can’t connect through 192.168.7.2.
reset doesn’t help
Led’s:
USR0 blinks fast(faster then the usual heartbeat)
USR2 blinks 2x the speed of USR0
BBB 1 week old and has worked properly all the time with putty
and BB.org homepage “Getting started” and VNCserver
only connection is USB, no SD and original Debian-Linux OS and nothing changed
Smart people believe, that not sharing knowledge will keep you smarter then anyone else.
“Smart people” also probably know the difference between then and than, and know when it is appropriate to use one rather than the other.
anyone else.
Knowledge is not a zero-sum game.
Harvey
I'm actually curious what happened and how you solved your
problem---could you find a moment to explain this, for others'
benefit? I hope you don't take the above as your personal credo...
So, with this problem, there are so many possible different causes for this specific failure there is no way anyone can answer this question without more information.
It’s a bit like me saying “Hey someone help me, my car does not work . . .r”
Doesn’t work how ? What have you( I ) done so far to troubleshoot the issue ? We’re not mind readers . . .
The really smart people didn’t respond, alleen de klootzakken, die z.g. anderen willen verbeteren.
for me the discussion is closed, Thanks again. I will solve my own problems.
