I’m trying to set up can on my beaglebone black. Right now I just want to know it works by communicating via CAN across two different boards.
I was able to send and receive can over one board with vcan, but am currently unable to get can working over two boards
On each board I have run the following commands
config-pin P9_24 can config-pin P9_26 can sudo modprobe can sudo modprobe can-dev sudo modprobe can-raw sudo ip link set can0 up sudo ifconfig can0 up
This is what I get when I run
debian@beaglebone:~/Desktop/can_code$ ifconfig can0 can0: flags=193<UP,RUNNING,NOARP> mtu 16 unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 10 (UNSPEC) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 device interrupt 169
I have set up two BBB’s by connecting two CAN transceivers as shown in the schematic:
I have tried running on board 1
cansend can0 5A1#01.02.03.04.05
and board 2
candump can0
but I am unable to get a reading on board 2.
What steps do I need to take to get can communication between my two boards?
Thank you
