Can't detect inbuilt bluetooth of BeaglePlay
Im running the hciconfig command and its not showing hci0, when i enter bluetoothctl and run ‘scan on’ it says no default controller available. Basically, the BeaglePlay’s bluetooth isnt getting detected.
I have already installed all pacakages and started bluetooth service, etc.
Do i need to use a bluetooth dongle then?
BeaglePlay’s Bluetooth is provided by thee cc1352, the out of box firmware doesn’t support BLE… You need to grab one of TI’s blobs and flash it…
Hello @RobertCNelson I happen to have the same problem as @Arhaan. Can you please explain what you mean by “You need to grab one of TI’s blobs and flash it…”? Thanks.
