I downloaded ‘bone-debian-7.5-2014-05-14-2gb’ (BBB eMMC flasher) from ‘http://beagleboard.org/latest-images’ and the website given MD5 checksum matched with my downloaded zip file. Then used Win32 Disk Imager (since windows 7), for image writing 4GB microSD.
Inserted microSD into BBB and pressed the boot button and then applied power using the power adapter. (Please note that I have not connected Ethernet and USB cable for power during the whole flashing process). But only power supply LED got lit and not the user LEDs for around 5 seconds. Then I removed the power supply and while pressing the boot button, I provided the power supply and then all LEDs got lit for an instance and then the LEDs started to glow erratically. Within 20 mins all the User LED were off and did not ON again as against the standard procedure in which all LEDs must glow after successful flashing of eMMC.
So, I thought to see if this works and I removed the microSD and power. Then I connected BBB with my PC (by USB) using putty (SSH). I was able to login successfully into debian but I was not able to ping google after adding new gateway (192.168.7.1) and changing nameserver to 8.8.8.8 in ‘/etc/resolv.conf’ file.
Please note that before SSH-ing, I shared my wifi internet with BBB in Network settings(Windows 7) and also I changed the IP address of my BBB to 192.168.7.1. All this worked earlier for me by following this youtube link: (https://www.youtube.com/watch?v=D-NEPiZDSx8).
Also, BBB (Linux USB ethernet/ RNDIS gadget) in Network settings shows ‘No Internet access’ eventhough I have shared internet and changed my ip address to 192.168.7.1 with subnet mask 255.255.255.0 leaving the DNS server addresses blank as in the youtube video.
But now it doesn’t work eventhough I have already done the same procedure (flashing) many times now with the same result and feeling really frustrated now. Please let me know if I am missing anything here. Is it due to the flashing issue?
Waiting for all your inputs! Thank you!!
Output:
BeagleBoard.org BeagleBone Debian Image 2014-05-14
Support/FAQ: http://elinux.org/Beagleboard:BeagleBoneBlack_Debian
debian@192.168.7.2’s password:
Last login: Thu May 15 02:19:40 2014 from 192.168.7.1
debian@beaglebone:~$ sudo su
root@beaglebone:/home/debian# route add default gw 192.168.7.1
root@beaglebone:/home/debian# route -n
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 192.168.7.1 0.0.0.0 UG 0 0 0 usb0
192.168.7.0 0.0.0.0 255.255.255.252 U 0 0 0 usb0
root@beaglebone:/home/debian# cat /etc/resolv.conf
domain localdomain
search localdomain
nameserver 192.168.1.1
root@beaglebone:/home/debian# vim /etc/resolv.conf
domain localdomain
search localdomain
nameserver 8.8.8.8
root@beaglebone:/home/debian# ping http://www.google.com
ping: unknown host http://www.google.com
: Problems pinging
