ.dtb ...
156238 bytes read in 73 ms (2 MiB/s)
uboot_overlays: loading /boot/dtbs/4.19.94-ti-r73/overlays/BB-ADC-00A0.dtbo ...
645 bytes read in 125 ms (4.9 KiB/s)
uboot_overlays: loading /boot/dtbs/4.19.94-ti-r73/overlays/BB-BONE-eMMC1-01-00A0.dtbo ...
1605 bytes read in 133 ms (11.7 KiB/s)
uboot_overlays: loading /boot/dtbs/4.19.94-ti-r73/overlays/BB-BBGW-WL1835-00A0.dtbo ...
5089 bytes read in 128 ms (38.1 KiB/s)
loading /boot/initrd.img-4.19.94-ti-r73 ...
7071609 bytes read in 481 ms (14 MiB/s)
64 bytes from den08s05-in-f4.1e100.net (142.250.69.228): icmp_seq=1 ttl=58 time=43.1 ms
64 bytes from den08s05-in-f4.1e100.net (142.250.69.228): icmp_seq=2 ttl=58 time=43.3 ms
64 bytes from den08s05-in-f4.1e100.net (142.250.69.228): icmp_seq=3 ttl=58 time=42.9 ms
rtt min/avg/max/mdev = 42.887/43.095/43.326/0.247 ms
UBOOT: Loaded Overlay:[BB-ADC-00A0.kernel]
UBOOT: Loaded Overlay:[BB-BBGW-WL1835-00A0.kernel]
UBOOT: Loaded Overlay:[BB-BONE-eMMC1-01-00A0.kernel]
UBOOT: Loaded Overlay:[wl1835_bt]
kernel:[4.19.94-ti-r73]
nodejs:[v10.24.0]
pkg:[kmod]:[26-1]
dmesg | grep remote
[   47.560422] remoteproc remoteproc0: wkup_m3 is available
[   47.648523] remoteproc remoteproc0: powering up wkup_m3
[   47.648558] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217148
[   47.648844] remoteproc remoteproc0: remote processor wkup_m3 is now up
[   50.652063] remoteproc remoteproc1: 4a334000.pru is available
[   50.677030] remoteproc remoteproc2: 4a338000.pru is available
dmesg | grep pru
[   50.652273] pru-rproc 4a334000.pru: PRU rproc node pru@4a334000 probed successfully
[   50.677193] pru-rproc 4a338000.pru: PRU rproc node pru@4a338000 probed successfully
[    0.950521] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[    0.963067] gpio-of-helper ocp:cape-universal: ready
lsusb
END
Upgrade to 5.10.x-ti
debian@beaglebone:~$ sudo apt remove bbb.io-kernel-4.19-ti-am335x
debian@beaglebone:~$ sudo apt install -y bbb.io-kernel-5.10-ti-am335x
… idk, wifi works…
64 bytes from den08s05-in-f4.1e100.net (142.250.69.228): icmp_seq=1 ttl=58 time=46.2 ms
64 bytes from den08s05-in-f4.1e100.net (142.250.69.228): icmp_seq=2 ttl=58 time=44.5 ms
64 bytes from den08s05-in-f4.1e100.net (142.250.69.228): icmp_seq=3 ttl=58 time=46.9 ms
3 packets transmitted, 3 received, 0% packet loss, time 6ms
rtt min/avg/max/mdev = 44.525/45.882/46.929/1.005 ms
nodejs:[v10.24.0]
pkg:[kmod]:[26-1]
dmesg | grep remote
[    9.474160] remoteproc remoteproc0: wkup_m3 is available
[   36.319904] remoteproc remoteproc0: powering up wkup_m3
[   36.319944] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217148
[   36.320249] remoteproc remoteproc0: remote processor wkup_m3 is now up
[   51.334175] Bluetooth: hci0: change remote baud rate command in firmware
[   66.973400] remoteproc remoteproc1: 4a334000.pru is available
[   67.021865] remoteproc remoteproc2: 4a338000.pru is available
dmesg | grep pru
[    0.175710] platform 4a326004.pruss-soc-bus: Cannot lookup hwmod 'pruss'
[    9.087479] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[    9.088952] gpio-of-helper ocp:cape-universal: Failed to get gpio property of 'P8_03'
[    9.088981] gpio-of-helper ocp:cape-universal: Failed to create gpio entry
[    9.677007] gpio-of-helper ocp:cape-universal: Allocated GPIO id=0 name='P8_03'
[    9.677227] gpio-of-helper ocp:cape-universal: Allocated GPIO id=1 name='P8_04'
[    9.677396] gpio-of-helper ocp:cape-universal: Allocated GPIO id=2 name='P8_05'
[    9.677568] gpio-of-helper ocp:cape-universal: Allocated GPIO id=3 name='P8_06'
[    9.678033] gpio-of-helper ocp:cape-universal: Allocated GPIO id=4 name='P8_07'
[    9.678224] gpio-of-helper ocp:cape-universal: Allocated GPIO id=5 name='P8_08'
[    9.678406] gpio-of-helper ocp:cape-universal: Allocated GPIO id=6 name='P8_09'
[    9.678586] gpio-of-helper ocp:cape-universal: Allocated GPIO id=7 name='P8_10'
[    9.678882] gpio-of-helper ocp:cape-universal: Allocated GPIO id=8 name='P8_11'
[    9.679057] gpio-of-helper ocp:cape-universal: Allocated GPIO id=9 name='P8_12'
[    9.679318] gpio-of-helper ocp:cape-universal: Allocated GPIO id=10 name='P8_13'
[    9.679500] gpio-of-helper ocp:cape-universal: Allocated GPIO id=11 name='P8_15'
[    9.679659] gpio-of-helper ocp:cape-universal: Allocated GPIO id=12 name='P8_16'
[    9.679833] gpio-of-helper ocp:cape-universal: Allocated GPIO id=13 name='P8_18'
[    9.680019] gpio-of-helper ocp:cape-universal: Allocated GPIO id=14 name='P8_19'
[    9.680179] gpio-of-helper ocp:cape-universal: Allocated GPIO id=15 name='P8_20'
[    9.680359] gpio-of-helper ocp:cape-universal: Allocated GPIO id=16 name='P8_21'
[    9.680515] gpio-of-helper ocp:cape-universal: Allocated GPIO id=17 name='P8_22'
[    9.680682] gpio-of-helper ocp:cape-universal: Allocated GPIO id=18 name='P8_23'
[    9.680862] gpio-of-helper ocp:cape-universal: Allocated GPIO id=19 name='P8_24'
[    9.681020] gpio-of-helper ocp:cape-universal: Allocated GPIO id=20 name='P8_25'
[    9.681187] gpio-of-helper ocp:cape-universal: Allocated GPIO id=21 name='P8_27'
[    9.681351] gpio-of-helper ocp:cape-universal: Allocated GPIO id=22 name='P8_28'
[    9.681522] gpio-of-helper ocp:cape-universal: Allocated GPIO id=23 name='P8_29'
[    9.681688] gpio-of-helper ocp:cape-universal: Allocated GPIO id=24 name='P8_30'
[    9.681888] gpio-of-helper ocp:cape-universal: Allocated GPIO id=25 name='P8_31'
[    9.682070] gpio-of-helper ocp:cape-universal: Allocated GPIO id=26 name='P8_32'
[    9.682234] gpio-of-helper ocp:cape-universal: Allocated GPIO id=27 name='P8_33'
[    9.682403] gpio-of-helper ocp:cape-universal: Allocated GPIO id=28 name='P8_34'
[    9.682575] gpio-of-helper ocp:cape-universal: Allocated GPIO id=29 name='P8_35'
[    9.682833] gpio-of-helper ocp:cape-universal: Allocated GPIO id=30 name='P8_36'
[    9.683023] gpio-of-helper ocp:cape-universal: Allocated GPIO id=31 name='P8_37'
[    9.683181] gpio-of-helper ocp:cape-universal: Allocated GPIO id=32 name='P8_38'
[    9.683353] gpio-of-helper ocp:cape-universal: Allocated GPIO id=33 name='P8_39'
[    9.683531] gpio-of-helper ocp:cape-universal: Allocated GPIO id=34 name='P8_40'
[    9.683690] gpio-of-helper ocp:cape-universal: Allocated GPIO id=35 name='P8_41'
[    9.683866] gpio-of-helper ocp:cape-universal: Allocated GPIO id=36 name='P8_42'
[    9.684035] gpio-of-helper ocp:cape-universal: Allocated GPIO id=37 name='P8_43'
[    9.684199] gpio-of-helper ocp:cape-universal: Allocated GPIO id=38 name='P8_44'
[    9.684367] gpio-of-helper ocp:cape-universal: Allocated GPIO id=39 name='P8_45'
[    9.684524] gpio-of-helper ocp:cape-universal: Allocated GPIO id=40 name='P8_46'
[    9.684695] gpio-of-helper ocp:cape-universal: Allocated GPIO id=41 name='P9_11'
[    9.684870] gpio-of-helper ocp:cape-universal: Allocated GPIO id=42 name='P9_12'
[    9.685056] gpio-of-helper ocp:cape-universal: Allocated GPIO id=43 name='P9_13'
[    9.685226] gpio-of-helper ocp:cape-universal: Allocated GPIO id=44 name='P9_14'
[    9.685386] gpio-of-helper ocp:cape-universal: Allocated GPIO id=45 name='P9_15'
[    9.685568] gpio-of-helper ocp:cape-universal: Allocated GPIO id=46 name='P9_16'
[    9.685735] gpio-of-helper ocp:cape-universal: Allocated GPIO id=47 name='P9_17'
[    9.685893] gpio-of-helper ocp:cape-universal: Allocated GPIO id=48 name='P9_18'
[    9.686066] gpio-of-helper ocp:cape-universal: Allocated GPIO id=49 name='P9_19'
[    9.686222] gpio-of-helper ocp:cape-universal: Allocated GPIO id=50 name='P9_20'
[    9.686389] gpio-of-helper ocp:cape-universal: Allocated GPIO id=51 name='P9_21'
[    9.686555] gpio-of-helper ocp:cape-universal: Allocated GPIO id=52 name='P9_22'
[    9.686826] gpio-of-helper ocp:cape-universal: Allocated GPIO id=53 name='P9_23'
[    9.687023] gpio-of-helper ocp:cape-universal: Allocated GPIO id=54 name='P9_24'
[    9.687501] gpio-of-helper ocp:cape-universal: Allocated GPIO id=55 name='P9_25'
[    9.687694] gpio-of-helper ocp:cape-universal: Allocated GPIO id=56 name='P9_26'
[    9.687894] gpio-of-helper ocp:cape-universal: Allocated GPIO id=57 name='P9_27'
[    9.688057] gpio-of-helper ocp:cape-universal: Allocated GPIO id=58 name='P9_28'
[    9.688234] gpio-of-helper ocp:cape-universal: Allocated GPIO id=59 name='P9_29'
[    9.688402] gpio-of-helper ocp:cape-universal: Allocated GPIO id=60 name='P9_31'
[    9.688560] gpio-of-helper ocp:cape-universal: Allocated GPIO id=61 name='P9_41'
[    9.688746] gpio-of-helper ocp:cape-universal: Allocated GPIO id=62 name='P9_91'
[    9.688903] gpio-of-helper ocp:cape-universal: Allocated GPIO id=63 name='P9_42'
[    9.689075] gpio-of-helper ocp:cape-universal: Allocated GPIO id=64 name='P9_92'
[    9.689087] gpio-of-helper ocp:cape-universal: ready
lsusb
END
yeah… please share your full boot log when it failed…
ugh, just noticed this is a Buster → Bullseye upgrade in the middle of this mess..
I just thought this was a Buster just apt-upgrade… That’s going to be more painful to debug, and don’t want to waste my personal time on that..
