Cannot get pinmuxing to work
I’m a newbie trying to program the Beaglebone Black PRU for a school project and I’m having some trouble with pinmuxing on the board.
I’d like to connect some of the board’s pins to the PRU, but some of them don’t work. For example, running the following command :
config-pin -a P8_45 pruin
Yields the following error :
P8_45 pinmux file not found!
bash: /sys/devices/platform/ocp/ocpP8_45_pinmux/state: No such file or directory
Cannot write pinmux file: /sys/devices/platform/ocp/ocp
P8_45_pinmux/state
I tried running this command before, but nothing changed :
config-pin overlay cape-universala
Do you know what the problem might be ?
I am using the Debian 9.2 2017-10-10 4GB SD IoT image found there and this is the output of uname -a :
Linux beaglebone 4.4.91-ti-r133 #1 SMP Tue Oct 10 05:18:08 UTC 2017 armv7l GNU/Linux
Thanks in advance,
Loïc
P8_45 is used by hdmi:
in /boot/uEnv.txt you need to set:
disable_uboot_overlay_video=1
and reboot
Full Docs are here:
https://elinux.org/Beagleboard:BeagleBoneBlack_Debian#U-Boot_Overlays
