I have 3 stock Rev.C element14 BeagleBone Black boards and cannot apt-get install packages on any of them due to errors caused by an init script called ‘led-aging.sh’.
Here’s what I get:
insserv: warning: script ‘S18led_aging’ missing LSB tags and overrides
insserv: warning: script ‘led_aging.sh’ missing LSB tags and overrides
insserv: There is a loop between service rmnologin and mountnfs if started
insserv: loop involving service mountnfs at depth 7
insserv: loop involving service networking at depth 6
insserv: There is a loop between service led_aging and mountall if started
insserv: loop involving service mountall at depth 5
insserv: loop involving service checkroot-bootclean at depth 4
insserv: loop involving service urandom at depth 7
insserv: loop involving service checkfs at depth 5
insserv: There is a loop between service rmnologin and mountdevsubfs if started
insserv: loop involving service mountdevsubfs at depth 2
insserv: loop involving service udev at depth 1
insserv: There is a loop at service rmnologin if started
insserv: There is a loop between service rmnologin and mountnfs-bootclean if started
insserv: loop involving service mountnfs-bootclean at depth 2
insserv: loop involving service mountall-bootclean at depth 1
insserv: loop involving service kbd at depth 11
insserv: Starting led_aging.sh depends on rmnologin and therefore on system facility `$all’ which can not be true!
insserv: Max recursions depth 99 reached
insserv: loop involving service capemgr.sh at depth 1
insserv: There is a loop at service led_aging if started
insserv: loop involving service hwclock at depth 4
insserv: There is a loop between service led_aging and mountall-bootclean if started
insserv: exiting now without changing boot order!
update-rc.d: error: insserv rejected the script header
Removing the script altogether using update-rc.d causes the problem to go away, but I’d rather not solve it this way…
What does the script do? Is this an element14 BBB-specific issue?
I couldn’t find any information about the script except for one forum post in Chinese regarding LED driver development.
Thanks in advance,
Simon