Buster /etc/apt/sources.list
debian@beaglebone:~$ cat /etc/apt/sources.list
deb http://deb.debian.org/debian buster main contrib non-free
#deb-src http://deb.debian.org/debian buster main contrib non-free
deb http://deb.debian.org/debian buster-updates main contrib non-free
#deb-src http://deb.debian.org/debian buster-updates main contrib non-free
deb http://deb.debian.org/debian-security buster/updates main contrib non-free
#deb-src http://deb.debian.org/debian-security buster/updates main contrib non-free
#Kernel source (repos.rcn-ee.com) : https://github.com/RobertCNelson/linux-stable-rcn-ee
#git clone https://github.com/RobertCNelson/linux-stable-rcn-ee
#cd ./linux-stable-rcn-ee
#git checkout `uname -r` -b tmp
deb [arch=armhf] http://repos.rcn-ee.com/debian/ buster main
#deb-src [arch=armhf] http://repos.rcn-ee.com/debian/ buster main
Bullseye /etc/apt/sources.list
deb http://deb.debian.org/debian bullseye main contrib non-free
#deb-src http://deb.debian.org/debian bullseye main contrib non-free
deb http://security.debian.org/debian-security bullseye-security main contrib non-free
#deb-src http://security.debian.org/debian-security bullseye-security main contrib non-free
deb http://deb.debian.org/debian bullseye-updates main contrib non-free
#deb-src http://deb.debian.org/debian bullseye-updates main contrib non-free
deb [arch=armhf] http://repos.rcn-ee.com/debian/ bullseye main
#deb-src [arch=armhf] http://repos.rcn-ee.com/debian/ bullseye main
Bullseye Upgrade
debian@beaglebone:~$ sudo apt list --upgradable
Listing... Done
alsa-utils/stable 1.2.4-1 armhf [upgradable from: 1.1.8-2]
apt-utils/stable 2.2.4 armhf [upgradable from: 1.8.2.3]
apt/stable 2.2.4 armhf [upgradable from: 1.8.2.3]
autoconf/stable 2.69-14 all [upgradable from: 2.69-11]
automake/stable 1:1.16.3-2 all [upgradable from: 1:1.16.1-4]
autotools-dev/stable 20180224.1+nmu1 all [upgradable from: 20180224.1]
avahi-daemon/stable 0.8-5+deb11u1 armhf [upgradable from: 0.7-4+deb10u1]
avahi-utils/stable 0.8-5+deb11u1 armhf [upgradable from: 0.7-4+deb10u1]
base-files/stable 11.1+deb11u5 armhf [upgradable from: 10.3+deb10u13]
base-passwd/stable 3.5.51 armhf [upgradable from: 3.5.46]
bash-completion/stable 1:2.11-2 all [upgradable from: 1:2.8-6]
bash/stable 5.1-2+deb11u1 armhf [upgradable from: 5.0-4]
bb-node-red-installer/unknown 3.0.2.2-0~bullseye+20220810 armhf [upgradable from: 1.3.5-0rcnee2~buster+20210719]
bb-u-boot-am335x-evm/unknown 2022.04.20220602.1-0~bullseye+20220720 armhf [upgradable from: 2019.04.20211026.1-0~buster+20220102]
bc/stable 1.07.1-2+b2 armhf [upgradable from: 1.07.1-2+b1]
bind9-host/stable-security 1:9.16.33-1~deb11u1 armhf [upgradable from: 1:9.11.5.P4+dfsg-5.1+deb10u8]
binutils-arm-linux-gnueabihf/stable 2.35.2-2 armhf [upgradable from: 2.31.1-16]
binutils-common/stable 2.35.2-2 armhf [upgradable from: 2.31.1-16]
binutils/stable 2.35.2-2 armhf [upgradable from: 2.31.1-16]
bluetooth/stable 5.55-3.1 all [upgradable from: 5.50-1.2~deb10u3]
bluez/stable 5.55-3.1 armhf [upgradable from: 5.50-1.2~deb10u3]
bsdmainutils/stable 12.1.7+nmu3 armhf [upgradable from: 11.1.2+b1]
bsdutils/stable,stable-security 1:2.36.1-8+deb11u1 armhf [upgradable from: 1:2.33.1-0.1]
btrfs-progs/stable 5.10.1-2 armhf [upgradable from: 4.20.1-2]
build-essential/stable 12.9 armhf [upgradable from: 12.6]
bzip2/stable 1.0.8-4 armhf [upgradable from: 1.0.6-9.2~deb10u2]
ca-certificates/stable 20210119 all [upgradable from: 20200601~deb10u2]
can-utils/stable 2020.11.0-1 armhf [upgradable from: 2018.02.0-1]
cloud-guest-utils/unknown 0.33-1 all [upgradable from: 0.29-1]
connman/stable-security 1.36-2.2+deb11u1 armhf [upgradable from: 1.36-2.1~deb10u4]
coreutils/stable 8.32-4 armhf [upgradable from: 8.30-3]
cpio/stable 2.13+dfsg-4 armhf [upgradable from: 2.12+dfsg-9]
cpp/stable 4:10.2.1-1 armhf [upgradable from: 4:8.3.0-1]
cpufrequtils/stable 008-2 armhf [upgradable from: 008-1.1]
crda/stable 4.14+git20191112.9856751-1 armhf [upgradable from: 3.18-1]
cron/stable 3.0pl1-137 armhf [upgradable from: 3.0pl1-134+deb10u1]
curl/stable 7.74.0-1.3+deb11u3 armhf [upgradable from: 7.64.0-4+deb10u3]
dash/stable 0.5.11+git20200708+dd9ef66-5 armhf [upgradable from: 0.5.10.2-5]
dbus/stable-security 1.12.24-0+deb11u1 armhf [upgradable from: 1.12.24-0+deb10u1]
debconf-i18n/stable 1.5.77 all [upgradable from: 1.5.71+deb10u1]
debconf/stable 1.5.77 all [upgradable from: 1.5.71+deb10u1]
debian-archive-keyring/stable 2021.1.1 all [upgradable from: 2019.1+deb10u1]
debianutils/stable 4.11.2 armhf [upgradable from: 4.8.6.1]
device-tree-compiler/stable 1.6.0-1 armhf [upgradable from: 1.4.7-4]
dh-python/stable 4.20201102+nmu1 all [upgradable from: 3.20190308]
diffutils/stable 1:3.7-5 armhf [upgradable from: 1:3.7-3]
dirmngr/stable,stable-security 2.2.27-2+deb11u2 armhf [upgradable from: 2.2.12-1+deb10u2]
distro-info-data/stable 0.51+deb11u2 all [upgradable from: 0.41+deb10u6]
dmidecode/stable 3.3-2 armhf [upgradable from: 3.2-1]
dmsetup/stable 2:1.02.175-2.1 armhf [upgradable from: 2:1.02.155-3]
dnsmasq-base/stable 2.85-1 armhf [upgradable from: 2.80-1+deb10u1]
dnsmasq/stable 2.85-1 all [upgradable from: 2.80-1+deb10u1]
dosfstools/stable 4.2-1 armhf [upgradable from: 4.1-2]
dpkg-dev/stable 1.20.12 all [upgradable from: 1.19.8]
dpkg/stable 1.20.12 armhf [upgradable from: 1.19.8]
e2fsprogs/stable 1.46.2-2 armhf [upgradable from: 1.44.5-1+deb10u3]
fake-hwclock/stable 0.12 all [upgradable from: 0.11]
fdisk/stable,stable-security 2.36.1-8+deb11u1 armhf [upgradable from: 2.33.1-0.1]
file/stable 1:5.39-3 armhf [upgradable from: 1:5.35-4+deb10u2]
findutils/stable 4.8.0-1 armhf [upgradable from: 4.6.0+git+20190209-2]
firmware-atheros/stable 20210315-3 all [upgradable from: 20190717-2rcnee1~buster+20200305]
firmware-brcm80211/stable 20210315-3 all [upgradable from: 20190717-2rcnee1~buster+20200305]
firmware-iwlwifi/stable 20210315-3 all [upgradable from: 20190717-2rcnee1~buster+20200305]
firmware-libertas/stable 20210315-3 all [upgradable from: 20190717-2rcnee1~buster+20200305]
firmware-misc-nonfree/stable 20210315-3 all [upgradable from: 20190717-2rcnee1~buster+20200305]
firmware-realtek/stable 20210315-3 all [upgradable from: 20190717-2rcnee1~buster+20200305]
firmware-ti-connectivity/stable 20210315-3 all [upgradable from: 20190717-2rcnee1~buster+20200305]
firmware-zd1211/stable 1:1.5-7 all [upgradable from: 1:1.5-6]
fontconfig-config/stable 2.13.1-4.2 all [upgradable from: 2.13.1-2]
fonts-dejavu-core/stable 2.37-2 all [upgradable from: 2.37-1]
g++/stable 4:10.2.1-1 armhf [upgradable from: 4:8.3.0-1]
gcc/stable 4:10.2.1-1 armhf [upgradable from: 4:8.3.0-1]
gdbm-l10n/stable 1.19-2 all [upgradable from: 1.18.1-4]
git-man/stable 1:2.30.2-1 all [upgradable from: 1:2.20.1-2+deb10u4]
git/stable 1:2.30.2-1 armhf [upgradable from: 1:2.20.1-2+deb10u4]
gnupg-l10n/stable,stable-security 2.2.27-2+deb11u2 all [upgradable from: 2.2.12-1+deb10u2]
gnupg-utils/stable,stable-security 2.2.27-2+deb11u2 armhf [upgradable from: 2.2.12-1+deb10u2]
gnupg/stable,stable-security 2.2.27-2+deb11u2 all [upgradable from: 2.2.12-1+deb10u2]
gpg-agent/stable,stable-security 2.2.27-2+deb11u2 armhf [upgradable from: 2.2.12-1+deb10u2]
gpg-wks-client/stable,stable-security 2.2.27-2+deb11u2 armhf [upgradable from: 2.2.12-1+deb10u2]
gpg-wks-server/stable,stable-security 2.2.27-2+deb11u2 armhf [upgradable from: 2.2.12-1+deb10u2]
gpg/stable,stable-security 2.2.27-2+deb11u2 armhf [upgradable from: 2.2.12-1+deb10u2]
gpgconf/stable,stable-security 2.2.27-2+deb11u2 armhf [upgradable from: 2.2.12-1+deb10u2]
gpgsm/stable,stable-security 2.2.27-2+deb11u2 armhf [upgradable from: 2.2.12-1+deb10u2]
gpgv/stable,stable-security 2.2.27-2+deb11u2 armhf [upgradable from: 2.2.12-1+deb10u2]
gpiod/stable 1.6.2-1 armhf [upgradable from: 1.4.1-2rcnee3~buster+20190906]
grep/stable 3.6-1 armhf [upgradable from: 3.3-1]
groff-base/stable 1.22.4-6 armhf [upgradable from: 1.22.4-3+deb10u1]
gyp/stable 0.1+20200513gitcaa6002-2 all [upgradable from: 0.1+20180428git4d467626-3]
gzip/stable,stable-security 1.10-4+deb11u1 armhf [upgradable from: 1.9-3+deb10u1]
haveged/stable 1.9.14-1 armhf [upgradable from: 1.9.1-7]
hexedit/stable 1.5-2 armhf [upgradable from: 1.4.2-5]
hostapd/unknown 2:2.9.0-23rcnee1~bullseye+20211119 armhf [upgradable from: 2:2.7+git20190128+0c1e29f-6+deb10u3]
hostname/stable 3.23 armhf [upgradable from: 3.21]
htop/stable 3.0.5-7 armhf [upgradable from: 2.2.0-1+b1]
i2c-tools/stable 4.2-1+b1 armhf [upgradable from: 4.1-1]
ifupdown/stable 0.8.36 armhf [upgradable from: 0.8.35]
init-system-helpers/stable 1.60 all [upgradable from: 1.56+nmu1]
init/stable 1.60 armhf [upgradable from: 1.56+nmu1]
initramfs-tools-core/stable 0.140 all [upgradable from: 0.133+deb10u1]
initramfs-tools/stable 0.140 all [upgradable from: 0.133+deb10u1]
iperf/stable 2.0.14a+dfsg1-1 armhf [upgradable from: 2.0.12+dfsg1-2]
iproute2/stable 5.10.0-4 armhf [upgradable from: 4.20.0-2+deb10u1]
iptables/stable 1.8.7-1 armhf [upgradable from: 1.8.2-4]
iputils-ping/stable 3:20210202-1 armhf [upgradable from: 3:20180629-2+deb10u2]
isc-dhcp-client/stable-security 4.4.1-2.3+deb11u1 armhf [upgradable from: 4.4.1-2+deb10u2]
isc-dhcp-common/stable-security 4.4.1-2.3+deb11u1 armhf [upgradable from: 4.4.1-2+deb10u2]
iw/stable 5.9-3 armhf [upgradable from: 5.0.1-1]
javascript-common/stable 11+nmu1 all [upgradable from: 11]
klibc-utils/stable 2.0.8-6.1 armhf [upgradable from: 2.0.6-1+deb10u1]
kmod/stable 28-1 armhf [upgradable from: 26-1]
less/stable 551-2 armhf [upgradable from: 487-0.1+b1]
libacl1/stable 2.2.53-10 armhf [upgradable from: 2.2.53-4]
libapparmor1/stable 2.13.6-10 armhf [upgradable from: 2.13.2-10]
libasan5/stable 9.3.0-22 armhf [upgradable from: 8.3.0-6]
libasound2-data/stable 1.2.4-1.1 all [upgradable from: 1.1.8-1]
libasound2/stable 1.2.4-1.1 armhf [upgradable from: 1.1.8-1]
libassuan0/stable 2.5.3-7.1 armhf [upgradable from: 2.5.2-1]
libatomic1/stable 10.2.1-6 armhf [upgradable from: 8.3.0-6]
libattr1/stable 1:2.4.48-6 armhf [upgradable from: 1:2.4.48-4]
libaudit-common/stable 1:3.0-2 all [upgradable from: 1:2.8.4-3]
libaudit1/stable 1:3.0-2 armhf [upgradable from: 1:2.8.4-3]
libavahi-client3/stable 0.8-5+deb11u1 armhf [upgradable from: 0.7-4+deb10u1]
libavahi-common-data/stable 0.8-5+deb11u1 armhf [upgradable from: 0.7-4+deb10u1]
libavahi-common3/stable 0.8-5+deb11u1 armhf [upgradable from: 0.7-4+deb10u1]
libavahi-core7/stable 0.8-5+deb11u1 armhf [upgradable from: 0.7-4+deb10u1]
libbind9-161/stable 1:9.11.19+dfsg-2.1 armhf [upgradable from: 1:9.11.5.P4+dfsg-5.1+deb10u8]
libbinutils/stable 2.35.2-2 armhf [upgradable from: 2.31.1-16]
libblas3/stable 3.9.0-3 armhf [upgradable from: 3.8.0-2]
libblkid1/stable,stable-security 2.36.1-8+deb11u1 armhf [upgradable from: 2.33.1-0.1]
libbluetooth3/stable 5.55-3.1 armhf [upgradable from: 5.50-1.2~deb10u3]
libbrotli1/stable 1.0.9-2+b2 armhf [upgradable from: 1.0.7-2+deb10u1]
libbsd0/stable 0.11.3-1 armhf [upgradable from: 0.9.1-2+deb10u1]
libbz2-1.0/stable 1.0.8-4 armhf [upgradable from: 1.0.6-9.2~deb10u2]
