Hi, I need your help,
I need to read data of an SPI Master device on the BeagleBone. Since the SPI kernel driver doesn't support an SPI slave mode I have to implement it in the PRU (Because the maximum frequency one BeagleBone's GPIO can be toggle is only 15 KHz).
From what I have read, the PRU cycle time is 200 MHz, even so, I can't read data up to 10 MHz. I am doing the following:
                     k=0;
shift = 0;
while((__R31&cs) != cs){ // CS = 0
Why not simply
#define CS  15              /* whatever */
while(__R31 & CS) {};
I hope that cs is a #defined macro and not a variable;
In C there is the convention that macros are written in upper case,
as a warning that there may be more action inside than meets the eye.
And macros should employ parentheses generously to avoid bugs like this:
#define A  2 + 3
if (5 * A)  .....  which results in
if (5 * 2 + 3)  , which is probably not what was intended.
Note that EVERY computation result can be used as a boolean.
0 is false, EVERYTHING else is true, so your compares to
generate a boolean are just a non-wanted complication.
while((__R31&sclk) == sclk);
while((__R31&sclk) == sclk){ //sclk = 1
if((__R31&cs) == cs)
goto END;
I don't know where END is, but gotos are known to not work well
with optimizing compilers since the the compiler may have to
throw assumptions overboard that are not safe any more since the
goto is non-local.
buffer[cnt] = ((__R31&miso) == miso)?  buffer[cnt] | 0x01 << shift: buffer[cnt]; // Here is where my cycle is being stranded!!!
The conditional assignment makes the program read back buffer[cnt]. That is bad
in concept since the buffer may be in shared ram and reading that may cost many clocks
for arbitration. Writing the shared RAM may be a little bit cheaper since the bus logic
might buffer the write and let the PRU run on.
Thinking about it, even the PRU local data RAM is somehow shared since the
ARM CPU and the other PRU can read & write it; let's hope that the priorities are set
in a sensible way.
Also the address of buffer[cnt] is computed 3 times in this line.
The compiler might spot that it has the values already. But you could kick it into the
right direction:
register int tmp;        // I have no idea if the TI compiler honors that. It is just a hint.
int *bufferp =  KJHGKJHJHM;
tmp = __R31 & MISO;  // the & result is already usable as a boolean
if (tmp) tmp = tmp | (1 << shift);  // that feels somehow wrong since the original bit is kept.
*bufferp++ = tmp;
You might also leave that shifting to the ARM CPU; it probably can be done
when the data is further proccessed.
regards,
Gerhard
