So I have gotten the c++ compiler to work in angstrom 2.6.28 I was
wondering if anyone knows how to get a C compiler to work? It seems
that I am going to need to use c++ for some stuff and c for other
stuff. Let me know if anyone knows how to install a native version or
how to get access to the compiler if it is already on there.
If your C++ compiler is based on GCC (GNU Compiler Collection) then it
should already be a C compiler. According to the GCC manual (4.3.0),
the "gcc" command assumes ".c" files are C programs and ".cc", ".c++",
and ".C" are C++ programs. However, if you invoke GCC using the "g++"
command it assumes ".c" files are C++.
It looks like either the C compiler didn't get included in Ångström
image 2.6.28 or else "gcc" can't find it because PATH is screwed up.
It's hard to imagine that whoever created 2.6.28 included C++ but not
C. You might look around through the usual binary directories to see
if "cc1" is anywhere. Another helpful tool is to turn on the
"verbose" option "-v" when running both g++ and gcc so you get get a
better picture of what gcc is trying to do.
You might also try the IRC (BeagleBoard chat) as lots of the
BeagleBoard experts visit there.