libc-ares2/stable,stable-security 1.17.1-1+deb11u1 armhf [upgradable from: 1.14.0-1+deb10u1]
libc-bin/stable-updates 2.31-13+deb11u5 armhf [upgradable from: 2.28-10+deb10u2]
libc-dev-bin/stable-updates 2.31-13+deb11u5 armhf [upgradable from: 2.28-10+deb10u2]
libc-l10n/stable-updates 2.31-13+deb11u5 all [upgradable from: 2.28-10+deb10u2]
libc6-dev/stable-updates 2.31-13+deb11u5 armhf [upgradable from: 2.28-10+deb10u2]
libc6/stable-updates 2.31-13+deb11u5 armhf [upgradable from: 2.28-10+deb10u2]
libcap-ng0/stable 0.7.9-2.2+b1 armhf [upgradable from: 0.7.9-2]
libcap2-bin/stable 1:2.44-1 armhf [upgradable from: 1:2.25-2]
libcap2/stable 1:2.44-1 armhf [upgradable from: 1:2.25-2]
libcc1-0/stable 10.2.1-6 armhf [upgradable from: 8.3.0-6]
libcom-err2/stable 1.46.2-2 armhf [upgradable from: 1.44.5-1+deb10u3]
libcpufreq0/stable 008-2 armhf [upgradable from: 008-1.1]
libcpupower1/stable-security 5.10.149-2 armhf [upgradable from: 4.19.260-1]
libcryptsetup12/stable,stable-security 2:2.3.7-1+deb11u1 armhf [upgradable from: 2:2.1.0-5+deb10u2]
libcurl3-gnutls/stable 7.74.0-1.3+deb11u3 armhf [upgradable from: 7.64.0-4+deb10u3]
libcurl4/stable 7.74.0-1.3+deb11u3 armhf [upgradable from: 7.64.0-4+deb10u3]
libdaemon0/stable 0.14-7.1 armhf [upgradable from: 0.14-7]
libdb5.3/stable 5.3.28+dfsg1-0.8 armhf [upgradable from: 5.3.28+dfsg1-0.5]
libdbus-1-3/stable-security 1.12.24-0+deb11u1 armhf [upgradable from: 1.12.24-0+deb10u1]
libdbus-1-dev/stable-security 1.12.24-0+deb11u1 armhf [upgradable from: 1.12.24-0+deb10u1]
libdebconfclient0/stable 0.260 armhf [upgradable from: 0.249]
libdevmapper1.02.1/stable 2:1.02.175-2.1 armhf [upgradable from: 2:1.02.155-3]
libdpkg-perl/stable 1.20.12 all [upgradable from: 1.19.8]
libdw1/stable 0.183-1 armhf [upgradable from: 0.176-1.1]
libedit2/stable 3.1-20191231-2+b1 armhf [upgradable from: 3.1-20181209-1]
libelf1/stable 0.183-1 armhf [upgradable from: 0.176-1.1]
liberror-perl/stable 0.17029-1 all [upgradable from: 0.17027-2]
libestr0/stable 0.1.10-2.1+b1 armhf [upgradable from: 0.1.10-2.1]
libexpat1-dev/stable-security 2.2.10-2+deb11u5 armhf [upgradable from: 2.2.6-2+deb10u6]
libexpat1/stable-security 2.2.10-2+deb11u5 armhf [upgradable from: 2.2.6-2+deb10u6]
libext2fs2/stable 1.46.2-2 armhf [upgradable from: 1.44.5-1+deb10u3]
libfastjson4/stable 0.99.9-1 armhf [upgradable from: 0.99.8-2]
libfdisk1/stable,stable-security 2.36.1-8+deb11u1 armhf [upgradable from: 2.33.1-0.1]
libfontconfig1/stable 2.13.1-4.2 armhf [upgradable from: 2.13.1-2]
libfreetype6/stable 2.10.4+dfsg-1+deb11u1 armhf [upgradable from: 2.9.1-3+deb10u3]
libfstrm0/stable 0.6.0-1+b1 armhf [upgradable from: 0.4.0-1]
libgcrypt20/stable 1.8.7-6 armhf [upgradable from: 1.8.4-5+deb10u1]
libgd3/stable 2.3.0-2 armhf [upgradable from: 2.2.5-5.2]
libgdbm-compat4/stable 1.19-2 armhf [upgradable from: 1.18.1-4]
libgdbm6/stable 1.19-2 armhf [upgradable from: 1.18.1-4]
libgeoip1/stable 1.6.12-7 armhf [upgradable from: 1.6.12-1]
libgfortran5/stable 10.2.1-6 armhf [upgradable from: 8.3.0-6]
libglib2.0-0/stable 2.66.8-1 armhf [upgradable from: 2.58.3-2+deb10u4]
libgmp10/stable 2:6.2.1+dfsg-1+deb11u1 armhf [upgradable from: 2:6.1.2+dfsg-4+deb10u1]
libgnutls30/stable,stable-security 3.7.1-5+deb11u2 armhf [upgradable from: 3.6.7-4+deb10u9]
libgomp1/stable 10.2.1-6 armhf [upgradable from: 8.3.0-6]
libgpg-error0/stable 1.38-2 armhf [upgradable from: 1.35-1]
libgpiod2/stable 1.6.2-1 armhf [upgradable from: 1.4.1-2rcnee3~buster+20190906]
libgpm2/stable 1.20.7-8 armhf [upgradable from: 1.20.7-5]
libgssapi-krb5-2/stable 1.18.3-6+deb11u2 armhf [upgradable from: 1.17-3+deb10u4]
libi2c0/stable 4.2-1+b1 armhf [upgradable from: 4.1-1]
libidn11/stable 1.33-3 armhf [upgradable from: 1.33-2.2]
libidn2-0/stable 2.3.0-5 armhf [upgradable from: 2.0.5-1+deb10u1]
libiio-utils/unknown 0.24-1bbbio0~bullseye+20220720 armhf [upgradable from: 0.19-1rcnee0~buster+20200303]
libiio0/unknown 0.24-1bbbio0~bullseye+20220720 armhf [upgradable from: 0.19-1rcnee0~buster+20200303]
libinline-files-perl/stable 0.71-1 all [upgradable from: 0.68-1]
libio-pty-perl/stable 1:1.15-2 armhf [upgradable from: 1:1.08-1.1+b5]
libipc-run-perl/stable 20200505.0-1 all [upgradable from: 20180523.0-1]
libiptc0/stable 1.8.7-1 armhf [upgradable from: 1.8.2-4]
libisccc161/stable 1:9.11.19+dfsg-2.1 armhf [upgradable from: 1:9.11.5.P4+dfsg-5.1+deb10u8]
libisccfg163/stable 1:9.11.19+dfsg-2.1 armhf [upgradable from: 1:9.11.5.P4+dfsg-5.1+deb10u8]
libiw30/stable 30~pre9-13.1 armhf [upgradable from: 30~pre9-13]
libjpeg62-turbo/stable 1:2.0.6-4 armhf [upgradable from: 1:1.5.2-2+deb10u1]
libjs-inherits/stable 2.0.4-1 all [upgradable from: 2.0.3-1]
libjs-is-typedarray/stable 1.0.0-3 all [upgradable from: 1.0.0-2]
libjs-jquery/stable 3.5.1+dfsg+~3.5.5-7 all [upgradable from: 3.3.1~dfsg-3+deb10u1]
libk5crypto3/stable 1.18.3-6+deb11u2 armhf [upgradable from: 1.17-3+deb10u4]
libkeyutils1/stable 1.6.1-2 armhf [upgradable from: 1.6-6]
libklibc/stable 2.0.8-6.1 armhf [upgradable from: 2.0.6-1+deb10u1]
libkmod2/stable 28-1 armhf [upgradable from: 26-1]
libkrb5-3/stable 1.18.3-6+deb11u2 armhf [upgradable from: 1.17-3+deb10u4]
libkrb5support0/stable 1.18.3-6+deb11u2 armhf [upgradable from: 1.17-3+deb10u4]
libksba8/stable-security 1.5.0-3+deb11u1 armhf [upgradable from: 1.3.5-2+deb10u1]
liblapack3/stable 3.9.0-3 armhf [upgradable from: 3.8.0-2]
libldap-2.4-2/stable,stable-security 2.4.57+dfsg-3+deb11u1 armhf [upgradable from: 2.4.47+dfsg-3+deb10u7]
libldap-common/stable,stable-security 2.4.57+dfsg-3+deb11u1 all [upgradable from: 2.4.47+dfsg-3+deb10u7]
liblmdb0/stable 0.9.24-1 armhf [upgradable from: 0.9.22-1]
liblocale-gettext-perl/stable 1.07-4+b1 armhf [upgradable from: 1.07-3+b4]
liblognorm5/stable 2.0.5-1.1 armhf [upgradable from: 2.0.5-1]
liblwres161/stable 1:9.11.19+dfsg-2.1 armhf [upgradable from: 1:9.11.5.P4+dfsg-5.1+deb10u8]
liblz4-1/stable 1.9.3-2 armhf [upgradable from: 1.8.3-1+deb10u1]
liblzma5/stable,stable-security 5.2.5-2.1~deb11u1 armhf [upgradable from: 5.2.4-1+deb10u1]
liblzo2-2/stable 2.10-2 armhf [upgradable from: 2.10-0.1]
libmagic-mgc/stable 1:5.39-3 armhf [upgradable from: 1:5.35-4+deb10u2]
libmagic1/stable 1:5.39-3 armhf [upgradable from: 1:5.35-4+deb10u2]
libmnl0/stable 1.0.4-3 armhf [upgradable from: 1.0.4-2]
libmount1/stable,stable-security 2.36.1-8+deb11u1 armhf [upgradable from: 2.33.1-0.1]
libmpc3/stable 1.2.0-1 armhf [upgradable from: 1.1.0-1]
libmpfr6/stable 4.1.0-3 armhf [upgradable from: 4.0.2-1]
libncurses-dev/stable 6.2+20201114-2 armhf [upgradable from: 6.1+20181013-2+deb10u3]
libncurses5-dev/stable 6.2+20201114-2 armhf [upgradable from: 6.1+20181013-2+deb10u3]
libncurses6/stable 6.2+20201114-2 armhf [upgradable from: 6.1+20181013-2+deb10u3]
libncursesw6/stable 6.2+20201114-2 armhf [upgradable from: 6.1+20181013-2+deb10u3]
libnetfilter-conntrack3/stable 1.0.8-3 armhf [upgradable from: 1.0.7-1]
libnewt0.52/stable 0.52.21-4+b3 armhf [upgradable from: 0.52.20-8]
libnftnl11/stable 1.1.9-1 armhf [upgradable from: 1.1.2-2]
libnghttp2-14/stable 1.43.0-1 armhf [upgradable from: 1.36.0-2+deb10u1]
libnginx-mod-http-auth-pam/stable-security 1.18.0-6.1+deb11u3 armhf [upgradable from: 1.14.2-2+deb10u4]
libnginx-mod-http-dav-ext/stable-security 1.18.0-6.1+deb11u3 armhf [upgradable from: 1.14.2-2+deb10u4]
libnginx-mod-http-echo/stable-security 1.18.0-6.1+deb11u3 armhf [upgradable from: 1.14.2-2+deb10u4]
libnginx-mod-http-geoip/stable-security 1.18.0-6.1+deb11u3 armhf [upgradable from: 1.14.2-2+deb10u4]
libnginx-mod-http-image-filter/stable-security 1.18.0-6.1+deb11u3 armhf [upgradable from: 1.14.2-2+deb10u4]
libnginx-mod-http-subs-filter/stable-security 1.18.0-6.1+deb11u3 armhf [upgradable from: 1.14.2-2+deb10u4]
libnginx-mod-http-upstream-fair/stable-security 1.18.0-6.1+deb11u3 armhf [upgradable from: 1.14.2-2+deb10u4]
libnginx-mod-http-xslt-filter/stable-security 1.18.0-6.1+deb11u3 armhf [upgradable from: 1.14.2-2+deb10u4]
libnginx-mod-mail/stable-security 1.18.0-6.1+deb11u3 armhf [upgradable from: 1.14.2-2+deb10u4]
libnginx-mod-stream/stable-security 1.18.0-6.1+deb11u3 armhf [upgradable from: 1.14.2-2+deb10u4]
libnl-3-200/stable 3.4.0-1+b1 armhf [upgradable from: 3.4.0-1]
libnl-genl-3-200/stable 3.4.0-1+b1 armhf [upgradable from: 3.4.0-1]
libnl-route-3-200/stable 3.4.0-1+b1 armhf [upgradable from: 3.4.0-1]
libnode-dev/stable-security 12.22.12~dfsg-1~deb11u1 armhf [upgradable from: 10.24.0~dfsg-1~deb10u2]
libnpth0/stable 1.6-3 armhf [upgradable from: 1.6-1]
libnss-mdns/stable 0.14.1-2 armhf [upgradable from: 0.14.1-1]
libnss-systemd/stable 247.3-7+deb11u1 armhf [upgradable from: 241-7~deb10u8rcnee0~buster+20211022]
libp11-kit0/stable 0.23.22-1 armhf [upgradable from: 0.23.15-2+deb10u1]
libpam-modules-bin/stable 1.4.0-9+deb11u1 armhf [upgradable from: 1.3.1-5]
libpam-modules/stable 1.4.0-9+deb11u1 armhf [upgradable from: 1.3.1-5]
libpam-runtime/stable 1.4.0-9+deb11u1 all [upgradable from: 1.3.1-5]
libpam-systemd/stable 247.3-7+deb11u1 armhf [upgradable from: 241-7~deb10u8rcnee0~buster+20211022]
libpam0g/stable 1.4.0-9+deb11u1 armhf [upgradable from: 1.3.1-5]
libpcap0.8/stable 1.10.0-2 armhf [upgradable from: 1.8.1-6+deb10u1]
libpci3/stable 1:3.7.0-5 armhf [upgradable from: 1:3.5.2-1]
libpcre2-8-0/stable 10.36-2+deb11u1 armhf [upgradable from: 10.32-5]
libpcre3/stable 2:8.39-13 armhf [upgradable from: 2:8.39-12]
libpcsclite1/stable 1.9.1-1 armhf [upgradable from: 1.8.24-1]
libpipeline1/stable 1.5.3-1 armhf [upgradable from: 1.5.1-2]
libpng16-16/stable 1.6.37-3 armhf [upgradable from: 1.6.36-6]
libpopt0/stable 1.18-2 armhf [upgradable from: 1.16-12]
libprotobuf-c1/stable 1.3.3-1+b2 armhf [upgradable from: 1.3.1-1+b1]
libpsl5/stable 0.21.0-1.2 armhf [upgradable from: 0.20.2-2]
libpython2-dev/stable 2.7.18-3 armhf [upgradable from: 2.7.16-1]
libpython2-stdlib/stable 2.7.18-3 armhf [upgradable from: 2.7.16-1]
libpython2.7-dev/stable 2.7.18-8 armhf [upgradable from: 2.7.16-2+deb10u1]
libpython2.7-minimal/stable 2.7.18-8 armhf [upgradable from: 2.7.16-2+deb10u1]
libpython2.7-stdlib/stable 2.7.18-8 armhf [upgradable from: 2.7.16-2+deb10u1]
libpython2.7/stable 2.7.18-8 armhf [upgradable from: 2.7.16-2+deb10u1]
libpython3-dev/stable 3.9.2-3 armhf [upgradable from: 3.7.3-1]
libpython3-stdlib/stable 3.9.2-3 armhf [upgradable from: 3.7.3-1]
librtmp1/stable 2.4+20151223.gitfa8646d.1-2+b2 armhf [upgradable from: 2.4+20151223.gitfa8646d.1-2]
libsamplerate0/stable 0.2.1+ds0-1 armhf [upgradable from: 0.1.9-2]
libsasl2-2/stable,stable-security 2.1.27+dfsg-2.1+deb11u1 armhf [upgradable from: 2.1.27+dfsg-1+deb10u2]
libsasl2-modules-db/stable,stable-security 2.1.27+dfsg-2.1+deb11u1 armhf [upgradable from: 2.1.27+dfsg-1+deb10u2]
libsbc1/stable 1.5-3 armhf [upgradable from: 1.4-1]
libseccomp2/stable 2.5.1-1+deb11u1 armhf [upgradable from: 2.3.3-4]
libselinux1/stable 3.1-3 armhf [upgradable from: 2.8-1+b1]
libsemanage-common/stable 3.1-1 all [upgradable from: 2.8-2]
libsemanage1/stable 3.1-1+b2 armhf [upgradable from: 2.8-2]
libsepol1/stable 3.1-1 armhf [upgradable from: 2.8-1]
