C Code to Access GPIOs-Getting permission denied when using open() to access /sys/class/gpio/export
I’m trying to manipulate my GPIOs using C code and running into “Permission Denied” when running my code and opening the file /sys/class/gpio/export. I’m using nano editor, compiling on the Beaglebone with gcc, and I’m under root user.
I would like to do this, so I can set directions and values for the GPIOs with my code. I’ve heard this might be a problem with user and kernel space conflicting. I know there are library calls in python and other languages to do this that work. Does anyone know what this problem might be and our their alternate calls I can do in C?
I tried to just include the necessary parts of the code.
Code:
#include<fcntl.h>
static const char *GPIO_PATH = “/sys/class/gpio/export”;
int main(){
int file;
if ((file = open(GPIO_PATH, O_RDWR))<0){
perror(“GPIO: Can’t open the device.”);
return -1;
return 0;
debian@beaglebone:~$ cat /sys/class/gpio/export
cat: /sys/class/gpio/export: Permission denied
debian@beaglebone:~$ sudo cat /sys/class/gpio/export
debian@beaglebone:~$ sudo su
root@beaglebone:/home/debian# cat /sys/class/gpio/export
root@beaglebone:/home/debian# ls -al /sys/class/gpio/
total 0
drwxr-xr-x 2 root root 0 Dec 31 1999 .
drwxr-xr-x 59 root root 0 Dec 31 1999 …
–w------- 1 root root 4096 Dec 31 1999 export
lrwxrwxrwx 1 root root 0 Dec 31 1999 gpiochip0 → …/…/devices/virtual/gpio/gpiochip0
lrwxrwxrwx 1 root root 0 Dec 31 1999 gpiochip32 → …/…/devices/virtual/gpio/gpiochip32
lrwxrwxrwx 1 root root 0 Dec 31 1999 gpiochip64 → …/…/devices/virtual/gpio/gpiochip64
lrwxrwxrwx 1 root root 0 Dec 31 1999 gpiochip96 → …/…/devices/virtual/gpio/gpiochip96
–w------- 1 root root 4096 Dec 31 1999 unexport
root@beaglebone:/home/debian# whoami
root
read this post . .
http://unix.stackexchange.com/questions/118716/unable-to-write-to-a-gpio-pin-despite-file-permissions-on-sys-class-gpio-gpio18
3rd post or second answer should fix you up. However do note that what you’re trying to do is “wrong”. Meaning: it is insecure. You ( and I too ) need to read up on process forking. IN short, and perhaps somewhat incorrect( as I’m not 100% up to speed either ) is that you fork a process, running privileged commands, and when that command is done, the privileges are done too . . .
Anyway, probably safer to add your regular user to a group that has limited access to that file.
Also, as I’m unsure what exporting a pin config will do while the system is running . . . you should make 100% absolutely sure you know what you’re doing. So you do not fry your board.
Thanks! That makes a lot of sense now. I figured out I have to open export as write only which agrees with the permissions you showed. I’ve moved GPIOs to export while the board was running using the command line, so I think its okay.
So changing my code subsituting O_WRONLY for O_RDWR and now I’m getting the error “Writing Error: Device or Resource is busy.” It doesn’t seem like I can use C code to bring a GPIO to the user space. Is there a way around it?
I’ll look up the process forking too.
root@beaglebone:/home/debian# echo 0 > /sys/class/gpio/export
root@beaglebone:/home/debian# ls /sys/class/gpio/
export gpio0 gpiochip0 gpiochip32 gpiochip64 gpiochip96 unexport
root@beaglebone:/home/debian# echo 0 > /sys/class/gpio/unexport
export gpiochip0 gpiochip32 gpiochip64 gpiochip96 unexport
So . . .write only.Here is a decent read on the subject. http://falsinsoft.blogspot.com/2012/11/access-gpio-from-linux-user-space.html
DO also keep in mind that /sys/ is a pseudo file system. SO does not always play by the same rules as disk based file systems.
Any forward traction ?
total 0
root
read this post . .
The spawned process inherits the real UID (and effective and saved UIDs) from the parent. But here he needs root to write to the GPIO file.
This is really only a security issue if there are ever other users on the box. Important security practices for a multiuser machine, yes, but for a BBB acting as (say) a media server with only a wired network connection, not really that important.
Fair enough. Though I tend to err on the side of caution, since sometimes you never know what can come back and bite you.
By the way, that was my own file system / commands above. No idea what his actual file system groups / permissions looks like.
Since you seem to be more knowledgeable on the subject. What would you suggest that one do in this situation. Assuming the system could be multi user, and internet facing ?
This is a big topic… securing an Internet-facing server requires a lot of training on how to write secure software, and it’s easy to get it wrong (there are daily reports of breaches when people blow it). I would say you install only well-known and well-trusted software, go for servers that are known to be more secure (eg, qmail instead of sendmail and djbdns instead of bind). And if you’re writing web apps, take a course in webapp security (OWASP is a good place to start).
Unrelated topic: I’ve tried to post my own question about the BBB here twice now and it says “your post will appear after it’s been approved” but this never happens. Is the group moderated? When do the mods come by? (Sorry to derail the thread!!)
Gerald and maybe Jason have the power to approve new users to post. No idea when they’ll get on, but do also keep in mind it’s the 4th of July weekend( possibly already started for some ) So you may have to wait until Monday.
jrblack, also, you can mail me personally, and I’ll forward, or just make a new post on your behalf. Assuming I can not answer the question myself.
you can write to gpios by first chmod’ing 666 to the folders and then to individual attributes.
I wrote a blog post on this a couple weeks ago as I needed to do the same for a software project I had of my own . . . and figured I’d share. Doing the same for the onboard USR LEDs is a bit problematic specifically when one tries to echo timer > trigger. on_delay and off_delay have eluded my so far when attempting to create a udev rule for them. However, I have not completely given up yet.
http://www.embeddedhobbyist.com/2016/05/beaglebone-black-gpio-permissions/
