CAN setup in BeagleBone AI-64
If the P9_26_can_pin and P9_24_can_pin macros configure the pins correctly then you should be able to use those.
What I showed is how I configured the pins in my overlay which does work, I have 6 CAN interfaces setup.
Is your overlay actually being loaded ?
No, the overlay is not loaded.
I need one more can connection. Could you please share the DTS file for the other one? I do not know how to create a new one.
Thank You!!!
You will need to be a bit more specific.
Below is the dts I use to enable 6 CAN interfaces, You can leave out the ‘bone_led’ sections.
The pins used are -
MCAN0 RX P9.19
MCAN0 TX P9.20
MCAN4 RX P9.24
MCAN4TX P9.26
MCAN5 RX P8.7
MCAN5 TX P8.8
MCAN6 RX P8.9
MCAN6 TX P8.10
MCAN7 RX P8.6
MCAN7 TX P8.5
MCAN8 RX P8.23
MCAN8 TX P8.21
Remove bits you don’t need.
/dts-v1/;
/plugin/;
#include <dt-bindings/pinctrl/k3.h>
&main_pmx0 {
	main_mcan0_pins_default:main_mcan0-pins-default {
		pinctrl-single,pins = <
		J721E_IOPAD(0x20C, PIN_OUTPUT, 6) /* W6: MCAN0_TX W6_AE25 */
		J721E_IOPAD(0x138, PIN_INPUT, 7) /* AE25: PRG0_PRU1_GPO14 W6_AE25 */
		J721E_IOPAD(0x208, PIN_INPUT, 6) /* W5: MCAN0_RX W5_AF29 */
		J721E_IOPAD(0x13C, PIN_INPUT, 7) /* AF29: PRG0_PRU1_GPO15 W5_AF29 */
	main_mcan4_pins_default:main_mcan4-pins-default {
		J721E_IOPAD(0x30, PIN_OUTPUT, 6)  /* AF24: PRG1_PRU0_GPO11 Y1_AF24 */
		J721E_IOPAD(0x1DC, PIN_INPUT, 7) /* Y1: SPI1_CLK Y1_AF24 */
		J721E_IOPAD(0x34, PIN_INPUT, 6)  /* AJ24: PRG1_PRU0_GPO12 Y5_AJ24 */
		J721E_IOPAD(0x1E0, PIN_INPUT, 7) /* Y5: SPI1_D0 Y5_AJ24 */
	main_mcan5_pins_default:main_mcan5-pins-default {
		J721E_IOPAD(0x38, PIN_OUTPUT, 6)   /* AG24: PRG1_PRU0_GPO13 AG24_MCAN5_TX */
		J721E_IOPAD(0x3C, PIN_INPUT, 6)   /* AD24: PRG1_PRU0_GPO14 AD24_MCAN5_RX */
	main_mcan6_pins_default:main_mcan6-pins-default {
		J721E_IOPAD(0x40, PIN_OUTPUT, 6)   /* AC24: PRG1_PRU0_GPO15 AC24_MCAN6_TX */
		J721E_IOPAD(0x44, PIN_INPUT, 6)   /* AE24: PRG1_PRU0_GPO16 AE24_MCAN6_RX */
	main_mcan7_pins_default:main_mcan7-pins-default {
		J721E_IOPAD(0x88, PIN_OUTPUT, 6)   /* AH25: PRG1_PRU1_GPO12 AH25_MCAN7_TX */
		J721E_IOPAD(0x8C, PIN_INPUT, 6)   /* AG25: PRG1_PRU1_GPO13 AG25_MCAN7_RX */
	main_mcan8_pins_default:main_mcan8-pins-default {
		J721E_IOPAD(0x7C, PIN_OUTPUT, 6)   /* AF21: PRG1_PRU1_GPO9 AF21_MCAN8_TX */
		J721E_IOPAD(0x80, PIN_INPUT, 6)   /* AB23: PRG1_PRU1_GPO10 AB23_MCAN8_RX */
&bone_led_P8_45 {
	label = "CAN0";
	status = "okay";
&bone_led_P9_40 {
	label = "CAN4";
	status = "okay";
&bone_led_P8_40 {
	label = "CAN5";
	status = "okay";
&bone_led_P9_38 {
	label = "CAN6";
	status = "okay";
&bone_led_P8_39 {
	label = "CAN7";
	status = "okay";
&bone_led_P8_44 {
	label = "CAN8";
	status = "okay";
&main_mcan0 {
	status = "okay";
	pinctrl-names = "default";
	pinctrl-0 = <&main_mcan0_pins_default >;
&main_mcan4 {
	status = "okay";
	pinctrl-0 = <&main_mcan4_pins_default >;
&main_mcan5 {
	status = "okay";
	pinctrl-0 = <&main_mcan5_pins_default >;
&main_mcan6 {
	status = "okay";
	pinctrl-0 = <&main_mcan6_pins_default >;
&main_mcan7 {
	status = "okay";
	pinctrl-0 = <&main_mcan7_pins_default >;
&main_mcan8 {
	status = "okay";
	pinctrl-0 = <&main_mcan8_pins_default >;
Thank You so much!!!
