Can't connect to wifi on Beagle Bone Black
Recently set up a beagle bone black with a Debian image. When I try to run the command “scan wifi”, I get this error message: Error /net/connman/technology/wifi: Method “Scan” with signature “” on interface “net.connman.Technology” doesn’t exist.
Any help appreciated!
Hello @vivek378 ,
I think w/ the updated images, one would need to use sudo nano /etc/wpa_supplicant/wpa_supplicant-wlan0.conf
Then…
sudo wpa_cli -i wlan0 reconfigure
That should help.
P.S. If you are using an older image, then connmanctl was the older way.
strange that you say that you are using a BBB, but do not specify the wifi add-on that you are using… you are aware that the stock BBB does NOT have a wifi capability aren’t you?
are you punking us?
