On Mon, 21 Jan 2019 11:25:53 -0800 (PST),
thejodenis14@gmail.com declaimed the
following:
I really like your Arduino DUE suggestion, how would you compare his speed
versus the PocketBeagle's?
Arduino DUE:
- Microcontroller with clock speed of 84MHz (AT91SAM3X8E)
- SRAM of 96KB (Two banks: 64KB and 32KB)
PocketBeagle:
- Processor Ocatvo Systems OSD3358 1GHz ARM Cortex-A8
- 512MB DDR3 RAM Integrated
I don't get how to compare a Processor with RAM versus a Microcontroller
with SRAM. (I know that the SRAM is faster than the RAM, but how I could
know in advance which is faster?)
Unless the RAM is so much slower that wait states need to be inserted
you probably don't need to be concerned with the difference -- the main
core of the Beagle is clocked at over 10 times the speed of the Arduino.
Being in the core vs an external chip removes the delays in driving
external memory -- and the overhead of DRAM refresh cycles, but faster
clock speed overwhelms that overhead. If the overhead were even 5 cycles,
the DRAM is still being accessed twice as fast.
In an Arduino, the SRAM is used solely for dynamic data (variables in
code). The code itself sits in FLASH which is mapped into the processor
address space, and executes out of that flash memory directly (hence the
fast restart capability -- the chip start-up basically jumps directly to
the loaded program). The banks probably won't come into play -- I suspect
the compiler(s) are smart enough to insert bank switching (which, true, may
take a processor cycle or two -- so optimizing variables to minimize bank
swapping is a later enhancement for the program). The DUE M3 core does not
have floating point hardware (TIVA C 123 uses an M4F core with 32-bit
floating point).
In the Beagle, the eMMC/SD Card is /not/ mapped into the processor
address space -- it is treated as a "disk" drive. The boot sequence has to
first load an OS image from eMMC into RAM before it can transfer control to
the OS. The OS then loads the application into RAM, sets up process control
structures, etc. before transferring control to the application. Even with
FreeRTOS (most RTOS systems I've been exposed to put all onus on the
application for communication access) your application is still an image
that has to be copied from eMMC to RAM before it gets control. OTOH: since
your application code is also loaded to RAM, you have RAM accesses for both
code and data (a small enough program may end up within cache, which would
reduce the RAM hits if you have a small enough main loop)
{NOTE: one source
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=2ahUKEwi2ksj414DgAhVGja0KHfoWCCcQFjAAegQICxAC&url=http%3A%2F%2Fmeseec.ce.rit.edu%2F551-projects%2Ffall2014%2F2-2.pdf&usg=AOvVaw0MN7jq264ir-9NoAOuOJw7
indicates that a total cache miss results in a 20 cycle overhead}
And if you need to use the PRUs, you'll have to figure out how to load
their program binaries from within your application. The PRUs in a Beagle
run, as I recall, at 200MHz -- so technically, if your application can run
in a PRU, it would be faster than the DUE... But still delayed by the
start-up overhead of the OS (you have to load the main OS before you can
load the PRU program).
In both, if you need networking, you might be looking at building
lwIP - Wikipedia into your application (though Arduino
does have a library for the Ethernet Shield and uses SPI to talk to the
shield, letting it handle the Ethernet hardware connection)
