I am reading tutorial from: https://github.com/digitalbond/canbus-beaglebone
I have run
npm install -g socketcan
with a following result
socketcan@2.1.3 install /usr/local/lib/node_modules/socketcan
node-gyp rebuild
gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/0.12.17"
gyp WARN EACCES attempting to reinstall using temporary dev dir "/usr/local/lib/node_modules/socketcan/.node-gyp"
make: Entering directory '/usr/local/lib/node_modules/socketcan/build'
CXX(target) Release/obj.target/can/src/rawchannel.o
SOLINK_MODULE(target) Release/obj.target/can.node
COPY Release/can.node
CXX(target) Release/obj.target/can_signals/src/signals.o
SOLINK_MODULE(target) Release/obj.target/can_signals.node
COPY Release/can_signals.node
make: Leaving directory '/usr/local/lib/node_modules/socketcan/build'
socketcan@2.1.3 /usr/local/lib/node_modules/socketcan
âââ nan@2.5.1
âââ xml2js@0.4.17 (sax@1.2.2, xmlbuilder@4.2.1)
Then I have typed:
root@beaglebone:~# node
var can = require('socketcan');
Error: Cannot find module 'socketcan'
at Function.Module._resolveFilename (module.js:336:15)
at Function.Module._load (module.js:278:25)
at Module.require (module.js:365:17)
at require (module.js:384:17)
at repl:1:11
at REPLServer.defaultEval (repl.js:132:27)
at bound (domain.js:291:14)
at REPLServer.runBound [as eval] (domain.js:304:12)
at REPLServer.<anonymous> (repl.js:279:12)
at REPLServer.emit (events.js:107:17)
Do you know why I am getting this error even though the installation seems successful?
Thank you in advance