libserialport0/stable 0.1.1-4 armhf [upgradable from: 0.1.1-3]
libsigsegv2/stable 2.13-1 armhf [upgradable from: 2.12-2]
libslang2/stable 2.3.2-5 armhf [upgradable from: 2.3.2-2]
libsmartcols1/stable,stable-security 2.36.1-8+deb11u1 armhf [upgradable from: 2.33.1-0.1]
libsqlite3-0/stable 3.34.1-3 armhf [upgradable from: 3.27.2-3+deb10u2]
libss2/stable 1.46.2-2 armhf [upgradable from: 1.44.5-1+deb10u3]
libssh2-1/stable 1.9.0-2 armhf [upgradable from: 1.8.0-2.1]
libssl-dev/stable,stable-security 1.1.1n-0+deb11u3 armhf [upgradable from: 1.1.1n-0+deb10u3]
libssl1.1/stable,stable-security 1.1.1n-0+deb11u3 armhf [upgradable from: 1.1.1n-0+deb10u3]
libstdc++6/stable 10.2.1-6 armhf [upgradable from: 8.3.0-6]
libsystemd0/stable 247.3-7+deb11u1 armhf [upgradable from: 241-7~deb10u8rcnee0~buster+20211022]
libtasn1-6/stable 4.16.0-2 armhf [upgradable from: 4.13-3]
libtext-charwidth-perl/stable 0.04-10+b1 armhf [upgradable from: 0.04-7.1+b1]
libtext-iconv-perl/stable 1.7-7+b1 armhf [upgradable from: 1.7-5+b7]
libtext-wrapi18n-perl/stable 0.06-9 all [upgradable from: 0.06-7.1]
libtiff5/stable,stable-security 4.2.0-1+deb11u1 armhf [upgradable from: 4.1.0+git191117-2~deb10u4]
libtinfo6/stable 6.2+20201114-2 armhf [upgradable from: 6.1+20181013-2+deb10u3]
libtool/stable 2.4.6-15 all [upgradable from: 2.4.6-9]
libubsan1/stable 10.2.1-6 armhf [upgradable from: 8.3.0-6]
libuchardet0/stable 0.0.7-1 armhf [upgradable from: 0.0.6-3]
libudev1/stable 247.3-7+deb11u1 armhf [upgradable from: 241-7~deb10u8rcnee0~buster+20211022]
libunistring2/stable 0.9.10-4 armhf [upgradable from: 0.9.10-1]
libusb-1.0-0-dev/stable 2:1.0.24-3 armhf [upgradable from: 2:1.0.22-2]
libusb-1.0-0/stable 2:1.0.24-3 armhf [upgradable from: 2:1.0.22-2]
libutempter0/stable 1.2.1-2 armhf [upgradable from: 1.1.6-3]
libuuid1/stable,stable-security 2.36.1-8+deb11u1 armhf [upgradable from: 2.33.1-0.1]
libuv1-dev/stable 1.40.0-2 armhf [upgradable from: 1.24.1-1+deb10u1]
libuv1/stable 1.40.0-2 armhf [upgradable from: 1.24.1-1+deb10u1]
libv4l-0/stable 1.20.0-2 armhf [upgradable from: 1.16.3-3]
libv4l2rds0/stable 1.20.0-2 armhf [upgradable from: 1.16.3-3]
libv4lconvert0/stable 1.20.0-2 armhf [upgradable from: 1.16.3-3]
libwebp6/stable 0.6.1-2.1 armhf [upgradable from: 0.6.1-2+deb10u1]
libwrap0/stable 7.6.q-31 armhf [upgradable from: 7.6.q-28]
libx11-6/stable 2:1.7.2-1 armhf [upgradable from: 2:1.6.7-1+deb10u2]
libx11-data/stable 2:1.7.2-1 all [upgradable from: 2:1.6.7-1+deb10u2]
libxau6/stable 1:1.0.9-1 armhf [upgradable from: 1:1.0.8-1+b2]
libxcb1/stable 1.14-3 armhf [upgradable from: 1.13.1-2]
libxext6/stable 2:1.3.3-1.1 armhf [upgradable from: 2:1.3.3-1+b2]
libxml2/stable-security 2.9.10+dfsg-6.7+deb11u3 armhf [upgradable from: 2.9.4+dfsg1-7+deb10u5]
libxslt1.1/stable,stable-security 1.1.34-4+deb11u1 armhf [upgradable from: 1.1.32-2.2~deb10u2]
libxtables12/stable 1.8.7-1 armhf [upgradable from: 1.8.2-4]
libzstd1/stable 1.4.8+dfsg-2.1 armhf [upgradable from: 1.3.8+dfsg-3+deb10u2]
linux-cpupower/stable-security 5.10.149-2 armhf [upgradable from: 4.19.260-1]
linux-libc-dev/stable-security 5.10.149-2 armhf [upgradable from: 4.19.260-1]
locales/stable-updates 2.31-13+deb11u5 all [upgradable from: 2.28-10+deb10u2]
login/stable 1:4.8.1-1 armhf [upgradable from: 1:4.5-1.1]
logrotate/stable 3.18.0-2+deb11u1 armhf [upgradable from: 3.14.0-4]
lsb-base/stable 11.1.0 all [upgradable from: 10.2019051400]
lsb-release/stable 11.1.0 all [upgradable from: 10.2019051400]
lsof/stable 4.93.2+dfsg-1.1 armhf [upgradable from: 4.91+dfsg-1]
lzma/stable 9.22-2.2 armhf [upgradable from: 9.22-2.1]
lzop/stable 1.04-2 armhf [upgradable from: 1.03-4+b1]
m4/stable 1.4.18-5 armhf [upgradable from: 1.4.18-2]
make/stable 4.3-4.1 armhf [upgradable from: 4.2.1-1.2]
man-db/stable 2.9.4-2 armhf [upgradable from: 2.8.5-2]
manpages-dev/stable 5.10-1 all [upgradable from: 4.16-2]
manpages/stable 5.10-1 all [upgradable from: 4.16-2]
mawk/stable 1.3.4.20200120-2 armhf [upgradable from: 1.3.3-17+b3]
mime-support/stable 3.66 all [upgradable from: 3.62]
moreutils/stable 0.65-1 armhf [upgradable from: 0.62-1]
mount/stable,stable-security 2.36.1-8+deb11u1 armhf [upgradable from: 2.33.1-0.1]
nano-tiny/stable 5.4-2+deb11u1 armhf [upgradable from: 3.2-3]
nano/stable 5.4-2+deb11u1 armhf [upgradable from: 3.2-3]
ncurses-base/stable 6.2+20201114-2 all [upgradable from: 6.1+20181013-2+deb10u3]
ncurses-bin/stable 6.2+20201114-2 armhf [upgradable from: 6.1+20181013-2+deb10u3]
net-tools/stable 1.60+git20181103.0eebece-1 armhf [upgradable from: 1.60+git20180626.aebd88e-1]
netbase/stable 6.3 all [upgradable from: 5.6]
nginx-common/stable-security 1.18.0-6.1+deb11u3 all [upgradable from: 1.14.2-2+deb10u4]
nginx-full/stable-security 1.18.0-6.1+deb11u3 armhf [upgradable from: 1.14.2-2+deb10u4]
nginx/stable-security 1.18.0-6.1+deb11u3 all [upgradable from: 1.14.2-2+deb10u4]
node-abbrev/stable 1.1.1-2 all [upgradable from: 1.1.1-1]
node-ajv/stable 6.12.6-2 all [upgradable from: 5.0.0-1]
node-ansi-align/stable 3.0.0-1 all [upgradable from: 2.0.0-1]
node-ansi-regex/stable 5.0.1-1~deb11u1 all [upgradable from: 3.0.0-1+deb10u1]
node-ansi-styles/stable 4.2.1-1 all [upgradable from: 3.2.1-1]
node-ansi/stable 0.3.1-1 all [upgradable from: 0.3.0-3]
node-ansistyles/stable 0.1.3-2 all [upgradable from: 0.1.3-1]
node-aproba/stable 2.0.0-1 all [upgradable from: 1.2.0-1]
node-archy/stable 1.0.0-3 all [upgradable from: 1.0.0-2]
node-are-we-there-yet/stable 1.1.5-1 all [upgradable from: 1.1.4-1]
node-asn1/stable 0.2.3-2 all [upgradable from: 0.2.3-1]
node-assert-plus/stable 1.0.0-2 all [upgradable from: 1.0.0-1]
node-asynckit/stable 0.4.0-3 all [upgradable from: 0.4.0-2]
node-aws-sign2/stable 0.7.1-2 all [upgradable from: 0.7.1-1]
node-aws4/stable 1.11.0-1 all [upgradable from: 1.8.0-1]
node-balanced-match/stable 1.0.0-1 all [upgradable from: 0.4.2-1]
node-bcrypt-pbkdf/stable 1.0.2-1 all [upgradable from: 1.0.1-1]
node-bluebird/stable 3.7.2+dfsg1-4 all [upgradable from: 3.5.1+dfsg2-2]
node-boxen/stable 4.2.0-3 all [upgradable from: 1.2.2-1]
node-brace-expansion/stable 2.0.0-1 all [upgradable from: 1.1.8-1]
node-builtin-modules/stable 3.1.0-1 all [upgradable from: 3.0.0-1]
node-builtins/stable 1.0.3-2 all [upgradable from: 1.0.3-1]
node-cacache/stable 15.0.5+~cs13.9.21-1 all [upgradable from: 11.3.2-2]
node-call-limit/stable 1.1.1-1 all [upgradable from: 1.1.0-1]
node-camelcase/stable 6.2.0-2 all [upgradable from: 5.0.0-1]
node-caseless/stable 0.12.1-1 all [upgradable from: 0.12.0-1]
node-chalk/stable 4.1.0-1 all [upgradable from: 2.3.0-2]
node-chownr/stable 1.1.3-5 all [upgradable from: 1.1.1-1]
node-cli-boxes/stable 2.2.1-1 all [upgradable from: 1.0.0-1]
node-cliui/stable 4.1.0-2 all [upgradable from: 4.1.0-1]
node-clone/stable 2.1.2-2 all [upgradable from: 2.1.2-1]
node-co/stable 4.6.0+~4.6.2-1 all [upgradable from: 4.6.0-1]
node-color-convert/stable 1.9.3-1 all [upgradable from: 1.9.0-3]
node-color-name/stable 1.1.4+~1.1.1-1 all [upgradable from: 1.1.3-1]
node-combined-stream/stable 1.0.8-1 all [upgradable from: 1.0.7-1]
node-concat-map/stable 0.0.1-2 all [upgradable from: 0.0.1-1]
node-concat-stream/stable 2.0.0-1 all [upgradable from: 1.6.2-1]
node-config-chain/stable 1.1.12-1 all [upgradable from: 1.1.11-1]
node-console-control-strings/stable 1.1.0-2 all [upgradable from: 1.1.0-1]
node-copy-concurrently/stable 1.0.5-7 all [upgradable from: 1.0.5-4]
node-core-util-is/stable 1.0.2-2 all [upgradable from: 1.0.2-1]
node-cyclist/stable 1.0.1-3 all [upgradable from: 1.0.1-2]
node-dashdash/stable 2.0.0-1 all [upgradable from: 1.14.1-2]
node-decamelize/stable 4.0.0-1 all [upgradable from: 1.2.0-1]
node-decompress-response/stable 6.0.0-1 all [upgradable from: 3.3.0-1]
node-deep-extend/stable 0.6.0-1 all [upgradable from: 0.4.1-2]
node-defaults/stable 1.0.3-2 all [upgradable from: 1.0.3-1]
node-delayed-stream/stable 1.0.0-4 all [upgradable from: 0.0.5-1]
node-delegates/stable 1.0.0-2 all [upgradable from: 1.0.0-1]
node-detect-indent/stable 6.0.0-1 all [upgradable from: 5.0.0-1]
node-detect-newline/stable 3.1.0-1 all [upgradable from: 2.1.0-1]
node-duplexer3/stable 0.1.4-5 all [upgradable from: 0.1.4-4]
node-duplexify/stable 4.1.1-1 all [upgradable from: 3.6.1-1]
node-ecc-jsbn/stable 0.2.0-2 all [upgradable from: 0.1.1-1]
node-editor/stable 1.0.0-2 all [upgradable from: 1.0.0-1]
node-encoding/stable 0.1.13-1 all [upgradable from: 0.1.12-2]
node-end-of-stream/stable 1.4.4-1 all [upgradable from: 1.4.1-1+deb10u1]
node-errno/stable 1.0.0-1 all [upgradable from: 0.1.4-1]
node-escape-string-regexp/stable 4.0.0-1 all [upgradable from: 1.0.5-1]
node-execa/stable 4.1.0+dfsg+~cs19.3.6-5 all [upgradable from: 0.10.0+dfsg-1]
node-extsprintf/stable 1.4.0-1 all [upgradable from: 1.3.0-1]
node-find-up/stable 5.0.0-1 all [upgradable from: 2.1.0-1]
node-flush-write-stream/stable 2.0.0-2 all [upgradable from: 1.0.3-1]
node-forever-agent/stable 0.6.1-2 all [upgradable from: 0.6.1-1]
node-form-data/stable 3.0.0-2 all [upgradable from: 2.3.2-2]
node-from2/stable 2.3.0-1.1 all [upgradable from: 2.3.0-1]
node-fs-vacuum/stable 1.2.10-5 all [upgradable from: 1.2.10-2]
node-fs.realpath/stable 1.0.0-1.1 all [upgradable from: 1.0.0-1]
node-gauge/stable 2.7.4-1.1 all [upgradable from: 2.7.4-1]
node-get-caller-file/stable 1.0.2-1.1 all [upgradable from: 1.0.2-1]
node-get-stream/stable 6.0.0-1 all [upgradable from: 3.0.0-1]
node-getpass/stable 0.1.7-1.1 all [upgradable from: 0.1.7-1]
node-glob/stable 7.1.6+~7.1.3-1 all [upgradable from: 7.1.3-2]
node-got/stable 11.8.1+~cs53.13.17-3+deb11u1 all [upgradable from: 7.1.0-1]
node-graceful-fs/stable 4.2.4+repack-1 all [upgradable from: 4.1.11-1]
node-gyp/stable 7.1.2-4 all [upgradable from: 3.8.0-6]
node-har-schema/stable 2.0.0-4 all [upgradable from: 2.0.0-1]
node-har-validator/stable 5.1.5-1 all [upgradable from: 5.1.0-1]
node-has-flag/stable 4.0.0-1 all [upgradable from: 2.0.0-1]
node-has-symbol-support-x/stable 1.4.1+dfsg-1.1 all [upgradable from: 1.4.1+dfsg-1]
node-has-to-string-tag-x/stable 1.4.1+dfsg-1.1 all [upgradable from: 1.4.1+dfsg-1]
node-hosted-git-info/stable 3.0.8-1 all [upgradable from: 2.7.1-1+deb10u1]
node-http-signature/stable 1.3.5-1 all [upgradable from: 1.2.0-1]
node-iconv-lite/stable 0.5.1-3 all [upgradable from: 0.4.13-2]
node-import-lazy/stable 4.0.0-1 all [upgradable from: 3.0.0.REALLY.2.1.0-1]
node-imurmurhash/stable 0.1.4-1.1 all [upgradable from: 0.1.4-1]
node-inflight/stable 1.0.6-1.1 all [upgradable from: 1.0.6-1]
node-inherits/stable 2.0.4-1 all [upgradable from: 2.0.3-1]
node-ini/stable 2.0.0-1 all [upgradable from: 1.3.5-1+deb10u1]
node-invert-kv/stable 3.0.1-1 all [upgradable from: 1.0.0-1]
node-is-builtin-module/stable 3.0.0-1 all [upgradable from: 2.0.0-1]
node-is-npm/stable 5.0.0-1 all [upgradable from: 1.0.0-1]
node-is-object/stable 1.0.2-1 all [upgradable from: 1.0.1-1]
node-is-plain-obj/stable 3.0.0-1 all [upgradable from: 1.1.0-1]
node-is-retry-allowed/stable 1.2.0-1 all [upgradable from: 1.1.0-1]
node-is-stream/stable 2.0.0-1 all [upgradable from: 1.1.0-1]