I checked the CAN interfaces enabled using ip link. It showed interfaces like can0, can1, can2, etc. How can I find which CAN interface corresponds to the enabled CAN interfaces like MCAN0, MCAN4, etc?
Sir, I have one more doubt. How should I write these hex values, and where can I find them?
Thanks!!
The hex values are the bottom address bits of the pad config registers for the TDA4VM.
They can be found in the datasheet for the chip.
However the file k3-j721e-bone-pins.h has a set of macros P8_xx & P9_xx for the various header pins.
You could use these instead. Not sure why I used the J721E_IOPAD macros directly.
Thank You !!!
Yes they get enumerated as they are discovered which does confuse.
I created a udev rule to rename the interface.
Just create a udev rule in /etc/udev/rules.d/ The below renames the interface name for each of the can interfaces in my dts file to match the physical hardware. Change the NAME to whatever you like.
#11-can.rules
KERNELS=="2701000.can", ACTION=="add", NAME="CAN0"
KERNELS=="2741000.can", ACTION=="add", NAME="CAN4"
KERNELS=="2761000.can", ACTION=="add", NAME="CAN6"
KERNELS=="2781000.can", ACTION=="add", NAME="CAN8"
KERNELS=="2751000.can", ACTION=="add", NAME="CAN5"
KERNELS=="2771000.can", ACTION=="add", NAME="CAN7"
OK …Thank You sir!!
Please let me know where you found this file, not having much luck getting the gpio pins setup on ai64 and this might have a clue.
I am on this branch:
On branch v6.1.x-Beagle
Your branch is up to date with 'origin/v6.1.x-Beagle'.
In the kernel source - include/dt-bindings/board
This is all that is in the tree.
What branch are you in, that might be my problem.
Ok it is from https://github.com/beagleboard/linux.git
Quite an old version
commit d615b5416f8a1afeb82d13b238f8152c572d59c0 (HEAD -> master, origin/master, origin/HEAD)
Okay, thank you I will check that out. Even looked in linux tree and it does not show up.
Yeah just pulled the repo to have a look.
It looks to me as though it has been dropped.
The k3-j721e-beagleboneai64.dts file only uses the J721E_ macros in the pinctrls
That is what I am using, and I am not able to get things working.
If you don’t mind, what branch are you using?
Not sure exaclty. If I try and checkout the above commit, I am also missing the file.
Anyway below is the contents of the file if it helps.
// SPDX-License-Identifier: GPL-2.0-only
 * Copyright (C) 2020 Deepak Khatri <deepaklorkhatri7@gmail.com>
 * Copyright (C) 2021 Jason Kridner <jkridner@beagleboard.org>
 * See Cape Interface Spec page for more info on Bone Buses
 * https://elinux.org/Beagleboard:BeagleBone_cape_interface_spec
#ifndef _DT_BINDINGS_BOARD_TDA4VM_BONE_PINS_H
#define _DT_BINDINGS_BOARD_TDA4VM_BONE_PINS_H
#define bb_device 1
#define board_soc TDA4VM
#define gpio_P8_03 &main_gpio0 20	/* AH21: PRG1_PRU0_GPO19 AH21_MCAN6_TX */
#define gpio_P8_04 &main_gpio0 48	/* AC29: PRG0_PRU0_GPO5 AC29_SYS_BOOTMODE2 */
