Can't SSH to the bone
I’ve connected the Beaglebone Black via USB cable. I’m using Windows7 and I’ve installed the USB driver. I can get the 101 page via a web browser, but I cannot connect to the beaglebone over SSH.
If I try to connect via SSH using putty, I get; client unexpectedly closed the connection.
If I try to connect via serial COM7 9600 it just hangs
If I try to connect using Gate One SSH in a web browser I get; Connection closed by remote host.
The bone doesn’t like me. Please help.
Steve
This might be your issue. It was with mine.
https://groups.google.com/d/msg/beagleboard/Ya2qE4repSY/q8_WkLcH5TwJ
Also Make sure you update the clock… SSH likes to verify things with time and dates… like the ssl certificates
I couldn’t get SSH to work either, but I know that for serial you need the baud rate to be 115200 (instead of 9600). You also need to press enter after the terminal opens to re-load the login screen.
