I want to use my beaglebone as access point, and I want to connect with my PC.
I’m in a point where I see the network on my PC, but I can’t connect.
Next are some details about the config I done after a google research:
Configured network interface /etc/network/interfaces
auto wlx5cf3702f2d4b
iface wlx5cf3702f2d4b inet static
address 192.168.4.1
network 192.168.4.0
netmask 255.255.255.0
broadcast 192.168.4.255
ifconfig
wlx5cf3702f2d4b Link encap:Ethernet HWaddr 5c:f3:70:2f:2d:4b
inet addr:192.168.4.1 Bcast:192.168.4.255 Mask:255.255.255.0
inet6 addr: fe80::5ef3:70ff:fe2f:2d4b/64 Scope:Link
TX packets:0 errors:0 dropped:13 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:1422 (1.3 KiB)
Set access point parameters /etc/hostapd/hostapd.conf
interface=wlx5cf3702f2d4b
driver=rtl871xdrv
country_code=RO
ssid=beaglebone
channel=7
hw_mode=g
wpa=2
wpa_passphrase=qwerty1234
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
Shared Key Authentication
auth_algs=1
Accept all MAC address
macaddr_acl=0
#enables/disables broadcasting the ssid
ignore_broadcast_ssid=0
Needed for Windows clients
eapol_key_index_workaround=0
Edit /etc/default/hostapd file to point to hostapd.conf
DAEMON_CONF="/etc/hostapd/hostapd.conf"
In /etc/dhcp/dhcpd.conf I have done this modifications:
If this DHCP server is the official DHCP server for the local
authoritative;
subnet 192.168.4.0 netmask 255.255.255.0 {
option broadcast-address 192.168.4.255;
option routers 192.168.4.1;
default-lease-time 600;
max-lease-time 720;
option domain-name-servers 192.168.4.1;
range 192.168.4.5 192.168.4.10;
Installed isc-dhcp-server
/etc/default/isc-dhcp-server
Path to dhcpd’s config file (default: /etc/dhcp/dhcpd.conf).
DHCPD_CONF=/etc/dhcp/dhcpd.conf
INTERFACES=“wlx5cf3702f2d4b”
When I try to restart isc-dhcp-server:
/etc/init.d/isc-dhcp-server restart
[FAIL] Stopping ISC DHCP server: dhcpd failed!
[FAIL] Starting ISC DHCP server: dhcpd[…] check syslog for diagnostics. … failed!
failed!
Tried to check the logs /var/log/syslog
Jan 1 03:41:39 beaglebone dhcpd: Internet Systems Consortium DHCP Server 4.2.2
Jan 1 03:41:39 beaglebone dhcpd: Copyright 2004-2011 Internet Systems Consortium.
Jan 1 03:41:39 beaglebone dhcpd: All rights reserved.
Jan 1 03:41:39 beaglebone dhcpd: For info, please visit https://www.isc.org/software/dhcp/
Jan 1 03:41:42 beaglebone dhcpd: Internet Systems Consortium DHCP Server 4.2.2
Jan 1 03:41:42 beaglebone dhcpd: Copyright 2004-2011 Internet Systems Consortium.
Jan 1 03:41:42 beaglebone dhcpd: All rights reserved.
Jan 1 03:41:42 beaglebone dhcpd: For info, please visit https://www.isc.org/software/dhcp/
Jan 1 03:41:42 beaglebone dhcpd: Wrote 0 leases to leases file.
Jan 1 03:41:42 beaglebone dhcpd: No subnet declaration for usb0 (192.168.7.2).
Jan 1 03:41:42 beaglebone dhcpd: ** Ignoring requests on usb0. If this is not what
Jan 1 03:41:42 beaglebone dhcpd: you want, please write a subnet declaration
Jan 1 03:41:42 beaglebone dhcpd: in your dhcpd.conf file for the network segment
Jan 1 03:41:42 beaglebone dhcpd: to which interface usb0 is attached. **
Jan 1 03:41:42 beaglebone dhcpd: Bind socket to interface: No such device
