Deepakvr, you are right. i am talking abt the calender app built from
the source
still the purpose of this list is not to guess what somebody intended to ask.
With you giving us no information at all, how is anybody expected to help you?
I propose you look into android debugging methods like logcat, ADB, DDMS and then
come back with a more detailed error report. You might also want to look for help in
more android oriented channels.
I've been using the USB OTG port on the BeagleBoard to supply it with power. When I boot Ubuntu 9.04 (I haven't tried 9.10 yet) the host computer (running Mac OS X) detects a couple of new network devices - CDC Composite Gadgets. One of them appears to be a modem type device, but the second one is an Ethernet port.
If I then configure a static IP on the beagleboard, and a static IP on the same subnet on the Mac, they talk perfectly. I can even configure Internet Connection Sharing to set up a DHCP server and routing on the USB port, and the beagleboard has full internet access...
After I reboot the beagleboard, this device doesn't seem to be visible from the Mac side of things any more. Also, I'm going through a lot of Ethernet interfaces as every time I boot a new build, I see a new device, I'm up to en18 or so by now... This is because I'm assuming it's generating a random MAC address each time it boots.
So, my questions are - does anyone know how to configure this CDC Composite port such that it has a persistent MAC address, and how to ensure it remains active after a reboot?