#define gpio_P8_05 &main_gpio0 33	/* AH25: PRG1_PRU1_GPO12 AH25_MCAN7_TX */
#define gpio_P8_06 &main_gpio0 34	/* AG25: PRG1_PRU1_GPO13 AG25_MCAN7_RX */
#define gpio_P8_07 &main_gpio0 15	/* AD24: PRG1_PRU0_GPO14 AD24_MCAN5_RX */
#define gpio_P8_08 &main_gpio0 14	/* AG24: PRG1_PRU0_GPO13 AG24_MCAN5_TX */
#define gpio_P8_09 &main_gpio0 17	/* AE24: PRG1_PRU0_GPO16 AE24_MCAN6_RX */
#define gpio_P8_10 &main_gpio0 16	/* AC24: PRG1_PRU0_GPO15 AC24_MCAN6_TX */
#define gpio_P8_11 &main_gpio0 60	/* AB24: PRG0_PRU0_GPO17 AB24_SYS_BOOTMODE7 */
#define gpio_P8_12 &main_gpio0 59	/* AH28: PRG0_PRU0_GPO16 AH28_PRG0_PWM0_A2 */
#define gpio_P8_13 &main_gpio0 89	/* V27: RGMII5_TD1 V27_EHRPWM0_B */
#define gpio_P8_14 &main_gpio0 75	/* AF27: PRG0_PRU1_GPO12 AF27_PRG0_PWM1_A0 */
#define gpio_P8_15 &main_gpio0 61	/* AB29: PRG0_PRU0_GPO18 AB29_PRG0_ECAP0_IN_APWM_OUT */
#define gpio_P8_16 &main_gpio0 62	/* AB28: PRG0_PRU0_GPO19 AB28_PRG0_PWM0_TZ_OUT */
#define gpio_P8_17 &main_gpio0 3	/* AF22: PRG1_PRU0_GPO2 AF22_PRG1_PWM2_A0 */
#define gpio_P8_18 &main_gpio0 4	/* AJ23: PRG1_PRU0_GPO3 AJ23_PRG1_PWM3_A2 */
#define gpio_P8_19 &main_gpio0 88	/* V29: RGMII5_TD2 V29_EHRPWM0_A */
#define gpio_P8_20 &main_gpio0 76	/* AF26: PRG0_PRU1_GPO13 AF26_PRG0_PWM1_B0 */
#define gpio_P8_21 &main_gpio0 30	/* AF21: PRG1_PRU1_GPO9 AF21_MCAN8_TX */
#define gpio_P8_22 &main_gpio0 5	/* AH23: PRG1_PRU0_GPO4 AH23_UART2_RXD */
#define gpio_P8_23 &main_gpio0 31	/* AB23: PRG1_PRU1_GPO10 AB23_MCAN8_RX */
#define gpio_P8_24 &main_gpio0 6	/* AD20: PRG1_PRU0_GPO5 AD20_SYS_BOOTMODE0 */
#define gpio_P8_25 &main_gpio0 35	/* AH26: PRG1_PRU1_GPO14 AH26_PRG1_PRU1_GPO14 */
#define gpio_P8_26 &main_gpio0 51	/* AC27: PRG0_PRU0_GPO8 AC27_PRG0_PWM2_A1 */
#define gpio_P8_27 &main_gpio0 71	/* AA28: PRG0_PRU1_GPO8 AA28_PRG0_PRU1_GPO8 */
#define gpio_P8_28 &main_gpio0 72	/* Y24: PRG0_PRU1_GPO9 Y24_PRG0_UART0_RXD */
#define gpio_P8_29 &main_gpio0 73	/* AA25: PRG0_PRU1_GPO10 AA25_PRG0_UART0_TXD */
#define gpio_P8_30 &main_gpio0 74	/* AG26: PRG0_PRU1_GPO11 AG26_PRG0_PRU1_GPO11 */
#define gpio_P8_31 gpio_P8_31A
#define gpio_P8_31A &main_gpio0 32	/* AJ25: PRG1_PRU1_GPO11 AJ25_AE29 */
#define gpio_P8_31B &main_gpio0 63	/* AE29: PRG0_PRU1_GPO0 AJ25_AE29 */
#define gpio_P8_32 gpio_P8_32A
#define gpio_P8_32A &main_gpio0 26	/* AG21: PRG1_PRU1_GPO5 AG21_AD28 */
#define gpio_P8_32B &main_gpio0 64	/* AD28: PRG0_PRU1_GPO1 AG21_AD28 */
#define gpio_P8_33 gpio_P8_33A
#define gpio_P8_33A &main_gpio0 25	/* AH24: PRG1_PRU1_GPO4 AH24_AA2 */
#define gpio_P8_33B &main_gpio0 111	/* AA2: SPI0_CS0 AH24_AA2 */
#define gpio_P8_34 &main_gpio0 7	/* AD22: PRG1_PRU0_GPO6 AD22_UART2_TXD */
#define gpio_P8_35 gpio_P8_35A
#define gpio_P8_35A &main_gpio0 24	/* AD23: PRG1_PRU1_GPO3 AD23_Y3 */
#define gpio_P8_35B &main_gpio0 116	/* Y3: SPI1_CS0 AD23_Y3 */
#define gpio_P8_36 &main_gpio0 8	/* AE20: PRG1_PRU0_GPO7 AE20_MCAN4_TX */
#define gpio_P8_37 gpio_P8_37A
