Can't get GSPCA Webcam working
Have a logitech QuickCam Chat hooked up to BB Rev C2 running Ubuntu
Karmic (http://www.logitech.com/en-us/435/281?hub=1)… having a heck
of a time trying to get it stream or dump to a file.
I tried the same cam on an x86 Ubuntu (Hardy) and had no problem using
the following command to stream:
vlc -vv --no-sout-audio v4l:// :v4l-vdev="/dev/video0" --sout
'#transcode{vcodec=mp4v,fps=10}:duplicate{dst=standard{access=http,mux=ts,dst=:
8080}}'
This works no problem... and can dump it to a file as well.
On the BB:
Running VLC gives me the following error:
ubuntu@beagleboard:~$ cvlc -v --no-sout-audio v4l2:// :v4l-vdev="/dev/
video0" --sout
'#transcode{vcodec=mp4v,fps=10}:duplicate{dst=standard{access=file,mux=ts,dst=tst.mp4}}'
VLC media player 1.0.2 Goldeneye
[0xb0ca0] dummy interface: using the dummy interface module...
[0xcbce0] v4l2 demux warning: Could not select any of the default
chromas; attempting to open as MPEG encoder card (access)
[0xcbce0] v4l2 demux error: cannot get video input characteristics
(Invalid argument)
[0xcbce0] main demux warning: no access_demux module matching "v4l2"
could be loaded
[0xc90e0] ps demux warning: this does not look like an MPEG PS stream,
continuing anyway
[0xc90e0] ps demux warning: garbage at input, trying to resync...
^C[0xb3a00] signals interface error: Caught Interrupt signal,
exiting...
What's more interesting is the syslog....
Sep 30 14:37:52 beagleboard kernel: [75482.018035] gspca:
usb_submit_urb [0] err -28
After I quit VLC when I do this, the light on the camera goes off,
whatever that means. It doesn't come on again without re-plugging.
Using FFMPEG on BB:
ffmpeg -s 320x240 -f video4linux2 -v 3 -i /dev/video0 -t 10 -acodec
none -y out.mpg
...gives me:
[video4linux2 @ 0x2ebb0]The V4L2 driver changed the pixel format from
0x32315559 to 0x31363553
0x50323234 to 0x31363553
0x56595559 to 0x31363553
0x59565955 to 0x31363553
0x50313134 to 0x31363553
0x39565559 to 0x31363553
0x4F424752 to 0x31363553
0x50424752 to 0x31363553
0x33524742 to 0x31363553
0x33424752 to 0x31363553
0x34524742 to 0x31363553
0x59455247 to 0x31363553
[video4linux2 @ 0x2ebb0]Cannot find a proper format.
No URB error in the syslog though.
When I insert the cam, syslog:
Dec 31 16:00:40 beagleboard kernel: [75719.557373] usb 1-2.4: new full
speed USB device using ehci-omap and address 4
Dec 31 16:00:40 beagleboard kernel: [75719.692047] usb 1-2.4:
configuration #1 chosen from 1 choice
Dec 31 16:00:40 beagleboard kernel: [75720.099639] Linux video capture
interface: v2.00
Dec 31 16:00:40 beagleboard kernel: [75720.303497] gspca: main v2.6.0
registered
Dec 31 16:00:41 beagleboard kernel: [75720.504791] gspca: probing 046d:
092e
Dec 31 16:00:41 beagleboard kernel: [75720.524261] gspca: probe ok
Dec 31 16:00:41 beagleboard kernel: [75720.531433] usbcore: registered
new interface driver spca561
Dec 31 16:00:41 beagleboard kernel: [75720.531524] spca561: registered
I have a hub in between the BB and the Cam.
I can't tell if this is a GSPCA or V4L2 issue. Any ideas?
I had another use email me with a similar problem with GSPCA
camera's.. I only have a couple uvc cameras, which seem to be working
fine..
Which kernel are you using?
if your using one my kernels, does this latest one fix the issue?
http://rcn-ee.net/deb/karmic/v2.6.36-rc6-d1/install-me.sh
". install-me.sh" on beagle...
Hey Robert,
Kernel Version:
ubuntu@beagleboard:~$ uname -a
Linux beagleboard 2.6.31.6-x6.0 #1 PREEMPT Fri Nov 13 17:02:45 UTC
2009 armv7l GNU/Linux
I did manage to get it working, not sure if that URB request is an
issue or not, but from doing a lot of reading around, it seemed like
there is a mismatch in kernel and V4L2 versions that are in this build
(again, not sure). But the way to work around it is by prepending /usr/
lib/libv4l/v4l1compat.so as an LD_PRELOAD (I just stuck it in /etc/
ld.so.preload). Works now.
Nice script btw. I will try it once I finish taking a look at this
Gstreamer release that was just posted!
