Hello!
My goal is to make a QT application for Technexion DevKit TDM-3730 BlizzardPack. Everything is OK, but it is impossible to click a button with a touchscreen, while with mouse it’s ok.
I’ve tried evtest, here its output:
root@devkit:/dev/input# evtest touchscreen0
Input driver version is 1.0.1
Input device ID: bus 0x0 vendor 0x0 product 0x0 version 0x0
Input device name: “prism_st”
Supported events:
Event type 0 (Sync)
Event type 1 (Key)
Event code 330 (Touch)
Event type 3 (Absolute)
Event code 0 (X)
Value 115
Min 0
Max 1499
Event code 1 (Y)
Value 397
Min 0
Max 899
Event code 24 (Pressure)
Value 0
Min 0
Max 255
Testing … (interrupt to exit)
Event: time 10551.906098, type 3 (Absolute), code 0 (X), value 735
Event: time 10551.906129, type 3 (Absolute), code 1 (Y), value 461
Event: time 10551.906129, type 3 (Absolute), code 24 (Pressure), value 255
Event: time 10551.906129, -------------- Report Sync ------------
Event: time 10551.915772, type 3 (Absolute), code 0 (X), value 734
Event: time 10551.915772, type 3 (Absolute), code 1 (Y), value 460
Event: time 10551.915802, -------------- Report Sync ------------
Event: time 10551.925201, type 3 (Absolute), code 0 (X), value 733
Event: time 10551.925201, type 3 (Absolute), code 1 (Y), value 459
Event: time 10551.925232, -------------- Report Sync ------------
Event: time 10551.934570, type 3 (Absolute), code 0 (X), value 732
Event: time 10551.934600, -------------- Report Sync ------------
Event: time 10551.943999, type 3 (Absolute), code 0 (X), value 730
Event: time 10551.944030, type 3 (Absolute), code 1 (Y), value 460
Event: time 10551.944030, -------------- Report Sync ------------
Event: time 10551.951659, type 3 (Absolute), code 0 (X), value 728
Event: time 10551.951690, type 3 (Absolute), code 1 (Y), value 462
Event: time 10551.951690, type 3 (Absolute), code 24 (Pressure), value 28
Event: time 10551.951690, -------------- Report Sync ------------
Event: time 10551.959014, type 3 (Absolute), code 0 (X), value 726
Event: time 10551.959044, type 3 (Absolute), code 1 (Y), value 464
Event: time 10551.959044, type 3 (Absolute), code 24 (Pressure), value 1
Event: time 10551.959044, -------------- Report Sync ------------
No matter how much I tapped there is no touch event (330).
I’ve made a GTK application and it’s ok, but it isn’t convenient at all. And it seems that touch-event processing realized inside GTK GUI. Am I right?
Here is my system parameters:
Host - Linux Mint 15, Linux version 3.8.0-19-generic, QT 5
Target - Angstrom, Linux version 2.6.37, qt4-embedded - 4.7.3-r33.1.9, tslib
Cpu - TI Sitara DM3730 @ 1Ghz
DSP Core - TMS320C64x+™ @ 800Mhz
Please, give me some advice how to get touch(tap) event?
Thank you in advance.
Egor