#define gpio_P8_37A &main_gpio0 106	/* Y27: RGMII6_RD2 Y27_AD21 */
#define gpio_P8_37B &main_gpio0 11	/* AD21: PRG1_PRU0_GPO10 Y27_AD21 */
#define gpio_P8_38 gpio_P8_38A
#define gpio_P8_38A &main_gpio0 9	/* AJ20: PRG1_PRU0_GPO8 Y29_AJ20 */
#define gpio_P8_38B &main_gpio0 105	/* Y29: RGMII6_RD3 Y29_AJ20 */
#define gpio_P8_39 &main_gpio0 69	/* AC26: PRG0_PRU1_GPO6 AC26_PRG0_PRU1_GPO6 */
#define gpio_P8_40 &main_gpio0 70	/* AA24: PRG0_PRU1_GPO7 AA24_PRG0_PRU1_GPO7 */
#define gpio_P8_41 &main_gpio0 67	/* AD29: PRG0_PRU1_GPO4 AD29_PRG0_PRU1_GPO4 */
#define gpio_P8_42 &main_gpio0 68	/* AB27: PRG0_PRU1_GPO5 AB27_SYS_BOOTMODE6 */
#define gpio_P8_43 &main_gpio0 65	/* AD27: PRG0_PRU1_GPO2 AD27_PRG0_PRU1_GPO2 */
#define gpio_P8_44 &main_gpio0 66	/* AC25: PRG0_PRU1_GPO3 AC25_PRG0_PRU1_GPO3 */
#define gpio_P8_45 &main_gpio0 79	/* AG29: PRG0_PRU1_GPO16 AG29_PRG0_PRU1_GPO16 */
#define gpio_P8_46 &main_gpio0 80	/* Y25: PRG0_PRU1_GPO17 Y25_SYS_BOOTMODE3 */
#define gpio_P9_11 &main_gpio0 1	/* AC23: PRG1_PRU0_GPO0 AC23_UART0_RXD */
#define gpio_P9_12 &main_gpio0 45	/* AE27: PRG0_PRU0_GPO2 AE27_MCASP0_ACLKR */
#define gpio_P9_13 &main_gpio0 2	/* AG22: PRG1_PRU0_GPO1 AG22_UART0_TXD */
#define gpio_P9_14 &main_gpio0 93	/* U27: RGMII5_RD3 U27_EHRPWM2_A */
#define gpio_P9_15 &main_gpio0 47	/* AD25: PRG0_PRU0_GPO4 AD25_PRG0_PRU0_GPO4 */
#define gpio_P9_16 &main_gpio0 94	/* U24: RGMII5_RD2 U24_EHRPWM2_B */
#define gpio_P9_17 gpio_P9_17A
#define gpio_P9_17A &main_gpio0 28	/* AC21: PRG1_PRU1_GPO7 AC21_AA3 */
#define gpio_P9_17B &main_gpio0 115	/* AA3: SPI0_D1 AC21_AA3 */
#define gpio_P9_18 gpio_P9_18A
#define gpio_P9_18A &main_gpio0 40	/* AH22: PRG1_PRU1_GPO19 AH22_Y2 */
#define gpio_P9_18B &main_gpio0 120	/* Y2: SPI1_D1 AH22_Y2 */
#define gpio_P9_19 gpio_P9_19A
#define gpio_P9_19A &main_gpio1 1	/* W5: MCAN0_RX W5_AF29 */
#define gpio_P9_19B &main_gpio0 78	/* AF29: PRG0_PRU1_GPO15 W5_AF29 */
#define gpio_P9_20 gpio_P9_20A
#define gpio_P9_20A &main_gpio1 2	/* W6: MCAN0_TX W6_AE25 */
#define gpio_P9_20B &main_gpio0 77	/* AE25: PRG0_PRU1_GPO14 W6_AE25 */
#define gpio_P9_21 gpio_P9_21A
#define gpio_P9_21A &main_gpio0 39	/* AJ22: PRG1_PRU1_GPO18 AJ22_U28 */
#define gpio_P9_21B &main_gpio0 90	/* U28: RGMII5_TD0 AJ22_U28 */
#define gpio_P9_22 gpio_P9_22A
#define gpio_P9_22A &main_gpio0 38	/* AC22: PRG1_PRU1_GPO17 AC22_U29 */
#define gpio_P9_22B &main_gpio0 91	/* U29: RGMII5_TXC AC22_U29 */
#define gpio_P9_23 &main_gpio0 10	/* AG20: PRG1_PRU0_GPO9 AG20_SPI6_CS1 */
#define gpio_P9_24 gpio_P9_24A
#define gpio_P9_24A &main_gpio0 119	/* Y5: SPI1_D0 Y5_AJ24 */
#define gpio_P9_24B &main_gpio0 13	/* AJ24: PRG1_PRU0_GPO12 Y5_AJ24 */
#define gpio_P9_25 gpio_P9_25A
#define gpio_P9_25A &main_gpio0 127	/* AC4: UART1_CTSn AC4_W26 */
#define gpio_P9_25B &main_gpio0 104	/* W26: RGMII6_RXC AC4_W26 */
#define gpio_P9_26 gpio_P9_26A
#define gpio_P9_26A &main_gpio0 118	/* Y1: SPI1_CLK Y1_AF24 */
