SYSTEM:
Hello I have gotten Angstrom Running on my BB. I am now interested in
writing code for a robot. This robot will require a few virtual comm
ports over USB. I am interfacing to a board that ONLY SENDS serial at
115200 over the usb to the BB, and there is also a uC that will be
SENDING/RECEIVING at 115200 with the beagle board.
PLAN:
Basically I would like to develop a C++ library and complete program
for communications with the two boards at the same time.
QUESTIONS:
First off I am using windows and I have had the same results running
vmware linux ubuntu 8.10
(0.) I have been trying to get the code Sorcery compiler to work but I
have run into some issues. Is it free?..because I cannot get this to
work.
http://www.codesourcery.com/gnu_toolchains/arm/portal/release313
When I install CODE Sorcery it does not install an executable it just
installs documentation and an uninstaller. Does the free version have
a graphical user interface?...With that said can someone write a
tutorial for setting up a c compiler for the BB system it would be
greatly appreciated to have a hello world program that is simple and
straight forward. So how do I get it to run. Should I be using
CodeComposer Studio with Eclipse?...or should I be using some other
library to develop with Eclipse?
(1.) Is this possible with the drivers that are already available on
the board/ Or should I write Some new drivers?
(2).If I need to write drivers what is the best free environment for
writing drivers? Also is there a c++ compiler already on the BB board
when using the angstrom setup...and if so how is it accessed and where
can I find info on the libraries it uses? Also is there a hello world
tutorial for it.
(3.)To give a little back ground I have run a c++ program and made a
driver before using GCC on a TS-3300. Is there a similar development
environment on the BB?
(4.) Lastly can Anyone make a demo for a program that runs directly on
boot up. So that when the SBC is powered on it goes directly into a c
program? I am not sure if anyone has done this with the board yet?
Sorry I know there are many similar posts and examples out
there...unfortunately I am still running into some issues. Thanks for
any help in advance!
