Using 4G sd card.
Texas Instruments X-Loader 1.5.0 (Apr 11 2011 - 09:47:05)
Beagle xM
Reading boot sector
Loading u-boot.bin from mmc
U-Boot 2011.03 (Apr 20 2011 - 07:19:53)
OMAP3630/3730-GP ES2.1, CPU-OPP2, L3-165MHz, Max CPU Clock 1 Ghz
I2C: ready
DRAM: 512 MiB
NAND: 0 MiB
MMC: OMAP SD/MMC: 0
In: serial
Out: serial
Err: serial
Beagle unknown 0x02
No EEPROM on expansion board
Die ID #201200029ff800000163810c1401400d
reading boot.scr
362 bytes read
Running bootscript from mmc ...
## Executing script at 82000000
reading uImage
3605220 bytes read
reading uInitrd
4325729 bytes read
## Booting kernel from Legacy Image at 80000000 ...
Image Name: Linux
Data Size: 3605156 Bytes = 3.4 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
## Loading init Ramdisk from Legacy Image at 81600000 ...
Image Name: Ubuntu Initrd
Image Type: ARM Linux RAMDisk Image (gzip compressed)
Data Size: 4325665 Bytes = 4.1 MiB
Load Address: 00000000
Entry Point: 00000000
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Caching vfat content in /dev/.initramfs/jasper-vfat ...
Resizing root partition ...
Re-writing vfat partition ...
Resizing root filesystem. Please wait, this will take a moment ...
Resizing root filesystem ...
Checking filesystem before resizing...
Resizing, please wait...
sh: X: unknown operand
Enabling serial console login
cp: can't create '/root/etc/init/serial.conf': Read-only file system
fsck from util-linux-ng 2.17.2
/dev/mmcblk0p2: recovering journal
/dev/mmcblk0p2: clean, 46409/488640 files, 305212/953859 blocks
[ 88.771545] EXT3-fs (mmcblk0p2): error: ext3_remount: Abort forced
by user
An error occurred while mounting /
Press S to skip mounting or M for manual recovery
mount: cannot remount block device /dev/mmcblk0p2 read-write, is write-
protected
mountall: mount / [662] terminated with status 32
mountall: Filesystem could not be mounted: /
The disk drive for /tmp is not ready yet or not present
Continue to wait; or Press S to skip mounting or M for manual recovery
Skipping / at user request
could not write bytes: Bad file descriptor
[ OK ]rting AppArmor profiles
touch: setting times of `/var/lib/sudo': Read-only file system