#define gpio_P9_26B &main_gpio0 12	/* AF24: PRG1_PRU0_GPO11 Y1_AF24 */
#define gpio_P9_27 gpio_P9_27A
#define gpio_P9_27A &main_gpio0 46	/* AD26: PRG0_PRU0_GPO3 AD26_AB1 */
#define gpio_P9_27B &main_gpio0 124	/* AB1: UART0_RTSn AD26_AB1 */
#define gpio_P9_28 gpio_P9_28A
#define gpio_P9_28A &main_gpio1 11	/* U2: ECAP0_IN_APWM_OUT U2_AF28 */
#define gpio_P9_28B &main_gpio0 43	/* AF28: PRG0_PRU0_GPO0 U2_AF28 */
#define gpio_P9_29 gpio_P9_29A
#define gpio_P9_29A &main_gpio1 14	/* V5: TIMER_IO1 V5_AB25 */
#define gpio_P9_29B &main_gpio0 53	/* AB25: PRG0_PRU0_GPO10 V5_AB25 */
#define gpio_P9_30 gpio_P9_30A
#define gpio_P9_30A &main_gpio1 13	/* V6: TIMER_IO0 V6_AE28 */
#define gpio_P9_30B &main_gpio0 44	/* AE28: PRG0_PRU0_GPO1 V6_AE28 */
#define gpio_P9_31 gpio_P9_31A
#define gpio_P9_31A &main_gpio1 12	/* U3: EXT_REFCLK1 U3_AB26 */
#define gpio_P9_31B &main_gpio0 52	/* AB26: PRG0_PRU0_GPO9 U3_AB26 */
#define gpio_P9_33 &main_gpio0 50
#define gpio_P9_33B &main_gpio0 50	/* AC28: PRG0_PRU0_GPO7 K24_AC28 */
#define gpio_P9_35 &main_gpio0 55
#define gpio_P9_35B &main_gpio0 55	/* AH27: PRG0_PRU0_GPO12 K29_AH27 */
#define gpio_P9_36 &main_gpio0 56
#define gpio_P9_36B &main_gpio0 56	/* AH29: PRG0_PRU0_GPO13 K27_AH29 */
#define gpio_P9_37 &main_gpio0 57
#define gpio_P9_37B &main_gpio0 57	/* AG28: PRG0_PRU0_GPO14 K28_AG28 */
#define gpio_P9_38 &main_gpio0 58
#define gpio_P9_38B &main_gpio0 58	/* AG27: PRG0_PRU0_GPO15 L28_AG27 */
#define gpio_P9_39 &main_gpio0 54
#define gpio_P9_39B &main_gpio0 54	/* AJ28: PRG0_PRU0_GPO11 K25_AJ28 */
#define gpio_P9_40 &main_gpio0 81
#define gpio_P9_40B &main_gpio0 81	/* AA26: PRG0_PRU1_GPO18 K26_AA26 */
#define gpio_P9_41 &main_gpio1 0	/* AD5: UART1_RTSn AD5_EQEP0_I */
#define gpio_P9_42 gpio_P9_42A
#define gpio_P9_42A &main_gpio0 123	/* AC2: UART0_CTSn AC2_AJ21 */
#define gpio_P9_42B &main_gpio0 18	/* AJ21: PRG1_PRU0_GPO17 AC2_AJ21 */
#define P8_03(mode, mux) J721E_IOPAD(0x54, mode, mux)	/* AH21: PRG1_PRU0_GPO19 AH21_MCAN6_TX */
#define P8_04(mode, mux) J721E_IOPAD(0xC4, mode, mux)	/* AC29: PRG0_PRU0_GPO5 AC29_SYS_BOOTMODE2 */
#define P8_05(mode, mux) J721E_IOPAD(0x88, mode, mux)	/* AH25: PRG1_PRU1_GPO12 AH25_MCAN7_TX */
#define P8_06(mode, mux) J721E_IOPAD(0x8C, mode, mux)	/* AG25: PRG1_PRU1_GPO13 AG25_MCAN7_RX */
#define P8_07(mode, mux) J721E_IOPAD(0x3C, mode, mux)	/* AD24: PRG1_PRU0_GPO14 AD24_MCAN5_RX */
#define P8_08(mode, mux) J721E_IOPAD(0x38, mode, mux)	/* AG24: PRG1_PRU0_GPO13 AG24_MCAN5_TX */
#define P8_09(mode, mux) J721E_IOPAD(0x44, mode, mux)	/* AE24: PRG1_PRU0_GPO16 AE24_MCAN6_RX */
#define P8_10(mode, mux) J721E_IOPAD(0x40, mode, mux)	/* AC24: PRG1_PRU0_GPO15 AC24_MCAN6_TX */
#define P8_11(mode, mux) J721E_IOPAD(0xF4, mode, mux)	/* AB24: PRG0_PRU0_GPO17 AB24_SYS_BOOTMODE7 */
#define P8_12(mode, mux) J721E_IOPAD(0xF0, mode, mux)	/* AH28: PRG0_PRU0_GPO16 AH28_PRG0_PWM0_A2 */
