Hello, first time using a BBB, and I’ve hit a wall. I’m good with Arduino toys and before switching back to Windows 7 I used multiple Ubuntu machines for about 3 years. So some of this BBB stuff isn’t too far fetched for me.
I bought the board from Adafruit about 2 weeks ago now for the soul purpose of getting BeagleSNES to work on it. From what I can tell, the SD card isn’t getting written correctly or the Beagle can’t read it as it should.
I followed the getting started for BBB. I was able to plug it in and see it and then use Putty to log in as root. I also downloaded the latest software for it, imaged that onto an SD card and the update went fine, although it took about 65 minutes. Much longer than the “caution, may take 45 minutes” warning suggested. After plugging it back into my Windows 7 machine it looks fine, so the update seems to have worked, so my SD card burning ability is fine, and the BBB can read the card.
So I download the full BBB image, write that to a card, plug it into the BBB, plug in the miniUSB cable to Windows, and all I get is a unique blink pattern for about the first 10 seconds on power up. After that, its just the heartbeat pattern. Windows never sees any partition, so I can’t copy my roms to it. Basically it looks frozen somewhere. I checked the MD5 hash whatever code and it is a match for the file from Sourceforge. I try just plugging everything into the TV anyways (2 different TV’s) and there is nothing. I follow the instructions closely and repeat, nothing. I deviate a little and try resetting or holding the boot button longer, nothing. Just a heartbeat and no screen or sound action.
Then I go back and reburn the image to another 4Gb card, nothing on Windows or at the TV. I redownload the zipped image, rewrite both cards, nothing.
In summary, a whole lotta nothing It seems like all the pieces have proven they work somehow, except the actual BeagleSNES image, which I downloaded twice and re-wrote to multiple cards, multiple times.
Now I am downloading Android and going to burn that to another card to see if that will work. If that works for me, then what? Is BeagleSNES working with the latest of everything? I assume it is or I would be able to find more problems in searching this forum, but I didn’t.
Should I try to do a complete format of the microSD card before writing the image to it? I don’t think that should matter.
Should I try getting an 8Gb card? I saw on some write ups that 4Gb is close and might not always work for other images.
