Hi all,
I’m trying to control SPI bus on the Beagle Bone.
One thing I noticed is that I can’t set SPI clock speed properly. For example, if I configure the clock to “go” at 500kHz, on the scope I measure more or less a frequency of 350kHz.
If I configure it for 1MHz, I get a frequency of (roughly) 650kHz. With 2MHz setting, I get 1.15MHz frequency.
Do you have some ideas to fix this issue?
In order to talk SPI, I created a simple .c program, based on spidev_test.c. Please take a look at it, maybe it’s something stupid I did in the code.
Inside the archive you will find also the Makefile I used. Compile it with “make”. Then you can run the program with “sudo ./spilight /dev/spidev2.0”
Thank you in advance,
Daniele
spilight.tar.gz (2.14 KB)
Hi!
thank you for having shared your experience. From the time I found this problem I understood the spi speed-related settings far better.
Btw it works like you say. This is what I found:
for beaglebone the spi controller driver is found at driver/spi/spi-omap2-mcspi.c (this path refers obviously to the linux kernel sources). There there is a function whose job is to calculate the divider used to establish the real spi clock frequency. The function name is omap2_mcspi_calc_divisor(). Here follows function’s body:
static u32 omap2_mcspi_calc_divisor(u32 speed_hz)
u32 div;
for (div = 0; div < 15; div++)
if (speed_hz >= (OMAP2_MCSPI_MAX_FREQ >> div))
return div;
return 15;
OMAP2_MCSPI_MAX_FREQ is
48000000 Hz.
I found also a table describing the possible spi clock speed with the relative divider:
CLKD | Divide by | SPI_CLK [Hz] |
0 | 1 | 48.000.000 |
1 | 2 | 24.000.000 |
2 | 4 | 12.000.000 |
3 | 8 | 6.000.000 |
4 | 16 | 3.000.000 |
5 | 32 | 1.500.000 |
6 | 64 | 750.000 |
7 | 128 | 375.000 |
8 | 256 | 187.500 |
9 | 512 | 93.750 |
10 | 1024 | 46.875 |
11 | 2048 | 23.438 |
12 | 4096 | 11.719 |
13 | 8192 | 5.859 |
14 | 16384 | 2.930 |
15 | 32768 | 1.465 |
but I didn’t verify if the speed you can get is exactly the one reported in this table. For example with my scope I saw a speed of (roughly) 650kHz which is not reported in the table. I think I should have seen 750kHz instead. I will investigate further and report here.
Best regards!
