I’ve successfully ran Robert Nelson’s scripts (https://eewiki.net/display/linuxonarm/BeagleBone) which compile a kernel image, u-boot, installed root file system etc. and installed on microSD card.
It boots perfectly, I can use the serial device or SSH into a Beagleboard Green and all looks good.
I cloned the bb.org-overlays into the Debian home directory, and ran the dtc-overlay and install scripts.
It appeared that all ran good and no errors.
However, I can’t locate the config-pin executable. One another machine using a pre-build image, it is located in /usr/local/bin.
I must be missing a step which installs config-pin.
Also, I ran
zcat /proc/config.gz | grep CONFIG_BONE_CAPEMGR
CONFIG_BONE_CAPEMGR=y
What am I missing here?
Greg
