Hi all,
I was given a BBB and a Chipsee 7" to work with.
With the provided images (Angstrom, Debian and EZSDK) they boot and run and work fine, but with none of them I can ssh through USB into them.
I’ve worked on the same BBB but with other LCD cape (4d systems’ 4D-CAPE70T) that runs on original angstrom that comes with the board, and ssh was no problem, I was able to implement a Qt environment, remote deploy and everything, but not with the images provided by Chipsee.
What am I missing? Is ssh enabled? I’ve seen dropbear stuff on the images but can’t tell if it is enabled, running or if it is supposed to run. What should I look into?
ssh over USB isn't a hardware thing, it's a software setting by
loading g_multi on startup.
For the offical images, you can see how this is loaded on bootup here:
https://github.com/RobertCNelson/boot-scripts/blob/master/boot/am335x_evm.sh#L91
Note, it's more then just loading g_multi as udcpd or dnsmasq is used
behind the scene to set the eth ip address.
btw, the chipsee cape should be mostly supported in the newer "jessie" image:
see: http://elinux.org/Beagleboard:BeagleBoneBlack_Debian#Jessie_Snapshot
and: http://elinux.org/Beagleboard:Capes_3.8_to_3.14#Chipsee_bbb-exp-c
For /boot/uEnv.txt (dtb changes)
and /etc/X11/xorg.conf change..
