I’ve got a Beagle with a prototype card and the CAN bus driver installed on it. Connected to the CAN bus is also a Lawicel CANUSB on a PC. I can send messages from a terminal program and the low level CAN device on the Beagle is providing the ACK as the CANUSB does not fault. But I don’t get messages.
The system was updated, upgraded (Buster 10.12) and a new kernel was installed.
debian@beaglebone:~/lazarus/lazcandump$ uname -a
Linux beaglebone 5.10.106-bone62 #1buster SMP PREEMPT Wed Mar 23 00:33:25 UTC 2022 armv7l GNU/Linux
debian@beaglebone:~/lazarus/lazcandump$ cat /etc/*release
PRETTY_NAME="Debian GNU/Linux 10 (buster)"
NAME="Debian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=debian
HOME_URL="https://www.debian.org/"
SUPPORT_URL="https://www.debian.org/support"
BUG_REPORT_URL="https://bugs.debian.org/"
The CAN device was enabled with this:
debian@beaglebone:~/lazarus/lazcandumpsudo ip link set can1 up type can bitrate 250000
and using the socketcan candump program
debian@beaglebone:~/lazarus/lazcandump$ candump can1
It sits and does not show any received messages even though the messages are acknowledged.
Now. Shutdown the Beagle, remove the MicroSD card and replace it with this version SD card.
debian@ebb:~$ uname -a
Linux ebb 4.19.94-ti-r68 #1buster SMP PREEMPT Thu Sep 16 15:32:31 UTC 2021 armv7l GNU/Linux
debian@ebb:~$ cat /etc/*release
VERSION_ID="10"
ID=debian
debian@ebb:~$ cat /etc/dogtag
BeagleBoard.org Debian Image 2018-10-07
debian@ebb:~$ sudo ip link set can1 up type can bitrate 250000
[sudo] password for debian:
debian@ebb:~$ candump can1
can1 123 [4] FE ED C0 DE
Notice this time the candump program works. the ifconfig shows the device is there.
debian@ebb:~$ ifconfig
can1: flags=193<UP,RUNNING,NOARP> mtu 16
unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 10 (UNSPEC)
RX packets 10 bytes 20 (20.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 43
One other odd thing that I doubt is related is that this working system does this when I ask it to shutdown. Very annoying. The other one shuts down immediately.
debian@ebb:~$ sudo shutdown -h now
debian@ebb:~$ [ OK ] Started Show Plymouth Power Off Screen.
[** ] A stop job is running for Session 1 of user debian (20s / 1min 27s)
For the non-working system the results are similar for ifconfig other than it also doesn’t show any received packets and the device interrupt is 48 instead of 43 which may be the clue?
debian@beaglebone:~$ sudo ip link set can1 up type can bitrate 250000
debian@beaglebone:~$ candump can1
^Cdebian@beaglebone:~$ ifconfig
unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 10 ( UNSPEC)
RX packets 0 bytes 0 (0.0 B)
device interrupt 48
So the hardware is the same. the 5.10 version of the kernal and debian also does this for quite some time:
debian@beaglebone:~$ [ 102.084983] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 102.123986] PM: Cannot get wkup_m3_ipc handle
Be nice to also not see this.
