I´m using Debian Jessie 8.7 (Kernel 4.4.54) on my BBB. In the long-run I want to connect a LCD Display via the 16Bit Interface to the BBB. So I have to disabled the HDMI (Audio/Video) by uncommenting this in the uEnv.txt right?
#In the event of edid real failures, uncomment this next line:
#cmdline=coherent_pool=1M net.ifnames=0 quiet cape_universal=enable video=HDMI-A-1:1024x768@60e
But for now I try to load anything to my slotsfile, for example the PWM, but it seems like nothing happens:
To connect a 4.3" LCD (it´s not a cape) to my BBB I have to load a LCD overlay, for example the “BB-BONE-LCD4-01-00A1.dtbo”, which my 4D Systems LCD Cape uses, right? Can I adapt that dtbo to make it work with my non-cape display?
Try
sudo echo BB-PWM1 > /sys/devices/platform/bone_capemgr/slots
You can decompile the dtb by
dtc -@ -I dtb -O dtc -o BB-BONE-LCD4-01-00A1.dts BB-BONE-LCD4-01-00A1.dtbo
Chad
i figgured out that you have to be root to echo into the slotsfile, sudo with debian user is not enough.
Just in case someone else has the same issue: When you write an overlay for your custom cape, you have to include it over /etc/defaut/capemgr, NOT via /boot/uEnv ! This is for Debian Jessie 8.7 (4.4.54). All the changes with different kernels are confusing me so much as a beginner.
That's incorrect, and stated in my previous email
sudo echo "something" > "somewhere"
doesn't work..
You need to:
sudo sh -C "echo 'BB-PWM1-00A0.dtbo' > /sys/devices/platform/bone_capemgr/slots"
Then it works..
/boot/uEnv !
This just means the *.dtbo file isn't in the "initramfs"..
sudo update-initramfs -uk `uname -r`
and reboot..
I’ve tried your solution by typing : sudo sh -C “echo ‘bone_pwm_P9_14’ > /sys/devices/platform/bone_capemgr/slots”
But it didn’t work. I have the following error : sh: 0: Can’t open echo ‘bone_pwm_P9_14’ >/sys/devices/platform/bone_capemgr/slots
I just want to control the PWM module from pin P9_14. How can I do that in the latest debian image ?
