I'm fiddling with U-boot, and want to make sure that if I stuff it up, I'm going to be able to put back the original image on NAND
My beagleboard is in the state that it arrived...
When I tried to look at what was in nand at address 0 (where x-loader is stored?)
I get the following error when trying to read:
OMAP3 beagleboard.org # nand read 0x80200000 0 80000
NAND read: device 0 offset 0x0, size 0x80000
NAND read from offset 0 failed -74
524288 bytes read: ERROR
Texas Instruments X-Loader 1.4.2 (Feb 19 2009 - 12:01:24)
Loading u-boot.bin from nand
U-Boot 2009.01-dirty (Feb 19 2009 - 12:22:31)
I2C: ready
OMAP3530-GP rev 2, CPU-OPP2 L3-165MHz
DRAM: 256 MB
NAND: 256 MiB
*** Warning - bad CRC or NAND, using default environment
What would be causing this?
