Trying to connect to BBB I’ve tried 2 options for login:
- temppwd
- debian:tempwd
Both failed:
pavel@ALABAMA:~$ sudo ssh root@beaglebone.local
Debian GNU/Linux 9
BeagleBoard.org Debian Image 2019-10-01
Support/FAQ: http://elinux.org/Beagleboard:BeagleBoneBlack_Debian
default username:password is [debian:temppwd]
root@beaglebone.local’s password:
Permission denied, please try again.
root@beaglebone.local: Permission denied (publickey,password).
pavel@ALABAMA:~$
Any comments ?
Thanks.
That's not how you ssh into a device. You cannot ssh into root.
My understanding, login to root@ in first go doesn’t seems work,
Initially SSH for debian@… then we can switch to root just …by… sudo su.
I use PockerBeagle and connect internet-over-USB. here are steps commands, which may help you.
Ok, it works. Thanks
But IP you specified is for connection over USB.
The IP when connected over Ethernet is quite different.
Cool. That ip address is typically the default for both USB and eth0.
Glad I could help.
Not in my case:
debian@beaglebone:~$ ifconfig
eth0: flags=-28605<UP,BROADCAST,RUNNING,MULTICAST,DYNAMIC> mtu 1500
inet 10.42.0.39 netmask 255.255.255.0 broadcast 10.42.0.255
inet6 fe80::96e3:6dff:fed4:ae86 prefixlen 64 scopeid 0x20
ether 94:e3:6d:d4:ae:86 txqueuelen 1000 (Ethernet)
RX packets 43 bytes 5224 (5.1 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 75 bytes 11801 (11.5 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 55
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10
loop txqueuelen 1000 (Local Loopback)
RX packets 160 bytes 12960 (12.6 KiB)
TX packets 160 bytes 12960 (12.6 KiB)
usb0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 192.168.7.2 netmask 255.255.255.252 broadcast 192.168.7.3
ether 8a:7c:4a:06:36:ec txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
usb1: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 192.168.6.2 netmask 255.255.255.252 broadcast 192.168.6.3
ether 7e:13:e8:37:42:05 txqueuelen 1000 (Ethernet)
BTW why 2 USBs ?
Thanks.
… I mean two USBs (“big” and “small”) can be used for Internet connection.
I thought that “big” is only for pereferals.
Because, Microsoft (RNDIS) and Apple (USB-NCM) can't agree on what
technology to give access to "without" a signed driver..
With Windows, USB-CDM/NCM needs a 'signed driver'
With Mac, RNDIS needs a 3rd party driver..
So due to that crap..
usb0, is the RNDIS driver for Windows users
usb1, is the CDC-NCM driver for Mac Users..
and on linux we get two 'working' drivers..
That first octet looks like an assigned one by the network. Since eth0 is dhcp by default, it was assigned an ip address by the dhcp server.
usb0 is the virtual ethernet NIC. When you connect via uUSB it acts as a ethernet connection.
usb1 is (I think) the onboard server where you can use the ide and lists the startup stuff (when you click the little beagle icon on your desktop).
Lol.. sounds right. Look at how many different types of micro usb there are. Everyone wants to be the next standard. From Apple to Samsung. Pick one and go with it.
Ideally, you should not NEED to "switch to root". If you encounter some
operation that requires root privilege, you should run JUST that operation
using "sudo <the operation>".
usb0 is, I believe, the RNDIS protocol used by Windows -- typically the
192.168.7.x network.
usb1 is, again I believe, CDC protocol used by Mac -- 192.168.6.x
network
(Linux appears to have support for both so either IP could be used)
https://en.wikipedia.org/wiki/Ethernet_over_USB
Can’t connect BBB anymore by ssh:
pavel@ALABAMA:~$ ssh debian@10.42.0.39
@ WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED! @
IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY!
Someone could be eavesdropping on you right now (man-in-the-middle attack)!
This has nothing to do with the BBB, it’s your Ubuntu machine protecting you from something it thinks could be dangerous. If you switch from one board to another, you will get this warning. If you haven’t connected to a board in a long time (years), you may get it as well. If you garble up SSH the first time you connect, it will give you this warning.
Here’s a helpful link:
https://stackabuse.com/how-to-fix-warning-remote-host-identification-has-changed-on-mac-and-linux/
Hi Steve,
Works fine, thanks.