#define P8_13(mode, mux) J721E_IOPAD(0x168, mode, mux)	/* V27: RGMII5_TD1 V27_EHRPWM0_B */
#define P8_14(mode, mux) J721E_IOPAD(0x130, mode, mux)	/* AF27: PRG0_PRU1_GPO12 AF27_PRG0_PWM1_A0 */
#define P8_15(mode, mux) J721E_IOPAD(0xF8, mode, mux)	/* AB29: PRG0_PRU0_GPO18 AB29_PRG0_ECAP0_IN_APWM_OUT */
#define P8_16(mode, mux) J721E_IOPAD(0xFC, mode, mux)	/* AB28: PRG0_PRU0_GPO19 AB28_PRG0_PWM0_TZ_OUT */
#define P8_17(mode, mux) J721E_IOPAD(0xC, mode, mux)	/* AF22: PRG1_PRU0_GPO2 AF22_PRG1_PWM2_A0 */
#define P8_18(mode, mux) J721E_IOPAD(0x10, mode, mux)	/* AJ23: PRG1_PRU0_GPO3 AJ23_PRG1_PWM3_A2 */
#define P8_19(mode, mux) J721E_IOPAD(0x164, mode, mux)	/* V29: RGMII5_TD2 V29_EHRPWM0_A */
#define P8_20(mode, mux) J721E_IOPAD(0x134, mode, mux)	/* AF26: PRG0_PRU1_GPO13 AF26_PRG0_PWM1_B0 */
#define P8_21(mode, mux) J721E_IOPAD(0x7C, mode, mux)	/* AF21: PRG1_PRU1_GPO9 AF21_MCAN8_TX */
#define P8_22(mode, mux) J721E_IOPAD(0x14, mode, mux)	/* AH23: PRG1_PRU0_GPO4 AH23_UART2_RXD */
#define P8_23(mode, mux) J721E_IOPAD(0x80, mode, mux)	/* AB23: PRG1_PRU1_GPO10 AB23_MCAN8_RX */
#define P8_24(mode, mux) J721E_IOPAD(0x18, mode, mux)	/* AD20: PRG1_PRU0_GPO5 AD20_SYS_BOOTMODE0 */
#define P8_25(mode, mux) J721E_IOPAD(0x90, mode, mux)	/* AH26: PRG1_PRU1_GPO14 AH26_PRG1_PRU1_GPO14 */
#define P8_26(mode, mux) J721E_IOPAD(0xD0, mode, mux)	/* AC27: PRG0_PRU0_GPO8 AC27_PRG0_PWM2_A1 */
#define P8_27(mode, mux) J721E_IOPAD(0x120, mode, mux)	/* AA28: PRG0_PRU1_GPO8 AA28_PRG0_PRU1_GPO8 */
#define P8_28(mode, mux) J721E_IOPAD(0x124, mode, mux)	/* Y24: PRG0_PRU1_GPO9 Y24_PRG0_UART0_RXD */
#define P8_29(mode, mux) J721E_IOPAD(0x128, mode, mux)	/* AA25: PRG0_PRU1_GPO10 AA25_PRG0_UART0_TXD */
#define P8_30(mode, mux) J721E_IOPAD(0x12C, mode, mux)	/* AG26: PRG0_PRU1_GPO11 AG26_PRG0_PRU1_GPO11 */
#define P8_31A(mode, mux) J721E_IOPAD(0x84, mode, mux)	/* AJ25: PRG1_PRU1_GPO11 AJ25_AE29 */
#define P8_31B(mode, mux) J721E_IOPAD(0x100, mode, mux)	/* AE29: PRG0_PRU1_GPO0 AJ25_AE29 */
#define P8_32A(mode, mux) J721E_IOPAD(0x6C, mode, mux)	/* AG21: PRG1_PRU1_GPO5 AG21_AD28 */
#define P8_32B(mode, mux) J721E_IOPAD(0x104, mode, mux)	/* AD28: PRG0_PRU1_GPO1 AG21_AD28 */
#define P8_33A(mode, mux) J721E_IOPAD(0x68, mode, mux)	/* AH24: PRG1_PRU1_GPO4 AH24_AA2 */
#define P8_33B(mode, mux) J721E_IOPAD(0x1C0, mode, mux)	/* AA2: SPI0_CS0 AH24_AA2 */
#define P8_34(mode, mux) J721E_IOPAD(0x1C, mode, mux)	/* AD22: PRG1_PRU0_GPO6 AD22_UART2_TXD */
#define P8_35A(mode, mux) J721E_IOPAD(0x64, mode, mux)	/* AD23: PRG1_PRU1_GPO3 AD23_Y3 */
#define P8_35B(mode, mux) J721E_IOPAD(0x1D4, mode, mux)	/* Y3: SPI1_CS0 AD23_Y3 */
#define P8_36(mode, mux) J721E_IOPAD(0x20, mode, mux)	/* AE20: PRG1_PRU0_GPO7 AE20_MCAN4_TX */
#define P8_37A(mode, mux) J721E_IOPAD(0x1AC, mode, mux)	/* Y27: RGMII6_RD2 Y27_AD21 */
#define P8_37B(mode, mux) J721E_IOPAD(0x2C, mode, mux)	/* AD21: PRG1_PRU0_GPO10 Y27_AD21 */
#define P8_38A(mode, mux) J721E_IOPAD(0x24, mode, mux)	/* AJ20: PRG1_PRU0_GPO8 Y29_AJ20 */
