cape-universal & 4.1.x = default.. ;)
Hey Guys,
In the v4.1.x-ti tree, we have a couple more hdmi-audio pins but
otherwise i've enabled everything in cape-universal now:
https://github.com/beagleboard/bb.org-overlays/commits/master
I'd like to enable cape-universal by default on bootup, under the
conditions that:
/boot/uEnv.txt
no custom dtb= is defined
no custom cape_enable= is defined
and no other capes are enable in the slots..
Currently you can enable it via:
config-pin overlay cape-universal
Thoughts?
Sounds reasonable to me. This is Charles S’ universal IO ? Seems like it but . . . no hands on with it to date. Any non trivial implication that you can think of ?
root@beaglebone:~# config-pin overlay cape-universal
root@beaglebone:~# config-pin -l P9.24
default gpio gpio_pu gpio_pd uart can i2c pruin
root@beaglebone:~# config-pin -l P9.26
root@beaglebone:~# config-pin P9.24 can
root@beaglebone:~# config-pin P9.26 can
root@beaglebone:~# config-pin -q P9.24
P9_24 Mode: can
root@beaglebone:~# config-pin -q P9.26
P9_26 Mode: can
At which point can1 interface is wired to P9.24/P9.26 pin's...
Not sure I would ever use it, but as long as it would not conflict with eeprom based, or standard capes. I see no reason why not to include it.
e.g. I do not fool around with hardware - much. From the physical aspect anyway. I usually intrenched in something like I’m doing now. Which is basically a CANBus to http + websockets interface.
My thoughts too, just want to make sure we don't load it over
something else. :wink: Just remembered two other places...
/boot/uEnv.txt
/proc/cmdline
no extra cape_enable's..
/etc/default/capemgr (that 3.8.x hack i did..)
Sounds good to me, assuming it doesn't interfere with any of the stock software Jason's running.
Well, the BoneScript and PyBBIO libraries both need to be updated for
4.1. Shouldn't be that hard with a focused effort. Patches welcome.
Hi Robert,
I'd like to enable cape-universal by default on bootup, under the conditions
that:
/boot/uEnv.txt
Is there a document anywhere which describes the hierarchy of the uEnv files and how they define/override booting/environment/kernel args etc?
TAIA
Jerry
Not really, as with uEnv.txt your free to update any variable and
create variables...
For boot order you can take a look at this:
http://elinux.org/Beagleboard:U-boot_partitioning_layout_2.0
But the real important one is:
"mmcargs=setenv bootargs console=${console} " \
  "${optargs} " \
  "${cape_disable} " \
  "${cape_enable} " \
  "root=${mmcroot} " \
  "rootfstype=${mmcrootfstype} " \
  "${cmdline}\0" \
and
"if test -n ${dtb}; then " \
   "setenv fdtfile ${dtb};" \
   "echo using ${fdtfile} ...;" \
"fi;" \
https://github.com/RobertCNelson/Bootloader-Builder/blob/master/patches/v2015.07/0001-am335x_evm-uEnv.txt-bootz-n-fixes.patch
Cool, thanks.
Not really, as with uEnv.txt your free to update any variable and create
variables...
Beagleboard:U-boot partitioning layout 2.0 - eLinux.org
That's one of the critters ...
  "${optargs} " \
  "${cape_enable} " \
  "${cmdline}\0" \
Yep.
Question: Is it possible to override the TFTPROOT setting? i.e. set up each board so they reference different sub-directories on the TFTP server? Can this be done in uEnv alone?
TAIA
Jerry
So it's setup as:
"server_ip=192.168.1.100\0" \
"gw_ip=192.168.1.1\0" \
"netmask=255.255.255.0\0" \
"hostname=\0" \
"device=eth0\0" \
"autoconf=off\0" \
"root_dir=/home/userid/targetNFS\0" \
"nfs_options=,vers=3\0" \
"nfsrootfstype=ext4 rootwait fixrtc\0" \
"nfsargs=setenv bootargs console=${console} " \
   "${optargs} " \
   "${cape_enable} " \
   "root=/dev/nfs rw " \
   "rootfstype=${nfsrootfstype} " \
   "nfsroot=${nfsroot} " \
   "ip=${ip} " \
   "${cmdline}\0" \
Just set each bbb to have a different "root_dir=" ..
Robert, that sounds great to me.
4.1. Shouldn’t be that hard with a focused effort. Patches welcome.
My thoughts now, if cape-universal is loaded by default, would be to use cape-universal in BoneScript/PyBBIO if it’s loaded, and otherwise to use the current custom overlay method. How’s that sound to you, Jason?
Okay this now enabled:
https://github.com/RobertCNelson/boot-scripts/blob/master/boot/am335x_evm.sh#L213
#default (dtb=am335x-boneblack.dtb)
config-pin overlay cape-universaln
#dtb=am335x-boneblack-overlay.dtb
config-pin overlay cape-univ-hdmi
config-pin overlay cape-univ-audio
config-pin overlay cape-univ-emmc
#dtb=am335x-boneblack-emmc-overlay.dtb
#dtb=am335x-boneblack-hdmi-overlay.dtb
#dtb=am335x-boneblack-nhdmi-overlay.dtb
I think this takes care of all the pin's..
Hi
Yep, I get (and do) that for NFS. But can you do the same with TFTP booting? Is there a TFTP root dir var?
TAIA
We just load them blindly:
+ "tftp ${loadaddr} ${bootfile}; " \
+ "tftp ${fdtaddr} dtbs/${fdtfile}; " \
(uname_r)
+ "tftp ${loadaddr} vmlinuz-${uname_r}; " \
+ "tftp ${fdtaddr} dtbs/${uname_r}/${fdtfile}; " \
I guess we could do: ${tftp_dir}
+ "tftp ${loadaddr} ${tftp_dir}/${bootfile}; " \
+ "tftp ${fdtaddr} ${tftp_dir}/dtbs/${fdtfile}; " \
(uname_r)
+ "tftp ${loadaddr} ${tftp_dir}/vmlinuz-${uname_r}; " \
+ "tftp ${fdtaddr} ${tftp_dir}/dtbs/${uname_r}/${fdtfile}; " \
+ "tftp ${loadaddr} ${tftp_dir}/${bootfile}; " \ "tftp ${fdtaddr}
+ ${tftp_dir}/dtbs/${fdtfile}; " \
(uname_r)
+ "tftp ${loadaddr} ${tftp_dir}/vmlinuz-${uname_r}; " \ "tftp ${fdtaddr}
+ ${tftp_dir}/dtbs/${uname_r}/${fdtfile}; " \
Yep, that's what I had in mind. Let me see if I can make the changes here. If so I can do a PR on Github.
Thanks again.
Jerry
Pushed:
https://github.com/RobertCNelson/Bootloader-Builder/commit/92a2bb7cce78b7d8b265b0ac70bb7fcc0f4b444b
Currently building, once built, it'll be the default..
Pushed:
Ideal. Cheers.
cape-universal in BoneScript/PyBBIO if it's loaded, and otherwise to use the
current custom overlay method. How's that sound to you, Jason?
Yeah, I also like this loaded by default. Much cleaner for the script code. Disable only if an EEPROM says load something in conflict or a command-line option says so.
