My second and brand new Beaglebone Black was flashed to eMMC and worked fine with
BBB-eMMC-flasher-ubuntu-16.04.2-console-armhf-2017-07-14-2gb.img
following the excellent instructions of
http://derekmolloy.ie/write-a-new-image-to-the-beaglebone-black/#prettyPhoto
Next installed: sudo apt install linux-headers-3.8.13-bone86
because we have a driver that needs those 3.8.13 headers.
We have a script that calls update_kernel.sh --bone-kernel --stable
Afterwards the reboot will not start the kernel. My first board used 3.8.13-bone84 alright but is running from microSD not eMMC.
What is causing kernel start failure and how to fix it? Should I just replace the uname -r in the driver Makefile with explicit 3.8.13-bone86 ???
Console output for second Beaglebone Black has:
Running uname_boot …
loading /boot/vmlinuz-3.8.13-bone86 …
5594568 bytes read in 373 ms (14.3 MiB/s)
uboot_overlays: [uboot_base_dtb=am335x-boneblack-uboot.dtb] …
loading /boot/dtbs/3.8.13-bone86/am335x-boneblack.dtb …
26118 bytes read in 31 ms (822.3 KiB/s)
uboot_overlays: [fdt_buffer=0x60000] …
uboot_overlays: loading /lib/firmware/AM335X-20-00A0.dtbo …
378 bytes read in 340 ms (1000 Bytes/s)
fdt_overlay_apply(): FDT_ERR_NOTFOUND
uboot_overlays: loading /lib/firmware/BB-BONE-eMMC1-01-00A0.dtbo …
1105 bytes read in 238 ms (3.9 KiB/s)
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
fdt_overlay_apply(): FDT_ERR_BADMAGIC
uboot_overlays: loading /lib/firmware/BB-HDMI-TDA998x-00A0.dtbo …
4169 bytes read in 134 ms (30.3 KiB/s)
uboot_overlays: loading /lib/firmware/BB-ADC-00A0.dtbo …
695 bytes read in 350 ms (1000 Bytes/s)
uboot_overlays: loading /lib/firmware/AM335X-PRU-RPROC-4-4-TI-00A0.dtbo …
2402 bytes read in 130 ms (17.6 KiB/s)
uboot_overlays: loading /lib/firmware/univ-bbb-EVA-00A0.dtbo …
54858 bytes read in 209 ms (255.9 KiB/s)
loading /boot/initrd.img-3.8.13-bone86 …
4705709 bytes read in 320 ms (14 MiB/s)
debug: [console=ttyO0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk1p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 quiet cape_universal=enable] …
debug: [bootz 0x82000000 0x88080000:47cdad 88000000] …
ERROR: Did not find a cmdline Flattened Device Tree
Could not find a valid device tree
and finally is stuck at boot prompt,
Config file not found
starting USB…
USB0: Port not available.
link up on port 0, speed 100, full duplex
BOOTP broadcast 1
DHCP client bound to address 10.150.100.52 (37 ms)
Using cpsw device
TFTP from server 0.0.0.0; our IP address is 10.150.100.52; sending through gateway 10.150.100.1
Filename ‘boot.scr.uimg’.
Load address: 0x80000000
Loading: T T T T T T T T T T T T T T T T T T T T
Retry count exceeded; starting again
BOOTP broadcast 1
DHCP client bound to address 10.150.100.52 (40 ms)
Using cpsw device
Load address: 0x82000000
Would really enjoy running from eMMC rather than microSD. While waiting for reply, I will try changing the driver Makefile to explicitly plug in 3.8.13-bone86, which means I have to reflash since otherwise I am stuck at boot prompt.