node-is-typedarray/stable 1.0.0-3 all [upgradable from: 1.0.0-2]
node-isarray/stable 2.0.5-1 all [upgradable from: 2.0.4-1]
node-isexe/stable 2.0.0-5 all [upgradable from: 2.0.0-4]
node-isstream/stable 0.1.2+dfsg-1.1 all [upgradable from: 0.1.2+dfsg-1]
node-isurl/stable 4.0.1-2 all [upgradable from: 1.0.0-1]
node-jsbn/stable 1.1.0-1.1 all [upgradable from: 1.1.0-1]
node-json-parse-better-errors/stable 1.0.2+~2.3.1-1 all [upgradable from: 1.0.2-2]
node-json-schema/stable 0.3.0+~7.0.6-1+deb11u1 all [upgradable from: 0.2.3-1]
node-json-stable-stringify/stable 1.0.1+~cs5.1.32-1 all [upgradable from: 1.0.1-1]
node-json-stringify-safe/stable 5.0.1+repack-3 all [upgradable from: 5.0.1-1]
node-jsonify/stable 0.0.0-1.1 all [upgradable from: 0.0.0-1]
node-jsonparse/stable 1.3.1-7 all [upgradable from: 1.3.1-6]
node-jsonstream/stable 1.3.5-1 all [upgradable from: 1.3.2-1]
node-jsprim/stable 2.0.0-1 all [upgradable from: 1.4.0-1]
node-latest-version/stable 5.1.0-1 all [upgradable from: 3.1.0-1]
node-lazy-property/stable 1.0.0+repack-1 all [upgradable from: 1.0.0-3]
node-lcid/stable 3.1.1-1 all [upgradable from: 1.0.0-1]
node-locate-path/stable 6.0.0-1 all [upgradable from: 2.0.0-1]
node-lockfile/stable 1.0.4-3 all [upgradable from: 1.0.4-1]
node-lowercase-keys/stable 2.0.0-1 all [upgradable from: 1.0.0-2]
node-lru-cache/stable 5.1.1-5 all [upgradable from: 5.1.1-4]
node-mem/stable 1.1.0-1.1 all [upgradable from: 1.1.0-1]
node-mime-types/stable 2.1.28-1 all [upgradable from: 2.1.21-1]
node-mimic-fn/stable 3.1.0-1 all [upgradable from: 1.1.0-1]
node-mimic-response/stable 3.1.0-5 all [upgradable from: 1.0.0-1]
node-minimatch/stable 3.0.4+~3.0.3-1 all [upgradable from: 3.0.4-3]
node-minimist/stable 1.2.5+~cs5.3.1-2+deb11u1 all [upgradable from: 1.2.0-1+deb10u2]
node-mkdirp/stable 1.0.4+~1.0.1-1 all [upgradable from: 0.5.1-1]
node-mute-stream/stable 0.0.8-2 all [upgradable from: 0.0.8-1]
node-nopt/stable 5.0.0-1 all [upgradable from: 3.0.6-3]
node-normalize-package-data/stable 3.0.0+~2.4.0-1 all [upgradable from: 2.4.0-1]
node-npm-package-arg/stable 8.1.0-1 all [upgradable from: 6.0.0-2]
node-npmlog/stable 4.1.2-2 all [upgradable from: 4.1.2-1]
node-oauth-sign/stable 0.9.0-2 all [upgradable from: 0.9.0-1]
node-object-assign/stable 4.1.1-3 all [upgradable from: 4.1.1-2]
node-opener/stable 1.5.2-1 all [upgradable from: 1.4.3-1]
node-os-locale/stable 5.0.0-1 all [upgradable from: 2.0.0-1]
node-p-cancelable/stable 2.0.0-1 all [upgradable from: 0.3.0-1]
node-p-finally/stable 2.0.1-1 all [upgradable from: 1.0.0-2]
node-p-limit/stable 3.1.0+~cs2.3.0-1 all [upgradable from: 1.1.0-1]
node-p-locate/stable 5.0.0-1 all [upgradable from: 2.0.0-1]
node-p-timeout/stable 4.1.0-1 all [upgradable from: 1.2.0-1]
node-package-json/stable 4.0.1-1.1 all [upgradable from: 4.0.1-1]
node-parallel-transform/stable 1.2.0-1 all [upgradable from: 1.1.0-2]
node-path-exists/stable 4.0.0-2 all [upgradable from: 3.0.0-1]
node-path-is-absolute/stable 2.0.0-1 all [upgradable from: 1.0.0-1]
node-path-is-inside/stable 1.0.2-1.1 all [upgradable from: 1.0.2-1]
node-performance-now/stable 2.1.0+debian-1.1 all [upgradable from: 2.1.0+debian-1]
node-prepend-http/stable 3.0.1-1 all [upgradable from: 2.0.0-1]
node-promise-inflight/stable 1.0.1-1.1 all [upgradable from: 1.0.1-1]
node-promzard/stable 0.3.0-1.1 all [upgradable from: 0.3.0-1]
node-proto-list/stable 1.2.4-1.1 all [upgradable from: 1.2.4-1]
node-prr/stable 1.0.1-1.1 all [upgradable from: 1.0.1-1]
node-pump/stable 3.0.0-4 all [upgradable from: 3.0.0-1]
node-pumpify/stable 2.0.1-1 all [upgradable from: 1.5.1-1]
node-punycode/stable 2.1.1-3 all [upgradable from: 2.1.1-2]
node-qs/stable 6.9.4+ds-1 all [upgradable from: 6.5.2-1]
node-qw/stable 1.0.1-1.1 all [upgradable from: 1.0.1-1]
node-rc/stable 1.2.8-1 all [upgradable from: 1.1.6-2]
node-read-package-json/stable 3.0.0-1 all [upgradable from: 2.0.13-1]
node-read/stable 1.0.7-2 all [upgradable from: 1.0.7-1]
node-readable-stream/stable 3.6.0-2 all [upgradable from: 2.3.6-1]
node-registry-auth-token/stable 3.3.1-1.1 all [upgradable from: 3.3.1-1]
node-registry-url/stable 5.1.0-1 all [upgradable from: 3.1.0-1]
node-request/stable 2.88.1-5 all [upgradable from: 2.88.1-2]
node-require-directory/stable 2.1.1-1.1 all [upgradable from: 2.1.1-1]
node-require-main-filename/stable 2.0.0-1 all [upgradable from: 1.0.1-1]
node-resolve-from/stable 5.0.0+~3.1.0+~3.3.0+~2.0.0-1 all [upgradable from: 4.0.0-1]
node-retry/stable 0.12.0-1 all [upgradable from: 0.10.1-1]
node-rimraf/stable 3.0.2-1 all [upgradable from: 2.6.2-1]
node-run-queue/stable 2.0.0-1 all [upgradable from: 1.0.3-1]
node-safe-buffer/stable 5.2.1+~cs2.1.2-1 all [upgradable from: 5.1.2-1]
node-semver-diff/stable 3.1.1-1 all [upgradable from: 2.1.0-2]
node-semver/stable 7.3.4-1 all [upgradable from: 5.5.1-1]
node-set-blocking/stable 2.0.0-1.1 all [upgradable from: 2.0.0-1]
node-sha/stable 3.0.0-1 all [upgradable from: 2.0.1-1]
node-shebang-command/stable 1.2.0-1.1 all [upgradable from: 1.2.0-1]
node-shebang-regex/stable 3.0.0-1 all [upgradable from: 2.0.0-1]
node-signal-exit/stable 3.0.3-1 all [upgradable from: 3.0.2-1]
node-slash/stable 3.0.0-1 all [upgradable from: 1.0.0-1]
node-sorted-object/stable 2.0.1-1.1 all [upgradable from: 2.0.1-1]
node-spdx-correct/stable 3.1.1-1 all [upgradable from: 1.0.2-1]
node-spdx-expression-parse/stable 3.0.1-1 all [upgradable from: 1.0.4-1]
node-spdx-license-ids/stable 3.0.7-1 all [upgradable from: 1.2.2-1]
node-sshpk/stable 1.16.1+dfsg-2 all [upgradable from: 1.13.1+dfsg-2]
node-ssri/stable 8.0.1-2 all [upgradable from: 5.2.4-2]
node-stream-each/stable 1.2.3-1 all [upgradable from: 1.2.2-2]
node-stream-shift/stable 1.0.1-1 all [upgradable from: 1.0.0-1]
node-string-decoder/stable 1.3.0-2 all [upgradable from: 1.2.0-1]
node-string-width/stable 4.2.0-1 all [upgradable from: 2.1.1-1]
node-strip-ansi/stable 6.0.0-2 all [upgradable from: 4.0.0-1]
node-strip-json-comments/stable 3.1.1-1 all [upgradable from: 2.0.1-2]
node-supports-color/stable 8.1.0+~7.2.0-1 all [upgradable from: 4.4.0-2]
node-tar/stable,stable-security 6.0.5+ds1+~cs11.3.9-1+deb11u2 all [upgradable from: 4.4.6+ds1-3+deb10u1]
node-through2/stable 4.0.2-1 all [upgradable from: 2.0.5-2]
node-through/stable 2.3.8+~cs0.0.30-1 all [upgradable from: 2.3.8-1]
node-timed-out/stable 5.0.0-1 all [upgradable from: 4.0.1-4]
node-tough-cookie/stable 4.0.0-2 all [upgradable from: 2.3.4+dfsg-1]
node-tunnel-agent/stable 0.6.1-2 all [upgradable from: 0.6.1-1]
node-tweetnacl/stable 1.0.3+dfsg-1 all [upgradable from: 0.14.5+dfsg-3]
node-typedarray/stable 0.0.6-1.1 all [upgradable from: 0.0.6-1]
node-uid-number/stable 0.0.6-2 all [upgradable from: 0.0.6-1]
node-unique-filename/stable 1.1.1+ds-1 all [upgradable from: 1.1.0+ds-2]
node-unpipe/stable 1.0.0-1.1 all [upgradable from: 1.0.0-1]
node-url-parse-lax/stable 4.0.0-1 all [upgradable from: 1.0.0-1]
node-url-to-options/stable 2.0.0-1 all [upgradable from: 1.0.1-1]
node-uuid/stable 8.3.2+~8.3.0-4 all [upgradable from: 3.3.2-2]
node-validate-npm-package-license/stable 3.0.4-1 all [upgradable from: 3.0.1-1]
node-validate-npm-package-name/stable 3.0.0-1.1 all [upgradable from: 3.0.0-1]
node-verror/stable 1.10.0-1.1 all [upgradable from: 1.10.0-1]
node-wcwidth.js/stable 1.0.0-1.1 all [upgradable from: 1.0.0-1]
node-which/stable 2.0.2+~cs1.3.2-1 all [upgradable from: 1.3.0-2]
node-wide-align/stable 1.1.3-1 all [upgradable from: 1.1.0-1]
node-widest-line/stable 3.1.0-1 all [upgradable from: 1.2.2-1]
node-wrap-ansi/stable 4.0.0-2 all [upgradable from: 4.0.0-1]
node-wrappy/stable 1.0.2-1.1 all [upgradable from: 1.0.2-1]
node-write-file-atomic/stable 3.0.3+~3.0.1-1 all [upgradable from: 2.3.0-1]
node-xtend/stable 4.0.2-1 all [upgradable from: 4.0.1-2]
node-y18n/stable 4.0.0-4 all [upgradable from: 3.2.1-2+deb10u1]
node-yallist/stable 4.0.0-1 all [upgradable from: 3.0.3-1]
node-yargs-parser/stable 18.1.3+~15.0.0-1 all [upgradable from: 11.1.1-1+deb10u1]
node-yargs/stable 15.3.1+repack-2 all [upgradable from: 10.0.3-2]
nodejs-doc/stable-security 12.22.12~dfsg-1~deb11u1 all [upgradable from: 10.24.0~dfsg-1~deb10u2]
nodejs/stable-security 12.22.12~dfsg-1~deb11u1 armhf [upgradable from: 10.24.0~dfsg-1~deb10u2]
npm/stable 7.5.2+ds-2 all [upgradable from: 5.8.0+ds6-4+deb10u2]
openssh-client/stable 1:8.4p1-5+deb11u1 armhf [upgradable from: 1:7.9p1-10+deb10u2]
openssh-server/stable 1:8.4p1-5+deb11u1 armhf [upgradable from: 1:7.9p1-10+deb10u2]
openssh-sftp-server/stable 1:8.4p1-5+deb11u1 armhf [upgradable from: 1:7.9p1-10+deb10u2]
openssl/stable,stable-security 1.1.1n-0+deb11u3 armhf [upgradable from: 1.1.1n-0+deb10u3]
passwd/stable 1:4.8.1-1 armhf [upgradable from: 1:4.5-1.1]
patch/stable 2.7.6-7 armhf [upgradable from: 2.7.6-3+deb10u1]
perl-base/stable 5.32.1-4+deb11u2 armhf [upgradable from: 5.28.1-6+deb10u1]
perl/stable 5.32.1-4+deb11u2 armhf [upgradable from: 5.28.1-6+deb10u1]
pinentry-curses/stable 1.1.0-4 armhf [upgradable from: 1.1.0-2]
pkg-config/stable 0.29.2-1 armhf [upgradable from: 0.29-6]
pps-tools/stable 1.0.2-2 armhf [upgradable from: 1.0.2-1]
procps/stable 2:3.3.17-5 armhf [upgradable from: 2:3.3.15-2]
python-pip-whl/stable 20.3.4-4+deb11u1 all [upgradable from: 18.1-5]
python-pkg-resources/stable 44.1.1-1 all [upgradable from: 40.8.0-1]
python2-minimal/stable 2.7.18-3 armhf [upgradable from: 2.7.16-1]
python2/stable 2.7.18-3 armhf [upgradable from: 2.7.16-1]
python3-click/stable 7.1.2-1 all [upgradable from: 7.0-1]
python3-colorama/stable 0.4.4-1 all [upgradable from: 0.3.7-1]
python3-decorator/stable 4.4.2-2 all [upgradable from: 4.3.0-1.1]
python3-distro/stable 1.5.0-1 all [upgradable from: 1.3.0-1]
python3-distutils/stable 3.9.2-1 all [upgradable from: 3.7.3-1]
python3-flask/stable 1.1.2-2 all [upgradable from: 1.0.2-3]
python3-itsdangerous/stable 1.1.0-3 all [upgradable from: 0.24+dfsg1-2]
python3-jinja2/stable 2.11.3-1 all [upgradable from: 2.10-2]
python3-lib2to3/stable 3.9.2-1 all [upgradable from: 3.7.3-1]
python3-libgpiod/stable 1.6.2-1 armhf [upgradable from: 1.4.1-2rcnee3~buster+20190906]
python3-markupsafe/stable 1.1.1-1+b3 armhf [upgradable from: 1.1.0-1]
python3-minimal/stable 3.9.2-3 armhf [upgradable from: 3.7.3-1]
python3-numpy/stable 1:1.19.5-1 armhf [upgradable from: 1:1.16.2-1]
python3-pip/stable 20.3.4-4+deb11u1 all [upgradable from: 18.1-5]
python3-pkg-resources/stable 52.0.0-4 all [upgradable from: 40.8.0-1]
python3-scipy/stable 1.6.0-2 armhf [upgradable from: 1.1.0-7]
python3-setuptools/stable 52.0.0-4 all [upgradable from: 40.8.0-1]
python3-smbus/stable 4.2-1+b1 armhf [upgradable from: 4.1-1]
python3-werkzeug/stable 1.0.1+dfsg1-2 all [upgradable from: 0.14.1+dfsg1-4+deb10u1]
python3/stable 3.9.2-3 armhf [upgradable from: 3.7.3-1]
readline-common/stable 8.1-1 all [upgradable from: 7.0-5]
rfkill/stable,stable-security 2.36.1-8+deb11u1 armhf [upgradable from: 2.33.1-0.1]
rsync/stable 3.2.3-4+deb11u1 armhf [upgradable from: 3.1.3-6]
rsyslog/stable,stable-security 8.2102.0-2+deb11u1 armhf [upgradable from: 8.1901.0-1+deb10u2]