#define P8_38B(mode, mux) J721E_IOPAD(0x1A8, mode, mux)	/* Y29: RGMII6_RD3 Y29_AJ20 */
#define P8_39(mode, mux) J721E_IOPAD(0x118, mode, mux)	/* AC26: PRG0_PRU1_GPO6 AC26_PRG0_PRU1_GPO6 */
#define P8_40(mode, mux) J721E_IOPAD(0x11C, mode, mux)	/* AA24: PRG0_PRU1_GPO7 AA24_PRG0_PRU1_GPO7 */
#define P8_41(mode, mux) J721E_IOPAD(0x110, mode, mux)	/* AD29: PRG0_PRU1_GPO4 AD29_PRG0_PRU1_GPO4 */
#define P8_42(mode, mux) J721E_IOPAD(0x114, mode, mux)	/* AB27: PRG0_PRU1_GPO5 AB27_SYS_BOOTMODE6 */
#define P8_43(mode, mux) J721E_IOPAD(0x108, mode, mux)	/* AD27: PRG0_PRU1_GPO2 AD27_PRG0_PRU1_GPO2 */
#define P8_44(mode, mux) J721E_IOPAD(0x10C, mode, mux)	/* AC25: PRG0_PRU1_GPO3 AC25_PRG0_PRU1_GPO3 */
#define P8_45(mode, mux) J721E_IOPAD(0x140, mode, mux)	/* AG29: PRG0_PRU1_GPO16 AG29_PRG0_PRU1_GPO16 */
#define P8_46(mode, mux) J721E_IOPAD(0x144, mode, mux)	/* Y25: PRG0_PRU1_GPO17 Y25_SYS_BOOTMODE3 */
#define P9_11(mode, mux) J721E_IOPAD(0x4, mode, mux)	/* AC23: PRG1_PRU0_GPO0 AC23_UART0_RXD */
#define P9_12(mode, mux) J721E_IOPAD(0xB8, mode, mux)	/* AE27: PRG0_PRU0_GPO2 AE27_MCASP0_ACLKR */
#define P9_13(mode, mux) J721E_IOPAD(0x8, mode, mux)	/* AG22: PRG1_PRU0_GPO1 AG22_UART0_TXD */
#define P9_14(mode, mux) J721E_IOPAD(0x178, mode, mux)	/* U27: RGMII5_RD3 U27_EHRPWM2_A */
#define P9_15(mode, mux) J721E_IOPAD(0xC0, mode, mux)	/* AD25: PRG0_PRU0_GPO4 AD25_PRG0_PRU0_GPO4 */
#define P9_16(mode, mux) J721E_IOPAD(0x17C, mode, mux)	/* U24: RGMII5_RD2 U24_EHRPWM2_B */
#define P9_17A(mode, mux) J721E_IOPAD(0x74, mode, mux)	/* AC21: PRG1_PRU1_GPO7 AC21_AA3 */
#define P9_17B(mode, mux) J721E_IOPAD(0x1D0, mode, mux)	/* AA3: SPI0_D1 AC21_AA3 */
#define P9_18A(mode, mux) J721E_IOPAD(0xA4, mode, mux)	/* AH22: PRG1_PRU1_GPO19 AH22_Y2 */
#define P9_18B(mode, mux) J721E_IOPAD(0x1E4, mode, mux)	/* Y2: SPI1_D1 AH22_Y2 */
#define P9_19A(mode, mux) J721E_IOPAD(0x208, mode, mux)	/* W5: MCAN0_RX W5_AF29 */
#define P9_19B(mode, mux) J721E_IOPAD(0x13C, mode, mux)	/* AF29: PRG0_PRU1_GPO15 W5_AF29 */
#define P9_20A(mode, mux) J721E_IOPAD(0x20C, mode, mux)	/* W6: MCAN0_TX W6_AE25 */
#define P9_20B(mode, mux) J721E_IOPAD(0x138, mode, mux)	/* AE25: PRG0_PRU1_GPO14 W6_AE25 */
#define P9_21A(mode, mux) J721E_IOPAD(0xA0, mode, mux)	/* AJ22: PRG1_PRU1_GPO18 AJ22_U28 */
#define P9_21B(mode, mux) J721E_IOPAD(0x16C, mode, mux)	/* U28: RGMII5_TD0 AJ22_U28 */
#define P9_22A(mode, mux) J721E_IOPAD(0x9C, mode, mux)	/* AC22: PRG1_PRU1_GPO17 AC22_U29 */
#define P9_22B(mode, mux) J721E_IOPAD(0x170, mode, mux)	/* U29: RGMII5_TXC AC22_U29 */
#define P9_23(mode, mux) J721E_IOPAD(0x28, mode, mux)	/* AG20: PRG1_PRU0_GPO9 AG20_SPI6_CS1 */
#define P9_24A(mode, mux) J721E_IOPAD(0x1E0, mode, mux)	/* Y5: SPI1_D0 Y5_AJ24 */
#define P9_24B(mode, mux) J721E_IOPAD(0x34, mode, mux)	/* AJ24: PRG1_PRU0_GPO12 Y5_AJ24 */
#define P9_25A(mode, mux) J721E_IOPAD(0x200, mode, mux)	/* AC4: UART1_CTSn AC4_W26 */
