hi all
i m using below link to install "dvsdk_dm3730-
evm_4_01_00_09_setuplinux" and to get dsp functionalities on
beagleboard xm.
after following the procedure mentioned in hte above link images such
as boot.src, mlo, u-boot.bin and uImage successfully copied to sd
card.... but the kernel hangs while booting
U-Boot 2010.03-00050-g914e391 (Jun 06 2011 - 14:59:19)
OMAP3630/3730-GP ES1.0, CPU-OPP2, L3-165MHz,
I2C: ready
DRAM: 256 MB
NAND: 0 MiB
*** Warning - bad CRC or NAND, using default environment
In: serial
Out: serial
Err: serial
Probing for expansion boards, if none are connected you'll see a
harmless I2C error.
No EEPROM on expansion board
Beagle xM Rev A
Die ID #13ea00001bf00000015739ea0702701f
mmc1 is available
The user button is currently NOT pressed.
reading boot.scr
353 bytes read
Running bootscript from mmc ...
## Executing script at 80200000
reading uImage
3151196 bytes read
## Booting kernel from Legacy Image at 80200000 ...
Image Name: Linux-2.6.32
Data Size: 3151132 Bytes = 3 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing
Linux.......................................................
the boot.src says as below