screen/stable 4.8.0-6 armhf [upgradable from: 4.6.2-3+deb10u1]
sensible-utils/stable 0.0.14 all [upgradable from: 0.0.12]
ssl-cert/stable 1.1.0+nmu1 all [upgradable from: 1.0.39]
strace/stable 5.10-1 armhf [upgradable from: 4.26-0.2]
sudo/stable 1.9.5p2-3 armhf [upgradable from: 1.8.27-1+deb10u4]
systemd-sysv/stable 247.3-7+deb11u1 armhf [upgradable from: 241-7~deb10u8rcnee0~buster+20211022]
sysvinit-utils/stable 2.96-7+deb11u1 armhf [upgradable from: 2.93-8]
tar/stable 1.34+dfsg-1 armhf [upgradable from: 1.30+dfsg-6]
tasksel-data/stable 3.68+deb11u1 all [upgradable from: 3.53]
tasksel/stable 3.68+deb11u1 all [upgradable from: 3.53]
tmux/stable 3.1c-1+deb11u1 armhf [upgradable from: 2.8-3]
tzdata/stable-updates 2021a-1+deb11u8 all [upgradable from: 2021a-0+deb10u8]
u-boot-tools/stable 2021.01+dfsg-5 armhf [upgradable from: 2019.01+dfsg-7]
ucf/stable 3.0043 all [upgradable from: 3.0038+nmu1]
udev/stable 247.3-7+deb11u1 armhf [upgradable from: 241-7~deb10u8rcnee0~buster+20211022]
unzip/stable,stable-security 6.0-26+deb11u1 armhf [upgradable from: 6.0-23+deb10u3]
usb-modeswitch-data/stable 20191128-3 all [upgradable from: 20170806-2]
usb-modeswitch/stable 2.6.1-1 armhf [upgradable from: 2.5.2+repack0-2]
usb.ids/stable 2022.05.20-0+deb11u1 all [upgradable from: 2019.07.27-0+deb10u1]
usbutils/stable 1:013-3 armhf [upgradable from: 1:010-3]
util-linux/stable,stable-security 2.36.1-8+deb11u1 armhf [upgradable from: 2.33.1-0.1]
v4l-utils/stable 1.20.0-2 armhf [upgradable from: 1.16.3-3]
vim-common/stable 2:8.2.2434-3+deb11u1 all [upgradable from: 2:8.1.0875-5+deb10u3]
vim-runtime/stable 2:8.2.2434-3+deb11u1 all [upgradable from: 2:8.1.0875-5+deb10u3]
vim-tiny/stable 2:8.2.2434-3+deb11u1 armhf [upgradable from: 2:8.1.0875-5+deb10u3]
vim/stable 2:8.2.2434-3+deb11u1 armhf [upgradable from: 2:8.1.0875-5+deb10u3]
wget/stable 1.21-1+deb11u1 armhf [upgradable from: 1.20.1-1.1]
whiptail/stable 0.52.21-4+b3 armhf [upgradable from: 0.52.20-8]
wireless-regdb/stable 2022.04.08-2~deb11u1 all [upgradable from: 2016.06.10-1]
wireless-tools/stable 30~pre9-13.1 armhf [upgradable from: 30~pre9-13]
wpasupplicant/unknown 2:2.9.0-23rcnee1~bullseye+20211119 armhf [upgradable from: 2:2.7+git20190128+0c1e29f-6+deb10u3]
xauth/stable 1:1.1-1 armhf [upgradable from: 1:1.0.10-1]
xxd/stable 2:8.2.2434-3+deb11u1 armhf [upgradable from: 2:8.1.0875-5+deb10u3]
xz-utils/stable,stable-security 5.2.5-2.1~deb11u1 armhf [upgradable from: 5.2.4-1+deb10u1]
zlib1g/stable,stable-security 1:1.2.11.dfsg-2+deb11u2 armhf [upgradable from: 1:1.2.11.dfsg-1+deb10u2]
Since I allready upgrade to the latest verison of Buster, there are no other upgrades from our beagleboard.org repo other then:
So yeah, i’m not supporting this Buster → Bullseye upgrade mess..
Please give me a full boot log of U-Boot and the kernel version, we can fix the actual issue, and not some distribution upgrade mess.
Yikes - that looked painful! Yes, I have gone through an upgrade patch since Buster, but haven’t had any problems until now. If this becomes much more of an effort I can start with a fresh Bullseye image and rebuild my environment from there. That said, here’s my current boot log (dmesg output) with enable_uboot_overlays=1 reenabled.
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.10.145-ti-r53 (voodoo@rpi4b4g-02) (gcc (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.2) #1bullseye SMP PREEMPT Sun Nov 6 17:24:30 UTC 2022
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: TI AM335x BeagleBone Green Wireless
[    0.000000] Memory policy: Data cache writeback
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 48 MiB at 0x9c800000
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x0000000080000000-0x000000009fdfffff]
[    0.000000]   HighMem  empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009fdfffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000009fdfffff]
[    0.000000] On node 0 totalpages: 130560
[    0.000000]   Normal zone: 1148 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 130560 pages, LIFO batch:31
[    0.000000] CPU: All CPU(s) started in SVC mode.
[    0.000000] AM335X ES2.1 (sgx neon)
[    0.000000] percpu: Embedded 21 pages/cpu s54732 r8192 d23092 u86016
[    0.000000] pcpu-alloc: s54732 r8192 d23092 u86016 alloc=21*4096
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 129412
[    0.000000] Kernel command line: console=ttyS0,115200n8 root=/dev/mmcblk1p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
[    0.000000] Memory: 438164K/522240K available (14336K kernel code, 1443K rwdata, 3952K rodata, 1024K init, 444K bss, 34924K reserved, 49152K cma-reserved, 0K highmem)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] IRQ: Found an INTC at 0x(ptrval) (revision 5.0) with 128 interrupts
[    0.000000] TI gptimer clocksource: always-on /ocp/interconnect@44c00000/segment@200000/target-module@31000
[    0.000016] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000033] clocksource: dmtimer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000419] TI gptimer clockevent: 24000000 Hz at /ocp/interconnect@48000000/segment@0/target-module@40000
[    0.002578] Console: colour dummy device 80x30
[    0.002666] Calibrating delay loop (skipped) preset value.. 995.32 BogoMIPS (lpj=1990656)
[    0.002692] pid_max: default: 32768 minimum: 301
[    0.003331] LSM: Security Framework initializing
[    0.003446] Yama: becoming mindful.
[    0.003747] AppArmor: AppArmor initialized
[    0.003762] TOMOYO Linux initialized
[    0.003961] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.003975] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.005766] CPU: Testing write buffer coherency: ok
[    0.005849] CPU0: Spectre v2: using BPIALL workaround
[    0.028878] Setting up static identity map for 0x80100000 - 0x80100060
[    0.036488] rcu: Hierarchical SRCU implementation.
[    0.045786] EFI services will not be available.
[    0.056500] smp: Bringing up secondary CPUs ...
[    0.056516] smp: Brought up 1 node, 1 CPU
[    0.056528] SMP: Total of 1 processors activated (995.32 BogoMIPS).
[    0.056536] CPU: All CPU(s) started in SVC mode.
[    0.057460] devtmpfs: initialized
[    0.100856] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[    0.101348] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.101387] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[    0.105284] pinctrl core: initialized pinctrl subsystem
[    0.106481] DMI not present or invalid.
[    0.107435] NET: Registered protocol family 16
[    0.111437] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.152650] l3-aon-clkctrl:0000:0: failed to disable
[    0.153456] audit: initializing netlink subsys (disabled)
[    0.154978] thermal_sys: Registered thermal governor 'fair_share'
[    0.154991] thermal_sys: Registered thermal governor 'bang_bang'
[    0.155000] thermal_sys: Registered thermal governor 'step_wise'
[    0.155007] thermal_sys: Registered thermal governor 'user_space'
[    0.155015] thermal_sys: Registered thermal governor 'power_allocator'
[    0.155930] cpuidle: using governor ladder
[    0.155992] cpuidle: using governor menu
[    0.160605] audit: type=2000 audit(0.140:1): state=initialized audit_enabled=0 res=1
[    5.548364] hw-breakpoint: debug architecture 0x4 unsupported.
[    5.596933] Kprobes globally optimized
[    5.620885] raid6: skip pq benchmark and using algorithm neonx8
[    5.620906] raid6: using neon recovery algorithm
[    5.628608] iommu: Default domain type: Translated
[    5.633394] SCSI subsystem initialized
[    5.636678] libata version 3.00 loaded.
[    5.637066] usbcore: registered new interface driver usbfs
[    5.637123] usbcore: registered new interface driver hub
[    5.637207] usbcore: registered new device driver usb
[    5.638519] mc: Linux media interface: v0.10
[    5.638571] videodev: Linux video capture interface: v2.00
[    5.638745] pps_core: LinuxPPS API ver. 1 registered
[    5.638755] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    5.638780] PTP clock support registered
[    5.641380] NetLabel: Initializing
[    5.641401] NetLabel:  domain hash size = 128
[    5.641407] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    5.641548] NetLabel:  unlabeled traffic allowed by default
[    5.642806] clocksource: Switched to clocksource dmtimer
[    6.705274] VFS: Disk quotas dquot_6.6.0
[    6.705419] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    6.705710] FS-Cache: Loaded
[    6.706126] CacheFiles: Loaded
[    6.707269] AppArmor: AppArmor Filesystem Enabled
[    6.721030] NET: Registered protocol family 2
[    6.721349] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    6.723027] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    6.723334] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[    6.723402] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    6.723461] TCP: Hash tables configured (established 4096 bind 4096)
[    6.723750] MPTCP token hash table entries: 512 (order: 1, 8192 bytes, linear)
[    6.723848] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    6.723879] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    6.724130] NET: Registered protocol family 1
[    6.737582] RPC: Registered named UNIX socket transport module.
[    6.737599] RPC: Registered udp transport module.
[    6.737605] RPC: Registered tcp transport module.
[    6.737612] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    6.737629] NET: Registered protocol family 44
[    6.738532] Trying to unpack rootfs image as initramfs...
[    7.100031] Freeing initrd memory: 6700K
[    7.101141] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[    7.107311] Initialise system trusted keyrings
[    7.107811] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[    7.116125] zbud: loaded
[    7.124219] NFS: Registering the id_resolver key type
[    7.124285] Key type id_resolver registered
[    7.124294] Key type id_legacy registered
[    7.124488] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    7.124500] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    7.124546] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    7.125716] fuse: init (API version 7.32)
[    7.216603] xor: automatically using best checksumming function   neon
[    7.216623] Key type asymmetric registered
[    7.216633] Asymmetric key parser 'x509' registered
[    7.216720] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    7.221100] io scheduler mq-deadline registered
[    7.917402] ti-sysc: probe of 44e31000.target-module failed with error -16
[    8.044610] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 100 kHz
[    8.071327] ti-sysc: probe of 48040000.target-module failed with error -16
[    8.276566] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[    8.398202] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[    8.882154] debugfs: Directory '49000000.dma' with parent 'dmaengine' already present!