#define P9_25B(mode, mux) J721E_IOPAD(0x1A4, mode, mux)	/* W26: RGMII6_RXC AC4_W26 */
#define P9_26A(mode, mux) J721E_IOPAD(0x1DC, mode, mux)	/* Y1: SPI1_CLK Y1_AF24 */
#define P9_26B(mode, mux) J721E_IOPAD(0x30, mode, mux)	/* AF24: PRG1_PRU0_GPO11 Y1_AF24 */
#define P9_27A(mode, mux) J721E_IOPAD(0xBC, mode, mux)	/* AD26: PRG0_PRU0_GPO3 AD26_AB1 */
#define P9_27B(mode, mux) J721E_IOPAD(0x1F4, mode, mux)	/* AB1: UART0_RTSn AD26_AB1 */
#define P9_28A(mode, mux) J721E_IOPAD(0x230, mode, mux)	/* U2: ECAP0_IN_APWM_OUT U2_AF28 */
#define P9_28B(mode, mux) J721E_IOPAD(0xB0, mode, mux)	/* AF28: PRG0_PRU0_GPO0 U2_AF28 */
#define P9_29A(mode, mux) J721E_IOPAD(0x23C, mode, mux)	/* V5: TIMER_IO1 V5_AB25 */
#define P9_29B(mode, mux) J721E_IOPAD(0xD8, mode, mux)	/* AB25: PRG0_PRU0_GPO10 V5_AB25 */
#define P9_30A(mode, mux) J721E_IOPAD(0x238, mode, mux)	/* V6: TIMER_IO0 V6_AE28 */
#define P9_30B(mode, mux) J721E_IOPAD(0xB4, mode, mux)	/* AE28: PRG0_PRU0_GPO1 V6_AE28 */
#define P9_31A(mode, mux) J721E_IOPAD(0x234, mode, mux)	/* U3: EXT_REFCLK1 U3_AB26 */
#define P9_31B(mode, mux) J721E_IOPAD(0xD4, mode, mux)	/* AB26: PRG0_PRU0_GPO9 U3_AB26 */
#define P9_33A(mode, mux) J721E_WKUP_IOPAD(0x140, mode, mux)	/* K24: MCU_ADC0_AIN4 K24_AC28 */
#define P9_33B(mode, mux) J721E_IOPAD(0xCC, mode, mux)	/* AC28: PRG0_PRU0_GPO7 K24_AC28 */
#define P9_35A(mode, mux) J721E_WKUP_IOPAD(0x148, mode, mux)	/* K29: MCU_ADC0_AIN6 K29_AH27 */
#define P9_35B(mode, mux) J721E_IOPAD(0xE0, mode, mux)	/* AH27: PRG0_PRU0_GPO12 K29_AH27 */
#define P9_36A(mode, mux) J721E_WKUP_IOPAD(0x144, mode, mux)	/* K27: MCU_ADC0_AIN5 K27_AH29 */
#define P9_36B(mode, mux) J721E_IOPAD(0xE4, mode, mux)	/* AH29: PRG0_PRU0_GPO13 K27_AH29 */
#define P9_37A(mode, mux) J721E_WKUP_IOPAD(0x138, mode, mux)	/* K28: MCU_ADC0_AIN2 K28_AG28 */
#define P9_37B(mode, mux) J721E_IOPAD(0xE8, mode, mux)	/* AG28: PRG0_PRU0_GPO14 K28_AG28 */
#define P9_38A(mode, mux) J721E_WKUP_IOPAD(0x13C, mode, mux)	/* L28: MCU_ADC0_AIN3 L28_AG27 */
#define P9_38B(mode, mux) J721E_IOPAD(0xEC, mode, mux)	/* AG27: PRG0_PRU0_GPO15 L28_AG27 */
#define P9_39A(mode, mux) J721E_WKUP_IOPAD(0x130, mode, mux)	/* K25: MCU_ADC0_AIN0 K25_AJ28 */
#define P9_39B(mode, mux) J721E_IOPAD(0xDC, mode, mux)	/* AJ28: PRG0_PRU0_GPO11 K25_AJ28 */
#define P9_40A(mode, mux) J721E_WKUP_IOPAD(0x134, mode, mux)	/* K26: MCU_ADC0_AIN1 K26_AA26 */
#define P9_40B(mode, mux) J721E_IOPAD(0x148, mode, mux)	/* AA26: PRG0_PRU1_GPO18 K26_AA26 */
#define P9_41(mode, mux) J721E_IOPAD(0x204, mode, mux)	/* AD5: UART1_RTSn AD5_EQEP0_I */
#define P9_42A(mode, mux) J721E_IOPAD(0x1F0, mode, mux)	/* AC2: UART0_CTSn AC2_AJ21 */
#define P9_42B(mode, mux) J721E_IOPAD(0x4C, mode, mux)	/* AJ21: PRG1_PRU0_GPO17 AC2_AJ21 */
#endif
The file exists in v5.10.168-ti-arm64-r100 probaby lots more. I think I originally pulled a 5.10 kernel.
OK found the original branch I used - 5.10.120-ti-arm64-r57
