I want to use gpio1[8] as CAN Tx which is currently used for ethernet reset pin.
Can someone please help me in this on how to achieve this?
I’d say it would be a challenge
first:
GPIO1_8 (E18), ETH_RST_GPIO1_8, U1 (SN74AHC1G09DCKR)
you would need to cut a trace some where between GPIO1_8 (E18) and the input of U1
GPIO1_16 (R13), R160, P9-15
then remove R160
then add a jumper between R160, GPIO1_16 (R13) side
and U1 input that came from GPIO1_8 (E18)
after that if you don’t FUBAR things,
you would be ready to update the dts file
then you would need to bring the CAN TX/RX out to somewhere, with jumper wires.
so, IMO, unless your very skilled and have the tools to do this kind of change/work, don’t try it.
Thank you for your reply!
I have managed to do the hardware change…i now want to know what and where i should change the dts file?
Can you please provide me with the necessary dts file required for it?
what image are you working with ?
No worries, the issue has been solved.
Thank you for the help!