[    8.882207] edma 49000000.dma: TI EDMA DMA engine driver
[    8.916284] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[    8.917713] gpio-of-helper ocp:cape-universal: Failed to get gpio property of 'P8_03'
[    8.917742] gpio-of-helper ocp:cape-universal: Failed to create gpio entry
[    8.940389] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[    8.945291] printk: console [ttyS0] disabled
[    8.945403] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 20, base_baud = 3000000) is a 8250
[    8.973736] printk: console [ttyS0] enabled
[    8.975757] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 26, base_baud = 3000000) is a 8250
[    8.977461] 48024000.serial: ttyS2 at MMIO 0x48024000 (irq = 27, base_baud = 3000000) is a 8250
[    8.979388] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 40, base_baud = 3000000) is a 8250
[    8.979664] serial serial0: tty port ttyS3 registered
[    8.981112] 481a8000.serial: ttyS4 at MMIO 0x481a8000 (irq = 41, base_baud = 3000000) is a 8250
[    8.982546] 481aa000.serial: ttyS5 at MMIO 0x481aa000 (irq = 42, base_baud = 3000000) is a 8250
[    8.987495] omap_rng 48310000.rng: Random Number Generator ver. 20
[    8.991314] random: crng init done
[    9.006907] at24 2-0054: supply vcc not found, using dummy regulator
[    9.038307] at24 2-0055: supply vcc not found, using dummy regulator
[    9.069912] at24 2-0056: supply vcc not found, using dummy regulator
[    9.097827] at24 2-0057: supply vcc not found, using dummy regulator
[    9.220515] usbcore: registered new interface driver smsc95xx
[    9.223396] am335x-phy-driver 47401300.usb-phy: supply vcc not found, using dummy regulator
[    9.223768] am335x-phy-driver 47401300.usb-phy: dummy supplies not allowed for exclusive requests
[    9.232538] am335x-phy-driver 47401b00.usb-phy: supply vcc not found, using dummy regulator
[    9.232860] am335x-phy-driver 47401b00.usb-phy: dummy supplies not allowed for exclusive requests
[    9.235846] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    9.235914] ehci-platform: EHCI generic platform driver
[    9.236529] ehci-omap: OMAP-EHCI Host Controller driver
[    9.249468] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[    9.249545] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[    9.249934] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    9.249949] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    9.249958] usb usb1: Product: MUSB HDRC host driver
[    9.249966] usb usb1: Manufacturer: Linux 5.10.145-ti-r53 musb-hcd
[    9.249975] usb usb1: SerialNumber: musb-hdrc.1
[    9.251015] hub 1-0:1.0: USB hub found
[    9.251090] hub 1-0:1.0: 1 port detected
[    9.260785] omap_rtc 44e3e000.rtc: already running
[    9.262394] omap_rtc 44e3e000.rtc: registered as rtc0
[    9.262469] omap_rtc 44e3e000.rtc: setting system clock to 2022-11-17T02:39:49 UTC (1668652789)
[    9.264519] i2c /dev entries driver
[    9.271228] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    9.272057] softdog: initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0)
[    9.272071] softdog:              soft_reboot_cmd=<not set> soft_active_on_boot=0
[    9.274404] cpuidle: enable-method property 'ti,am3352' found operations
[    9.276737] sdhci: Secure Digital Host Controller Interface driver
[    9.276753] sdhci: Copyright(c) Pierre Ossman
[    9.276760] sdhci-pltfm: SDHCI platform and OF driver helper
[    9.287777] sdhci-omap 481d8000.mmc: supply vqmmc not found, using dummy regulator
[    9.289689] ledtrig-cpu: registered to indicate activity on CPUs
[    9.291902] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[    9.292248] omap-aes 53500000.aes: will run requests pump with realtime priority
[    9.295141] pinctrl-single 44e10800.pinmux: pin PIN10 already requested by ocp:P8_14_pinmux; cannot claim for 47810000.mmc
[    9.309176] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[    9.309694] omap-sham 53100000.sham: will run requests pump with realtime priority
[    9.311430] pinctrl-single 44e10800.pinmux: pin-10 (47810000.mmc) status -22
[    9.318897] mmc1: SDHCI controller on 481d8000.mmc [481d8000.mmc] using External DMA
[    9.323581] hid: raw HID events driver (C) Jiri Kosina
[    9.324288] usbcore: registered new interface driver usbhid
[    9.324301] usbhid: USB HID core driver
[    9.325331] remoteproc remoteproc0: wkup_m3 is available
[    9.333893] drop_monitor: Initializing network drop monitor service
[    9.335086] pinctrl-single 44e10800.pinmux: could not request pin 10 (PIN10) from group pinmux_wl18xx_pins  on device pinctrl-single
[    9.347414] NET: Registered protocol family 10
[    9.348551] sdhci-omap 47810000.mmc: Error applying setting, reverse things back
[    9.357283] sdhci-omap: probe of 47810000.mmc failed with error -22
[    9.390508] mmc1: new high speed MMC card at address 0001
[    9.399756] mmcblk1: mmc1:0001 Q2J54A 3.64 GiB
[    9.400366] mmcblk1boot0: mmc1:0001 Q2J54A partition 1 2.00 MiB
[    9.400884] mmcblk1boot1: mmc1:0001 Q2J54A partition 2 2.00 MiB
[    9.401315] mmcblk1rpmb: mmc1:0001 Q2J54A partition 3 512 KiB, chardev (241:0)
[    9.404384]  mmcblk1: p1
[    9.442533] Segment Routing with IPv6
[    9.442688] mip6: Mobile IPv6
[    9.442711] NET: Registered protocol family 17
[    9.447438] Key type dns_resolver registered
[    9.447452] mpls_gso: MPLS GSO support
[    9.447734] ThumbEE CPU extension supported.
[    9.447759] Registering SWP/SWPB emulation handler
[    9.447771] omap_voltage_late_init: Voltage driver support not added
[    9.455551] registered taskstats version 1
[    9.455592] Loading compiled-in X.509 certificates
[    9.455759] zswap: loaded using pool lzo/zbud
[    9.460622] Key type ._fscrypt registered
[    9.460640] Key type .fscrypt registered
[    9.460647] Key type fscrypt-provisioning registered
[    9.467911] Btrfs loaded, crc32c=crc32c-generic
[    9.468064] AppArmor: AppArmor sha1 policy hashing enabled
[    9.490231] OMAP GPIO hardware version 0.1
[    9.515570] tps65217-pmic: Failed to locate of_node [id: -1]
[    9.526680] tps65217-bl: Failed to locate of_node [id: -1]
[    9.529821] tps6521x_pwrbutton tps65217-pwrbutton: DMA mask not set
[    9.531034] input: tps65217_pwr_but as /devices/platform/ocp/44c00000.interconnect/44c00000.interconnect:segment@200000/44e0b000.target-module/44e0b000.i2c/i2c-0/0-0024/tps65217-pwrbutton/input/input0
[    9.531889] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[    9.532480] at24 0-0050: supply vcc not found, using dummy regulator
[    9.533302] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    9.533468] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[    9.534156] gpio-61 (LS_BUF_EN): hogged as output/high
[    9.536170] gpio-112 (MCASP0_AHCLKR): hogged as output/low
[    9.541705] gpio-of-helper ocp:cape-universal: Allocated GPIO id=0 name='P8_03'
[    9.541921] gpio-of-helper ocp:cape-universal: Allocated GPIO id=1 name='P8_04'
[    9.542086] gpio-of-helper ocp:cape-universal: Allocated GPIO id=2 name='P8_05'
[    9.542270] gpio-of-helper ocp:cape-universal: Allocated GPIO id=3 name='P8_06'
[    9.542742] gpio-of-helper ocp:cape-universal: Allocated GPIO id=4 name='P8_07'
[    9.543081] gpio-of-helper ocp:cape-universal: Allocated GPIO id=5 name='P8_08'
[    9.543270] gpio-of-helper ocp:cape-universal: Allocated GPIO id=6 name='P8_09'
[    9.543442] gpio-of-helper ocp:cape-universal: Allocated GPIO id=7 name='P8_10'
[    9.543631] gpio-of-helper ocp:cape-universal: Allocated GPIO id=8 name='P8_11'
[    9.543811] gpio-of-helper ocp:cape-universal: Allocated GPIO id=9 name='P8_12'
[    9.544063] gpio-of-helper ocp:cape-universal: Allocated GPIO id=10 name='P8_13'
[    9.544244] gpio-of-helper ocp:cape-universal: Allocated GPIO id=11 name='P8_14'
[    9.544430] gpio-of-helper ocp:cape-universal: Allocated GPIO id=12 name='P8_15'
[    9.544603] gpio-of-helper ocp:cape-universal: Allocated GPIO id=13 name='P8_16'
[    9.544804] gpio-of-helper ocp:cape-universal: Allocated GPIO id=14 name='P8_17'
[    9.544974] gpio-of-helper ocp:cape-universal: Allocated GPIO id=15 name='P8_18'
[    9.545156] gpio-of-helper ocp:cape-universal: Allocated GPIO id=16 name='P8_19'
[    9.545331] gpio-of-helper ocp:cape-universal: Allocated GPIO id=17 name='P8_20'
[    9.545493] gpio-of-helper ocp:cape-universal: Allocated GPIO id=18 name='P8_21'
[    9.545691] gpio-of-helper ocp:cape-universal: Allocated GPIO id=19 name='P8_22'
[    9.545852] gpio-of-helper ocp:cape-universal: Allocated GPIO id=20 name='P8_23'
[    9.546025] gpio-of-helper ocp:cape-universal: Allocated GPIO id=21 name='P8_24'
[    9.546193] gpio-of-helper ocp:cape-universal: Allocated GPIO id=22 name='P8_25'
[    9.546367] gpio-of-helper ocp:cape-universal: Allocated GPIO id=23 name='P8_26'
[    9.546561] gpio-of-helper ocp:cape-universal: Allocated GPIO id=24 name='P8_27'
[    9.546734] gpio-of-helper ocp:cape-universal: Allocated GPIO id=25 name='P8_28'
[    9.547004] gpio-of-helper ocp:cape-universal: Allocated GPIO id=26 name='P8_29'
[    9.547187] gpio-of-helper ocp:cape-universal: Allocated GPIO id=27 name='P8_30'
[    9.547368] gpio-of-helper ocp:cape-universal: Allocated GPIO id=28 name='P8_31'
[    9.547544] gpio-of-helper ocp:cape-universal: Allocated GPIO id=29 name='P8_32'
[    9.547715] gpio-of-helper ocp:cape-universal: Allocated GPIO id=30 name='P8_33'
[    9.547882] gpio-of-helper ocp:cape-universal: Allocated GPIO id=31 name='P8_34'
[    9.548081] gpio-of-helper ocp:cape-universal: Allocated GPIO id=32 name='P8_35'
[    9.548245] gpio-of-helper ocp:cape-universal: Allocated GPIO id=33 name='P8_36'
[    9.548421] gpio-of-helper ocp:cape-universal: Allocated GPIO id=34 name='P8_37'
[    9.548610] gpio-of-helper ocp:cape-universal: Allocated GPIO id=35 name='P8_38'
[    9.548773] gpio-of-helper ocp:cape-universal: Allocated GPIO id=36 name='P8_39'
[    9.548947] gpio-of-helper ocp:cape-universal: Allocated GPIO id=37 name='P8_40'
[    9.549105] gpio-of-helper ocp:cape-universal: Allocated GPIO id=38 name='P8_41'
[    9.549295] gpio-of-helper ocp:cape-universal: Allocated GPIO id=39 name='P8_42'
[    9.549477] gpio-of-helper ocp:cape-universal: Allocated GPIO id=40 name='P8_43'
[    9.549658] gpio-of-helper ocp:cape-universal: Allocated GPIO id=41 name='P8_44'
[    9.549835] gpio-of-helper ocp:cape-universal: Allocated GPIO id=42 name='P8_45'
[    9.549995] gpio-of-helper ocp:cape-universal: Allocated GPIO id=43 name='P8_46'
[    9.550182] gpio-of-helper ocp:cape-universal: Allocated GPIO id=44 name='P9_11'
[    9.550363] gpio-of-helper ocp:cape-universal: Allocated GPIO id=45 name='P9_12'
[    9.550538] gpio-of-helper ocp:cape-universal: Allocated GPIO id=46 name='P9_13'
[    9.550719] gpio-of-helper ocp:cape-universal: Allocated GPIO id=47 name='P9_14'
[    9.550997] gpio-of-helper ocp:cape-universal: Allocated GPIO id=48 name='P9_15'
[    9.551171] gpio-of-helper ocp:cape-universal: Allocated GPIO id=49 name='P9_16'
[    9.551385] gpio-of-helper ocp:cape-universal: Allocated GPIO id=50 name='P9_17'
[    9.551549] gpio-of-helper ocp:cape-universal: Allocated GPIO id=51 name='P9_18'
[    9.551726] gpio-of-helper ocp:cape-universal: Allocated GPIO id=52 name='P9_19'
[    9.551900] gpio-of-helper ocp:cape-universal: Allocated GPIO id=53 name='P9_20'
[    9.552065] gpio-of-helper ocp:cape-universal: Allocated GPIO id=54 name='P9_21'
[    9.552238] gpio-of-helper ocp:cape-universal: Allocated GPIO id=55 name='P9_22'
[    9.552423] gpio-of-helper ocp:cape-universal: Allocated GPIO id=56 name='P9_23'
[    9.552599] gpio-of-helper ocp:cape-universal: Allocated GPIO id=57 name='P9_24'
[    9.553078] gpio-of-helper ocp:cape-universal: Allocated GPIO id=58 name='P9_25'
[    9.553286] gpio-of-helper ocp:cape-universal: Allocated GPIO id=59 name='P9_26'
[    9.553480] gpio-of-helper ocp:cape-universal: Allocated GPIO id=60 name='P9_27'
[    9.553646] gpio-of-helper ocp:cape-universal: Allocated GPIO id=61 name='P9_28'
[    9.553833] gpio-of-helper ocp:cape-universal: Allocated GPIO id=62 name='P9_29'
[    9.554017] gpio-of-helper ocp:cape-universal: Allocated GPIO id=63 name='P9_30'
[    9.554193] gpio-of-helper ocp:cape-universal: Allocated GPIO id=64 name='P9_31'
[    9.554375] gpio-of-helper ocp:cape-universal: Allocated GPIO id=65 name='P9_41'
[    9.554548] gpio-of-helper ocp:cape-universal: Allocated GPIO id=66 name='P9_91'
[    9.554722] gpio-of-helper ocp:cape-universal: Allocated GPIO id=67 name='P9_42'
[    9.555027] gpio-of-helper ocp:cape-universal: Allocated GPIO id=68 name='P9_92'
[    9.555039] gpio-of-helper ocp:cape-universal: ready
[    9.564551] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000 microseconds (-22)
[    9.564574] sdhci-omap 48060000.mmc: Got CD GPIO
[    9.564798] sdhci-omap 48060000.mmc: supply vqmmc not found, using dummy regulator
[    9.568645] of_cfs_init
[    9.568716] of_cfs_init: OK
[    9.602641] mmc0: SDHCI controller on 48060000.mmc [48060000.mmc] using External DMA
[    9.605190] Freeing unused kernel memory: 1024K
[    9.607851] Checked W+X mappings: passed, no W+X pages found
[    9.607886] Run /init as init process
[    9.607899]   with arguments:
[    9.607907]     /init
[    9.607914]   with environment:
[    9.607921]     HOME=/
[    9.607927]     TERM=linux
[    9.658978] usb 1-1: new high-speed USB device number 2 using musb-hdrc
[    9.808517] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=32.98
[    9.808543] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    9.808552] usb 1-1: Product: USB2.0 Hub
[    9.811749] hub 1-1:1.0: USB hub found
[    9.815110] hub 1-1:1.0: 4 ports detected
[   16.617826] EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. Opts: (null)
[   16.832771] Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist.
[   17.344138] systemd[1]: systemd 247.3-7+deb11u1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[   17.345064] systemd[1]: Detected architecture arm.
[   17.352941] systemd[1]: Set hostname to <ColorTechnica>.
[   19.197616] systemd[1]: Queued start job for default target Graphical Interface.
[   19.197723] systemd[1]: Unnecessary job for /dev/bone/uart/0 was removed.
[   19.197794] systemd[1]: Unnecessary job for /dev/ttyO0 was removed.
[   19.197883] systemd[1]: Unnecessary job for /sys/devices/platform/ocp/44c00000.interconnect/44c00000.interconnect:segment@200000/44e09050.target-module/44e09000.serial/tty/ttyS0 was removed.
[   19.210181] systemd[1]: Created slice system-getty.slice.
[   19.213922] systemd[1]: Created slice system-modprobe.slice.
[   19.217539] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   19.220252] systemd[1]: Created slice User and Session Slice.
[   19.221200] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   19.221868] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   19.223814] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   19.224396] systemd[1]: Reached target Local Encrypted Volumes.
[   19.225035] systemd[1]: Reached target Paths.
[   19.225401] systemd[1]: Reached target Slices.
[   19.225667] systemd[1]: Reached target Swap.
[   19.260103] systemd[1]: Listening on RPCbind Server Activation Socket.
[   19.261867] systemd[1]: Listening on Syslog Socket.
[   19.263704] systemd[1]: Listening on fsck to fsckd communication Socket.
[   19.264594] systemd[1]: Listening on initctl Compatibility Named Pipe.
[   19.266448] systemd[1]: Listening on Journal Audit Socket.
[   19.268375] systemd[1]: Listening on Journal Socket (/dev/log).
[   19.269932] systemd[1]: Listening on Journal Socket.
[   19.272075] systemd[1]: Listening on udev Control Socket.
[   19.273266] systemd[1]: Listening on udev Kernel Socket.
