i have a new BBB rev c from aidafruit and i downloaded the latest Debian from http://debian.beagleboard.org/images/BBB-eMMC-flasher-debian-7.5-2014-05-14-2gb.img.xz extracted it, and copied it to a16G MicroSD card i had laying around (using win32 disk imager)
i attempted the update with a 1A power cord / wall wart and no Ethernet cable attached.
i held the “boot” button and applied power, it looks like it is supposed to and then after a while it just shuts down.
after booting it back up i noticed that it had not updated.
so i tried it again with my brand new serial cable connected to it.i get this:
beaglebone login: [ 25.134741] libphy: PHY 4a101000.mdio:01 not found
[ 25.139945] net eth0: phy 4a101000.mdio:01 not found on slave 1
Sending SIGTERM to remaining processes…
Sending SIGKILL to remaining processes…
Unmounting file systems.
Unmounted /sys/fs/fuse/connections.
Unmounted /dev/mqueue.
Unmounted /sys/kernel/security.
Unmounted /sys/kernel/debug.
Disabling swaps.
Detaching loop devices.
Detaching DM devices.
[ 972.131075] (NULL device *): gadget not registered.
[ 972.145535] Power down.
[ 972.150454] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000000
[ 972.150454]
[ 972.160175] [] (unwind_backtrace+0x1/0x9c) from [] (panic+0x59/0x158)
[ 972.168833] [] (panic+0x59/0x158) from [] (do_exit+0x5ff/0x68c)
[ 972.176944] [] (do_exit+0x5ff/0x68c) from [] (sys_reboot+0x105/0x15c)
[ 972.185604] [] (sys_reboot+0x105/0x15c) from [] (ret_fast_syscall+0x1/0x46)
[ 972.194795] drm_kms_helper: panic occurred, switching back to text console
any ideas what i did wrong / how to recover?
from
win32 disk imager)
Well, that's the same image adafruit used.
cable attached.
i held the "boot" button and applied power, it looks like it is supposed to
Can you be more specific? What do you "notice" that would hint it
needs an update?
this:
972/60 = 16.2 minutes, so it "flashed" then shutdown...
exitcode=0x00000000
[ 972.150454]
[ 972.160175] [<c00111f1>] (unwind_backtrace+0x1/0x9c) from [<c04c8955>]
(panic+0x59/0x158)
[ 972.168833] [<c04c8955>] (panic+0x59/0x158) from [<c00336ff>]
[ 972.176944] [<c00336ff>] (do_exit+0x5ff/0x68c) from [<c003dc5d>]
[ 972.185604] [<c003dc5d>] (sys_reboot+0x105/0x15c) from [<c000c841>]
console
This error is known on v3.8..
I'm apparently an idiot.
to elaborate, it's working fine now. i had misread the instructions and was
expecting the LEDs to stay full on when it finished flashing. when it
shutdown i had assumed the worst. so i tried it again with the serial cable
connected and saw the kernel panic and that just cemented the notion that i
somehow broke it.
thanks for entertaining a fools question.
--MikeW
