Cannot get ubuntu work on beagleboard C4
I tried all the methods (for prebuilt demo image) mentioned at:
http://elinux.org/BeagleBoardUbuntu
I still cannot get ubuntu work. For Lucid and Maverick, I can get it
boot on the single user mode. Is there a way to get it directly boot
to multi-user mode just like a regular Ubuntu on desktop?
For NetInstall, it brought me to the installation screen and alway
complains the root file system and cannot go any further.
Any idea? Thanks a lot for the help.
Tao
BeagleBoardUbuntu - eLinux.org
Strange can you be more specific? Did you do anything different then
what was written on the wiki? bootarg's etc are VERY important.. A
full serial boot log from power on will help us troubleshoot your
issue..
What does it complain about? error message/screen shot etc?
Thanks a lot for the response.
Really nothing special. All I did are:
wget http://rcn-ee.net/deb/rootfs/ubuntu-10.04-minimal-armel.tar.7z
7za x ubuntu-10.04-minimal-armel.tar.7z
tar xf ubuntu-10.04-minimal-armel.tar
cd ubuntu-10.04-minimal-armel
./setup_sdcard.sh --mmc /dev/sdb --uboot beagle_c4
Then, put sd card into beagleboard and hold "USER" button and click
"RESET". It will boot to single user mode every time.
I have HDMI cable connect to a monitor and have usb keyboard and mouse
connected to beagle board via powered USB hub. I don't have serial
cable right now.
Tao
That's good..
SO it looks like this???:
[ 5.158752] sd 0:0:0:0: [sda] Assuming drive cache: write through
Ubuntu 10.04 LTS beagleboard ttyS2
beagleboard login:
??? If not post the actual error/or problem with a screen shot...
Here is part of teraterm log (don't know how to attach a file):
[ 0.000000] Kernel command line: console=tty0
console=ttyS2,115200n8 root=/de
v/mmcblk0p2 rootwait ro vram=12M omapfb.mode=dvi:1280x720MR-16@60
fixrtc mpurate
=720
[ 26.105468] cmdlinepart partition parsing not available
[ 26.110870] Creating 5 MTD partitions on "omap2-nand":
[ 26.116058] 0x000000000000-0x000000080000 : "X-Loader"
[ 26.122467] 0x000000080000-0x000000260000 : "U-Boot"
[ 26.128906] 0x000000260000-0x000000280000 : "U-Boot Env"
[ 26.134948] 0x000000280000-0x000000680000 : "Kernel"
[ 26.142242] 0x000000680000-0x000010000000 : "File System"
Loading, please wait...
[ 27.039886] udev: starting version 151
Begin: Loading essential drivers... ...
Done.
Begin: Running /scripts/init-premount ...
Done.
Begin: Mounting root file system... ...
Begin: Running /scripts/local-top ...
Done.
[ 27.905700] mmc0: new high speed SDHC card at address 1234
[ 27.913452] mmcblk0: mmc0:1234 SA04G 3.68 GiB
[ 27.918395] mmcblk0: p1 p2
Begin: Running /scripts/local-premount ...
Done.
[ 28.161956] EXT3-fs: INFO: recovery required on readonly
filesystem.
[ 28.168670] EXT3-fs: write access will be enabled during recovery.
[ 30.656250] EXT3-fs: recovery complete.
[ 30.660369] kjournald starting. Commit interval 5 seconds
[ 30.912170] EXT3-fs: mounted filesystem with writeback data mode.
Begin: Running /scripts/local-bottom ...
Done.
Done.
Begin: Running /scripts/init-bottom ...
Done.
init: ureadahead main process (171) terminated with status 5
fsck from util-linux-ng 2.17.2
init: procps main process (192) terminated with status 255
rootfs: clean, 14547/237104 files, 172157/947835 blocks
init: ureadahead-other main process (348) terminated with status 4
beagleboard login: ubuntu
Password:
Then, enter the single user mode. Thanks,
Tao
for the future pastebin.com is a good source for posting these.. :wink:
fixrtc mpurate
=720
Done.
Done.
Done.
Done.
filesystem.
Done.
Done.
Done.
Password:
Yeah so, it's called a "minimal" rootfs,
(ubuntu-10.04-minimal-armel.tar.7z) that's exactly what you get a very
minimal base os ready for you to install 'anything' with "apt-get" and
friends.
Thanks a lot for the response! I think I am missing this part:
sudo rootstock --fqdn beagleboard --login ubuntu --password temppwd --
imagesize 2G \
--seed wget,nano,linux-firmware,wireless-tools,usbutils --dist lucid --
serial ttyS2 \
--script fixup.sh --components "main universe multiverse" \
--kernel-image http://rcn-ee.net/deb/kernel/beagle/lucid/v2.6.32.11-l13/linux-image-2.6.32.11-l13_1.0lucid_armel.deb
however, when I try to do it, I got the following error:
I: Extracting zlib1g...
chroot: cannot run command `debootstrap/debootstrap': Exec format
error
I: First stage install done
I: Downloading kernel image (deb) from external site
and the dl directory is empty.
imagesize 2G \
serial ttyS2 \
Yeah, I'm sorry... I don't have unlimited hosting space so I only
keep the last 3-4 releases on rcn-ee.net..
Cable Modem Mirror:
http://rcn-ee.homeip.net:81/dl/mirrors/deb/kernel/beagle/lucid/v2.6.32.11-l13/linux-image-2.6.32.11-l13_1.0lucid_armel.deb
But you "really" should download it and keep a local backup of that
file just in case.
That's weird, there's been lots of fixes in bzr trunk.. (unless your
on karmic, then upgrade to at-least lucid)
https://code.launchpad.net/~project-rootstock-developers/project-rootstock/trunk