[   19.274756] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[   19.283124] systemd[1]: Mounting POSIX Message Queue File System...
[   19.301622] systemd[1]: Mounting RPC Pipe File System...
[   19.332300] systemd[1]: Mounting /sys/kernel/debug...
[   19.373193] systemd[1]: Mounting Kernel Trace File System...
[   19.373821] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[   19.404783] systemd[1]: Starting Restore / save the current clock...
[   19.449998] systemd[1]: Starting Create list of static device nodes for the current kernel...
[   19.488493] systemd[1]: Starting Load Kernel Module configfs...
[   19.536569] systemd[1]: Starting Load Kernel Module drm...
[   19.587326] systemd[1]: Starting Load Kernel Module fuse...
[   19.592862] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   19.593357] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[   19.632548] systemd[1]: Starting Journal Service...
[   19.668531] systemd[1]: Starting Load Kernel Modules...
[   19.700702] systemd[1]: Starting Remount Root and Kernel File Systems...
[   19.740532] systemd[1]: Starting Coldplug All udev Devices...
[   19.856381] systemd[1]: Mounted POSIX Message Queue File System.
[   19.857832] systemd[1]: Mounted RPC Pipe File System.
[   19.875648] systemd[1]: Mounted /sys/kernel/debug.
[   19.877217] systemd[1]: Mounted Kernel Trace File System.
[   19.907121] systemd[1]: Finished Restore / save the current clock.
[   19.934409] systemd[1]: Finished Create list of static device nodes for the current kernel.
[   19.938275] systemd[1]: modprobe@configfs.service: Succeeded.
[   19.976075] systemd[1]: Finished Load Kernel Module configfs.
[   19.989222] systemd[1]: modprobe@drm.service: Succeeded.
[   20.031256] systemd[1]: Finished Load Kernel Module drm.
[   20.034680] systemd[1]: modprobe@fuse.service: Succeeded.
[   20.061035] systemd[1]: Finished Load Kernel Module fuse.
[   20.123018] EXT4-fs (mmcblk1p1): re-mounted. Opts: errors=remount-ro
[   20.124242] systemd[1]: Mounting FUSE Control File System...
[   20.253456] systemd[1]: Mounting Kernel Configuration File System...
[   20.436293] systemd[1]: Finished Load Kernel Modules.
[   20.467592] systemd[1]: Finished Remount Root and Kernel File Systems.
[   20.469580] systemd[1]: Mounted FUSE Control File System.
[   20.479145] systemd[1]: Mounted Kernel Configuration File System.
[   20.484049] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[   20.484544] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[   20.512595] systemd[1]: Starting Load/Save Random Seed...
[   20.552638] systemd[1]: Starting Apply Kernel Variables...
[   20.613467] systemd[1]: Starting Create System Users...
[   20.876025] systemd[1]: Finished Load/Save Random Seed.
[   20.877608] systemd[1]: Condition check resulted in First Boot Complete being skipped.
[   20.916024] systemd[1]: Finished Apply Kernel Variables.
[   21.052378] systemd[1]: Finished Create System Users.
[   21.076625] systemd[1]: Starting Create Static Device Nodes in /dev...
[   21.383746] systemd[1]: Finished Create Static Device Nodes in /dev.
[   21.385014] systemd[1]: Reached target Local File Systems (Pre).
[   21.385239] systemd[1]: Reached target Local File Systems.
[   21.410097] systemd[1]: Starting Preprocess NFS configuration...
[   21.410747] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[   21.425562] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[   21.488796] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[   21.524622] systemd[1]: nfs-config.service: Succeeded.
[   21.539498] systemd[1]: Finished Preprocess NFS configuration.
[   21.541179] systemd[1]: Condition check resulted in RPC security service for NFS client and server being skipped.
[   21.541361] systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
[   21.541661] systemd[1]: Reached target NFS client services.
[   21.811492] systemd[1]: Started Journal Service.
[   22.120185] systemd-journald[538]: Received client request to flush runtime journal.
[   37.849134] remoteproc remoteproc0: powering up wkup_m3
[   37.849171] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217148
[   37.849437] remoteproc remoteproc0: remote processor wkup_m3 is now up
[   37.849459] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192
[   52.340011] Bluetooth: Core ver 2.22
[   52.340238] NET: Registered protocol family 31
[   52.340249] Bluetooth: HCI device and connection manager initialized
[   52.340283] Bluetooth: HCI socket layer initialized
[   52.340299] Bluetooth: L2CAP socket layer initialized
[   52.340341] Bluetooth: SCO socket layer initialized
[   54.824296] Bluetooth: HCI UART driver ver 2.3
[   54.824323] Bluetooth: HCI UART protocol H4 registered
[   54.824332] Bluetooth: HCI UART protocol BCSP registered
[   54.887229] Bluetooth: HCI UART protocol LL registered
[   54.887253] Bluetooth: HCI UART protocol ATH3K registered
[   54.887343] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   54.887852] Bluetooth: HCI UART protocol Intel registered
[   54.888249] Bluetooth: HCI UART protocol Broadcom registered
[   54.888356] Bluetooth: HCI UART protocol QCA registered
[   54.888366] Bluetooth: HCI UART protocol AG6XX registered
[   54.888434] Bluetooth: HCI UART protocol Marvell registered
[   56.878943] Bluetooth: hci0: command 0x1001 tx timeout
[   61.620149] PM: bootloader does not support rtc-only!
[   65.007027] Bluetooth: hci0: Reading TI version information failed (-110)
[   65.013958] Bluetooth: hci0: download firmware failed, retrying...
[   66.009550] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   66.009574] Bluetooth: BNEP filters: protocol multicast
[   66.009609] Bluetooth: BNEP socket layer initialized
[   66.251143] remoteproc remoteproc1: 4a334000.pru is available
[   66.277117] remoteproc remoteproc2: 4a338000.pru is available
[   67.055080] Bluetooth: hci0: command 0x1001 tx timeout
[   75.247105] Bluetooth: hci0: Reading TI version information failed (-110)
[   75.254060] Bluetooth: hci0: download firmware failed, retrying...
Current contents of uEnv.txt:
uname_r=5.10.145-ti-r53
#uuid=
#dtb=
###U-Boot Overlays###
###Documentation: http://elinux.org/Beagleboard:BeagleBoneBlack_Debian#U-Boot_Overlays
###Master Enable
#enable_uboot_overlays=1
###Overide capes with eeprom
#uboot_overlay_addr0=/lib/firmware/<file0>.dtbo
#uboot_overlay_addr1=/lib/firmware/<file1>.dtbo
#uboot_overlay_addr2=/lib/firmware/<file2>.dtbo
#uboot_overlay_addr3=/lib/firmware/<file3>.dtbo
###Additional custom capes
#uboot_overlay_addr4=/lib/firmware/CT-INPUT-KEYS-00A0.dtbo
#uboot_overlay_addr5=/lib/firmware/CT-PWM-P8_34-00A0.dtbo
#uboot_overlay_addr6=/lib/firmware/CT-EGPIO-00A0.dtbo
#uboot_overlay_addr7=/lib/firmware/CT-PRUMEM-00A0.dtbo
###Custom Cape
#dtb_overlay=/lib/firmware/<file8>.dtbo
###Disable auto loading of virtual capes (emmc/video/wireless/adc)
#disable_uboot_overlay_emmc=1
disable_uboot_overlay_video=1
disable_uboot_overlay_audio=1
#disable_uboot_overlay_wireless=1
disable_uboot_overlay_adc=1
###PRUSS OPTIONS
###pru_rproc (4.14.x-ti kernel)
#uboot_overlay_pru=/lib/firmware/AM335X-PRU-RPROC-4-14-TI-00A0.dtbo
###pru_rproc (4.19.x-ti kernel)
#uboot_overlay_pru=/lib/firmware/AM335X-PRU-RPROC-4-19-TI-00A0.dtbo
###pru_uio (4.14.x-ti, 4.19.x-ti & mainline/bone kernel)
#uboot_overlay_pru=/lib/firmware/AM335X-PRU-UIO-00A0.dtbo
#uboot_overlay_pru=/lib/firmware/uio-pruss-5.4.dtbo
###Cape Universal Enable
#enable_uboot_cape_universal=1
###Debug: disable uboot autoload of Cape
#disable_uboot_overlay_addr0=1
#disable_uboot_overlay_addr1=1
#disable_uboot_overlay_addr2=1
#disable_uboot_overlay_addr3=1
###U-Boot fdt tweaks... (60000 = 384KB)
#uboot_fdt_buffer=0x60000
cmdline=coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet
#In the event of edid real failures, uncomment this next line:
#cmdline=coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet video=HDMI-A-1:1024x768@60e
#enable Generic eMMC Flasher:
#make sure, these tools are installed: dosfstools rsync
#cmdline=init=/opt/scripts/tools/eMMC/init-eMMC-flasher-v3.sh
Can you grab a serial boot log? I’d like to see what uboot is doing…
The hci0 errors are annoying and break Bluetooth, I have a sorta hackish work around to make them work. (Give up on mainline driver and trigger hciatach the old way to enable Bluetooth…)
But I don’t see any other breakage on that bootup…
Sure, here’s the serial log. Thanks!
root@ColorTechnica:/home/ctdevel# systemctl reboot
[38726.479229] watchdog: watchdog0: watchdog did not stop!
[38727.113987] reboot: Restarting system
U-Boot SPL 2022.04-gd0771d53 (Jul 21 2022 - 02:13:23 +0000)
Trying to boot from MMC2
U-Boot 2022.04-gd0771d53 (Jul 21 2022 - 02:13:23 +0000)
CPU  : AM335X-GP rev 2.1
Model: TI AM335x BeagleBone Black
DRAM:  512 MiB
Reset Source: Global warm SW reset has occurred.
RTC 32KCLK Source: External.
Core:  150 devices, 14 uclasses, devicetree: separate
WDT:   Started wdt@44e35000 with servicing (60s timeout)
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
Loading Environment from EXT4... Board: BeagleBone Black
<ethaddr> not set. Validating first E-fuse MAC
BeagleBone Black:
Model: SeeedStudio BeagleBone Green Wireless:
BeagleBone Cape EEPROM: no EEPROM at address: 0x54
BeagleBone Cape EEPROM: no EEPROM at address: 0x55
BeagleBone Cape EEPROM: no EEPROM at address: 0x56
BeagleBone Cape EEPROM: no EEPROM at address: 0x57
Net:   Could not get PHY for ethernet@4a100000: addr 0
eth2: ethernet@4a100000, eth3: usb_ether
Press SPACE to abort autoboot in 0 seconds
board_name=[A335BNLT] ...
board_rev=[GW1A] ...
switch to partitions #0, OK
Scanning mmc 1:1...
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
Scanning disk mmc@48060000.blk...
Disk mmc@48060000.blk not ready
Scanning disk mmc@481d8000.blk...
Found 2 disks
No EFI system partition
BootOrder not defined
EFI boot manager: Cannot load any image
Checking for: /uEnv.txt ...
Checking for: /boot/uEnv.txt ...
2145 bytes read in 3 ms (698.2 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt...
Running uname_boot ...
loading /boot/vmlinuz-5.10.145-ti-r53 ...
10514944 bytes read in 663 ms (15.1 MiB/s)
debug: [enable_uboot_overlays=1] ...
debug: [enable_uboot_cape_universal=] ...
debug: [uboot_base_dtb_univ=am335x-boneblack-uboot.dtb] ...
uboot_overlays: [uboot_base_dtb=am335x-boneblack-uboot.dtb] ...
uboot_overlays: Switching too: dtb=am335x-boneblack-uboot.dtb ...
loading /boot/dtbs/5.10.145-ti-r53/am335x-boneblack-uboot.dtb ...
211600 bytes read in 17 ms (11.9 MiB/s)
Found 0 extension board(s).
uboot_overlays: [fdt_buffer=0x60000] ...
uboot_overlays: uboot loading of [BB-ADC-00A0.dtbo] disabled by /boot/uEnv.txt [disable_uboot_overlay_adc=1]...
uboot_overlays: loading /boot/dtbs/5.10.145-ti-r53/overlays/BB-BONE-eMMC1-01-00A0.dtbo ...
1605 bytes read in 7 ms (223.6 KiB/s)
uboot_overlays: loading /boot/dtbs/5.10.145-ti-r53/overlays/BB-BBGW-WL1835-00A0.dtbo ...
3977 bytes read in 7 ms (554.7 KiB/s)
loading /boot/initrd.img-5.10.145-ti-r53 ...
6859210 bytes read in 439 ms (14.9 MiB/s)
debug: [console=ttyS0,115200n8 root=/dev/mmcblk1p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet] ...
debug: [bootz 0x82000000 0x88080000:68a9ca 88000000] ...
Kernel image @ 0x82000000 [ 0x000000 - 0xa07200 ]
## Flattened Device Tree blob at 88000000
   Loading Ramdisk to 8f975000, end 8ffff9ca ... OK
   Loading Device Tree to 8f8dd000, end 8f974fff ... OK
Starting kernel ...
[    0.152468] l3-aon-clkctrl:0000:0: failed to disable
[    8.874022] debugfs: Directory '49000000.dma' with parent 'dmaengine' already present!
[    8.909552] gpio-of-helper ocp:cape-universal: Failed to get gpio property of 'P8_03'
[    8.909580] gpio-of-helper ocp:cape-universal: Failed to create gpio entry
[    9.287066] pinctrl-single 44e10800.pinmux: pin PIN10 already requested by ocp:P8_14_pinmux; cannot claim for 47810000.mmc
[    9.303312] pinctrl-single 44e10800.pinmux: pin-10 (47810000.mmc) status -22
[    9.323018] pinctrl-single 44e10800.pinmux: could not request pin 10 (PIN10) from group pinmux_wl18xx_pins  on device pinctrl-single
[    9.340288] sdhci-omap 47810000.mmc: Error applying setting, reverse things back
[    9.438918] omap_voltage_late_init: Voltage driver support not added
rootfs: clean, 61030/238560 files, 676644/953344 blocks
ColorTechnica login:
FYI, prior to the upgrade my logs did not contain any pinctrl or gpio-of-helper messages. Not sure why I’m getting “gpio-of-helper ocp:cape-universal” messages when the universal cape is disabled in uEnv.txt.
Thanks for posting this @ridgelift , my board is at home, so i’ll test this tonight…
Great, thanks! BTW, did you ever get the schematics for the v1.1 BBGW board from Seeed? Those boards still don’t correctly power down.
Looks in Slack… Nope, let me ping Seeed again…
Okay, committed a quick fix:
5.10.145-ti-r54 is building right now…
I need to cleanup the overlay more going forward, but this will get wifi working today…
That worked Robert, thanks!
Thanks for this thread. I just got a BBGW today as a late-ish birthday gift and was googling around to see what to do with it before formally unboxing. It wasn’t one I’d researched and I hadn’t seen much about it on the forums (I think the only reference I saw was with the Freedom with Greybus, which granted is on my project list, just not quite this soon).
I’ll do some more reading before I start configuration to see if there are any unexpected surprises.
