When I run my javascript in Cloud9 I get the following warning and I don’t know what it means.
Also I can’t access the web page the script is supposed to be serving. The relevant code is posted below the warning.
Running Node Process
Your code is running at ‘http://0.0.0.0:46464’.
Important: in your scripts, use ‘process.env.PORT’ as port and ‘0.0.0.0’ as host.
info: socket.io started
Server running on: http://192.168.10.108:8080
Code Start:
var app = require(‘http’).createServer(handler);
var io = require(‘socket.io’).listen(app);
var fs = require(‘fs’);
var b = require(‘bonescript’);
app.listen(8080);
// socket.io options go here
io.set(‘log level’, 2); // reduce logging - set 1 for warn, 2 for info, 3 for debug
io.set(‘browser client minification’, true); // send minified client
io.set(‘browser client etag’, true); // apply etag caching logic based on version number
console.log(‘Server running on: http://’ + getIPAddress() + ‘:8080’);
var outputPin1 = “P8_16”; //0.5dB
var outputPin2 = ‘P8_11’; //1dB
var outputPin3 = ‘P8_12’; //2dB
var outputPin4 = ‘P8_14’; //4db
var outputPin5 = ‘P8_15’; //8dB
var outputPin6 = ‘P8_17’; //Latch Enable
// configure pins and set all low
b.pinMode(outputPin1, ‘out’);
b.pinMode(outputPin2, ‘out’);
b.pinMode(outputPin3, ‘out’);
b.pinMode(outputPin4, ‘out’);
b.pinMode(outputPin5, ‘out’);
b.pinMode(outputPin6, ‘out’);
function handler (req, res) {
if (req.url == “/favicon.ico”){ // handle requests for favico.ico
res.writeHead(200, {‘Content-Type’: ‘image/x-icon’} );
res.end();
console.log(‘favicon requested’);
return;
fs.readFile(‘webpage.html’, // load html file
function (err, data) {
if (err) {
res.writeHead(500);
return res.end(‘Error loading webpage.html’);
res.writeHead(200);
res.end(data);
io.sockets.on(‘connection’, function (socket) {
// This is where we check the status of each Switch on the GUI
socket.on(‘Output1’, function (data) {
if (data == ‘on’) {
//Set the Pin High
b.digitalWrite(outputPin1,1);
console.log (“0.5dB On”);
} else if (data == ‘off’) {
//Set the Pin Low
b.digitalWrite(outputPin1,0);
console.log (“0.5dB Off”);
// Get server IP address on LAN
function getIPAddress() {
var interfaces = require(‘os’).networkInterfaces();
for (var devName in interfaces) {
var iface = interfaces[devName];
for (var i = 0; i < iface.length; i++) {
var alias = iface[i];
if (alias.family === ‘IPv4’ && alias.address !== ‘127.0.0.1’ && !alias.internal)
return alias.address;
return ‘0.0.0.0’;
http://www.packtpub.com/building-a-home-security-system-with-beaglebone/book
